- Looking for parts interchange / historical info on 9-inch rearends
- JW ultrabell
- Tremec T56 same as my tranny??
- Add paddle shifters to your car
- SPEC stage 3 vs SPEC stage 3+, whats the difference?
- '93 tranny with 4.10's?? Bad idea??
- 3.73s...Now Slower 0 to 60?
- T56 owners ... how to fix reverse going out?
- drive shaft loop
- Th350 swap out shaft
- Order, or not to order
- Trany mount
- Where this tranny fluid come from!?!?!?
- M6 conversion in A4 LS1
- what auto trans is in my 93 T/A?
- 4L60E Dip Stick pops out
- LT1 Clutch Master U bolt part number?
- T56 conversion questions
- t56 transmission inquiry
- How difficult swap the converter?
- Hhhhhhhhhhhhheeeeeeeelllllllllpppppppp!!!
- Rear Axle Replacement
- Anyone running a monster converter?
- 1/2 " ARP Wheel Stud Torque Specs
- Changing Automatic 2 a Manual
- Manual or Automatic?
- Transmission Rebuild
- No Tach, Speedo, A/C after M6 swap
- Check out my Pedal Assembly. It came out awesome!!
- 1-2 Shifts When Hot
- Shift linkage question
- Clutch question on 3.8L 1996
- Going from T56 to TH350
- Installing M6 Tranny.... OMG, SOB.
- 4.10 vs 3.73
- Need nut size for clutch fork actuator studs.
- 96 Camaro Auto-Tranny Problem
- Options for 93 w/ 700R4
- help diagnose please..
- Where do you buy rear end rebuild tools?
- 4L60E wont go into park =(
- Humming/Grinding sound from T56 - Please help diag.
- six speed queastion. harder shifting gears.
- 4L60E stuck in 3rd Gear
- Getting ready to buy a 9 inch from DLS
- Parts list for a bulletproof 4l60e rebuild?
- street twin
- Differential Gear Problems??
- One Wheel Wonder
- how to get a speedo to work after a tranny swap
- new clutch,slave master etc...still hard shifting!!!
- need a new flexplate
- 3.73's in 6 speed cause vibration please help
- Help me choose gears
- clutch cover plate
- Throw out bearing reatainer
- Auburn posi and chattering?
- Rebuild 4l60e Myself?
- noise coming from bellhousing
- Broke My HD Torsen
- Reverse & skip shift problems w/ M6
- What is my Built 4L60e worth?
- Anyone swap a 4l80e in the a camaro?
- Information about transmission coolers
- got a 9 inch rear end ....what next
- '97 LT1 M6 - Trouble getting in gear, clutch seems partialy engaged.
- Short Shifter Selection
- Built 4L60E maybe toast??? Feels like I'm towing a boat in OD???
- Flywheel
- LS1 clutch
- Turbo350 trans?
- Master cylinder question...somebody help!
- Strange sound from rear end...
- My speedometer's not reading right?
- whats wrong with my trans pic inside(4l80e)
- Overdrive vs. Drive on the streets?!?
- 94 z28 auto trans problems
- 93z M6 tranny problems
- PLEASE HELP tranny problems!!!!
- "Gauge" fuse blows when I put M6 in Reverse
- ABS Inop Light
- whining noise
- Diff Recomendations
- Just put in Trans cooler
- What is this about S10 converters?
- Can't decode axle
- what gears for my 10 bolt?
- WS6 rims don't fit WS6 rearend!?!?
- Weird problem with my M6 - car behaves like it's stuck sometimes
- clutch position sensor pigtail connector? Cruise Switch Y Harness??
- Transmission Service And Mount . . .
- transmission mount
- Torque Converter with LT4 Hotcam?
- LT1 Mcleod Clutch MASTER/SLAVE setup part numbers and info.
- 93 v6 a4 shifting too soon
- BIG problem after getting on it.
- shift points???
- T56 questions....what part is this (pics inside)
- T56 Clutch Fluid AND gear box fluid... What do you use?
- Question on bleeding the Master/Slave Cylinders
- Should i buy a new clutch? Drifting \ Dragging 2 weekends apart
- t56 parts question
- question to the rear end gurus
- how to put on transmission mount . . .
- Clicking Noise Sometimes When Goes into Overdrive
- bleeding master cylinder
- Torque converter and rear end help
- LT1 T56 t-stud part number
- Identifying the trans in my car?
- LT1 trans cooling lines?
- cruise control no work
- Recieved my MCLEOD Clutch Master today!!!
- Now Spec 3+ is gone (1000miles)
- New Flywheel
- What Actually Locks Up the Converter?
- relocation brackets wrong ones!
- Thump on takeoff
- inspecting a used rearend?
- Dang It!! I think somethine is loose
- 4l60e?'s
- Pilot Bearing or bushing and what kind. Found out some good info..
- Who sells?
- What 4l60e trans will be a direct replacement for me?
- Transmission oil cooler into Oil cooler. Can I?
- Trans Cooling line Fitting?
- TH350 Swap dipstick question
- LT1 inspection cover same as SBC?
- cannot get flywheel on
- Who has aftermarket gears in their 10B?
- lt1 clutch fork bolt
- Viper t56 mainshaft question
- Manual Transmisson Rear seal & bushing issues (please read)
- torque converter questions
- Master clutch cylinder location
- Question about rear end... YES I ALLREADY READ THE STICKY...
- Aluminum Flywheel...balancing
- help me choose a clutch
- transmission how many quarts for a 4 ?
- stall question
- help transmission mount . . .
- transmission mount help . . .
- What could this be?
- Motive Gear "break-in"
- six speed automatic
- Just Fought my T-56 For 2 hours... The T56 Won..
- What did your 10 bolt hold up to?
- Trans fluid low
- How hard can I launch my stock t-56?
- 4l60e Lockup Issues And Probable Causes And Fixes Fyi
- noise when i step on the clutch
- 4l60e no 1-2 shift
- Torque converter questions
- General tech info on the 4L60E and 700R4
- comonly ask trans Questions
- 97 4L60E slippage...or something...lol
- tranny temp reads -40 on scan tool - code 59
- pilot bushings/bearings from local store?
- Weird clank noise around 55mph, causes vibration and makes car jerk??
- Rear End question
- 94 V6 car, posi or open? GU5
- Whine with a load
- LS1 M6: Just put in Motive 3.90's. Report:
- Satisfied CPT + Fuddle Customer
- Transmission Mount/Torque Arm Bushing
- Help Please Soon!!!
- WOT lockup / Fuddle converter questions
- are my 3-4 clutch packs going?
- 95 4L60E Problem
- Is the Trans Cooler..OK to use? Need help from the pro's
- emergency: t56 rebuild help
- Basic Clutch Question
- Pinion Seal How-To?
- will LSD additive hurt anything if it's not needed??
- Driveshaft problems...
- Can you tell what this "chatter" is? (video)
- safety loop
- Does anyone know what size and tread pitch
- URGENT will 95 a4 work in 97
- Weird problem after clutch install..
- Is this normal?
- removing caliper brackets?
- Need help choosing stal converter
- Is diff fluid like tranny fluid?
- Tranny (VSS) Issue...
- Who here had broken the axle shafts on a 10 bolt?
- Looking for some info on assembling 9-inch center sections
- please help, can't get tranny to come out
- Operation TH400/LT1
- How Many Of You Guys Running 4.30 Or 4.56 Gears
- rearend noise
- LS1 with a LT1 T-56?
- Bad transmission input shaft bearing?
- Gears 2.73 to ??
- 2.73 to 3.73 questions
- Got Fuddle?
- Whos running 4.56s with a stockish LT1
- Moser 12 bolt u-join girdle straps
- A4 > M6 Conversion
- Trans Dead - Looking for Recomendations
- Driveshaft Length.
- Differential options
- GM Hightech 10bolt Build Up...
- M6 Shift boot ring fix
- 1995 4L60E lockup question.
- gears on a 94 camaro z28 6spd
- What gears i have
- Skip Shift Solenoid
- Has anyone ever bought 9-inch parts through Quick Performance?
- Parts needed to make build a 9in rear end?
- 3.73 (2 series) gear install pricing
- NEED HELP...problems shifting...
- m6 conversion with different interiors
- zexel torsen HD LSD
- Shifter Choices?
- 80's tbi rearend = ls1 rear?
- manual tranny instead of automatic=> good performance increase?
- Spec Flywheels?
- 9" guys - is your driveshaft offset now?
- 4L60E doesnt stay in gear when decellerating
- Cheapest Places to Get Clutches? Now which is the best?
- o.d stopped engaging, cooled for hour works great
- Six speeds inc... my expierence. long...
- wont go into reverse... all gears are harder to get into gear.. works with car off...
- LT1+4L60E - will 168 tooth flexplate fit?
- How tight does 20"lbs feel?
- what should i pay for someone to install gears
- Vibration diagnostic check list
- How much to have gears installed? And what do I need?
- 6-speed guys with disengagement issues step inside
- Will a LS1 Aluminum driveshaft work and fit properly on an A4 Lt1?
- WOT 2>3 shift problems
- what kind of shifter would you buy from these three?
- Cpt Trans Owners, Post Your Et, Hp And Weight In Here
- Viper T-56 Conversion "Write UP"
- 1993 Z with M6 and 2:73 gears
- T-56 Source
- Clutch problem HELP!!!!!!
- Did I just destroy my 10 bolt 400 miles from home?
- 95 z-28 t56 specific camaro z-28 questions. Electrical circuits help please :)
- Axle seal part number?
- New Gears in Speedo Correction Help
- Transmission flush at 91K?
- No line pressure in tranny. Bad pump?
- 700-r4 owners
- A4s Going Out....Weighing Options
- Anybody recommend a clutch?
- vibration issue
- Lock-up or non-lock up???
- Performabuilt
- Pinion Yoke Weights
