- is this a good product?????
- NEED HELP FAST (best combo)
- 4L60E line pressure specs i set
- Trans linkage off?
- tranny problem or what?
- Driveline Clunk.. Driveshaft?
- change 2 series to 3 series
- ----------------Strange gears ---------------
- gains with stall
- shifter console mod, a4 to m6
- removing tranny?
- Auto VS Manual clutches
- Bearing Races in Rear End
- Extremely quick A4 question...(need answer today)
- Got 250 bux. NEED TORQUE CONVERTER
- grinding in torque converter????
- need fast help about pilot bearing install
- electrical connector on top of 700r4 tranny
- So which gears do I have???
- Mcleod Street Twin vs. Spec Stage V
- how to tell if a tranny is slipping?
- clutch problem that has me stumped
- slippin' ???????
- 12 bolt moser HELP!!
- 4.11's
- Questions about gear installation
- Lost ALL gears in transmission
- how long from first rear end noises to rear end explosion?
- What can it be
- Overbuilding for Reliability
- small bolt pattern flexplate
- vss and turbo 350?
- Got the A4 out of my car, got Q about speed sensor...
- Replace pilot bushing?
- Best Shift Kit?
- Servo Questions
- tire size?
- No more Posi
- Gear slap?
- Moser is in...
- Is 3500 to high...
- aluminum driveshaft
- Only 1st and 3rd Gear
- Fluid Capacity of Stock Rear Axle?
- Kids, behave while I am away (or else)
- What should my Shift Points be?
- Re-build or buy a new one????
- high stall TC w\o head\cam
- Wierd Problem with my 4L60
- T56 conversion... need 12V switched power for !CAGS
- axle removal
- help. need LT1 4L60E valve body rebuild guide
- 4.10's and tire size PLEASE!!!!!
- Need input shaft seal help
- how to change axles on 01 SS
- th350
- clutch chatters badly, barely get car moving
- Tranny cooling line bolt size??
- SPEC stage 4 clutch slipping??????
- how many shift solenoids in the automatic
- Vibration, and nasty noise? Any thoughts?
- 3rd gen rear ends
- HELP!!! No OD, slipping 2nd
- Manual Shift Auto
- big trouble! clunking noise when I get on it....
- stall converters
- 4.10's and RPM's at the end of the 1/4
- Corvette torque converter...
- Need Help Now!
- Clutch slip?
- No gears in 700R4
- T56 Tube on Top of Trans?
- 4L60E Transmission Line Pressure Plug
- What is the minimum speed you should cruise in 6th gear?
- My rearend just got owned by my Street Twin... on stock tires???
- swapping from a a4 to a t56 in a ls1 car
- Bleeding clutch hydraulics. . .
- installed rear end..BIG PROB. PLZ HELP!!
- Howl after gear change
- Replaced tranny mount......now what?
- SOLID T-56 Tranny Mount ????????
- just changed my rear differential fluid
- loud whine from rear
- bellhousing stuck? what do to?
- A4 Bellhousing bolt sizes?
- 4L65 rebuilt kit
- slave cylinder rod hanging out??
- Gearbox Mystery!
- transmission magnets??
- tranny swap
- Is This Spec Clutch Right For Me?
- need responce asap
- Which Shifter?
- How does this sound for a stronger stock rear end?
- Feeling slow from a stop
- Driveability Issues... Need a resolution.
- Help with my 4L60E upgrade
- No OD after Transgo install? Anyone have this happen?
- Converter Comes Unlocked...
- 2800 stall with 2.73
- those with 9"ford in fourth gen in here
- Help me decide on rear.....
- worried about my transmition
- changing the throw out bearing? how hard/long?
- Need help
- Hurst Billet Plus shifter and question needing verification.
- clutch hydraulics ?
- Mind game or other 9" owners
- 4L60E Line Pressure question
- Tailshaft bushing on a 4L60E
- Shifting hard into 2nd gear
- want to put posi in my car
- Dealership re-calibrate speed-o?
- Slave Cylinder
- FYI---> Energy Suspension
- Stock Flywheel with SPEC Clutch
- rear end
- posi
- 8.5 in S10?
- OBD1..can I run a 3000+ stall?? Whats the odds
- what do you think?
- need info
- High Stall torque converter???
- Tranny probs still....i'm out of ideas....i'm gonna push my car in the river
- tranny slipping
- Problems with SLP Clutch PP Set
- Which tranny shop to go with????
- Hard to get out of 4th (M6)
- Torsen dif isn't getting power to both wheels
- quality of superior gears?
- Which ARP bolts for 4L60E converter
- slave cylinder rod stuck. need advise
- Gears
- For Knowlegable tranny builders/gurus only.
- Drilling Slave Cylinder
- Rear End Fluid
- what are the TQ specs for the LT1-T56 clutch bolts?
- scatter shield
- 2000 Z28 3.42 in a 96Z28
- T56 swap for a Cleveland.
- Clutch Hydraulics
- Who has taken out their poly trans, or torque arm mount because you didn't like it?
- Something you should know about SPEC
- Aluminum Driveshaft
- vig part number
- shift jump
- Trans-GO shift kit
- Rachet Shifter for 4th Gen. Z28
- Anyone know of any SPEC sales going on?
- Strange 12-bolt question
- A4 clunks into 2nd
- Need help getting car into neutral
- 383 flywheel???
- pros/cons 4.10 gears
- 12 bolt ??
- Clutch grabbing high up after not driving car for over 1 month
- rearend noise Please help
- went to track, now weird noise? help please!!
- Need trans help bad(T56)
- 4l60e swap to Manual tranny?
- Crush collar or solid spacer
- G E A R S..
- Spec stage 4 from lmperformance?
- Yet another humming F-Body!!
- 2800 stall already, upgrade to 3200 or 3400?
- BMR relocation bracket help.
- Viper guy here in need of help with his T-56!
- Finally came out of denial
- 4L60 weight
- Grind in 5th and 6th
- Is a pro shifted t-56 any different that a shift kitted auto?
- Need help with stall converter!!!!!
- deep screeching sounds?
- Corvette Servo in 700r
- Slave Cylinder pushrod bent??
- 4.10 gears.. any makes to avoid?
- stall? buying this friday
- Viper 6spd in an IROC
- transmission mount
- Bad throwout bearing? Ram clutch kit?
- Where to get a Tranny Cooler?
- 31 spline axles ok?
- ...Another 3.73/4.11 Question
- Is this true?
- New tranny or rebuild?
- Clutch Chatter Help
- rear end oil change how much do i need to put?
- help me with my trans build
- how big of a difference will i feel?
- HELP --> Very bad vibration with LT1 M6
- Slight Bumping/Poping under driver side floor board under load...
- 94 T/A, how many spline axles?
- "Genuine" Gears?
- T56 fluid capacity?
- What driveshaft do I have?
- Ring and Pinion Install Question
- Do i have a short shifter???
- Should I change my tranny fluid myself or get it flushed?
- Cheap converter for a 4L60E +N2O?
- What stock gears does my car have?
- Aftermarket shifter for 4l60e?
- Transmission shop in B'Ham, AL?
- Slight surge/jerk..
- HELP! Trans won't stay in park
- Installing Pilot bearing
- what clutch for 350RWHP &350RWTQ???
- F-Body Rear Ends
- Excessive rear end noise
- 8.8 ford conversion questions (in process)
- is this my bearing?
- 95 LT1, T56 makes noise when "unloaded"?
- Axle switched?
- did i buy the right shift kit
- Bad Engine or Tranny Mounts??
- terrible clunk need help please
- 3.73 or 4.11
- somethings not right!!!
- how do i bleed ls1 slave????
- installed posi. whats this nosie?
- Speedometer off with 4.10's???
- Anyone have a problem with driveshaft in a t-56 swap in a 3rd gen
- What the crap is wrong with my tranny?
- Beef up a 3rd gen rear end....?
- Bearings?
- 3.23 or 3.37 and also what else need to be done?
- Those with built trans or trans builders (A4s)
- broke my posi, considering welding differential for temp fix?
- street twin, throwout bearing shot in less then a year??
- 4.10 question
- Alum DS and U-Joints
- A4 Problem?
- my rear puked? help please
- Posi options for Moser 9"
- How to remove carrier assembly?
- tranny id, 94 vs. 95 ASAP
- torque converter hot?
- Ripped the yolk apart on my 10-bolt at the track!!
- 90-10 front springs for a 4th gen?
- buying a '00 z28, t-56. Trannie symptoms, please advise
- Clunking gone but worse vibration present
- What's the deal with getting the right stall conv.?
- Yellow wire going to A4
- 12 bolt from a 88 vetet?
- VSS problem
- torque for tranny pan bolts
- Torque Converter wiped out trany?
- Hanging onto 2nd gear at WOT
- 4L60E Weak Points
