- i need facts!!!
- Gear swap in the Toronto area
- str? need help
- '93 t56 to '94 t56 swap question
- ;busting hydrolic lines
- finally installing my 12 bolt. How much loss in performance
- Delayed downshift
- need a tranny expert
- noise from rearend when turning left
- Street twin installed, Q?s about whirring noise
- Drivetrain clunk
- GM 3.73 Gears ?s
- need help with bell housing bolt
- Welding axle tubes to housing
- 12 bolt/9" out of old truck in our cars?
- 3.73's or 3.90's????
- Have the horses but can't use em cuz of wheel hop-help
- Installing tranny help!
- vig3200 stall and obd1 problems??
- will a 2800 stall work with this setup
- trans and differental question
- Clutch break-in
- Connecting tranny cooler lines with T-56?
- Clutch replacement: how hard is it?
- 92-96 Corvette tranny?
- Shifter moves up and down
- Clutch Slippage..?
- Sensor on rear?
- Spohn Torque Arm?
- 95 obd1 4l60 to th350 swap
- Is my transmission going?
- Prevent fishtailing on launch
- Power Capacity of the 4L60E?
- p/n's and thoughts on a Z06 clutch, etc
- speedometer with moser 9"
- Tranny Fluid
- Auto tranny: reverse/OD gone...replace or rebuild?
- High mileage gear swap
- Flywheel Questions
- Driveshaft length
- Damn Tranny Shops.
- Tranny fluid
- What Transmission combination to go with? what aftermarket company to use?
- 4th gen A4 rpms at 60MPH? Found something interesting please post
- New gears
- Is the clutch pedal lower than the brake pedal?
- gear question...
- 2001 trans into a 1994
- Transmission
- t-5 rebuild kit, lots of torque
- 4L60E to 700R4 swap
- 4th gen performance th350 install *q's
- Borg Warner T 56 Differances
- Borg Warner T-56 Transmission Differances
- Clutch Engages Roughly
- SPEC Clutch was DESTROYED!
- Transmission Problems
- Rear Gears Recommendation
- Name These's Noises! My rear end.
- t-56 in a 3rd gen
- Spacer use on Moser 9"
- gears for six speed swap?
- what tranny should i use?
- pics of my slipping clutch...
- 6 speed f-body/corvette identification?
- Th350 Swap 4L60E To Th350 swap
- T56 rebuild
- strange 12 bolt ?
- 4L60E Conversion question
- What do you know - or think of - GM rebuilt 4L60E's ?
- M 6 second gear problem?
- I believe my VIG Stall has bit the dust
- 3 Series ABS/9 Inch Rear
- Bad Problem shifting 1-2 HELP!
- How much should it cost me?
- Torque Converter
- a4 to m6 conversion who sells them
- TKO500/600/600RR + LT1 + Dana 36 + Cobra = hmmm?
- Franl Help Me!!
- Spohn TQ Arm Question?
- pro 5.0 knob any good?
- Cheap Alternate
- Bad Slave or Bad Clutch or ??
- Trans crossmember help
- Richmond Transmission
- What grade gear oil to use in new 12 bolt?
- 4l60e to th400 conversion
- 700r4 TCC control w/ 94 pcm
- 26 vs 28 spline
- SS 10 bolt strength
- Rear End Girdle Question
- using the 4l60e
- 4L60E Shifting Troubles...
- LS1 rear in LT1 car?
- what is a torsen rearend
- Code P1870
- put the torque converter in "dry"
- funny sound in reverse
- Transmisson
- Shifting hard
- What do these problems sound like? (Tranny)
- lt1 rear brakes fit onto 98 + rears?
- '67 Saginaw M20 Speedo Drive Gear?
- Info On Rear End Gears
- 10 bolt series 2 and 3 carrier difference
- optimum rear gear ratio w/th-400?
- cheapest place to buy a street twin?
- New Spec 3 clutch
- Gear whine.
- Dreaming of a 6 speed...
- gear selection questions for set up with th350
- Was Reading the Vigi Manual
- 4L60E/700R4 upgrade question (input drum/shaft)...
- longer wheel studs and open end acorn lugs
- What would cause.....
- Who Has A Trans-Go?
- Reverse problem
- What is my weak link?
- Converter Selection
- Question on 3.73 Gears in a 1997 Camaro
- Accel loss on highway
- Which clutch is better: Centerforce or Spec
- Something missing from my t56...
- hard to downshift in m6
- need help, did I mess up??
- C Clips
- LT1 Stock torque arm
- I don't friggin' believe this
- Going to have TH350 built RIGHT, any advice on parts?
- Pro 5.0
- Shift-kits good/bad mod..?
- SLP LT4 PP & Spec Hybrid disc?
- Have to rebuild my T-56 ... Questions
- Transmission saga Part II - apparently, the Vigilante 2800 I had ...
- th350 vaccum modulation
- any of you guys tried to fit a ratcheting shifter into your console?
- ls1 & turbo 350 or 400
- friction plate question
- Stall???
- Transmission Shudder
- Gear question
- SPEC Stage II Wear in Questions
- 3200 stall
- max power through the stock drivetrain
- Which TCI Sizzler?
- B&M SHIFT PLUS INSTALL???
- Clutch Problems?
- m6 3:42 vrs auto 3:73 3800 stall
- Re-pucking spec stg 2 clutch for more power...Copper?
- T56 Slave/Master fitting
- Best price to buy a Spec 3 clutch?
- TH350 conversion
- t56 input shaft gear tooth count differences?
- 4.10's worth it in an A4???
- 1997 Camaro Posi unit Help please.
- t-56 swap question
- Noob Stall Converter Question
- 500+ hp 6speeds.
- Rear End Help 97 Z28
- trans question
- stock '94 forumla rear end?
- Finally getting 3.73's!!!!!!
- 4th gen rear into a 3rd gen?
- symptoms of bad clutch
- Posi may be dying, cheap options?
- Who makes blue torque converters
- keep the auto, or switch to m6
- Question about gears
- Driveshaft length with Moser 12-bolt
- part # for arp flywheel bolts?
- 94' Rear-end re-build, am i missing anything?
- Where can I get 4.11 gears for 10 bolt?
- Impressions of the Yank SS4000
- Question on TCI 2400-2800 converter
- did any 93-97 z28's come with hurst shifter?
- posi Carrier Help
- 9 Inch posi type?
- to all lss owners
- Posi Carrier and gear Help please
- Autozone clutch question
- 4.10's Installed Yourself Come inside?
- 4.10 in an A4
- another dumb ? 200mph???
- Are My Gears Gone?
- Clutch Job Pictures - Need Advice
- What's the best way to flush the rear end?
- Would a different TQ arm really help traction that much?
- Anyone using Ram Power Grip HD?
- Afew questions, TO bearing, gears...
- rear end clicking noises help!!
- ? 4L60E When does yours shift ?
- 93 Trans Shifting Problems Help?
- A4 what fluid?? B&m or RP or reg ???
- Shift points
- 4l60e stuck in reverse
- noise when turning, AGAIN
- shifting problem
- 4L60 ? Hollander interchange
- Trans Crossmember
- Is ford t5 tran the same as a chevy T5
- ordered an EATON, they sent me an AUBURN, did I get ripped off?
- need taking out carrier advice big time, please look
- 4l60e here we go again =/ ... 3rd gone
- 2.73 to 3.42?
- question about TH350 conversion
- T/A cover/Magnet Question....
- Tranny Probs
- should c-clips be loose
- 89 world class t5
- 2.73's to 3.73's
- B&M electronic Transmission kit.
- Gear Change Question
- diff between nonlock up and lockup
- 4l60e kicks hard from a stop... tranny mount?
- Vigilante Torque Converter
- Skip Shift
- Good Rebuild Kit Needed!
- Is my converter junk now??
- Does this pressure plate look bad?
- broke t-56 2nd time want to go auto
- Will 97 pump fit into a 95 4l60e
- 93 A4 problems starting off in 1st gear
- spec stage 5
- Need help finding the right LSD for my car!
- I need Backlash, and various other Rear-End SPECS
- gear swap
- S10 TQ convertor mod...
- ever hear of Mad Dog transmitions?
- MOSER Gears
- difference between m6 and a4 crossmember
- Average life on A4 tranny's on LT1's everyone w/experience post inside!
- anyone know thread size on stock t-5 shifter?
- Clicking noise coming from under console area......
- bushing / bearing in the tailshaft of T56?
- Clutch Problems
- is this a spec stage4 for lt1 ?
- U-joints, which one to change?
- TH350 Question
- How do I install trans cooler on 95 Camaro?
- driveshaft issue
- 3.73 or 4.11 for my 6 speed?
- A4 grinding noise while driving
- automatic to manual swap
- 700R4 Self rebuild
- Tranny Rebuild
- Torque Converter
- drivetrain loss question...
- Clutch Pedal Dropped to Floor
- Swapping Out Trannys to a T56 Questions.
- thickness of ring gear for a 3-series carrier?
