- Spec Stage 3 disc
- 4.10's or 4.56's?
- Street Clutch for 380RWHP ???
- what's needed for a clutch install?
- Torsen t-2 carrier
- Clutch Problem Need help ASAP!
- TH350 kickdown??
- Can I use used gears?
- 4L60E Output shaft ?LS1-LT1
- I Need Help Bad!
- Would mixing up the trans cooler lines cause it not to cool properly?
- 1st gear mod ?
- rear end width???
- so the 4L60E will shift into 2ed at 100mph
- i need a 12 bolt! anyone have one?
- Looking for a transmission part
- confused on clutches
- 96 4l60e input shaft TCC ball capsule?
- SLP shifter rocks
- Pops out of second when letting the clutch out.
- New Clutch, need to replace throwout bearing??
- Quick question-help choose clutch
- Whining gears in differential?!
- aftermarket trans pan install problems
- stock 3.42 to 3.73 gears worth it?!
- Need tech info on 6 speed conversion
- 6-speed noisier after clutch swap...
- Stock gear ratio
- Looking for gear brand suggestions
- rearend .....loss of power
- 4:10 gears
- Need help asap please, clutch problem!!
- temp
- t56 trouble
- Gears grinding, Hard reverse gear
- Pilot spacer for TH400 swap?
- Transmission to bellhousing torque spec.
- Are 2.73s really better for highway racing?
- Trans Temp Gauge.Where to Ground Sender Unit.Help
- LT-1/LS-1 rear axle swaps
- 4L65e Tranny mated to a ODB1 LT1
- Transbrake wiring
- New Gear Break in period.
- Actuator slave install/Clutch Fork!
- How much to RR a TQ?
- 6 spd NOISY.....time for new fluid?!
- Sorry I don't know what a stall is?
- NOOB question, but I have to ask..stock=posi rear???
- trans temp question please help
- Trans install-bolt on verter or trans first
- New synchros and still won't go into gear?
- flywheel questions
- I'm a happy boy . . .
- Removing stock a4 shifter assembly, what is this hose???
- stock wheel stud length
- Which Clutch??
- 4.10 Gears
- auto tranny pull
- A4 going out? Please advise..
- T56 problems, help!
- SLP clutch questions
- need advice on torque converter
- Tranny Jumping?
- I want new gears. What kind do I need?
- Rear End Woes
- Need HELP!!!
- Best gear ratio for FI
- Transmission question
- Spec Clutch Gone Bad 20,000 Miles
- Installing 12-bolt, few questions.
- Trap Speed - Rear Ends
- throwout bearing
- Torque Converter ?
- Clutch Questions?
- Auto transmission service - how often?
- 12 bolt swap, what cars are direct bolt ins w/ posi?!
- sycro problem or ??? on a LS1 T56
- Torque arm bolt size
- Couple Clutch questions
- Spec Stage 4 is BADA** (PICS)
- Ls1 rear in and Lt1 car
- Stronger Transmission???
- help me pick a stall
- ??? driveshaft won't come out
- How is/was your experiance with the Spec stage 2/3 clutch
- I have a FORD 9" Available that came out of a Gen 3 Z28. Housing and Axles $750
- Say.... does anybody have a......
- Center Force Dual Fricition Clutch??
- Need Mcleod Clutch install help pls!
- High stall converter
- b&m shift kit
- Do torque converters hurt mpg?
- Yoke/Driveshaft question
- Console ratchet shifter for 95 z28?
- Stock gear ration questions
- how much gear oil does a 2001 Camaro
- Fixed Pinion/Yoke seal, now my gears whine like crazy... WTF?
- Does PP need to be in certain orientation for balance?
- How to take care of new Ring&Pinion?
- Questions for a friend
- Rear End Fluid?
- Need your help with clunking noise
- Replacement Clutch
- Rear Wheels move in and Out, need Help...
- 12-Bolt Bearings vs 10-bolt?!
- need help with a couple problems I am having.
- Bad wheel hop
- Please don't tell me i need a rebuild tranny
- 1993 Z28 Gears...help
- What do i need going from 2.73 to 3.73??
- Is TCI street friendly?
- Why is my McLeod clutch clipping????
- question about flywheels...
- 8.8 rearend u-joint
- turbo 350 with 700 tail housing
- i have a ? about abs hookn up on a 12 bolt!!
- Replacing clutch, any details I should know about?
- lost first gear tonight
- converters
- Trans cooler, need to remove trans to install?
- clutch hydraulics?
- Can I patch / JB weld my bellhousing?
- Installing 4.10's, need a panhard rod for differential?!
- abs ?
- Clanking when put in Gear
- 04 cobra tranny in 95z28 ???
- tranny temp
- DUAL REAR WHEEL DRIVE??? Fishtailing!!
- What size welds? Brakes?
- just a clutch or the whole tranny?
- Auto VS Manual Trans
- T-56 Input Shaft
- Will a lose trans mount cause a vibration at high speeds?
- Posi/Gear Install
- t56?
- How loud is your 12 bolt???
- aftermarket trans cooler install question
- How to get transpan to stop leaking
- Can't shift out of first!! help!
- stupid tranny
- Flushing the transmission?
- 145mph vibration problem
- how much power can a stock tranny and rear end take?
- Is this clutch still useable????
- cam no tune..transmission
- how hard is it to drop the rear end...
- 94 and 95 tranny the same?
- v-6 rear end
- changing fluids
- continous clunk
- stock trans cooler question
- tranny code
- bleeding a clutch
- M6+DR's+10 bolt?
- 3:23's to 3:73's
- What exactly is the carrier?
- Driveshaft ID
- How to lower transmission?
- 6sp. conversion Need help
- Centerforce dual friction clutch
- Changing valve body?
- Where to buy 3.73's.
- How much to get tranny fluid changed
- M6 to A4 swap
- Rear end thud.
- tranny temp question
- stall
- Clutch??
- 4L60E won't shift
- engine stutter when idling in gear
- tranjny code
- Chosing gears. Motive or Richmond?
- Spec Stage 3 clutch..way cool.
- tranny
- Clutch? maybe?
- pro's/con's of 12bolt to 9"
- limited-slip additive in 4l60e??
- HELP - 12 bolt Moser
- any good clutches besides mcleod?
- Bad Torque Converter?
- Ls1 Ram V.D.S. clutch in a Lt1
- Stock Gear Series Number?
- 6 speed swap
- 2 Questions: Clutch & Gears
- Clutch rebuild $
- Transmission help T56
- I need some opinions
- What is needed to convert from 4l60E to 700R4
- clutch?
- Zexel Torsen rear
- something really bad happend
- auto shifter
- New eaton posi/gear install
- turbo 400 question
- Converter help please!
- 5 speed trans
- parts needed for a4 to m6 swap
- turbo 400 with 4.10s and N20?
- Problem with 94Z ?
- Rear mounted spare tire...
- Cheaper Adj. Master Cyl. than McLeod?
- TH400, TCI flex-plate shield, TCI trans shield...what dipstick?
- trans coversion question
- New updated SPEC stage III vs. old version (crap) - good, bad, ugly??
- 12 bolt question?
- Wheel studs? Are 12 MM but longer strong enough?
- converter not locking
- gear install kit???
- can i just throw a z28 limited slip unit and ring and pinion in my v6 axle
- Replacing solenoids on 4L60E
- 10 Bolt limits
- 1994 Firebird Auto Trans Shifting Problems
- squealing on left turn
- New clutch goin on soon need opinion
- how durable is a stock t56
- M6 x-member, TH-400...spacer? VSS sensor?
- LS1 rear end in an LT1
- Raybestos Master Cylinder
- how hard to get an 01 ls1 rear end in a 94 camaro
- Does this sound like a converter problem?
- Does anyone have any experience with...
- question on torque arm clamp for a 700r4
- Lower E/T mile with lower gears???
- 50 mph wobble
- Clunk! New Poly trans mount, U-joints? Torque Arm?
- Need CClip Eliminators for 4.56s???
- Torque converter problems, please help!!!
- what carrier do i have with 2.73 lsd rear?
- Bent T56 output shaft, need help!!!!!
- Tran's mount don't mount right.
- Time for a new transmission
- what gears
- Clunking Woes
- Torn Transmission Mount + Stripped Bolt Hole. HELP
- Rear axle play
- best way to set up trans shift kit?
- Getting 1st Gear
- Hays clutch???
- 4L60E or 4L80E?
- Shifter Question
- Push in clutch hear grinding noise
- speed...times
- AH!!!!!! Tranny mount ?
- Automatic Transmission Service
- Skip Shift Selenoid
- Take foot off Gas Loud Rubbing/Grinding Sound
- V6 Auto-Man.
- Why very hard to push the shifter knob?
- steel transmission mount??
