- making a 7.5" stronger
- guys with 8.8 rears in your car inside please
- free set of 3.42s or pay for 3.73
- My transmission is clunking?
- Axle Upgrade Required for 4.10s?
- 8.5" from a 96 S10...will it fit?
- Thinking of a lower gear ratio?
- How many teeth do our flywheels have?
- taking a leak
- Will my stock 10 bolt handle 500-600 horsepower??
- Brain Fart During Clutch Install..Quick response needed
- pilot bearing noise
- Spec stage 3&4 Pressure plates the same?
- Panhard Bar?
- Clutch problems NEED HELP!!!
- Highest Quality 3.73 Gear
- WTB 2 Series 3:73
- Clutch slave and master
- 3:42 or 3:73's??
- New valve for 4L60E from TCI
- Few ?s - Strange & Superior gears
- $900 LABOR to install Gears???
- t56 question, help please
- Poll!!! Swap my auto for a T56?
- I need Tranny Rebiuld Shops & Prices
- A4 to M5 (Auto to 5 Speed Manual)
- Trying to bleed the clutch..pedal just goes to the floor and stays...
- where to get ahold of Viper shift fork for my '95 T56
- 4L60E swap to th400
- 4-channel rear swap in 95 TA?
- converter tuning?
- 1310 to 1350 combination/conversion u-joint part numbers
- Really Hot T-56!
- Shifter For 4l60E
- Annoying!!!
- T56 to TH400 swap, need some help
- Rear Rotor Swap
- th 350 trouble!
- does anyone use a shift improver?
- Normal Transmission Temps?
- Reducing shift pressure
- what s the difference in a lt t56 and a ls t56
- HeAt!! too much of it!
- clutch problems
- 93 lt1 speedo recalibrator
- What gear brand is best???
- Rpms with 3500 stall
- Kickdown to 2nd at 100% TPS going 60mph
- 2.73's and a stall
- 200-4R install writeups?
- Weird Jolt
- Help me get my 4L60E out of my car!!!
- TCI pro super kit, opinions?
- TCI=bad
- Header Install, Tips Welcomed
- Slipping(?) 700R4
- Carrier stuck??
- How much would you pay for a Mustang 8.8 bolt in for your F-body?
- Making t56 stronger...
- 4L60E Convert to M5?
- 95 Z28 clutch & flywheel Q
- clutch bleeding technique
- Gears
- Installing new 12 bolt... couple ?'s
- Wierd Sound! :(! Sounds bad
- How do I pull the axles?
- rear and posi
- Need Help with Freshly Rebuilt A4!!!
- 1993 z28 gear change?? Speedo??
- Possible serious problem with tranny or rear end....need help
- Clutch chatters.... normal???
- First Gear Ratio????
- Axle Size??
- t-56 conversion wireing
- Question about unplugging torque converter ?
- tranny problems
- I think I put clutch in wrong.
- Converter confusion: higher STR or steeper gears?
- from 2.73's to 3.73's
- Dead Rear End?
- overdrive ratio in t5
- Gear/Stall--> Two part, Help
- 400 people inside please
- my rear end...
- Transmission leak
- Pinion Seal Leak
- Ok got new carrier and 3.42 gears for my 2.73 car..actual observations and opinons.
- Will this 2002 rear end work in my car?
- Removing Torque Arm.
- i hear a clunking noise when i make a complete stop
- Spohn Torque Arm problem
- can i use synthetic gear oil in my 2 series carrier?
- rear end gear ratio
- clutch adjustment
- when changing shift points what aim i looking for?
- T56 to non computer controlled auto tranny
- how much can it handle?
- Tranny may have went!! Need Help ASAP!!
- need to upgrade 4l60e for a FI setup...
- Question abotu Stock 10 bolt with 500-600 horsepower??
- where and what 4.11s to get?
- Those who have switched from 4l60e to 700r4
- strange 12 bolt questions
- My new Moser 12 bolt has alot of "play" ????
- Transmission Shift Cable
- 3RD Gen rearend-to a 4th Gen car
- Throw out bearing.. making noise.. ???
- quick question
- Universal joint for 9"
- What does gear whine sound like?
- T56 slave cylinder problem
- What's your pinion depth and backlash set at?
- Did I toast the trans and clutch or just the clutch?
- Manual lock up switch for Converter??
- stock 10 bolt vs.12 bolt
- cheepest place for gears?
- bad vibration at higher speeds
- tranny shifting hard, doesn't want to...
- 10 bolt risk and me?
- Stock LS1 Rear-End on LT1???
- BMR torque arm for a Moser 9"
- Need quick help. TCS rear in non TCS car.
- Drag racing torque convertor and tranny selecting
- Where and how do you adjust the master cylinder on a ST
- How much will gears knock off in the 1/4?
- vibration when rolling to stop
- 99'camaro engine swap V6 to V8
- Who has a Pro-Built 4L60E?
- Trans Fluid for a TH400
- new clutch?
- 373 gears seems to have sluggish acceleration when driving
- tranny prob
- Gear wine
- Rust on lsd
- Clutch Pedal Vibration and others
- Factory backlash specs for 94 Z ring gear?
- Anyone interested in trading a m6 for a4??
- Good driveshaft
- How do I stop flywheel from turning!
- What hardware needed to install a new driveshaft???
- Will my rear hold?
- should i get it?
- which tci converter will go well with my 373 gears
- 4.10 vs 3.73
- Vigilante TC Install???
- Used GM 3:73 gear install
- Can I save my tranny?
- Moser 12 Bolt
- gears install
- Transmission noise when standing still
- who has 373-4.10 gears that whine-how bad
- Bell housing grit and oil seapage? Is this normal at 85000km?
- A4 to M6 Conversion. Whats involved?
- i need help, iam having a hard time installing energy suspension torque arm bushing?
- 4l60e delayed shifts?
- Flywheel grinding?
- Any verts with these mods looking for some time slips.?
- Tranmission Trouble!!!
- oil leak ruining clutch...input shaft seal?
- TH350 speedo
- tranny help, po753 and brown, bubbly fluid
- Tranny mount???
- Will 8.2 gears fit 7.625 rears?
- Won't shift 2-3 at WOT
- want to convert
- looking for t56
- rear end axle play.......how much requires repairs?
- Shifter linkage?
- Moser 12 bolt cover gasket, where to get?
- Transmission shift is never consistant
- thoughts on locking up in the middle of 3rd gear ?
- Over drive wont engage.
- positraction
- Best rear end for 95 z28
- Clutch Issues???
- gears affect speedometer
- whats the best transmission mount to use for my 00 LS1 camaro?
- Polyurethane tranny mounts????
- Rear Differential Fluid - My Experience
- Gear or Convertor?
- Anyone else have this problem? Please Help!
- I know nothing about auto transmissions...is this any good?
- Gears
- Stall convertors on the Dyno
- a4 tranny fluid change????
- Best Place For Trans Rebuild in NJ
- New Gear Break In Question
- T5 Help
- Clutch Going?
- Stupid plastic cup for shifter part #?
- Torque convertor lockup
- Clutch pedal soft, What's the problem?
- gear or stall 1st?
- New Converter: Now Extreme Vibration.
- Differential Cover mods
- A-4 tranny problems
- Transmission problem.
- Transmission change ????????
- torque converter cover, yes/no?
- So my tranny blew......
- Re: obd1 high rpm issues...
- Tranny temp gauge
- help m6 tranny problem
- have a question about bringing my car to get a tune for my A4 trans
- can 342's go in a 2 series carrier?
- Strange rearend pricing and opinions
- Help me pick vig torque converter stall speed for my car
- Numbers on Stock Stall in 96 Z28
- Just installed my 3.42 gears in my 96 vert.
- got ls1 edit programmer installed today and still doesn't have 2nd downshift at wot
- A4 Having trouble going into gear. Need advice
- No first or third gear? please help!
- Engine brake kit
- Trying to decide on a stall converter.
- 4.11s?
- Will I need a tranny cooler?
- 4:11s
- Any one who has shipped a complete rear end...
- wich converter for my cam
- shifters for reverse pattern
- What does a 12bolt REALLY cost?
- will ls1 yank st3500 fit my lt1?
- Question about Tranny swap to th350
- Pops out of reverse....
- Need Clutch Advice
- How hard is your clutch pedal?
- New Tranny....Break in?
- 2.73s to 3.73s
- Rear End Weeping...
- Are 4.10's too much for my setup?
- Tranny is bad/What about the converter?
- 93 Tranny gearing
- Why did it do this
- Question about Short Shifters
- New gear issue, lil' input plz
- currie 9" with tru-trac problems????
- 94 T/a A4 -help- No Place For First Gear!
- T56 vs 4L60E dyno results
- Question about new lsd
- ASAP does the trans need to be unbolted to put clutch fork on?
- Ordered Moser.Now what do i need..(install)
- How does your Spec clutch drive?
- Transmission Crossmember: Auto's and manuals use same one?
- Spec 3, 4, or 5?
- tranny problem need help ASAP!!!!
- transgo manual kit
- Gear Vendors overdrive ?
- 4.33 or 4.56?
- Shifter Knob
- "Proper" way to drive...
