- shift kit issues on 4L60E
- Does ATF "wear out" in a T56?
- Torqe Converter Question
- T56 scatter shield???
- Couple gear questions
- auto wont shift, redlines
- Need clutch recommendations
- clutch peddle reponse
- street twin or spec 4???
- Gear Change to 3:73
- good converter and cooler???
- How many shims are too many?
- Top of third with 3.23s, 3.42s, 3.73s
- Shifter Bobs Up/Down over bumps, vibrates at idle
- Drive shaft tube o/d
- ? about moser nine inch
- should I resurface my flywheel? pics..
- Flywheel Turning
- 700r4 -- 4l60e
- LT1 Torque converter the same as an LS1 TC?
- Replacing torque converter lockup switch
- ss rear gear ?
- 1995 Z28 Camaro A4 4L60E
- bad vibration in tranny afcter clutch install(only rolling from a stop)
- think my tranny is going
- 2.73 to 3.42 or 3.73
- syncros???
- Q regarding V6 5speed swap
- Need help ASAP (4L60E Trannsmission)
- Speed Sensor DTC comes on after hard launch
- 700r4 2nd gear start
- Gear swap W/Torsen diff?
- ?conversion?
- 4l60E, no engine braking in 1,2, or drive
- slave cyl ????
- megamaxtrannys on ebay
- operation of a 4l60e
- need a part # please
- First ever 4L60E trans brake
- Help!4l60e
- Rear End leaks?
- What should I get TA Girdle or AAM Girdle
- I need a new auto tranny mount.
- 3.73's In An A4. What RPM?
- Shifting Wierd on automatic
- is this right 93 z 4.10 steeper than 94z 4.10 gears
- ls1 rear in lt1
- A4 won't shift at WOT
- Just bought some 3.73s...hope these are the right ones...
- streetability of aluminum flywheel??
- blew my rear- whats best option
- the best cam for a 3400 stall?
- tranny help
- clutch and band chart 4L60E
- M6 is not good...need help!!!
- General Question About Carriers & gears
- Question on my clutch...
- 6 speed reverse popping out
- Time to rebuild 4L60E - 303K miles!
- spohn crossmember possible issue
- 3:73 or 4:10's???
- How to beef up Stock rearend????
- 3:42 gears in an auto?
- T/A/ Performance Cover - Question about magnet
- Better gear for an A4... 3.42 or 3.73?
- Used gears?
- how meny hours to install a converter and cooler
- Longer Shift Handle? and a newbie M6 driver question
- Balance Driveshaft??
- SLP Rear Diff Cover (AAM)
- slap shift
- 4L60E valve body
- Bad Vibration in Gear HELP!!!!
- Did I buy the wrong clutch?
- wrong clutch?
- Which stall
- Line lock
- posi installation
- Transmission bellhousing
- Stock LS1 Driveshaft
- CPT on "hiatus" for a few weeks.
- Oil pressure
- Which Clutch Kit/Flywheel is better....?
- Question please vote!! which is the best clutch and flywheel setup?
- Gears or Stall?
- McLeod Master chewing piston seals
- can anyone give me some specs on the clutch and some bolts
- crossmember for 400 into 87
- Loud metallic screech sound, new rear end swap today
- Quick question
- stock gears
- Low gearing better mpg?
- Stock Converter
- TH-400 5 pinion planetary gears?
- HELP!!! Drivetrain Vibration
- Bad Throwout Bearing?
- Spec 4 problems.... :(
- ready to burn car after clutch install
- Converter installed!
- what do you prefer?
- tq install
- missing 3rd and fourth
- torque converter ID
- 1995 Z28 Transmission fluid leak
- P0740 Torque Converter Clutch Circuit Malfunction
- Bad throw out bearing?
- My Clutch Is Not Fully Disengageing
- EXTEREMELY BAD shifting problem
- shift kit
- Spec 4 --to much for the streets???
- Rearend question
- 4L60E install
- T-56 question
- Transmission crossmember
- u joint questions
- Petition - GM To Stop Manual Transmissions
- Will It Fit
- T56 almost impossible to go into 6th gear
- Lock the converter on the dyno?
- Cost for 4.10's + install?
- clutch plate
- Mobil 1 full synthetic ATF
- tq question
- additional Transmission cooler placement, need opinion
- LPE driveshaft
- Hard(er) to shift t56 after wot run.
- 4L60E input drum air check issue
- ls1 ds in a 12 bolt 95z
- What's need to do m6 to a4 swap?
- Upgrading 10-Bolt GU5
- 96 diff
- clunking noise in rear
- SLP short shifter
- rear end gear break in?
- McLeod single: Will it hold?
- T56 upgrades
- just blew up my 10 bolt ! whats the best 12 bolt or 9inch ?
- STR - Tradeoffs
- McLeod release issues.
- Anything special when installing alum FW?
- installation price range?
- TH350 Questions ???
- Problemo!!!
- strange 12 bolt pinion nut size
- clutch fork pivot bolt
- new clutch?
- Gear noise from T56
- How to change output shaft bushing?
- Has anyone had any problems with their LPE driveshaft?
- Front Wheel hub Assembly
- Putting a Transmission cooler on my 4L60e
- finished the th350 swap and wow
- 4L60E Interchangability
- Shifting issues
- LS1 4L60E in an LT1?
- Wont shift 2->3
- Help with my tranny
- Input shaft bearing replacement
- LS7 clutch kit ordered.....
- Where to buy rebuild parts for T-56?
- LT1 slave cylinder assembly?
- how long will a ST last?
- 9" question
- rear end noise
- Q: regarding 4L60E-Rebuild, used or new?
- What's involved in changing stall converter?
- Can it fit
- Can it fit
- Stock gearing for 2002 Z-28
- To get gears or not to get gears, that is the question
- will a 99 m6 flywheel fit in a 93 m6
- Flywheel install question (poll)
- tranny service
- Pilot Bearing Stuck, Any ideas?
- 5spd V6 crossmember..??
- Syncrhomesh in 96' t56?
- Raptors converters for 4l60e??
- My 9inch Build up- pics and BLING!
- shifters
- 4th gen drive shaft in a 3rd gen?????????
- Mad Dog 700R4 Punisher
- Need Help Fast!!! T56 Tail Housing
- Need Help With 4l60e In 95 Z28, Help!!
- Good LT1 Clutch Disc?
- Changing The Oil in My Rear Tomorrow...
- 12-bolt
- ? about puuting 94 tranny into a 95 car.
- Which Trans Cooler To get?
- HELP ! Changing tranny mount in driveway?
- Weight reduction in Alum. driveshaft?
- How hard to replace clutch?
- Valco Clutch and pressure plates? how good?
- Racing w/ the stock shifter..
- T56 #'s run
- gearing question
- bleeding the clutch
- Stupid Question + Help With Vibration
- lakewood traction bars
- 3 hooked to 4 channel ABS
- Tranny Is Gone!!!!please Help!!!
- 97 camaro 4l60E, How many spline is inputshaft
- Strange 12 bolt shipped weight.
- HELP!..TRUE or Random BS
- 700r4 to Turbo 350/400 conversion
- ABS to work with newer rearend?
- trans go shift kit install ??'s
- how can i tell if i have an M28 or 29?
- Best clutch for LT1? Spec?
- Orange sensor for m6.
- Where can I get the plastic cover for the back of a six speed?
- T5 identification
- Couple of tranny questions
- Question for those who have knowledge of 10 bolt internals
- Tranny is gone Please!!!
- Saginaw 4 spd in 67 camaro 6 cylinder
- Stall Rpm For A Stock 95 4l60-e
- McLeod Street Twin break-in Q's
- High stall guys inside please!! (WS6ZXR post)
- Loose converter
- Need opinion on Spec Stage 1
- A4 transmission mount?
- What to do with core 4l60e
- need help with adjusting my ratchet shifter
- U joint/yoke questions
- Obdi 4l60e??
- Whats the Stock Trans Cooler Look like?
- 1995 Stall Converter Stock A4
- SHIFT RPM FOR A 95 Z28 LT1 A4 - Stock
- anyone running 4.10s in their a4?
- Question about my new TH-400
- 10 Bolt Rear Removal
- convert options ???
- LS1 rear in LT1 car
- Installed rebuilt trans, now will only shift when you left off gas?
- Signs of a bad master/slave clutch cyl?
- No Bleeder on LT1 T56?
- Blown LT1.. Go with a Used M6 or A4 or LS1
- Shifter Button Won't Go Down
- Tranny swap
- rebuild my own transmission.
- possible converter issues, please read
- 3.73 or 4.10's
- Need some help with a noisy T56
- transgo breaking splines/spider gears?
- just got my moser 12 bolt in ! its assembled but should it be checked ?
- Just installed motive 4.10s
- What is stock trans type?
- how to tell a stall apart??
- 4l60e Only Works in D or 3
- ok stall questions
