- viper clutch fork
- 4L60E going south... Rebuild? Or M6 swap?
- issues using studs on block to bellhousing bolt holes?
- What clutch should i get?
- Torque Converter Install!!! What Will it feel like??
- how aggressive of a clutch with a 10 bolt with 4.10s take?
- Differential/Rear End fluid changing?
- for all you with 12 bolts.. I have the cash, but where is th best place to buy?
- spec stage 3
- got transmission serviced now shifts like mush
- Good converter for me Help please
- 3-4 steel clutch fork install, is it easy or should I leave it to a shop to install
- t56 to th350 conversion-having flywheel/starter issues
- A4 Flush and Refill...
- Will a V6 A4 swap onto a LT1?
- Need a new clutch
- Keep cooking clutch fluid? Whats up?
- stock vs Yank PY3400E converter
- m6 conversion problem
- Damage from driving with spare on rear?
- transmission doesnt shift into any gear!!!!
- 1st thread! Transmission problem! I need your help!
- replacing u joints
- Rear End ???
- 1st or not
- Are these the same...Transgo shiftkits?
- Rear End / Tranny Fluid
- T56 Trans problems
- Need info on putting a 350 turbo into 94 Z28.
- Limited slip additive, is it needed with Royal Purple?
- Pinion Yoke size
- Spools
- Best clutch and alum flywheel combo for 500hp
- Where to find clutch alignment tool?
- Trans Conversion
- Brand new posi broke!
- Best Drag Racing Posi???
- McLeod [screwed] Up w/ Street Twin Recent Buyers Inside!!
- Rear end question
- T5 into LT1
- What to do with comp for A4 to M6
- Only 1 tire going bald!!
- LS1 rear in aLT1?
- For those who did the 6 speed conversion. Pedal question.
- Whats missing? T56 question
- What clutch do ls1's have?
- gm limited slip additive
- Transmission Pan bolts??
- Need help on choosing Converter
- t56 to th400 swap??'s
- wolf drag race swaybar?
- DOT3/4 Valvoline vs. The White Bottle (DOT3)
- Clutch out of adjustment
- knock in the rear
- Lockup converter. Explain to me how they work.
- Problem with trans at WOT
- is a 94 LT1 z28 4l60e same as 97 z28 lt1 4l60e
- difference between spec 2 and 3
- Anyone having a sale on rears right now
- stuck bolt in steering rack
- SLP ds loop w/ oversize ds?
- T-56 is BAD?
- Tranny dont kick down
- My Tranny is Squeeling (A4)
- car pulls to the right
- 2 series vs 3 series carrier
- are all 4L60E's the same?
- 700R4 Planetaries?
- Disadvantages of aluminum flywheel?
- Wierd rattle coming from transmission?!?!
- need some quick solid info. rear from 93 to 97..
- Rear axel bearing replacement on a Z28 1999
- Putting together a 12bolt, what else do i need?
- 400
- HELP! Wierd rattle from trans!
- Suggestions for a 6spd shifter?
- brownish tranny?
- Will a Z06 clutch and flywheel fit an LT1?
- LT-1 M6 into LS-1 Qs???
- convertor to flywheel bolts
- Gear swap ???s
- Strange TCC Readings........?
- Energy Suspension Polyurethane Tranny Mount Installed
- New Clutch
- Rear end checking out?
- Motor and Tranny Mounts...
- B&M Ripper + D&D Tranny
- cheapest flywheel??
- Could a bad clutch cause vibration...
- Clutch safety switch backwards?
- Clicking noise out of rear end
- dana 44 in a 3rd gen?????help asap
- Rear End Might Be Loose
- What STR for daily driver?
- Would my TCI 3000 stall cause a PO751 code?
- best tranny cooler?
- What type of lube for pilot bushing?
- Hesitation after replacing pilot bushing?
- Tranny help??
- stall question...
- Eaton differentials
- Big problem, i think with the driveshaft.. Need help
- How much HP can a CF drive shaft take?
- Clutch fried or just needs adjustment ???
- Mcleod install ?'s
- gears
- 4l60e gurus questions
- Car pops out of gear.. or DID pop out..
- Accurate trans temp readings from inspection port?
- simple question , master cylinder line
- Clutch slipping - what's the least I can spend to fix?
- 4:10 gears to much??
- LS1 Tranny mount on LT1
- LS1 Trans Mount on LT1
- Which tranny would be best for 600+ rwhp?
- who sells precision gears?
- Which gears?
- possible bad torque converter?
- replacing thrust bearing
- Gear pattern on the heel- shim estimate?
- Is this flywheel usable?
- Where to find stock flywheel?
- removing trans in driveway....how did you guys do it?
- hp gains (or non-loss) from lightweight flywheel?
- t 56 rebuild
- What Gear Ratio To Use
- Strange price increase coming soon!
- Got flywheel resurfaced... is it supposed to be smooth?
- Which is better Eaton or Auburn?
- probuilt tranny
- m6 trans....any good rebuilder? $$??
- mcleod disk replacement
- Tranny or clutch..which is bad????
- Flexplate for LT1/th400
- Tranny experts...i need a diagnosis
- Are 4l60e and 700r4 valve bodies exchangable
- Torque Converter Install: What to buy?
- RPO codes for rear end gearing
- guys i need your opinion !!!!!
- Are Richmond gears stronger?
- Non-Synchronized 1st Gear - why?
- 4l60e swap 4 t56
- Where to get flywheel shims from?
- Cant get the driveshaft off my LT1
- Which of these clutches is best?
- Clutch Pedal Vibrating Horribly After Clutch Install! Help!
- Question on 9 inch
- tranny bad?
- Clutch wont disenguage
- Could a little undertorque of pp bolts ruin a clutch?
- Adding transcooler
- Put a new tranny in and installed old clutch.. Chatter Problems..
- roomate touched clutch...brake cleaner fine?
- Ok, I need to make some plans for my converter install..
- alumn flywheel ....bad idle?
- Synthetic ATF?
- Add a shift kit?
- Tranny won't enguage--any ideas?????
- how to remove pressure plate bolts??
- line for the "drill mod"?
- Can't find .012 flywheel shim
- TRADE my A4 for your T56, i need T56
- flywheel
- Tranny Experts Please Help, Fresh A4 Rebuild developing problems?
- broken peice
- Changing clutch...and flywheel???
- AC Delco clutch or aftermarket???
- A4 shifts too hard.
- TransGo Problem
- In the market for a new stall
- Shift issues
- LS1 tranny mount nut
- driveshaft rpm
- want a 12 bolt
- Sun shell failed - total failure imminent?
- limited slip rebuild
- Clutch Change Without Resurfacing Flywheel
- what gears to buy
- ringear spacer do they have them
- Special tools?
- what series rearend do I have?
- bleed the system after slave cyl install?
- umi short stick?
- rear diff upgrade
- 700r4 in a 91?'s
- Which brand of gears do I use?
- Need some answers about rebuilding my 700
- problems with shifter
- LS1 clutch install...hell continuation
- where to buy a 12bolt or 9 inch from...
- looking for new 3.73's for a 2 series
- rearend build
- Gears now or save up for 12 bolt?
- transmission question
- please help me with my clutch woes
- is the slp clutch and billet steel flywheel as good or better than spec &street twin
- are the problems resolved with the spec stage 3 clutch?
- do you have to buy an adjustable master cylinder with new clutch?
- what built internals for a t-56?
- Stall speed question
- Pressure plate bolt question
- highway driving bad for clutch break in?
- 4:11's for 7.5 10 bolt?
- street twin too aggressive for a relatively stock car?
- Stock rear whines..
- t56 question
- what do i need in order to change gears in my moser 12 bolt?
- Moser v. Strange, 12 bolt v. 9-inch...
- what tools for ring gear swap, dial ind. question 2
- Noise in back when turning... brakes? differential? lsd additive?
- Quick Axle Question
- a little help regarding slave cylinder
- For those looking to buy a ST.....
- Pic of 4l60e?
- Need Help With Torque Converter....
- Clutch problems, have a few questions.
- M28 internals?
- tranny probs need some advice Quick???
- Stock 10 bolt strength
- What do you guys think of this homemade tranny mount option?
- Tranny problem or computer related??
- New Clutch Sticks Like Old One
- Street Twin clutch alignment
- street manners with light alum flywheel
- Open diff or LSD?
- t56 rebuild help w/ some options. allready found the problems
- 4000 or 4400 stall?????
- downshift?
- Spec probs?
- Thinking of going 3.42 to 3.73
- Need rearend help...
- Rear End Swap (LS1 to V6)
- No 3rd Gear
- Having trouble getting stock TQ arm to fit on Moser 9 inch
- 1993 T-56 swap
- ? on torque converter
- How much power can a stock m6 bolt handle??
- T56 won't disengage from engine.
- ckperformance 2004r transmission manual
- Skip Shift
- 4l60 vs. 4l60e
- Clutch
- ANY way to determine gear ratio ? by looking at gears ?
- T56 probs...need some help!!
- tranny
- Trans Help. What Next?
- Gauge Cluster, or VSS???
- Torque converter (4l60/4l60E)
- 700r4 vs. 4l60e
