  1. need clutch help
  2. Ford 9" Install
  3. 4th gen driveshafts
  4. shift kit question
  5. LT1 OBD1 versus OBD2 4L60Es
  6. WHat kind of gears
  7. Flywheel To Pressure Plate
  8. Are rear-end gear swaps something i can do?
  9. 4.10 in an a4
  10. Prothane polyurethane transmission mount
  11. Any one know good aftermarket auto Trans?
  12. Need Part Number for Trans Dipstick and Tube
  13. overdrive trouble?
  14. shift kit help...plz
  15. question about parts from summmit and jegs
  16. Tranny gods, in here plz
  17. ? diffrence between 3 & 4 channel
  18. how is your 2 step wired to you clutch
  19. Gear question
  20. Balancing Flywheel and clutch
  21. what t56 clutches are the best
  22. Balancing Flywheel and clutch
  23. Need instructions for replacing a broken M6 tranny mount
  24. Where do I buy a performance T-56?
  25. ES Trans Mount Whine??
  26. T56 swap
  27. leaking transmission fluid
  28. Viper slip yoke
  29. Whats needed for TH400 conversion in A4 94 Z28 ???
  30. shifter rattles in 3rd gear
  31. 4L60E Vaccum Line?
  32. Please Help!!!! tranny problem
  33. Getting my Tranny rebuilt
  34. straight forward question need straight forward answer
  35. What rear tires do you recommend?
  36. McLeod street twin install problems
  37. DAMNIT I knew I would run into problems PLEASe help!
  38. Rear End Girdle
  39. mixed reviews: drill out mod (for clutch/slave line) or no?
  40. 12 bolt from older 60-80 chevy worth it?
  41. Rear Axle Bump Stop OPTIONS?
  42. how much did you guys pay to get a torque converter installed in your LT1
  43. Car trouble acting up.
  44. Spool in a 7.5 10 bolt, Break or not to bread??
  45. For those who have Moser 12 Bolts...
  46. Broke rear end and now tranny seems messed up..
  47. 1-2 shift getting soft
  48. Can i run drag radials?
  49. Which Clutch. Spec IV or Street Twin?
  50. Will tail shaft on 700r4 work on TH350?
  51. Removing A4 dipstick tube bracket
  52. 01 Z28 rear end noise
  53. 1999 Camaro Skip Shift>? Help
  54. Edelbrock Torque arm=CRAP
  55. No tmission gears?
  56. Which VSS do I need?
  57. Pigtails?
  58. Tranny swap, throwing new code for TC??
  59. any good sites for installing spec 3
  60. th350 dipstick
  61. installed B&M Transpak, now...
  62. Will I have enough gear??? th350 guys
  63. transmission/driveshaft alignment
  64. Which is better Buy transmission or rebuilt?
  65. Spec stage 2 installed!
  66. Rearend noise
  67. axle help
  68. T56 dust shield part number?
  69. New here...rear end noise
  70. 1994 4l60e into 95 z28???
  71. t56-6
  72. 94 4l60e in a 97 not compatible??
  73. Screetching noise from the rear end?
  74. 83 z28 campatibility with a 88 camero
  75. stock T56 ?
  76. limited slip to posi
  77. 26 or 28 spline?
  78. What would keep a T56 from going into Reverse
  79. What gears do I have???????
  80. 383/396 owners inside - Q on flywheel balancing
  81. High Stall Problem Possibly
  82. 700R4 Leaking
  83. Need Cluch Recommendation
  84. 8.8" rear end
  85. 3rd gen wheel size
  86. manual valvebody
  87. has anyone used the hurst TH350 conversion kit
  88. Quote for Rear End gear installation..
  89. Mcleod Street Twin Install Question
  90. Gears
  91. Mcleod Street Twin HELP ASAP!!!!
  92. 4L60E Articles
  93. What is stronger LT1 or LS1 drive shaft?
  94. a4 to m6=car wont start
  95. "click"?? in rear axle/diff
  96. transmission fluid color?
  97. about my stall converter
  98. Rear End Gasket
  99. Rear end leak
  100. Trans cooler
  101. Which clutch is better SLP or RAM??
  102. will a stall kill an a4?
  103. What series carrier does my Moser 12-bolt have? (and other ?'s )
  104. Help me pick which gear ratio
  105. PLEASE HELP- problem with 12-bolt order from Tbyrne
  106. 700r4 probs
  107. Will a yoke from an LT1 10 bolt fit ....
  108. t5 poping out of 1st
  109. clutch for 350rwhp
  110. 10 bolts ford sale
  111. TH350 conversion complete now car wont start
  112. Fitting issues with the Spec Stage IV
  113. 3.73 problem
  114. Growling noise
  115. A4 Wanting to get a new shifter
  116. Shifting problem
  117. what's involved 94z moser 12 bolt setup?
  118. Help pick a trany setup
  119. When engaging clutch something is binding and motor will stall
  120. T56 popping out of reverse - Something I can fix myself?
  121. a4 wont shift at or close to WOT
  122. clutch will not disengage -help cars stuck
  123. anyone replace tranny bearing races? -- need help
  124. will ls1 adj clutch master work in lt1 car??
  125. Has Anyone Else Had This Problem
  126. Do i have 3 or 4 channel ABS?
  127. problem with 3rd
  128. Paging Pro Built Automatics ??? pm`s full
  129. Speedometer gear install problems (couldn't find what I needed with search feature)
  130. Tranny noises in 1st and 2nd
  131. New rear end?
  132. Tranny Question
  133. converter doesnt lock
  134. v6 drive shaft on strange 12 bolt?!?!
  135. need help with an axle problem.
  136. NEW 9 Bolt Borg Warner Rear End ideas needed
  137. wich stall?
  138. Sumitomo HTR z tires?
  139. Third gear is gone
  140. Few questions on a moser 12 bolt before buying...
  141. Tranny Flush?
  142. 700R4 Vig 4000
  143. New Spec 4 Does not totally disengage????
  144. I need a few questions anwered (4l60e)
  145. Should I get an aftermarket shifter or just the handle???
  146. How involved is a pinion seal?
  147. How fast am I rolling? Math Prob!
  148. A4 and M6 Torque arm the same?
  149. another convertor question
  150. Rear Install... in driveway...
  151. 5 speed poping out
  152. Anyone use braided steel line for tranny cooler??
  153. A4 and T56 Crossmember similar?
  154. Hurst billet plus install ?
  155. Does ARP sell pressure plate bolts that actually work?
  156. how do you tell what kind of gears?
  157. T56 bolt to 6.0?
  158. Car is stuck in drive
  159. How much power can a Stock clutch hold?
  160. Roller pilot bearing install in LT1
  161. th350 trans cooler q?
  162. ebay shifters
  163. Pro's & Con's: Roller Pilot Bearing or Stock Bushing..
  164. Is this a good idea?
  165. 3400-3600 stall
  166. A4 shift issue
  167. spec or centerforce?
  168. transmission swap
  169. Slave cylinder adapter spacer thing, where can I find one? whats its correct name?
  170. tranny cooler?
  171. A4 Trans help
  172. Clutch Install problems!
  173. 98 stallconverter in a 95
  174. clutch install
  175. flywheel
  176. rear strength
  177. POS 4L60E "HELP"
  178. Details on Trans and Rear help plz
  179. transmission wont go on all the way
  180. Buy auto trans or rebuild it?
  181. Auto Shifter
  182. SLP Shifter question????
  183. Spun an axle in my Eaton at the Track
  184. HELP!!! removing tranny
  185. Stock 2.73 Gears
  186. Spec Stage 2 clutch and Q's
  187. What kind of clutch should I get?
  188. Ripper shifter install.
  189. Transmission Shifting Problem!
  190. Weird vibration
  191. how much work and cash for Manual Conversion
  192. Rear Pinon Seal?
  193. should i attempt to rebuild my t-56?
  194. Hurst T handle
  195. Help Please
  196. 5 speed.
  197. Need close up picture of Clutch Fork
  198. What are the symptoms of a bad clutch?
  199. car make-over
  200. Help my find this mysterious clunk.
  201. rear end question
  202. Distance from the fly wheel to the edge of the throwout bearing?
  203. 3rd gen posi and gears interchangeable?
  204. Will my 9 bolt hold up?
  205. Shifter popping out of 3rd?!?
  206. LT1 T56 Bellhousing?!?!
  207. NEED HELP!! 700r4 overheated and wont shift!!
  208. A4 Problem when Changing gears
  209. has anyont installed a hurst v-matic II shifter
  210. Rear end gear oil?
  211. Rear pinion seal ?'s
  212. What does a torque converter do?
  213. Are the LT4 and LT1 Flywheels the same?
  214. Mcleod ?'s
  215. 4L60E Perormance?
  216. Chattering Clutch is Waaaay Better
  217. Would this clutch kit work?
  218. HELLLLPPPPP me
  219. installing site for spec three
  220. T56 Inspection Cover bolt size
  221. Richmond Gear install video
  222. installed shift kit, code 73
  223. Installing Short Stick?
  224. what torque converter and lockup for a cc306 and ported heads?
  225. 4L60E pan
  226. spec stage 4 noise during break in?
  227. Th350
  228. tranny's out, should i rebuild it?
  229. Moser 12 Bolt or Strange 12 Bolt
  230. th350 performance fluid reccomendation
  231. 4CH rear into 3CH car???
  232. Clutch install problems continue.......!
  233. what could this be...??
  234. Torque Converter Or Not?
  235. Is my rearend ruined?!
  236. Tranny Swap
  237. tranny mount seems shot at 48K miles on 94Z A4
  238. ? on posi rear end
  239. stock rearends
  240. Differential Pinion Shaft Hole
  241. Differential Pinion Shaft Hole
  242. To rebuild/replace my 4L60E, that is the question
  243. Clutches
  244. having t-56 rebuilt, should i beef it up?
  245. 1995 Z28 Traction Control Option?
  246. Strong 4L60E
  247. Starter not disenguaging fast enough after A4 -> M6 Swap
  248. humming sound when driving????
  249. Brand new SPEC III slipping.....help!
  250. Spec 4 clutch/SLP flywheel install, rubbing pressure plate!
