  1. Anyone using the 4L80E???
  2. Disappointed with SLP
  3. Converting 4L60E to vacuum operation...
  4. Hpp Iii Shift Points
  5. anyone out there using a centerforce cluctch on a fbody?
  6. torque arm and pinion angle
  7. setting pinion angle??
  8. Lets say i put clutch disk in backwards?
  9. New Clutch?
  10. Trans Problem ?
  11. T56 - occasionally jumps out of 2nd
  12. a4 to m6 swap!!!!!!
  13. 3000 stall with stock setup
  14. Problem with CenteForce D/F clutch
  15. Is anyone running a McCleod adjustable clutch master cylender? Where do you get them?
  16. M6 Guys: Gears?
  17. Rear End Girdles?
  18. Bad pinion seal
  19. New GM Motive and gear whine?
  20. Arrgh... Just got a conversion u joint... still doesnt fit right!
  21. 500 RWHP+3700lbs+4L60E Will it live?
  22. Grinding rear end
  23. What clutch (non street twin) to support 500 rwhp??
  24. Drill Out Mod on a Spec Clutch
  25. Driveshaft Compatibility
  26. chattering noise
  27. Reinforcing a 10 bolt?????
  28. Who builds the strongests 4L60E's out there??
  29. Differential Upgrade
  30. is this what you called a slipping tranny?
  31. Whats the tq specs on a pressure plate?
  32. How to identify a stock LT1 torque converter?
  33. How much for a new rear end, and where?
  34. Where to get T56 parts?
  35. Best Place for LT1 Rear Rotors
  36. LT1 TC in a LS1?
  37. Spec Stage Iii
  38. How Can I Tell If This Is A Ford 9 Inch or A 8.8 Rear
  39. High stall TC characteristics ?
  40. Transimission Question
  41. swaping from a t56 to a th350
  42. Stock Torque Converter?
  43. different 4l60?
  44. Tranny up in smoke
  45. trans problems---- help
  46. gears????
  47. Please help shift kit install
  48. Setting Backlash.
  49. Gears?
  50. pro 5.0 review
  51. 7.5" open carrier for spool question
  52. which driveshaft fits?
  53. How much power can the stock d/s hold?
  54. Slipping?
  55. TCI Shift Kit install and one problem
  56. 9" moser
  57. 4.71s in a 10bolt??
  58. A clutch replacement is hard work!
  59. What Trany to go with
  60. Bellhousing Bolt Pattern Dimensions
  61. Midwest stalls
  62. What is so freaking spectacular about a GM stock replacement throw-out bearing?!?!?!
  63. Pilot Bearing Disinigrated
  64. High mileage tranny and TC: yes or no?
  65. new clutch problems, please help!!
  66. Clutch problem, can anyone help?
  67. 95 4l60e
  68. How hard to put 7.5 axle tubes on a 8.8 or 8.5?
  69. Need help on which clutch to buy
  70. Will a shift kit from a.....
  71. LT1 and LS1 auto tranny's
  72. What suspension parts are best.
  73. Rearend Swap, What do I need to do?
  74. transmission service
  75. Steering weird with locker engaged?
  76. New Mcleod Clutch...Still Problems.
  77. diameter of 98 VSS sensor
  78. $375 shipped a good deal?
  79. who uses transgo shift kit
  80. What clutch would you guys suggest...
  81. Need advice..rebuild my trans or get an aftermarket? Pros/cons to each?
  82. tranny flush
  83. Fix master cylinder?
  84. wierd tranny rattles
  85. TCI shift kit first impressions
  86. shift kti
  87. Driveshafts, best bang for the buck?
  88. Traction bars?
  89. LS1 driveshaft into an LT1
  90. Need advise on a Turbo 400
  91. 9Inch pinion seal
  92. Clutch or rear axle fooked?
  93. should I flush the tranny or not?
  94. So how bad for your brakes is doing a burnout w/out Linelock?
  95. Why do my gears grind when i jump on it?
  96. 79 Z28 Transmissiom
  97. Posi?
  98. 4L60E up shifts when in 1st Gear
  99. Knocked off .4 w/ B&M 2400!!!!!!!
  100. Changing Auto into Manuel???
  101. what gears?
  102. my transmission fell 3in inches while driving
  103. Symptoms of bad rear/posi?? Loud snapping when turning hard
  104. cant find blinker fluid at autozone (big thinkers inside)
  105. Possibility of tranny going bad?
  106. Clutch Disc Springs
  107. Possible Tranny Prob?
  108. A4 to synthetic Question
  109. speedo is in-op
  110. Should a new clutch slip?
  111. Sprung -vs- Unsprung clutch?
  112. UH OH, What The .....?
  113. throwout or pilot bearing? help & explain please
  114. 4L60E repair in DFW? otherwise PMAC/CM in Houston.
  115. rearend starting to make some noise
  116. A4 rebuild
  117. Clutch pedal must be stabbed for the car to start???
  118. 700R4, highway RPMS a tad high :/
  119. tranny slipping or no?
  120. 4l60e- 700r4
  121. question about gears
  122. Extreme Automatics trans ???
  123. pops out of third
  124. LT1 T-56 vs. LS1 T-56
  125. Rear end question
  126. 4th Gen REAREND, WELDED-ON CALIPER BRAKE MOUNTS
  127. Center Force pressure plate with some other disk?
  128. snapping sound with hard shift?
  129. What stall to get? (rpm)
  130. This may be a dumb question
  131. Torque Arm question?
  132. Anybody who's done the drum/disc swap some help plz!
  133. How is converter lockup controlled on a '93?
  134. wheel bearing help
  135. 9" questions
  136. is the lt4 clutch a direct bolt on for lt1 cars?
  137. New noise please help...
  138. Torque converter question
  139. T-56 problems
  140. t-56 parts
  141. Updated slave cylinder p/n?
  142. rear end swap
  143. My M6 All of a Sudden Became Hard to Shift
  144. Rear fluid
  145. Advice Needed!
  146. Fabulous Brakes, Much Less than Baer, etc.
  147. Is a T56 3-4 Syncro Assembly Easy to Get At?
  148. Is it possible to make a Z28 into AWD?
  149. Soft Shifts when car is cold????
  150. Torque arm mount -dana 60
  151. Rear axle, bearing or seal problem???
  152. moser question
  153. 4l60e ?'s
  154. Gear install... do it myself? hints? tips?
  155. rwhp to flywheel hp conversion?
  156. Problems with the B&M Short throw shifter
  157. Help! I dont know trannys
  158. T56 is out the TH400 is in!
  159. At what speeds is the 93' A4 4l60/700r4 suppose to shift?
  160. anyone think of running a 4 link?
  161. Need opinions on what the best quality lifter is for stock cam ...one has gone bad
  162. Electronic shift improvers?
  163. Help! Moser 12-bolt broken after 1 pass!
  164. aack another speedbump on my way to discbrakes! Give a chick a break!
  165. 95 4l60e in a 94
  166. ls1 tranny mount & drive shaft
  167. 3:73's or stock ?
  168. Is it worth the extra $145...???
  169. 95 4l60e
  170. 4L60E No Upshift!!??
  171. How hard to replace the differential unit?
  172. shift kit install price?
  173. Anyone Rebuild their 4L60e theirself ?
  174. Flexplate/starter help? Please!
  175. so the factory hurst sucks huh???
  176. Z06 Clutch...is it worth it???
  177. Clutch noise when clutch pedal floored??
  178. rear end swap (ABS) hook up
  179. Axle Condition Question...... :D
  180. Step By Step cuutch install
  181. What is the best aftermarket shifter for T56?
  182. Ls1 t56 for lt1?
  183. New Bolt-In Sequential 6-speed Manual!!!
  184. who said the 10bolt was weak?
  185. Rear caliper e-brake bracket part name?
  186. best rebuild kit for T5
  187. will t56 from ls1 work on lt1????????
  188. spec stage 3 probs
  189. anyone running 2.73 gears and a converter?
  190. McLeod clutch value??
  191. Stock Master Cylinder Blown!
  192. M6 guys , I have a question !
  193. brakeline help MAJOR!!!
  194. gear question
  195. Ford 8.8?
  196. bleeding clutch master cylinder
  197. Thinking about a new flexplate??? should i?
  198. How do you use the Dial Indicator?
  199. 95 Trans Am transmission
  200. limited slip/posi ?
  201. LT1 4l60e vs ls1 4l60e
  202. Mcleod Master Cylinder interchangable ?
  203. Shifter M6 in 58 El Camino
  204. What do I need for a TH350 swap.
  205. How do you change shift points in a 93' 700r4/4l60??
  206. Gears
  207. A stupid question from a new M6 owner
  208. Maintanence schedule for t-56
  209. What is !CAGS? What about Skip Shift Eliminator?
  210. HP&TQ limits of a Yank ST 3500
  211. auto wont go in to gear
  212. Had a little accident, not sure if I can fix or not
  213. Best way to disable converter lock up???
  214. Some one help
  215. T56 experts inside
  216. HELP! Clutch torn to pieces...
  217. trans mount?clutch?wtf?????
  218. looking for strange sized tire
  219. Reasonably priced clutch for nearly stock car?
  220. Possible stock shifter for turbo 400 swap?
  221. Tailshaft question?
  222. A few more ?s about the 93 tranny.
  223. A few ?'s about gears
  224. Problem downshifting
  225. Motive 2-cut vs. 5-cut gears
  226. About to replace my clutch...
  227. Weird Shifter Problem, Please Help....
  228. Grenaded Stock Trans....
  229. 4.10 Gear/Posi? Paddle Kit?
  230. Can anyone tell ,e where to get the best price on a 12 bolt moser
  231. Stock Torque Coverter Question
  232. clutch and hydraulics
  233. Just one irritating bolt to go...
  234. rear end
  235. Tranny Valve Hanging??
  236. Anyone with RPS turbo clutch?
  237. Ring and pinion install prices?
  238. t56 growling
  239. 01-02 Master Cylinder
  240. URGENT: Best clutch for abuse/reliability under/around $300
  241. Help With C-Clip!!
  242. what rear end gears do I have?
  243. Two different ranges per gear???
  244. Whats a good transmission? and Where can i buy it?
  245. trans wont move
  246. Where is the Clutch Slave Cylinder located?
  247. right turn hop
  248. zoom clutch kit
  249. gear install in TX?
  250. More on that clutch pedal of mine
