- What is the prefered posi units for the stock 10 bolt 3 series?
- Rearend question
- Yank s2800 or s3000
- Odd 4L60e 1-2 shift issue...
- whats the easiest way to check/fill trans fluid on a 6spd?
- Cheap rear end
- 98 TA gear question
- slave cylinder removal
- Rear end/hub noise? Help!
- CPT rocks!!
- Fried 2nd 3-4 clutch pack in 1 week!
- Removing hydraulic line from slave cylinder... HELP
- T56 shift fork question
- 10 bolt with drags
- 700r4 rebuild and in car, some Q
- Where to tap into the 4l60e for a trans temp gauge?
- Which Transmission Upgrade?
- What's needed for going to a Disc brake rear-end?
- Broke transmission mount
- Should my shifter move?
- 700r4
- 97 SS axle into 95 Z
- promblem
- Check These guy's out
- Does this look like a 12 bolt?
- what different ways are there to get trans fluid back in my 6spd?
- How do you remove the 6spd shifter to add fluid??
- Trans filter external
- High HP loss with high stall!
- Affects of STR on convertors topend or bottom?
- Who makes the strongest T-56???
- Torque converter question...........
- Here we go again ! 4L60e broke
- Madman dipstick
- what auto to buy?
- kinda similar thread...but torque converter loss
- A4 Shift Kit
- does anyone know if the diameter of a 12 bolt axle tube is the same as a 10 bolt?
- Will this fit.
- Prothane trans mount installed, not as bad as I thought
- What is so bad about the B&M Transpak?
- How much will the ten bolt handle?
- Gear Selection
- 5 speed swap, different starter?
- how to tell if the PP is bad?
- Problems with axle seal leaking
- new gears
- Clutch Package
- Aluminum or Steel Flywheel
- Is the 3800 V6 A4 tranny compatible to LT1?
- Rears in our cars
- rear install
- vigilante stall converter wait...
- Slipping when flooring it. Help!!!
- M6 to A4
- Drivetrain Noise After ST Install
- 12 Bolt Install
- Help me figure out if I have gears
- LT1 T/O bearing part #
- Please help! Clutch is clicking after install
- Little ball bearing fell out of Bellhousing when i removed slave cylinder....
- M6 sticking in 4th gear
- Gears for 18" wheels??
- Stock Replacment Clutch Gone Already???
- Which brand/series 2 carrier
- vig 2800 stall question
- slave cylinder shim for T56
- Torque specifications for 10 bolt 7.5 gear install?
- Auto guys...help
- What clutch to get?
- crap, what's this bolt size??
- 1995 transmission
- Where can you find Motive gears for a 2 series carrier ???
- What is the length of 93-02 rear ends?
- Torque Arm mount
- ls1 rear in lt1
- Vigilante Converters
- reverse is messed up!
- look what happend to my 10-bolt!
- Why does no one make mini spool for 94 up f body
- plz help with gears....
- 4L60E problem
- 4L60E 94/95 valve bodies
- WHAT IS THIS????? tranny part **pic**
- mcloud street twin
- Will not go into ANY gear...
- Another day another problem....
- Tranny Cooler
- 3.73 or 4.10
- swapping th-350 to t56 in a carbed 94Z HELP PLEASE!!
- th400 valvebody ?
- '94 4L60E in a '96 Z28
- Viper T56 Questions
- fourth gen rear in third gen car
- Not your typical vibration, I don't know what it is
- Carrier ID
- clutch problem
- Does a new 3000rpm stall converter require tuning?
- problem
- Lucas oil in M6??
- Possible clutch slip affecting performance....
- Caprice cop car 12 bolt fit in an F-body?
- Idea for adapting a 8.5" 10 bolt?
- Street twin...
- proshifted t-56
- Building my 10-bolt up, whatcha think?
- Clutch, tranny mount? idk help
- LS1 Rear axle in an LT1?
- 4.10 gears
- no lockup
- Think i got an accurate reading of my 6spd trans fluid level?
- LS1 tranny mount better than LT1? Not this one...
- Limited slip operation
- Cracked forward piston
- Best/Cheap Place To Get a 9inch Housing
- 3.42 gears for a 2 series?
- 12 Bolt Question?
- A4 bouce off revlimiter?
- trans wont shift HELP
- Replacement Rear Axles
- Anyone built their own 700R4?
- what is needed for a t56 swap
- McLeod single disk
- Weird 4L60E behavior after rebuild
- Need info on clutch line mod
- car won't shift into reverse M6
- Throwout bearing and pilot bearing lube....
- 4L60E trans filter?
- need advise for a bearing puller
- Dead Torsen?
- metal in speed sensor /4L60E /1994
- drive shaft?
- 4l60e acting up!!!!
- Clutch now grabs off the floor??
- Transmission Question
- strength of 4.10s
- Stumble/hesitation caused by my stall??
- T56 swap question, firewall slave
- How many times can you resurface an LT1 flywheel
- 4L60E rebuild advice
- Ouch....pulling 700r4 from 91 vette..bad pressures
- LT1 T56 Question...
- Bolt torque specs for t56
- T56 input shaft play. Is this normal?
- Slip yoke Woes.... solved....
- After spec stage 3 in lt1 t56, crazy bad chatter letting clutch out!!
- can a stock converter be used on LE2 setup temporarily
- Where to buy a 9" of a Strange 12 bolt?
- Do your A4 3.73s whine like crazy?
- 4L60 TCC Code 27 Error
- 12 bolt info
- Clutch Recomendations
- New B&M Pro Stick looks like crap!
- Flywheel help
- Clunking sound while engine is running
- lt1 t56 bolt question
- LT1 Corvette TOB and Z28 TOB...Are they the same?
- 6 spd conversion-what is needed
- transmission fluid
- gear change
- need tips/suggestions on removing a4
- Near from the rear end; how long until it breaks?
- 1-2 shift clunk from rear
- SPEC pressure plate casting number...can someone give me this
- Need LSD Additive in '97 Z28?
- Anybody break a 30 spline axle?
- Need help w/gear ratio's
- Want to change rear-ends
- where can i get a pressure plate?
- 92 Camaro - MX0 - Rev High before shift??
- ? about throw out bearing/ retainer ring
- Alternative to the 12 bolt or 9".... The OLD 10 bolt...
- anybody using c-clip eliminators?
- LT1 and LS1 transmission
- Do I need this bolt?
- How much HP will a T56 handle, launches?
- Higher Stall feels sluggish in OD???
- are lakewood control arms any good???
- What does Flash the Stall mean?
- Plastic piece of rear end housing
- Weight Diff. T-56-turbo-400
- where to get probuilts auto 4l60e?
- Started ordering parts to build my 8.8"
- Motive "white box" gears? Good for street use? Quiet?
- Possible throw-out bearing failure
- Trans shifting slow between P, R and D
- how well would this clutch do for me I NEED TO BUY A CLUTCH
- trans
- Gears
- That bolt in overdrive sounds pretty cool...
- What Type Of Rear End Do I Have?? Hell If I Know!
- who has replaced their clutch? I might try
- th350 leaking problems
- Whats the size of the nut for a prothane tranny mount?
- Check out my new clutch disk....
- amount of power to turn a 12 bolt and a 9 inch rear end?
- Which posi in 12-bolt? + other questions
- Stock 96 torque converter in 95 WILL IT WORK
- Does it make a difference?
- Would these houses, third members, etc for a 9 inch work from this company on ebay?
- Bad TPS leads to horrible shifting
- wont stay in gear
- Midwest converter not engaging into back of Eagle crank and binding up, help!
- Which to choose Dual Centerforce or Spec stge 3
- Iroc Rearend Swap
- Guys with ProTorque converters inside....
- clutch not disengaging, can't go in reverse
- Best 4l60e for 475hp/500ftlb lt1 car.....
- gearvendors od
- Reverse problem
- Bellhousing Problem
- I just installed a 9"
- Questions about stall torque converters
- Rusted Clutch Assembly
- what is the torque capacity of the 7500 rpm mcleod disc?
- ls1 Driveshaft with 1350 Conversion U-joint
- not resurfacing flywheel with new PP & clutch... whats the worst that could happen?
- best gear for a 6 speed ws6?
- Quick question about 9" moser set-up 4 my 94
- How much does it cost to get the PI torque conv. restalled?
- 95 z28 stock lsd????
- No pressure in Clutch Pedal after replacing Slave
- m6 inspection cover
- Question about my 4l60E
- Who has fabbed their own adjustable torque arm?
- How do I know what series carrier I have?
- need some converter help
- best new tranny
- pics of my broken rear end
- What Are Signs of a Tranny Going Out?
- Quick: Should I get a new driveshaft?
- Where can i get a pressure plate!
- Auto to manual
- 4l60e or 4l80e?
- Do i need a rebuild?
- Transmission whines in 3rd gear.
- Question about rear ABS exciter ring
- Best place to get T-56?
- Clink in the rear (A4)
- 150+ more HP = transmission or driveshaft failure?
- T56 gear upgrades
- Just makin sure
- What Gears to Use?????
- Driveshaft
- Ebay TORQUE CONVERTER's
- Need Opinion on Tranny Problem
- 2-3 upshift
- T56 Bearings
- 12 bolt trq arm bolts...help
- "Thud" when accelerating
