  1. Clutch Recommendations
  2. Pinion seal leak repair
  3. T56 Rebuild Underway!
  4. how torque converters work
  5. did i get the wrong stall?
  6. trouble bleeding!
  7. does not shift into 3rd under load
  8. difference in rearends...
  9. B&M Pro Stick Install
  10. 700r4 no forward gears just reverse
  11. will a auburn carrier fit in a torsen rear end ?
  12. clutch problem or lsd problem
  13. How long has your CPT transmission lasted?
  14. Recent 94 4l60e rebuild vibration 2-3 shift.
  15. anyone build a 8.8 inch ford rear end ?
  16. looking for a new d/s
  17. reluctor ring?
  18. trading 7.5 for 8.8
  19. Rear end squeak?
  20. Disable the lock up?
  21. convertable gears
  22. Who builds a good 4L60E, street and mild strip ?
  23. time for the rear-end..
  24. split bellhouse 4l60e
  25. Need a 12 bolt
  26. Clutch Problem
  27. how do you tell if your 10 bolt is a 7.5 or 8.5
  28. 94 lt1 tranny options
  29. Trans cooler lines: Feed & return???.
  30. manual 4l60e
  31. Trans. swap need info
  32. Who Makes Aluminum Flywheels For LT1's
  33. Anyone with u-joint knowledge please read
  34. ram powergrip hd rated at 600hp?
  35. Gear Chip
  36. 3.73 vs 4.10 ratio mph difference
  37. Part Number
  38. Tricks on pinion spline
  39. What's a good clutch? (only slightly modded)
  40. Transmission seal leak
  41. Whats the difference between a '95-'97 LT1 4l60E
  42. Late upshift, no downshift?
  43. made the swap
  44. Strange 12 bolt
  45. Best supercharged gear ratio
  46. 97 4L60E in a 95
  47. What Stall????
  48. New Tranny Pan
  49. 1996 T/A - How much would a differential cost?
  50. Pilot bushing and input shaft ???'s
  51. 6 speed help
  52. 6 speed manual ratios
  53. removing axles, need help with c-clips....
  54. Help diagnose 4l60e problem
  55. Spec 3+
  56. What was the 1993 Automatic Tranny
  57. Transmission Fluid- Synthetic or Dino??
  58. ATF at the back the trans
  59. Gear Question
  60. Frank @ CPT ... EXCELLENT customer service!!
  61. transmission problem maybe??
  62. axle bearings/seals question
  63. Dead pump or converter?
  64. Bad clutch I think.
  65. I think is the drivetrain
  66. and....the TA breaks down.
  67. Help me pick the right parts
  68. Limited slip breakaway torque
  69. whats wrong?
  70. New tires/rear end concerns
  71. 97 Camaro LT1 Tranny Options
  72. Any Fidanza clutch users?
  73. 4l60e torque converter #4842ss info
  74. Pro 5.0
  75. Trans guy need sum info
  76. street twin space and washer setup help
  77. 96' t56 Input shaft check
  78. GM Synchromesh Fluid?
  79. bent axle or warped rotor..
  80. Newb tc question.. yes I read the lock up sticky
  81. A4 trans problem, opinions please
  82. Need some Ford 9" help...
  83. How Hard Is It To Change The Spider Gear From One Auburn Diff To Another?
  84. clutch installation
  85. where to go to buy shims or spacers for dialing in the differential
  86. could this been the pressure plate or clutch ?
  87. Cost for A4 to M6 conversion?
  88. Torque Converter Lockup Switch?
  89. tranny guys...
  90. T400 vs. T56 in a turbo car?????????? Looking to maybe swap...
  91. torque specs for lt1 pressure plate
  92. Whats the black tube on t56?
  93. Converter sporadically locks/unlocks
  94. Clutch Pedal Vibration
  95. Clutch little slippery on cold/damp starts
  96. 3-4 clutches burned up..... again
  97. Rear end howl/ whine
  98. redlining in first, give me the news.
  99. Synchros or Clutch???
  100. M-6 to A-6 conversion
  101. My Fuddle Review
  102. 1/2 inch studs
  103. GM Gears - Part #??
  104. TH350 Re-Seal -- Parts List?
  105. Centerforce Clutch?
  106. LT1 4l60e bolt up to LS1?
  107. Building a 10b to handle ~500hp.
  108. Car feels like someone is holding bumper
  109. Will my stock 10 bolt last?
  110. flywheel balancing
  111. Spohn LCA Relocation Bracket Owners - In Here Please
  112. t56 input shaft
  113. 3400 Stall to big for bolt-on/sprayed LT1??
  114. What kind of T-56
  115. what parts to buy for strong t-56?
  116. SPEC stage3+
  117. Caliper mounts
  118. Trans maintenance
  119. Transmission Help
  120. Part number for stock driveshaft and 1350 yoke?
  121. Questions on T5 Transmissions and other specs
  122. 4L60E to T56 conversion??
  123. valvebody and th400 rebuild question
  124. DTC P0758 2-3 Shift Solenoid Circuit Electrical
  125. accumulators
  126. HELP more drivetrain problems...
  127. Educate me on stall converters
  128. replaced slave cylinder, WTF now no line pressure.....
  129. Slave Cylinder hose connection
  130. 4l60e help
  131. 4.10's
  132. T56 swap - hard to shift
  133. My rearend has been changed?
  134. 4L60E problem?!
  135. New to the fourm, spec clutchs....
  136. Would you buy a used clutch?
  137. will a 4l60e work on a lt1?
  138. 2800 stall speed
  139. LS2 Flywheel / LS7 Clutch - What else do I need with my 2001 Z?
  140. trans cooler fittings
  141. Can you have a anti-ballooning plate installed?
  142. 700r4 ?
  143. clutch fork t stud
  144. Anybody know part# for LPE DS u-joint?
  145. is there a way
  146. Whats needed to swap to a 700R4?
  147. Gear ratios for various trans of interest
  148. spragless?
  149. Need Help with 91 Camaro RS
  150. What should it cost to have gears installed?
  151. Finally! A Trans shield for 700/4L60E
  152. shift light in side defrost hole?
  153. Need help with clutch!
  154. Performabuilt?
  155. Transmission problems...
  156. A4 and M6
  157. M6 and A4 ?
  158. 2.73, 3.73, 4.11, stall
  159. Gear questions 10 bolt
  160. Some may have taken my post about Performabuilt wrong
  161. 4l60E to 700R4 conversion.
  162. 700r4/4l60e question
  163. people with 2800 stall
  164. M6-A3(th350) help.
  165. Broken Tranny Mount
  166. ooh ooh that smell...
  167. Shift kit?
  168. Rear end whine
  169. Changing rear gears to 3:73
  170. what gears should i get?
  171. 4.10's?
  172. question about shift kits and transmission perform
  173. five speed question
  174. Rear End Replacement Questions?
  175. Tranny problems please help !!!!
  176. B&M Racing Buys Hurst Shifters
  177. New Driveshaft--U-joint Strap?
  178. Rear Axle Removal - What Tools and Where?
  179. Prescision GEars Question???
  180. Is it worth it spending $300?
  181. Will a Dodge 8 3/4 or Ford 9" go into our cars?
  182. help me build up a T-56 for some serious TQ...suggestions?
  183. T56 Conversion Question
  184. Need Flywheel Help
  185. rear end girdle
  186. Not shifting to fourth
  187. B&M Shift Improver to Transpak?
  188. aliminum driveshaft
  189. LT1 bellhousing bolts........
  190. Couple of Questions
  191. question about stalls....
  192. clutch install?
  193. Question on swap
  194. Rear End Removal
  195. GLOBAL WEST TRACKLINK w/MOSER 12 Bolt
  196. McLeod Soft-Lok clutch
  197. Anyone ever use an LT1 T56 with an LS1?
  198. 4.56 gears.
  199. need too change tranny fluid 104k
  200. About flippnig synchos? reverse only?
  201. rebuilding rear end
  202. What size gears are these?
  203. Trans Question?
  204. high torque shift rattling...
  205. Thinkin 4.10s A4
  206. will a Lt1 T56 bolt right up to a SBC
  207. rear debackle
  208. gear install, and c clip elimonators
  209. Anyone Rebuild Their Own Tranny
  210. 2nd to 3rd Gear Not Shifting At WOT?
  211. What to do my 6th gear is gone i guess
  212. dont know if this is the right spot but..
  213. Any advantage to a WOT lock-up on a torque converter?
  214. auburn diff
  215. What tranny fluid for ZF-6?
  216. I have a mod kit can i make it work? 4l60E
  217. clutch/slave question
  218. Pilot Bearing Install
  219. installing gears help
  220. Slipping tranny
  221. Moser 9" axles
  222. For strength which gear ratio is best 373 or 410
  223. 8.8 ford rear in camaro
  224. Stall converter
  225. Max power for a stock 10 bolt?
  226. A4 exhaust mount/cat support vs M6 exhaust mount/cat support... same?
  227. 1993 A4?
  228. Used gear question
  229. Stock rearend can't handle 398RWHP HELP!!
  230. Anyone ever rebuilt a DS center bearing?
  231. 700r4 question
  232. 4L60E no 1st or 4th gear. HELP
  233. Rear end noise
  234. 3-4th Not shifting @ WOT
  235. good price for 3:73 gears..
  236. Lowest price for Mcleod LS1 bellhousing??
  237. Dangers of testing w/ rear wheels off the ground
  238. big stall guys please chime in..
  239. 12bolt From A Truck?
  240. RAM HDX Clutch Disc Died on me, for no apparent reason
  241. 4 series axles on a 3 series
  242. What Gears Do I Have???
  243. Textrailia review(30 miles). M6 question. This clutch is cool!
  244. No Overdrive
  245. 4L60E from a '94 Silverado?
  246. Replacing tranny what do I need?
  247. 700-r4 shift kit selection
  248. Weird vibration on decel after the track last night
  249. 3rd gen rear into 4th gen
  250. 4L60E on the way to Frank/CPT!
