- Gear change
- 4 speed padels
- T56 Tranny Fluid?
- 4l60e stuck in gear/no movement
- Slave cylinder question
- rough idea for shift point built 700r4
- Installing trans/converter...
- Differential Apart - Center section REALLY hard to get out...
- 4.10 Automatic Guys
- Diff fluid
- Torque Converter?
- autometer trans temp install
- Converter not locking up.
- Speedometer reads low?
- Installing new carrier
- 94 z28 tranny problem??
- Bigger tires, gear change?
- 4.10s and an A4
- Yank PT 4400
- Did a search and just want to make sure...
- Quick clutch question
- New rear gear...computer ok?
- Are LT1 and LS1 clutch pedals the same?
- Put my Spec 2 in and....
- Size of some bolts for LT1 T-56 swap
- 12 bolt backlash?
- What's the cost and difficulty level of....
- Automatic shifters
- Converting A4 to M6 and Vice Versa
- Grinding Third and other issues
- 9.5" vs. 12" Torque Converter
- car sits lower out back after 9" install
- Cost To Rebuild T56?
- 94-early 95 tranny ????
- I need trans Range switch diag. & 1994 M6 shifter Diag
- tranny still dosent work
- 4L60e will not engage in park??
- Dial Indicators??
- summit racing ring and pinion's(my review)
- Possible Street Twin Problem Please Help
- Used clutch?
- 2002 camaro z28 axle end play
- Main shaft bearing
- Auto trans/road race questions.
- Slave cylinder rod bent - 95 LT1
- Tranny/Shift Kit Question!
- Auto Tranny Isuues...
- M6 swap wiring help!! VSS/polarity
- vibration after gear install
- Problems with T56 gears
- Tires not spinning?!
- car has the shakes...
- clutch hydralic line removal tool
- jumps when i start try to start the car?
- Hard engaging gears=Clutch Adjustment?
- Removing axels
- taking transnission apart
- RAM HDX is really a Valeo product?
- Master, slave or ??? Whats going out.
- Burning out with street tires...
- T56 Torque arm to trans mount
- Possible 4L60E World Record
- 700r4 question
- V6 and V8 Transmission Diagnostic Codes Lists.
- LT1 T56 in a 1st gen camaro
- lt1 a4 slipping
- Transmission
- Stall questoins
- Clutch
- 4.10's or stay stock for my setup NOW?! ---
- 4L80E Tranny Swap ? ? ?
- Drawing/exploded view of lt1 clutch
- trans noise
- Clutch recommenation
- Cpt
- transmission problem????
- street twin vs mcleod single disk
- Gear Install
- Yank vs. Fuddle
- Detroit Tru-trak users, inside!
- Vibration problems
- 95 firebird auto stuff
- t-56 grinds second gear at higher rpm's ---
- Tranny leaking!
- installing my converter whadt else should i do at the same time?
- t56 same or different
- More shifter noise after new clutch normal?
- Tranny w/od for 1000hp??
- Ram clutches? good/bad?
- M6 Tranny Fluid
- transmission removal problem
- aluminum flywheel on a nearly stock lt1/ is it worth it
- Speedo sending unit
- Going to rebuild my rea end...
- Help me with this clutch???
- TCI 3000 on stock motor?
- Has anyone rebuilt Thier own 4L60e??
- lt1 adjustable clutch master
- INFO: Stock LT1/T56 flywheel weighs 20 lbs
- Is the SLP Billet Steel Flywheel SFI Rated?
- Clutch Problem
- 5th gear grind on new T56
- 3.23 to 3.73?
- Clutch Fork Bolt?
- Cheap Ebay Shifter-Review/Pics
- 4l60e band sliping
- Need OEM LT1 Flywheel Balance Spec.
- Luk Clutch Kit
- Is my stall that ineffiecent???
- Which Differential?
- stock converter
- Pinion Seal Replacement Info
- 93 Z28 trans prob
- stock rear end c-clip
- Powertrax?
- Help with clutch install
- 3:23s or 3:42s need some help...
- Weird noise coming from the back of car
- How Tight Is Too Tight For Gears?
- Is the T-56 in the LT1 and LS1 cars the same?
- Well.... clutch related issue
- bellhousing cracked
- Tranny slipping already
- Stupid question
- 1-2 and 2-3 shifts really hard??? please some info???
- Diff. b/t Spec Stage 3 and 3+
- NEED a T56 94-97 Help!!!
- Maddogracing Stage 3 Clutch Kit?
- is 14.2 good
- Drag radials = bad for trans. mount?
- what is a transmission additive
- posi trac
- 4L60 Issue, Lost gears 2-4 then retained them?
- parts to buy for rebuild
- Light fly wheels
- P0748 Code
- 2.73s to 4.10s - in a 6 speed
- Swapping Rear End Question
- Where to buy gears from
- optional gear ratio
- sheared off passenger back wheel studs
- trans problem
- Duralast or Mcleod for me?
- Howling Noise in rear
- Nut to drain torque converter?
- 4l60e 1995 1-2 accumulator
- 1995 z28 conv. no 1st gear on shifter?
- Rear end sings on deceleration
- lt1 flywheel question
- M6 trap speed, 4.10 gears vs. 3.73s or lower
- question turbo 350
- Th350 Swap, Trans cross member mount ??
- 12 bolt rebuild
- who makes strong t56 for about 700rwhp
- 96 M6 Z28 3.42 Gears (Rearend Question) HELP!
- M6 issue? HELP!
- 3.23's to 3.42's?
- Transmission Pump
- TCI Outlaw Shifter
- Highest rpm's on stock motor?
- keeps bouncing from 3rd to 4th in OD
- Problem with my Transmission, (i think)...
- swaping t56 for th 350?
- Rear end swap
- how many qaurts to fill a t56??
- type of transmission
- a4 to t56 conversion!
- 700R4 compatability?
- bad vibrations
- How Bad Is This. Gear Shreds
- speedometer
- 95 a4 trans mods=13.60@100.17
- This is gonna need "insight" from a GURU!!!
- Car jerks when put into drive or reverse.
- trany sings on accel...
- how much slower?
- Whiney rear end after gear install 2.73 -> 4.10
- Where to buy Ram power grip clutch disc only
- Racheting sound now clutch pedal high
- Overdrive Cable
- 1-2 shift problem 4l60e HELP!!
- We really need an LT1 sticky on clutch/flywheel options
- Flywheel recommendations?
- Just installed UMI Lower Control Arms.
- rearend work on 10-bolt.....
- Rebuilding 12-bolt posi
- 4l60e identification
- Whats wrong with my tranny!?!?!
- 1-2 shift probelm 4l60/700r4
- 94 z28 rearend
- Strengthening the 10 Bolt.... Ideas?
- 3000 Stall?
- Strange tranny noise yesterday
- 9 inch torque arm placement?
- Tranny Help Please!!
- tranny grind..please help
- Gear Swap - Before Recalibration
- The hits just keep on coming. Kicking out 4th
- weird problem with trans
- Trying to bleed clucth and getting nothing
- fluids for rear and tranny?
- Removing a 4L60E
- Trans cooler
- drill mod didn't help at all
- Clutch master gone?
- tranny question
- Gear installation
- Changing Tranny Fluid?
- Camaro rear end question
- CPT pro race build in!
- A4 vs M6 on the strip
- Visual signs a synchro is dead...
- How Do I Check Front Wheel Hub Assy?
- Help- Gear Install Problems
- VIG 3000 converter with 2.73 gears?
- I need a 95 and later 4L60E visual inspection on YOUR car
- 3.42's on a 97 auto?
- best clutch for everyday 450 hp?
- maybe this should be a sticky( maybe it already is)
- clutch problem
- Can't get M6 into reverse....
- clutch pedal?
- Question about Spec 3 vs. 4
- Cheap re-stalled converter. Any gains??
- Rear End Gears :: Installation
- Another satisfied CPT Customer
- PerformaBuilt FAQ page LOOK
- Need help with t56 part
- no shift on hard take off
- 12 Bolt
- 4L60E Problems!
- Smoked my A4 today, Who is well know for building 4L60E's and will back it up!!
- Rear End and Speedo question.
- Help!!!!
- TC switch install?? Did a search NO how to guide??
- another 3.73 question
- Converter and gear combo
- Tranny temp and air conditioning?
- anyone use a hays clutch?
- 2.73's to 3.23's
- torque converter
- McLeod Clutch Slave Adapt???
- best gears for my set up
- Bad vibration when clutched in. [edit]
- 4L60E problems
- What do I need to make this rear fit?
- Spec 3+ vs. Street Twin.
- whats better
- Just got a Strange 12 bolt and now......
- Need suggestions for transmision rebuild
