- Clutch Pedal Releasing too high off floorboard
- 4L60E input shaft size for torque converter
- Which Gears???
- how do you know when motor mounts are worn?
- what will i need for a 700R4(92 model)install in 94 Z28
- Cheap 6speed shifters?
- Safety check for high speeds
- another 4l60e problem
- quick question reguarding safety loop.
- Tranny ?
- Drivetrain shudder
- Shifter question
- motor free revs (torque converter)
- 6 Speed Rebuild Info Needed !!!
- driveshaft question
- Pressure plate tq spec?
- moser housing
- how do you find out what brand gears you have?
- tall tell signs off dying posi
- input shaft advice
- 4l60e & 13 vane pump?
- best clutch for a street driven 600-700rwhp car?
- I have searched and searched.....
- clunk when i gun her'
- 12 Bolt and Rattles
- Shifter question.
- Tranny slip? Need help asap!
- Limited slip going out........
- clutch choice help please..
- valve body
- 98 Z28, New Trans.
- A4 problem for a friend of mine
- tranny ID
- Hours to install
- Do i need a clutch?
- traction control question
- Tranny slipping?
- 3rd Gen Fbody - T-56 Trans - Which Clutch?
- Which new clutch?
- conversion
- Shift Kit is in, Engine Stalls on Startup
- Moser Axles.........
- My car is in the shop
- Aluminum Driveshaft
- Slack/Noise in Drivetrain
- What actually breaks?
- How to tell gears
- Brand of gears?
- synthetic gear lube
- skulte t56 crossmember question
- t56
- Help with gears
- 700R4 conversion problems!!
- pro's of B & M pro stick
- a4 to m6 swap
- Help with automatic tranny!!!!
- Anyone wondering if a 6L80E swap is possible?
- LS1 transmission mount... *PICS*
- Torque Arm Bracket Bolts
- auto to manual on a 93 LT1?
- converters ??????????
- replacing clutch disc (lt1, t56)
- 50K. . . bad clutch?
- Kickdown to Neutral??
- Auto Tranny Questions
- converter problems?
- shaky shifter
- Car wont move
- Tranny oil smells a bit burned... vacuum modulator to blame?
- Racing car without lockup system?
- Transmission Installation Problem
- McLeod Street Twin Internal Balance??
- How Do I know I need a new clutch?
- Replacing C-clips. Need part#
- What's wrong 2002 z28
- Flywheel Teeth
- Bleeding Rear Drums
- Need help with flywheel sizes from factory!
- buying tranny...which one??
- Tranny won't go into park, sometimes reverse and drive. Plus loud clunk.
- differance in 4l60e
- in need of new transmission..
- Mileage and stock 4l60e
- okay i need answers
- Two Questions....
- what stock gears do i have?
- Extra stud for poly trans mount
- swithcing to th-400, can,t get flexplate to tighten down
- drive shaft
- Anyone used the platinum torque ring and pinions from national drivetrain?
- rear end help
- Is this driving style bad for the A4 transmission?
- Replacing rear wheel studs?
- Rockland "Tranzilla" 1,000 lb-ft T56
- Changing the pinion angle on new 12 bolt rear end? Q's
- Here's how to bleed the clutch without getting under the car.
- Question about 2.73 to 3.73
- t56 clutch
- which one do i have...how to tell
- bad vibration m6
- Autozone /Advanced Auto clutch as good/better than stock?
- not sure what's wrong
- Extending the shifter on my T-56
- Grinding noise when coming to a stop...
- shifting problem
- How do I recalibrate the spedometer
- Any other options besides 12bolt/9inch?
- Vibration at high RPM and speed.. any idea?
- t56 hydraulics
- 2 series and 3 series differentials..whats the diff.
- question about installing posi in 10 bolt
- 3.55's?!?!?
- clutch quote $1,347 this can't be right.....
- Tranny bolt help!
- Aluminum or steel with ls7 clutch?
- rebuilt tranny
- 10 bolt life+tires+gears+stall
- Late Model Wheel stuck on Early Model
- clutch pictures
- 6spd To 700r4
- Help me out with this.
- Vin number to axle type?
- Tranny and Rear strength
- 92k on trans. Stall?
- Driveshafts
- yes another which clutch post
- hesitation related to trans mount?
- 94 rear end in my 95
- LT1 T56 PP orientation? Yellow dot?
- Horrible Mileage Help!!!
- McLeod disc + stock pp. Car won't go to reverse.
- Does this DS depth look ok?
- BMR conversion crossmember pics.
- Changing from 3.73s to 4.11s in an A4. Worth it?
- anyone ever have this happen?
- manual trans q...
- 2.73 to 3.73 conversion questions
- conversion
- 6 sp pops out of reverse
- Break in procedure?
- Might have too much power for my 4.10's
- 96 Z broke tran mount
- 'Bouncing' on take off in warm weather?
- how will I like it? (tq converter)
- Pressure bleeding the slave cylinder.
- HELP!!Really loud and brutal slam when first accelerating
- flywheel and clutch question
- 94 z28 tranny
- Another tranny cooler question
- shocks/struts
- Shaky clutch and pedal
- shift kit and turning down shift time?
- short stick fitting question
- Is torsen diff better than auburn type?
- Tranny Leak
- Just had my laugh of the day...
- clunks... 02 ls1 w/ 4L60E i think?
- Gear ratio for RR
- Help my 6-speed tranny is messed up
- Bad Transmission mount?
- Shudder under load
- New Converter Causes Car To Hit Rev Limiter Top Of Second Gear, Help!
- drive shaft
- loose Clutch fork
- Centerforce Dual Fricition Clutch Rating?
- metal click noise type deal
- Who makes GM Gears?
- 4l60e may be turning in to scrap parts!
- Ford 9" for my 96WS6
- ta cover?
- New spec stage 3 clutch
- torque converter or not?
- Wierd Noise from t56 under 1500 rpm. Help please.
- should i stay a m6 or go to a th 350
- Quick Gear Question
- ls1speed short stick
- LOUD shifter rattle at high RPMs (T56)
- BREAKING Tranny Mount
- T-56 bronze shift fork pads...
- T-56 swap from 700R4
- Bad vibration with Moser 12 bolt
- REAR End stuff
- Powerglide, no 1st gear..
- raptor 700r4 tranny ?????
- Slave Master Cylinder Upgrade?
- Torque Converter making noise - help
- Gear brand and TA cover
- ABS sensor - Strange 12 bolt
- quick rear end gear question
- 1350 Drive Shaft 4L60E Trans and Stock Rear
- Is it really a 2500 stall??
- need help
- Tremec Part Numbers?
- Need help picking stall
- Transmission temps
- Shift point issues
- Just verify bleeding clutch for me?
- first post
- Trans cooler questions
- LT1 Center Force Clutches?
- Which gears (carrier???)
- t56 clutch adjustable?
- Flywheel?
- Question about 4L60E-mine is a 3 speed auto?
- Zoom MU series clutche
- 96 LT1/4L60e in a 95 Z28. Transmission issues?
- need help with tranny problem
- chatter under hard accel?
- loud popping noise when auto shifts
- What do you think of this stall converter?
- aftermarket clutch
- TH350 transbrake, fully auto, reg shift pattern?
- Converter ordered!
- ? what is right
- What type of resistor to disable CAGS?
- good to deal with, t56rebuilds.com
- Is there anything I can do to stop the tranny from rattling in neutral?
- LS1 clutch slippage until hard acceleration
- Choosing a clutch
- tranny help!!!??please
- Need replacement bearings for the MOSER 12 Bolt
- Gears howling?
- 3.73's howling
- no 2nd?
- Tranny Advice.
- transmission problem?
- What is "normal" aftermarket gear noise?
- th350 with manual valve body
- Trans fluid question
- what are the diffrences
- Stupid tranny fluid question
- T56 Conversion starter question.
- Clip for clutch pedal????
- lt1/4l60e/273 question
- What exactly causes 3rd to slip on A4s?
- 88 GTA Kickdown cable adjustment
- how long does a ST last?
- Just installed Moser 9"
- did you have to "set" your spec clutch?
- Another spec III bites the dust
- Considering the T56 swap.
- difference between 6@8 cly rear and
- Noisy T56
- Pinion seal leak after replacement
- rear axle hp loss
- Powertrax
- How many teeth on the stock '94 flexplate?
- LT1 Street twin balancing
- Can someone explain strength of gears 4.10 vs. 3.9 etc
- Anyone done a 4sp conversion on a LTx?
