- clutch pedal spoungy no slipage
- issues with welding relo brackets on a NEW rear!!! Please help!
- shift lever shaft seal change
- b&m ripper shifter issues
- 1995 Camaro Z28 Auto
- 4L60E swap to 700R4
- torque converter will not lock
- Flywheel loctite, What color?
- TH350 to manual help!
- Where to buy Just the clutch disc?
- What causes slip yoke play?
- A4 to M6 conversion
- New clutch. Now reverse grinds.
- What is the thread size for a shifter handle?
- t56 speed sensor question
- 4l60e lt1 vs ls1?
- How to test a bad convertor?
- Trans Temp Guage
- Flywheel possibly warped?
- 4l60e shift quality
- Trans Go/Pcm tuning w/Vig convertor
- Starter doesn't always engage?
- Transmission cooler installed wrong?..
- 4.11 gear guys... where did you buy? Best price?
- SPEEDO SENSOR for TH400 SWAP!!!
- Reverse grinds. Slave or master bad? New clutch
- Lockup connector on 700R4
- 4l60 swap probeblems
- How many miles should a performance tranny last?
- posi unit?
- another satisfied CPT customer
- AUTO shift knobs
- T10 tranny behind LT1, how difficult
- Dr Tranny Shudder eliminator
- Poly trans. monut
- 2 Snapped Axles??
- Street LT1 build - Drivetrain
- Replacing Rear Bearing and Seal - Not sure about what I got
- How well is your 10 bolt holding up!! "6sp" only
- slipping on overdrive only
- Weird T56 issue
- 3.73 in a 2 series carrier?
- SLP 3.73 Gears
- Leaking Tail Shaft...
- Balancing Flywheel...Should I have done this?
- Signs of bad diff bearings?
- t56 question
- 1st and 2nd gear...if i step on it too hard the rpms shoot up, but drivable 4l60e
- My car doesn't like to upshift 4l60
- hard 1st gear?
- gears
- What gears?
- 9" build up?
- Hurst Short throw problem?
- Strange 12 bolts gear oil capacity?
- MALF 83 TCC control feedback...was 94 now is a 95.
- Shift Kit
- 10th off LT1 flywheel?
- 4.10 gear A4
- Clutch won't disengage
- Hydraulic clutch line Qs
- caliper/ebrake mounting question
- Help with a rear axle squeek...
- Quick Question????
- clutch problems
- HURST Billet Plus or Competition Plus: Which is better?
- Gear Tune with Tech 2?
- lt1 - posi
- Master cylinder adapter fitting
- Bell housing Question.
- Tranny For 93 Z to A 94 Z?
- trans!! question
- t5 slave/t56?
- Help adjusting 4l60E
- 2 and 3 series
- Rear Axle Posi 2-3 series
- 4.10 or 3.73 on 10 bolt
- Think it's worth it?
- how to build a budget rear end?
- banging i gear
- LT1 Tranny ?'s
- Stop bolts
- Changing tranny gearing...
- What's the difference
- Rear axle pivoting?
- rear end
- HELP! what is wrong with my car!
- What is the best set up?
- auto or manual
- U bolt for slave
- Ring&Pinion need replacing:what to do?
- Clutch Issues
- Help me pick a clutch kit !
- Which Auto Tranny?
- Vibration- Driveshaft or Tailshaft bushing?
- Does a high stall converter affect dyno numbers?
- Part # for T-56 Shifter Isolator Cup Bushing, Please.
- Power Steering Cooler Install Issues
- Vigilante lock-up problem
- so I rebuilt the stock T-56 shifter.....
- Slipping
- Is this the part number for a 93 TV Cable???
- Centerforce Clutch and High Rpms
- pilot bushing = stuck
- Automatic shifter?
- 700r4 won't go in all the way
- Performabuilt Stage 2 Tranny Problem?
- New Clutch for M56 behind a 383
- Auto Trans Swap
- LS1 Driveshaft for LT1??
- clutch pedal
- installing a kevlar pilot bushing...
- 4l60 problem still present
- I Need Opinions On What Type Of Clutch To Buy
- Did my clutch go out? Plz help ASAP THANKS
- tranny rebuild kits
- Thinner T56 Mount
- Clutch Adjustment
- going into reverse
- 3.73's + T2R Differential?
- Super T10 question
- Any 700R4 guys still here fielding questions?
- 3.73 Gears?
- Performabuilt Heavy Hauler Series A-OK so far
- 2001 SS 6-speed 3rd & 4th grind
- Ford 9" vs Dana 60 vs GM 12 Bolt - Rear Axle Comparisons
- gear vs tire size
- Please Help 5 Grand Let Off at WOT to Shift
- Poll: Stock Trans Mount or Poly Trans Mount
- 3.23??
- U joints for LS1 driveshaft
- Burnout 3.8l Camaro automatic 1999?
- Some questions about clutch
- T56 issue?
- clutch fork binding on release
- Ticking timebomb?
- McLeod - external slave question.
- how bad is an out of balance driveshaft??
- 3:73 Install Question
- 4l60e?
- Violent shaking from a dead stop on my 97' z28
- t56 reinstallation
- Is my torque converter bad? Weird small vibration/knocking?
- 1996 transmission into a 1995 F Body
- Why do converters fail?
- Clutch fully engaged after little paddle travel!
- what kind of clearance should the pilot bushing have?
- grinding noise???
- need transmission help
- will balancing the D.S. get rid of the high speed shudder?
- Dust Cover/Screw Thread??
- 95 trans into a 94, how to get lockup?
- Trifecta tune?
- 3.73 in 6-speed
- Help me with this clutch/T56 buzzing sound
- how do i know what stall to go with?
- Help! Horrible vibration and noise
- M6 Clutch Failure and Protection
- SPEC LT1 steel flywheel and internal balancing
- 4l60 god durnit
- 4l60e
- Wheelspin or slipping converter/tranny?
- New WS6Store shortshifter
- Where to go for 4L60E
- Diff Spitting Fluid
- Th400, tires and gears
- swapped 9.5" to 10.5" stall
- Is Synchromesh Fulid ok for '95 M6?
- blowproff bell housing
- question on carriers????
- Maddog stage 3 clutch Kit ?
- Opened the differential cover. What gears are these?
- 3.73 or 4.10 gears
- Trans Mount Question....
- Stock converter/gears guys inside please...
- 4l60e question
- Building my new rear end
- trans coolers, 1? can i run 2? any advantages or disadvantages?
- 9" in the near future.
- Shifter and flex plate recommendations?
- 3.73 A4 gas mileage
- DIY stall converter install
- TH400 converter bolts
- Will this clutch kit work
- 9" am i screwed??
- Is it stupid to install a used clutch
- Need to replace differential bearings.. help! [Pics]
- 99 v6 alum ds in 95 lt1 6 sp
- tork master 2400
- 4.10 Install
- A4 Slow into first gear, help w/ diagnostics
- Question about TH400 and driveshafts
- anyone near wichita, ks want to drop my t56
- Check out my new FREE tranny
- Strange S60
- when disengaged street twin w/ adj master grinds
- 4L80E Shifting Issue
- Transmission Swap *Too tight?*
- 4.10's just installed! Speedometer 15mph off??
- trying to install a global Traclink that i got used and wont fit any help with dife
- Bad master/slave? Or throwout bearing?
- Anyone know bore size of LS1 clutch master/slave cylinders?
- Going TH400/ T brake, rear end question
- Spec Clutch Kit
- stock transmission hp rating ??
- Clutch problems
- B-body trans in F-body?
- Clutch releases too high
- "Howling" in differential
- Please Help!
- 10 bolt - damaged or normal?
- lt1 clutch bleeding
- Urethane tranny mount - thumbs DOWN
- 3.23 to 3.73 swap?
- is something wrong?
- t56 swap
- Help me diagnose clutch problem.
- T56 rebuild, how to make it bulletproof?
- Clutch wont hold 100shot!!!!!!!!
- New Shifter!!!
- Rear end howling noise. Axle bearing?
- Differential spider gears causing my 'hum' ?
- Tranny Going?
- Problem after clutch install...
- Need some th350 help.....again
- Reverse lockout solenoid
- Race converter shopping
- Hard reverse and 1st after car sits
- Pressure plate resurfacing....where?
- worn spider gears???
- Looking To Lessen Drivetrain Loss
- Can you take out clutch fork w/out dropping tranny?
- budget rear - options?
- TODAY SALE, LEVEL 2 $100 OFF, LEVEL 3 $300 off
- 0 degree pinion angle
- rear end article
- TCI Street fightrer 700r4
- I have a rear end clunk I need you pro's to help me with
- New Firebird owner...have a couple of questions for the pro's here
- LT1 vs 10 bolt rear axle
- Shattered Input Drum??
- Driveshaft length and 12 bolt?
- Driveshaft?
- 1995 Camaro vibrating
- ACC torque converters?
- 83 z28 clutch conversion
- What do i need to do to update the rear end of my car
- What Trans would be best
- problems with rear?
- New Clutch Breakin period
