- 4l60e
- Just got the 5.0 installed !!!
- 3400 Yank too big...
- What kind of 60' is expected with a moser 12bolt with 4.10s?
- Rebuilding T56???
- Question about "stallin' at the line"
- clutch pedal problems. 3" and stop.
- t56 trans fluid?
- master cylinder install!!!!!!!!!
- Trying to figure shipping. Need TH-400 stats.
- aluminum drive shaft
- D.S. Loop no fit?????
- Can't get Tranny on!!!
- 1993 Z28 Tranny help?
- Weird Noise from shifter area??????
- Turbo 350 downshift problems
- Stock Hurst Vs. Pro 5.0
- differential oil, hellllllp!
- Hypertech shift firmness setting - Good / Bad?
- Best Shift Point?
- component list for clutch swap
- RPM's to Gear Ratio
- question for M6'ers
- Clutch Shims
- What did I do wrong?
- Those w/ Aftermarket Auto Shifters
- 3.8 V6 4l60e?
- Anyone ever double sealed their T56 tranny input?
- So I'm driving home..........
- Opinions on SLP Clutch/PP/TO Bearing
- B&M Ripper ?
- Clutch experts, Need your help, my Street Twin is toasted
- Did I break it?
- winter tires
- B&M Transmission SuperCooler, does it work ?
- moser installed ... but..
- full manual 700R4 in a 93 Camaro, what are my shifter options??
- Upgrading T56 - D&D vs Donato Engineering.
- help me please... Ford 9" fluid change.
- I Rule!!!
- Need Part #'s
- loud gears
- Flywheel balancing?
- What kind of Bearing puller.....
- Transmission Syncro
- tranny help!!!!
- going to rebuild my t-56, how to make it stronger?
- button on shifter wont depress easily
- Tranny Question
- TC and 373's
- What are some simptoms of a bad clutch?
- trans question
- reverse lock out gone bad
- New strange noise
- which gears should i get?
- 3.73 a4
- TCC solenoid part number?
- width of lt1/ls1 10 bolt rear?
- Help installing an aluminum driveshaft
- carrier??
- T56 rebuild
- How do you use a dial indicator?
- shifting without a clutch??
- a4 tranny rebuild kit?
- One-way clutch grabbing? Rich Krause, 12SCNDZ, please help.....
- clutch pedal noise
- transmission help
- Concerning TC change
- Spec Clutch?
- B&m Shift Kit
- Motive OR Strange?
- Question on 95 4L60E
- guys running th400 come in
- how does a gear
- Synthetic Gear Oil
- Powertrax Locker
- 3.73s? Gonna throw me in the seat?
- th400 guys come in
- stupid newbie trans. question
- Drivetrain vibrations
- Up shims creek!
- identifying a 8.5" 10-bolt from the rest?
- Here's a die that works for the Pro 5.0 handle...
- Need info about 6spd swap. Search=No Luck.
- Can't get them off.
- TV cable problems?
- Goodyear P275/40ZR17 Eagle F1 Question
- need stall advice
- Need opinions on a good clutch setup
- Anyone use Centerforce Dual Friction clutch?
- choosing stall speed
- 4l60e delayed shift/ PLEASE respond.
- increased line pressure via PCM... good? or bad?
- Broken Wheel Stud on New Strange RE
- 4.10 lowest differenial ratio?
- what is the best tranny fluid, rear gear fluid???
- TH400 VSS Sensor Install ?
- Posi Unit for 9"
- funny noise making me go insane!
- where do i get the A4 to M6 conversion kit?
- 7.625 Eaton
- 4L60E Problem
- What is needed for 4.10 install on 136k mi car?
- Who sells spools for 10 bolts?
- Could this have something to do with my Drivetrain?
- Auto shifter sticking
- transmission wont shift
- Grinding/rubbing noise from T-56
- 3.90 gears now available for the Strange 12 bolt
- LT1 + 5-speed manual?
- How are 3.73's in an M6???
- Th400 running a NON lock-up 2800 vigilante, is this "too much"?
- Converter questions!!!
- 3.73 gears
- Pros and Cons or Redline Synthetic Tranny Fluid
- Can I mis-match gears???
- Help With Getting C-Clip Off
- LS1 Axle Shaft in LT1 Rear End
- Can splines be fixed?
- Getting my TC soon
- 3.73 gears?
- SLP gears...
- Cheapest place to get 12bolt rears?
- Cheapest 12 bolt out there?
- Whats wrong with TCI??
- shift kit for a4
- How bad is a leaking rear main?
- I CANT stop misshifting even with a pro 5.0 shifter! I NEED a rocket scientest HELP!!
- Big hp (650rwp+) guys with m6s inside please.
- Agghh!!! Someonehelp!
- Yank stall questions...
- Clutch disk material... what do I want?
- Key Stuck / Wheel and Clutch won't lock
- Heeeeelllllpppp!!!!!!
- Bad Vibration
- reverse lockout wiring help!!!
- Corporate GM 12-bolt out of a Suburban? Can it work?
- Tranny Cooler Question
- Rear axle work
- 400 speedo sender
- Best Clutch
- IS this on right?
- LS1 Rear End Questions (Brakes, Torsen, Gears?)
- Gears for an A4???
- How can I tell if the CLutch fork isn't on right? What are the symptoms?
- Vigilant vs. TCI converters
- Transmission, Overhaul or Reman?
- traction was bad before.... with cam forget about it! HELP!!
- Is this noise normal??
- 4:10 Questions...
- New tranny goes in this week, what else do I need ?
- Did I ruin my rear end?
- a4 to m6 conversion?
- Torque Convertor Question
- tranny mount broken. please help...
- Problems a month or so after SLP Clutch install. T/O Bearing?
- A4 to M6 advice
- Jarods or Lous short stick( i need quick response so i can get this b4 christmas)
- quick help on pulling trans!
- Is My Tranny Shot???
- Can I
- Money 2 spend...clutch?
- new transmission acting wierd...help?
- where can i get a midwest or edge convertor?
- How much did your ET drop with a vigilante converter?
- SLP clutch w/ a 150 shot?
- How to do "Resistor trick"
- Lt1 Clutch bleeding procedure
- Need help, will this work??
- Autozone clutch no longer $199
- where to go now?
- Auto or Manual for very high power
- Very Bad Shaking.....
- My SPEC Stage II Experience
- when do you need a Viperized T56?
- Mcleod street twin info
- I can shift from 4 to 5, but not 6 to 5, what gives?
- shift kit q's
- G-Force T56
- Tranny Problem????
- where to get a new axle?
- Six speed gears into an A4 Car
- Need Help with New Transmission
- clutch squeaking?
- flex plate on 383
- t-56 stuck in 4th gear...whats wrong?
- Replacing Clutch
- Short shifter Question
- Shifts feeling a little harder
- very knocking/hard going into 2nd
- 94 A4 Tranny problem (missing 2nd)
- tranny prob, please help
- Torque specs for the McLeod street twin please...
- Yokohama v/s Nitto
- M21 or M20?
- Transmission Cooler Install
- best clutch for the money
- I know its been asked a million times, BUT, what is the best convertor?
- Auto tranny fluid leak...
- 4L60 vs. 4L60E
- How much for labor and parts on Syncros?
- What RPM stall convertor to get?
- Figuring out gears in used car I am buying
- Need advice on rebuild or swap
- Factory Hurst v. Aftermarket Hurst - Visual difference
- Th-400
- Has anyone built a strong 10 bolt and what is the best 60s your getting out of it?
- Clutch peddle position question
- help with gears!?
- ls1 t56 to lt1
- Differential Vibration???
- No WOT Downshift...
- No reverse in A4 - need advise
- fbody 10 bolt in an s10?
- can i make these gears work?
- Car shakes real bad when accelerating from a stop.
- A4 to Muncie swap?
- Th400__vss__fast
- Someone Explain this please
- stall questions
- rotors
- Clutch Install?
- 4L60 will it mate to other SBC's
- Torque specs for the 12 bolt rear?
- Vibrates under moderate acceleration.
- Conveter Size
- Where do I get Vaccum source for Transmission ?
- GEar pattern?
- Spec stage 3 owners inside -->
- clutch slips on launch/hard shifts ??
- clutch problems
- New Tranny needed...
- M6 Tranny Seal Replacement
- tightening drive train bolts - how tight??
- torque converter
- Lets try this again...PAtterns!!!!
- Hard thump / popping sound
- Gears installed today... break in period?
- Tranny optons for LS1
- Awd Z28
- Clutch engages at various distances from the floor ;(
- bought some used slicks... this dont look right
- Jarrod's Short Stick installed
- 3.42's or 3.73's?
- stock clutch replacement
- aftermarket part
- Transmission selections, need help please
- Best Shift Kit????
- M6 High Speed Transmission Rattle ( I Think)
- Transmission Cooler Install Questions...
