- TH 400 wont shift to third on the jug!
- Just bought Moser 12 bolt have some questions...
- no tranny data
- 3.73's or 3.90's ?
- Transmission woes.....
- v6 drive shaft fit a v8?
- Going to get a shift kit
- Changing Rearend.. and Removing Rearend Need tips Fast!
- transmission/converter question !!!
- Abs Inop
- 4.10 in an auto
- My setup th350 or th400
- Transmission slipping, have an idea
- Spec Stage 2
- Transmission wont shift into second when I floor it
- Well my SPEC4 lasted 2 years and 50,000 miles......
- alum. or stick w/stock DS after engine install?
- Moser 12 bolt.....or 9"
- break stock 3.42s with 315 nittos?
- Vendors for complete bolt-up 12 bolt rear ends.
- People with stall converters(3000+)
- tranny won't fit all the way
- Torque Converter
- What is this diff part?
- Anyone restall their stock converter?
- Diff magnet adhesive? Need it?
- Stock Posi and 4.30 gears
- stalls and gearing
- Abs sensor on my 12 bolts(Strange)
- Need Part number for 3150 U Joint
- LS1 tranny mount to replace LT1 mount?
- Upgrading the clutch --
- 4L60E Transmision in Ebay
- ZF 6 speed in a Camaro?
- Race Clutch Comparison
- Converting To Manuel
- How to tell 3.23's apart from 3.42's by looking?
- Upgrading the slave master cyl?????
- Would this tranny cooler be worth getting?
- Help with 94' 4L60E failure, I think?
- Strange Dana 60 for '82-02 F-bodies...
- Noisy Spec stage 3
- Is the slave cylinder outside the tranny?
- Any Yank SS3200 users out there?
- 4L60E question
- Which fill hole should I use?
- Alright - Tranny Coolers, Shift-kits?
- Question about A4 to M6 Swap
- shift light 4 automatic?
- loose flywheel?
- a4 question
- Question About Torque Converters
- Magnet in 4L60E?
- Answer this correctly and I will pay you!!!!!
- Clutch for bolt on car < $500
- Ways to know your trans is slipping?
- problems engaging reverse in my t56 with mecloed street twin
- Slip after change to Royal Purple .
- Which launches harder..camaro w/ 9 inch w/ slicks, or awd EVO
- Momo shift knob/short shift?
- Poll: What would you do??
- Help! Rearend knocking and whining. Must drive 800 miles...
- Spec 4 clutches what pad design should I buy
- limited slip?
- having trouble finding tranny mount part#
- t56 help i think it gernaded
- no 2nd 4th 6th gear
- M6 not wanting to go into 5th after engne rebuild!!!
- Wiring question around shifter area: 1995 LT1- M6 drivetrain.....
- Stock Z28 rear end gear options??
- clutch pedal stiffness with SPEC 4
- th350 questions........
- Stall Question
- A4 Line Pressure Question
- Tranny Plug In?
- 98 stall on earlier camaros
- 93 LT1 Clutch going out, recommendations please?
- Re-use 10k mile LT4 PP with McLeod Single Disk?
- Anbody ever shim the slave cylinder?
- Trans not holding rpms
- after moser 12 bolt install i have a weird bad sound from rear....
- pro 5.0 vs. hurst billet plus
- One Wheel Spinning
- Mcleod Single Disc + LT4 PP ? Good Combo
- Intermittent SES light -no TCC lockup - any ideas? Please!
- Truetrac Rearend Opinion
- A few questions for you 4L60e gurus...
- Easiest way to change a throw out bearing
- RAM-88516HDX Anyone use it?
- z28 rear end with 3.42/lsd/disc
- Rear gear ratio related to tire size??
- 3.23 or 3.42? Which should it be?
- Replaced broken tranny mount with poly one
- Do I definatly have 3.42's ?
- 3 trans pumps in a year.....
- rear end question, as always
- 1LE T-56 Tranny mount?
- Chaning Tranny Filter?
- what gears?
- Inefficient converter or normal power loss?
- Rear too far back?
- DShaft End Caps :(
- 10 Bolt?
- Just broke something
- what rear end do i have
- Rearend Fluid suggestions
- Is it normal for my 2800 stalled car to.....
- Gears or different convertor?
- transmission service help
- all A4 with 4:10's or 3:73's come inside!!!!!!!!
- Electronic or hardware 4l60e problem
- Replacing a AT trans. for a Manual in 2000 WS6
- Installing built t56
- Tranny swap
- Can a driveshaft go bad?
- Converter Problems?
- Mcleod Twin w/aluminum flywheel
- Reverse Lockout Code 83
- 700r4 for the lt1?
- t-56 fluid change?
- changing transmission fluid t-56
- RAM HDX or Spec stage 1?....
- 4.10 just dont work .....kid need HELP!!
- need help with shift kit
- could I use a higher stall converter?
- T56 swap - speedo questions
- Noisy Rear? Help me out....
- 05 GTO Drivetrain
- detent cable ( kick down cable)
- everybody with a STALL come inside!!!
- does anyone know what gears were ofered in 01 z28's
- installed twin disk and now car won't turn over
- 1997 V6 clutch hydraulic hose removal
- Violent shaking when slamming 3rd...any ideas?
- 6 speed auto swap.
- The age old question, 12 bolt or 9 inch rear?
- McLeod Street Twin first impressions
- What kind of power you running through your stock T56s...
- 96 Chevy Silverado Question
- ? will puting a 3.73 in change my shift points alot
- looking for a new driveshaft
- Rear Gears
- how to upgrade to 3.73?
- Need help fast!
- C5 torque converter in a LT1
- 3.73 Gears
- Line Pressure Check
- Good T56 Rebuilder
- Whine in new gears???
- NO shift to 3rd gear 4L60E, HELP FAST
- Selling My 700r4/4l60-How Much?
- SLP vs HURST
- T-56 Clutch fork??
- ("for sale" content deleted)
- Will gears fit ??
- t-56 shift kit.
- 12 bolt rebuild kit?
- newby-z owner
- Clunk In The Front
- My 6 spd did something weird this morning, help me out
- Whats up with corvette servos
- Grip Force clutch from Ebay for LT1
- possible torque converter problems?
- gears...
- What's this noise???
- How can I find out what my...
- Drivetrain problems - Can't use 1st gear now??
- Transmission options
- need new discs for my street twin.... where do I getthem?
- clutch hard shift
- 3 channel - 4 channel diff question
- Used pinion bearing preload?
- How to BANG the pinion out of the rearend housing?
- breaking in a new clutch?
- spec stage 3 is worn out at 30,000 miles
- Shifting issue with transmission A4
- got the 9 inch in, getting vibration at 75+ mph
- What do I want in a Rebuild?
- How much play in rear
- blown tranny pan gasket
- Where to get clutches for stock 10 bolts
- need measurements on a 9 inch,everybody that has one
- shifter keeps popping out of gear.
- Looking for info for T56 trans.
- what code to look for tranny
- pinion nut torque
- A4 output line to cooler
- Broke 4L60e...again
- need shift kit part number
- Will LT4 Throw out bearing work on LT1?
- Screeching noises from the clutch
- Axle Pin Alignment Help!
- 4l60E vs TH350/TH400
- wheel sensor..
- Minor Drivetrain Issues
- need to know what stock torque converter
- 6spd clutch pedal coming off of master??
- has anyone here done the "drill mod" on an M6?
- stock T-56 + 383... how long till it goes?
- Which Stall?
- t-56 Huge Problem!
- 01 Z-28 10 Bolt in 96?
- Speedo Calibration for my 93
- Car won't shift into 3rd???
- LT1 PP vs. LT4 PP. Can I use LT1 PP w/ Mccleod?
- Getting a camaro with an auto trans to shift into 1st?
- Need Help Now!!!!!
- Why, the master and slave cylinder come together but..
- ls1 trans cooler
- Manual having trouble shifting
- Clutch w/ no breakin?
- Stock Shifter vs. Hurst?
- ford 9 inch
- 98 rear end swap- need to know?
- Odd lockup on converter
- Maximizing Stroker Motor Efficiency
- 6l80/6l90
- What rear end?
- speed vs rpm, 4L60E, 3.23 axle
- Brand New Detroit Locker for GM 7.5 10bolt
- P1810 code...what to do?
- This sound like bad syncros or something else?
- 3rd and 4th gear mid RPM
- 3.73 gears or 4.10 ?? thats the question
- How can I understand it is Viper Specs T56 ?
- Help! Check my ring and pinion setup pics!
- Tranny questions
- How to adjust pinion angle properly?Weird sound...
- 4l60e compatability question
- looking for second gen aluminum driveshaft
- Swapping rear ends
- need help removing my axles!!!!
- 3200 or 3600 converter for LT1?
- stock 10 bolt
- What to rebuild my rearend with?
- Best Place to buy Mccleod Single Disk
- Holy Crap, MAD vibrations above 90mph
- Mcleod single disc - Adjustable master needed on and LT1?
- Hard to get into reverser after....
- 1994 4L60E in a 2002 WS6....
- Stall Speed for modded LS1
- Blew my rear end
- lt1 and ls1 yolk, is the ls1 bigger
- Big tranny problems!!
- Hurst Internal Rail Comp Plus!? Anyone Use?
- posible wrong stall converter
- MCcleod Single disk vs. Centerforce DFX Clutches
- 98 six speed shifting problems
- POSI Question
