- Where to get my 12-bolt, all option :D
- car eats trannies? intermitten electrical HELP PLEASE!!!
- Tranny jerks
- gears
- Big bang when punched (automatic)
- gm motive gears howl??
- shifters
- gear swap?
- do you think my rearend is gonna break when i finnaly "get on it"
- Auto rebuild???
- Newbie needs help with transmission swap
- How to determine proper Driveshaft length?
- Shifter stand up when accelerating
- Trans pan
- Rear end gear change....Experts Inside!!
- t56 Hydraulic Linkage Same for Lt1's and Ls1's?
- How can I lose 5th and 6th gears in my t56?
- Car sometimes wont shift (4l60e)
- Open Differential Question
- What shifters will a Lou's short stick work with?
- Stall questions??? 2800 guys!!!
- Question for those that have installed their SPEC stage 4 (LT1)
- Do carbon fiber synchros degrade by not being used over a long period of time?
- weird tranny issues
- How much HP do you lose when you add a stall?
- Are Ls1 Pedals the same for Lt1's?
- Help!!
- T56: What mods are necessary to support this HP/TQ?
- help me choose between gears
- Looking for a t56 part....help please.
- Spohn Torque Arm Questions???
- What is best t56 shifter to use
- Gears?
- 6inch or 6.5inch short stick
- Clutch Pedal Sticking
- 4L60E Filter... $125.00?
- Tranny clunks into R
- clutch for 400+rwhp
- Auto - Manual Conversion ...
- McLeod Single Disk...will it work well for me?
- Leaky trans pan gasket?
- rear end change?
- Down shift problems
- flywheel question/opinions on ram hdx clutch?
- Converter #
- reccomended clutch...
- Okay need with with rear calipers
- Clutch Chatter, could it be the metal Grinding i hear eariler?!
- aluminum flywheel
- trying to get my shift knob off on my 6spd.. but it wont come off..
- Rebuilding My 4L60E
- Good sources for driveshafts
- Quick question on gears
- Drivetrain BANG
- Best way to eliminate cags
- Newbie M6 Question
- shifting to race
- Did I do the pinion seal correctly?
- How much does it cost to tub a car??
- throwout bearing
- Input Shaft Endplay Specs?
- T56 removal questions...
- Gm MOTIVE 373's howl terrible
- Where can i find a shift knob?
- Are the LT1 clutch disk and the LS1 disk the same?
- 12 bolt or 9", advantages, disadvantages
- Pinging noise going through driveshaft?
- rear end question
- Will 95 4L60E fit my 94
- Best use I've ever found for the stock shifter
- 8.5" 10 bolt source FYI
- 12 bolt
- What converter for GM 847??
- Mcloed single disc
- Borg Warner 9 Bolt
- Pro 5.0 is it worth it?
- dumb question
- 6 speed gear ratios?? Different?
- 4l60e questions
- installing shift kit in A4
- B&m Pro Stick Install
- What Gear?
- What clutch to buy????
- CPT is now "supporting vendor"
- how much hp will a 10 bolt hold
- 93 to a 94 4L60E
- Summit TCI converters,any good?
- t56 vss question
- asking for opions on switching to a bigger gear
- vibration after gear install
- Pigtails
- Shifting A4
- Broke the hydraulic line going to the slave cylinder, help me... please.
- T56 fluid and additives
- What converter for 400hp?
- A4 to M6 swap
- Replaced slave/master..still cant disengage clutch
- Dumb??
- T56 Input Shaft Seal Leak??
- Which stall for G5X3 and 3.73?
- Can't Find 383 Stroker Flywheel
- What to do?
- Best clutch recommendation! Quick
- 305 swap into a V6, using the V6 700r4?
- 4l60e
- Howling gears, what settings to use for new Motive's?
- anyone try a clutchnet disc?
- Clutch stuck to floor solved...mabye
- Getting alot of parts put on, good shop quote?!
- Clicking sound when engaging the clutch...
- Mcleod Adjustable Master Cylinder
- shift kit for a 95z28 4l60e
- what gears are you running in m6
- Who is runing an LT1 and a blanket?
- Is the 3.73 stronger than the 4.10.
- Need New Clutch, down to two choises...
- A bit confused
- 3.08 to 3.73 will this effect abc brakes
- running rear gear "COMPETITION CONTACT"
- hp threshold for stock T-56
- differences in v8/v6 4l60e
- Tailshaft bearing
- 2000 6spd, hard to shift into gear at a stop
- Best transmission for a 383
- McCloud Single Disk
- Weeping Pinion Seal
- th 400
- Transmission Cooler Lines
- Auto to manaul swap
- Rear end- 12bolt,9inch, or 10bolt with upgrades??
- t-56 tail section
- Any way to remove gears without a press?
- my 94 4L60E
- 12 bolt: Strange vs. Moser
- trans shifting hard... A4
- MPH for gearing in rear?---
- gear options???
- Downshifting from 4rth(OD) to 3rd in A4 (4L60E) at high speeds
- help with T-56 and skip shift solenoid
- tranny valve body?
- Difference in transmissions
- 1st & 2nd gear probs (M6)
- Trans Mount - Whats the story for A4's?
- Weirdness when I turn?
- pilot bushing
- should i replace the flex plate when doing high performance tranny ?
- 4.10's
- D&D Performance Viper Specs T56
- Vacuum modulation
- 1998 rear end
- Should I junk this 700R4?
- 3.73 info for 97 z28
- Any LT1 guys running Fuddle's?
- TH-400 questions
- new clutch in, got a noise
- New Tranny
- decisions decisions, 2800-3200 stall
- T-56 Hard to Put in Gear
- B&M trick shift
- slight grind when letting out clutch after burnout
- torque convertor question
- Should I go down to 2.73s?
- Eaton, powertrax or what?
- Automatic shifters"what to choose"
- Building a 9 inch
- How many of you used the T.O bearing that SPEC sent with your new clutch
- maybe doing the ford 9 inch...
- drive shaft
- Let's talk manual valve bodies...
- another name that noise thread
- best place for replacement 4l60e?
- 2 Pieve Drive Shaft
- what about Fuddle?
- Tranny Mount Gone?
- What tranny?????
- Need help from you pros. please
- Need help from you guys please
- 4l60e shifting problems, paging tranny gurus
- Need help!!
- Possible Clutch Problem
- Anyone have Trans-Go instructions for a '97 4L60E???
- new rear end pieces
- park doesnt "click" in
- Dr. Evil trannys?? Need opinions.. (M6)
- tranny problems
- swapping gears
- 12 Bolt Help
- Jegs gears?
- Any 4L60E Experts Here?
- gear install question
- street twin
- Torque Converter/Fly Wheel spacing
- rebuild kit options
- 4.11 gears
- axle/ driveshaft question
- Best tranny fluid?
- Shifter linkage inside a t56
- Still Waiting
- Engineering and Pinion Angles
- NEW Moser leaking!
- 4.56 gears to much for street driven M6?
- Experts In Here!!!! Help!
- What Size Rear?
- 1995 6-speed fluid capacity
- Vigilante - Edge - Fuddle
- GTO Trans in F-Bod?
- Ram Powergrip Problem!!!
- T-56 Problems
- quick rear end quest
- short throw shifter
- Can I still do 150mph with 4.10s
- WTB: Clutch Kit..Stage 2 preffered..
- 400
- My magical auto tranny stopped working
- SPEC 4 install complete.... 1st drive thoughts
- Universal Joint
- Towed my car home: what's wrong?
- 4l60 rebuild guide
- 1995 Z28 Camaro A4 4L60E
- rev limiter
- Z threw the drive shaft today at 135MPH.
- Need T-56 Rebuild
- What trannys have you Killed?
- Help with Rear End Ratio
- 3 series to a 2 series
- Blown 4L60E
- Those doing a4/m6 swap
- SPEC clutch questions
- Carbon Fiber D/S
- different.......
- 02 4L60e fit into a 94 TA??!
- Will a LS1 transmission work in a LT1?
- T56 gear ratios - can they be changed?
- Gears???
- SPEC Stage 3??? How is it?
- strengthening 10 bolt
- transmissions the same?
- Clutch for 600 RWHP
- M6 help, ASAP, semi-stuck
- A4 lugging engine on decel @ low speed?
- Ls1 Rear In LT1
- 3rd gear grinding (sometimes)
- LT1 and LS1 Clutches
- SLP billet alum. or Spec billet steel flywheel
- Aftermarket Hydrolic clutch line?
- Trans won't shift into overdrive....
- Gear change in my 01' Z28
- Clutch problem!
- preload cover torque spec for strange 12 bolt
- gasket for strange 12 bolt??
