- 700R4 shift kit install Q
- Just ordered RAM Powergrip
- Automatic to Manual?
- Clutch engagement problems
- transmission help
- Turbo 400 tale shaft
- 3.73 Installation Checklist.
- Poly tranny mount with or without the plate ???
- need help guys...(clutch)
- Spec III Clutch Help
- T56 parts
- rear gears
- T-56 jumps out of reverse
- rear end yoke?
- aftermarket shifter in 4l60e
- Few questions about this tranny.
- Stop Leak Additives
- Who knows there E40D's
- 3:73' s with auto
- What flex plate???
- Clutch pedal gone. Need help ASAP PLEASE!!!
- Can I change a steering rack in my garage (home)?
- Is my Ring and Pinion done for?
- I know it's been asked, but the T5...
- ring and pinion broke loose
- LS1 swap into a 94 Z28?
- What gear (rear end)
- Are LS1 and LT1 rearends the same??
- Best Converter Brand?
- 4.10 gears??
- BMR torque arm relocation bracket
- LT1 or LS1 T-56 tranny crossmember?
- Auto Trans Rebulid
- noise from new clutch install
- 96 LT1 AutoTrans Rebuild?
- Washer for torque arm?
- AC Delco clutch, good or bad?!
- Anyone have a "how too" on rear gear change?
- SWRacecars.com
- HElp tranny problems....
- 10 bolt ?
- t56 swap question(cable)
- Need info to install 700r4 in 69 Camaro
- Is it possible to mate an LS1 tranny to an LT1?
- rear differential series?
- stock trans question
- Where can i find gears for my Aussie 9 Bolt Rear?
- 10 bolt housing v6/v8 the same?
- What fluid 88 T5 WC atf 3 syn or a synchromesh
- 10 bolt build up??? vs dana s60
- Built 4l60e or TH350
- How much?
- Skip Ship?????
- Non LT1 Trans cooler question
- How much $?
- tranny temp
- 4l60e Pump issue
- Powerglide
- 2500 stall
- Help diagnose
- Strange rear axles
- Trans removal...
- best shift kit
- stall installed
- SBC/BBC Flywheel ?'s
- 9" axle pinion offset?
- Strange 12 bolt
- Will it hold!?!?
- How big is yours? Converter
- how much can this 9" handle?
- Clutch problems i need help!plz
- Which Converter? (Under $700)
- v6 -> v8 swap auto->manual
- Mcleod single disk good for 400+ hp
- T56 Rebuild: local or T56rebuilds.com
- PLease help, tranny messin up....
- tranny type...
- More A4 trans problems...
- Transgo-shift kit questions.
- tranny issue on 2001 z28
- will this work on my car
- 12-bolt w/spool
- labor price for Strange 12-bolt install
- short stick for pro 5.0
- Part # for pilot roller bearing
- trans temp question..
- found old gears
- 4l80e shift controller
- trans swap
- moser 12 bolt ?'s
- A4 Gears
- Budget 9in..
- torque converter
- Converter question
- t5 question....
- What is chattering???
- Non-Fbody Trans Question?
- stahl
- 4.10 & M6 in 1/4
- Corvette-Fbody T56 flywheel interchangable?
- auto only works in revers
- rear end gearing help
- glove box sticker 1995 T/A
- wiring questions on t56 swap!
- Issues??
- Transmission lines
- Misc bracket
- TCI Saturday Night Special converter
- Replacement cooler line fittings & re-flare of lines (4L60E)
- how hard to swap t56 to th350 or 4L60E
- 383 folks with 3.73 or 3.91 gears?
- Rebuilding a street twin?
- 383 cc306 with 4l60e 3500tci 3.73 lockup shuter,
- My M6 car doesn't want to go in reverse? Suggestions??
- transmission??
- Rear End Fluid
- Transmission, Clutch, or something else?
- i need to put in new gears
- gas milege
- Car grinds at idle in gear,,,,,why?
- Are my auto shifts normal?
- what gears with GM847
- B&M shfit improver install
- M6 bellhousing pattern?
- stall and gears
- TRanny Problems
- Part #s for M6 pedals
- 400hp/M6 guys
- Transmission Noise (M6)
- lost all atf
- what series do I have?
- What clutch is best?
- torque converter issue after dragstrip
- Axle bearings wont move
- Help me identify some T-56 Conversion Parts
- zexel torsen
- Got my Fuddle Racing Stall today!
- tranny
- FIXED: Vibration above 4000 grand
- shift points w/ dyno tune??
- converter shudder
- Received my CPT transmission and my Yank PT4000
- Clutch Question
- so i've decided...
- Popping/Clunking when stopped/stopping PLEASE HELP!!
- gear in my A4
- Replacement transmission line options? Part #'s?
- New Moser M9
- Need some help?
- Pressure plate bolts and flywheel bolts p/n please
- Need help diagnosing 4l60e problem
- TNA Short Stick
- one question after reading stickies
- Post your A4 to M6 conversion experience
- Anybody rebuild your own t56? Or reverse synchro/fork replacement?
- Good tranny specialist
- t-56 to th350 swap ds length
- How much fluid so I need for a 4L60E fluid /filter change?
- GM 3.73's for 10m bolt
- Differential on its way out..Question
- recommend a converter
- What gears do I have exactly?
- Transmission Service at 80K Miles?
- $500 for gear install??
- Does anybody have anything good to say about TCI
- Stall speed vs. Shift Points??
- M6 fluid check?
- Going 65 my buddy is 3 1/2 MPH faster!
- clutch fork problem
- Need T-56 parts
- how many spline rear end in a 93z28
- Thoughts on Spec Stage 3
- Royal Purple Gear Oil?
- Redline Transmission fluid,OK?
- Learning to build a 4l60e
- Vibration at 4K after clutch install
- Weird non shifting problem COME IN AND SEE
- Bouncing off rev limiter need help
- Tremec TR6060
- hey, 4th gen question
- Grand Prix Transmission whine, please help if you can.
- T56 Interchangability
- transmision
- T56 jumping out of 2nd?
- locker vs. auburn/torsen posi
- Questions about bolting torque converter to flywheel
- Yank PT4000 = totally streetable
- M6 Conversion
- 3rd gen rear in a 4th gen
- 3 series Carrier
- stall from a 4l60e work in a 700r4??
- Best way to drain 4l60E?
- Throw-out bearing lube...
- Aubern posi problem
- Ok still doing alittle wiring on t56 swap
- what works in a 95z a4
- zexel or auburn?
- th400
- noise anyone else have and fix?
- what gears!!?
- how do i disable traction control
- ring and pinion question
- Anyone with Yank 3200 or Yank 3600 ?? Need some advice...
- clutch
- T56 Install problem - Won't go on all the way
- Anybody with Yank 3200 or Yank 3600? Need some advice...
- Stripped bellhousing bolt A4 HELP !!!
- Got My New Ram HD PowerGrip Clutch
- T56 Clutch Fork issue
- Strange Seamless Chrome Moly DS vs Denny's Nitrous Ready DS
- A4 gear choice
- clutch replacement need some info
- LT 4 Clutch, what do you think
- '96 4 channel rear end fit on '02?
- Whatcha Ma Call IT?
- Please help with stall recommendations for 383 daily driver LE2 heads/cam
- Strange Dana S60 rear posi selection?
- HELP!! 2001 Z28 shakes violently!!!
- new gears got whine
- Driveshaft strap bolt torque spec
- 10 bolt with different axels handles more power?
- Tranny knock/rattle? HELP!!
- Will a shifter for a 700R4 work for my 4L60E?
- need a tranmission
- your thoughts lt1 T56 4.22's
- tranny issue
- Is it done?
- does this tranny cooler look
- Clutch / Trans. making wierd noise / vibration
- t5 transmission questions
- t-56 swap
- t56 conversion impossible with long-tube headers??
- How to disconnect line from slave cylinder?
- POSI Question
- NEED HELP...rear end paddle question
- Gear Grind
- why a 700r4 conveter wont work with 4l60e
- clutch install
- can tranny take 360rwhp?
- Turbo 350 no first gear
- Pinion Nut Torque
- 4L60E problem
- 94 Z28 A4 Tranny problems, need help!
- T-56 conversion people - where did you get wiring pigtails?
- What all should I buy for a rear gear swap?
- Do I have 3.73's?
- trans problem
- posi unit
- centerforce dual friction _ bad or good idea
