  1. lt4 clutch disc in z28
  2. What is all needed for gear install?
  3. Identify this part please! (pics inside)
  4. rear end going soon?
  5. Is this normal operation for a tourqe converter?
  6. trans not shifting wot
  7. driveshaft yoke
  8. super strength posi
  9. Slave Cylinder, Street twin Master Cylinder
  10. What brand of gears?
  11. Max Main Line Pressure settings for 4L60E
  12. The answers we've been looking for (attn: firepheasent, etc)
  13. Manual valve body 4l60e? (for OBD1 high stall fix)
  14. Ford 9"
  15. HELP...Transmission
  16. Changing point of clutch engagement
  17. speedometer wont go past 20
  18. LT1 Brakes, all the same?
  19. 12 Bolt vs 9 Inch Rearends
  20. trans wont shift out of 2nd what setup?
  21. Flywheel balancing...
  22. 3rd gen 12 bolt in 4th gen?
  23. difference in viper t56 and ours???
  24. Auto to M6. Question on Flywheel.
  25. Torque specifications for tail mount repair
  26. How Bulletproof is a T56?
  27. no third gear at wot
  28. Number of splines on T-56 output shaft?
  29. Possible manual transmission problem, need insight
  30. Converter making banging noises when it locks up
  31. Aluminum Driveshafts?
  32. I never thought I'd ask this, but.....
  33. question about manual transmission fluid
  34. shifter spring to center
  35. What would cause my a4 not to shift
  36. popping around right turns
  37. A4 Question
  38. Gears?
  39. DIY gear install
  40. A4 Reverse GONE -please help, serious crisis
  41. good deal on transmission?
  42. clicking noise from betwee the backseats
  43. detroit locker?
  44. Grinding in third!?!?
  45. Shifter?
  46. Buick 8.5 rear?
  47. Will a 2001 10 Bolt fit on a 97?
  48. Torque converter and dyno #'s
  49. 3rd gen Temp Spare (inflatable type)
  50. TransGo full manual shift kit
  51. Weights of different rear ends
  52. Exact width of our rear ends
  53. Removing the mainshaft bearings without a bearing press?
  54. Installing weld in relocation brackets
  55. Try this here, grinding in third...
  56. Where can I get a shift kit?
  57. Thoughts on M6 conversion...
  58. Gear swap on a 93. Questions on Speedo gears
  59. 98+ 7.5" carrier the strongest made?
  60. Rear end clunk noise/problems
  61. Quick, what do I put on the rear diff pinion splines to seal theyoke?
  62. 3600 stall and Trans go
  63. Torque Converter, will it only help on the launch?
  64. Difference in V-6 4L60E and V-8 if any????
  65. Starnge 12 Bolt Whine...
  66. How much would a new clutch installed cost for a '94 Z?
  67. I'm in need of stall converter suggestions...
  68. Good Girdle price
  69. Bolts n' nuts for 9"
  70. down shift noise??
  71. Gear Swap Questions (2.73 to 3.42)
  72. Persistent clutch problems, has the shop stumped.... HELP PLEASE
  73. Master Cylinders, LS-1 and LT-1 the same?
  74. Does a new clutch need a break-in period?
  75. Clutch Replacement
  76. 1350 u-joint
  77. Transmission Problem
  78. Suspension Setup
  79. spec Stage 3 ceramic install finished!! but have a question??
  80. Mcloed Adj Master Problems!!! Please help
  81. Play in the driveshaft...Is this normal?
  82. where to buy t56 internals
  83. How do I know when its time for a clutch?
  84. Need help 4L60E question
  85. Rear End Girdle worth it?
  86. ls1 brake swap
  87. 4l60e trashed 2 pumps in 2 weeks?
  88. Broke the slave cylinder...
  89. LT1 and LS1 STALLS Compatible????
  90. drive train noise!!
  91. Low-speed Rear end noise when backing/turning
  92. autozone clutch
  93. know any good tranny shops around here?
  94. Drill mod with the Street twin
  95. A4 to T56 swap, what mods do I need to do to the A4 harness??
  96. Soft clutch pedal
  97. high speed "humming"
  98. How hard to replace a driveshaft???
  99. Urgent Clutch Info Needed!!!
  100. Vibration
  101. Trans temp gauge won't work
  102. whining sound in rear end
  103. TA cover
  104. What has to be done to put a powerglide in a 3rd gen?
  105. Engine vibration & motor mounts
  106. T/A rear girdle leaks?
  107. A4 with a mind of it's own
  108. Th 400?
  109. Called McLeod and this is what I found out
  110. Rear End size
  111. T56 rebuild
  112. Bearing Question
  113. Grinding noise from shifter after new clutch install!
  114. GM Parts instead of shift kit....
  115. Street Twin installed....loud screaching noise
  116. Adj. Master Cylinder for the street twin.
  117. Is my tranny dead?
  118. How to tell if the new slave has over extended?
  119. 9 bolt vs 10 bolt
  120. Symptons of a Bad Pressure Plate?
  121. Anyone have problems with Spec billit steel flywheel?
  122. New Transmission...
  123. How loud are your 4.10's?
  124. Spec stage 3 is in WOW
  125. paddle kit
  126. change trans fuild-how many miles
  127. Axle Seal on a moser 12 bolt.
  128. Vibration at high speeds
  129. Jasper Transmission
  130. 2800 or 3000 stall for the new transmission?
  131. what type of pulse does the trans put out ?
  132. M6 shifter
  133. read end question
  134. 4:10 gear swap???
  135. Spohn Torque Arm
  136. Chattering from new clutch?
  137. TQ Convertor ?'s
  138. stock gears and et streets (3.23's)
  139. Trans Problem
  140. shift kits
  141. Tranny Rebuild
  142. Vibration
  143. ? about the pro 5.0/lous
  144. Transmission issues.
  145. Car doesn't shift at WOT
  146. Question about brakes and lower control arms.
  147. Lous SS website?
  148. HELP! I think I shattered my clutch!
  149. LS1 Clutch question
  150. Predator Torque Management?
  151. Towing rear wheels down will damage transmission??
  152. 3:73 ?
  153. TCI 4l60e??
  154. TCC Lockup
  155. Battle of the rear ends, 12 bolt or 9"?
  156. How much to get vigilante converter restalled?
  157. Where can I find out more info on PCM programming of 4L60E?
  158. T56 noise (again)
  159. shift kit??tranny rebuild
  160. Who builds the best tranny (4L60E)?
  161. tires, drivetrain related?
  162. okay...lets have a small quiz....tranny temps and longevity
  163. Hi-po lockup converter (TH400)
  164. How hard to launch with a street twin and a 10 bolt?
  165. Anybody using an aftermarket speedo with a TH-350 or 400?
  166. Problem installing slave cylinder into T56
  167. wrong tailshaft for TH350 swap? (9")
  168. Shim Pack Question
  169. LS1 clutch adjustment
  170. b&m or transpak
  171. Transmission
  172. Any way to tell if a T/O beaing is good?
  173. Actual line pressure vs pcm value
  174. A4 funny shifting
  175. intelligent opinions on gears 373?
  176. Rearend noise
  177. T-5 clutch engagment problem
  178. M6 doesnt feel right
  179. torque converter
  180. What oil to use in Moser?
  181. 12 Bolt Vs. 9inch??
  182. Clutch
  183. T56 Experts! Need help!
  184. Which Clutch
  185. Pete Z bars
  186. converter and gearing ??
  187. Will a LT4 clutch hold a 383 stroker?
  188. No first gear...whats wrong?
  189. Question for 9" owners.........
  190. Rear End Rebuild
  191. Vibrations with new driveshaft and rear diff
  192. What auto transmission?
  193. What inch and bolt differential?
  194. Clutch not gonna last much longer...
  195. Flywheel replacement? (A4)
  196. T56 Grinds when speed shifting into 2nd?
  197. 4th Gen SS- A4 to M6 Swap?
  198. Anyone go from 4L60E to 700R4?
  199. Transmission Mount Nut:
  200. Guys with a T400 or T350
  201. 12s with just bolt-ons?
  202. Tranny will not shift 2-3 @ WOT??
  203. Clutch Problems?
  204. strongest gears for stock rearend
  205. Holy crap! Look how bad my old clutch was....
  206. Sign Of Bad Ring and Pinion?
  207. Question on setting up gears, can someone help?
  208. SPEC clutch feedback...
  209. gearing and gas mileage..
  210. quick 4L80E question for all you tranny experts...
  211. quick diff question
  212. Tranny temp. gauge pinned over 250 Deg. !!!!!!
  213. Will it fit?
  214. Hard to get in gear
  215. Tranny Rebuild Questions.
  216. Recommendations for tranny and diff fluid brand and weight
  217. Squat or anti squat
  218. How much can the stock clutch and 10 bolt take.
  219. Spongy clutch pedal
  220. PCM will not see TCC soleniod ...maybe wrong year trans ?
  221. Hyd throw out bearings
  222. Rear end swap
  223. fidanza alumnium flywheel
  224. How much pinion angle do I need?
  225. Street Twin throwout bearing
  226. Stock Tranny mount or Poly?
  227. Differential question
  228. Very odd tranny problem (help!)
  229. Tc ??
  230. Broken axle and more...
  231. Considering trading my 12 bolt for a 10 bolt. Am I crazy?
  232. Where is the best tranny cooler location??
  233. what does a broken tranny mount affect?
  234. Daily driver: lockup or nonlock up?
  235. rpm w/ hot cam & 4:10
  236. Competition Engineering Rear Drag Shocks
  237. Rear squeals when cornering under accel.
  238. Car is lopsided after axle swap
  239. good stall speed for....
  240. rear end noise
  241. Help, Anyone know the size of the bolt for the Pan Hard Rod (PHR)?
  242. clutch and tranni question???
  243. driveshaft lenth with 6" tailshaft?
  244. Finally ordered my 12 bolt J I got
  245. Clutch going?
  246. shiftplus electronic shift improver??
  247. Anyone running a M6,230/236 and 4.56 gears ?
  248. How to store 4L60?
  249. TH350 or T-56?????
  250. Energy Suspension's Poly Tranny Mount Install Question
