- L98 + LS1 Driveshaft = BOOM
- Is my clutch going out, or is it something else.
- problems w/ clutch. need advice
- SLP LT4 PP & Mcleod Disc - who and $?
- Tranny went out (A4)
- SPEC clutch problems/questions after install
- What should I get? Please
- T56 output shaft seal
- new flywheel/master cylinder?
- rear pinion bearings wenbadt
- 98 auto tranny?
- TCC lock-up Issue solved?
- gears
- LT1 LS1 carrier differences
- Wires from TCC brake switch???
- TA gurdle worth it?
- Please help!
- What to get first
- t-350-400 guys help!
- Auzzy rear
- How to get the flywheel off!?
- Gears?
- rear diff noise? Need some advice
- Best Short Shifter?
- Trans/Bellhousing/PP/Flywheel torque specs?
- convert or just buy 6speed
- Should I get my billet flywheel resurfaced?
- rearend question
- Street Twin Rattles
- Stock Pcm top speed
- extension housing sealant?
- anyone ever use/using a powertrax unit?
- Please help me diagnose this problem.
- Is there an easy way?
- is my t56 shot
- Pilot bearing install HELP!!!
- Ring and Pinion install
- Traction Issues w/ gears and stall?
- B&M Shift improver kit
- automatic SS
- Got a PROBLEM!!!
- T56 Tailshaft Bushing? Where to get it?
- OBD conversion tranny fix?
- What is the measurements for our rearend? Want to build my own rearend, has anyone?
- Rev limiter on 2-3 shift
- 3000 stall issues
- 4L60E No engagement Help
- Good shifter for 700r4
- What stall is my converter?
- How far should the drive shaft be sticking out fromt he tailshaft?
- transco shift kit
- HELP installing tranny temp gauge
- Code 82 Solenoid A Fault
- Question on installing new clutch master cylinder...
- Do I really need a short throw?
- rebuilding m6 transmission
- Problems with my Transmission
- SLP Torque converter
- Clutch Question
- 4.10s Too Steep
- 2400-2600 converters
- 700R4 shifting options
- 3rd gen axle in a 4th gen?
- Shift points - 700R4
- clutch slipping
- Weird rear axle leak
- Spev Iv - Expected life?
- Horrible Sound Coming From Tranny/rear
- Spec Stage 3 install, now bad feelings! HELP!
- Anyone with this setup: Stock '95 Z28, 3.23 gears, rebuilt tranny with 2000 stall...
- Doing the T-56 switch, got questions
- Street Twin....sliping?
- vibration troubleshooting?
- how many spline on the axles?
- Can somebody tell me how to check the lash on gears?
- a4 plugs
- strange 12 bolt, fluid capacity
- Are the drivers/Pass axle shafts the same length?
- auto to manual
- A4....M6... What are the differences
- Th-400 Help
- fly wheel bolt size or part number
- clutch seems to stick, rpms rise until i press clutch pedal again
- Weird noise when going in REVERSE!!!
- ? for 4l60e rebuilder
- Can I siphon out my ATF from the dipstick tube?
- Removing T-56..@#$! BOLT!!
- tv cable broken?
- Cat Removal
- Looking for hardware...
- C-clip eliminator kit
- shift kit
- a4 to t56 conversion
- t-handle question
- clutch life
- How much for 3rd gear synchro replacement?
- tranny ????
- What the heck?
- clunk when car downshifts
- Need info on mounts
- Poll: T56 Fluid
- clutch pedal cylinder leaking
- New transmission, need help.
- How much play in a drive line?
- T56 Reverse question
- simple T56 conversion question
- 4L60E in 3rd gen?
- Too cold for the 4L60E?
- LS1 motor and tranny(A4) mounts
- need some help please
- Differential Problems
- have to push hard into 3rd gear
- Clutch help
- 4l60E trans from a Caprice into a Camaro ???? 11 pin VS 12 pin ??
- Wery high stall or?
- Tranny
- Need help on my transmission rebuild?
- 6spd with a 2.73 rear!! forget about 6th gear..
- how much does a 10 bolt weight?
- Auto to Manual Swap Question
- Just had my gears installed yesterday
- Hard shifting and No OD.
- master cylinder install....
- Shift Points
- Clutch Help
- Trans Problems
- Slave Cylinder problem
- Horrible sound from clutch
- LS1 Tranny Question
- turbo 350 speedo hook up?
- LS1 Tranny Help Needed
- new clutch still slipping
- Slave cylinder ? after street twin
- rear end ?
- torque converter questions
- In search for a good gear installer in MA
- Clutch fork messed up - bout to blow a fuse here
- Finally got a stall
- Come on guys quick help
- Driveshafts....
- please help
- Places to buy gears
- any ideas???
- missed a gear and now problems!
- Manual pedals question
- BMR now offers Trans K-member for 4L80E conversion!!
- th400 swap
- 4L60E to T-56 Conversion
- Best Clutch?????
- Short Throw Shifter
- SS needs clutch, what kind, easy install?
- Pinion seal install help
- Finally did it.......
- I have a question..Please Help.
- A4 to M6 swap
- Rear end fluid....
- Driveshaft vibes
- Transmission HELP!!!!!
- Corvette Servo firmness question
- Broke the damn slave off
- where to find rear axles for SS
- Noisy lockers?
- Disabling CAGS
- Axle Bearings!!! Please Help
- torq convertor
- th400 x members
- T-Brake brands?
- Whys my car such a dog woof woof
- 4.10 gear install
- Spec IV clutch review
- which shift kit/what are my options?
- What happened to my 3rd gear? (4l60E) Help!
- so i serviced my tranny today
- new slave cylinder goes out??
- Tranny Prob.
- Swaping rears?
- front steering box
- hard knock coming from tranny or drive shaft when accelerating. What is this???
- TH350 problem
- ram clutches
- My rear axle and diff is rusted.......look here
- What transmission cooler should I get for my '95 Z28 A4?
- tranny problems, please help
- WTF. Is this true?
- Moser owners
- 4L60E rebuild ?'s
- torque converter
- Trans-Go shift Kits
- Need tranny help in Dallas
- best 700r4 rebuild kits
- clutch question
- Will this tranny fit
- switching from a 97 4l60e to a 96 4l60e...
- th350 swap ?? where to get a core w/ 9"tail
- steering rack question
- Where to find oversized pinion bearing for setup?
- where to get a new tranny mount
- 4L60E a4 HELP need specialists PLEASE!!!
- Hayden brand transmission coolers any good?
- transmissions slips only in D, not in OD
- Liberty gearing for T56?
- Z06 clutch in LT1
- T56 Alternatives
- Moser 9" install problem...
- wierd noise???
- 4.10's or 3.73?
- Transmission conversion
- Slipping clutch! but for how much longer?
- 69 Camaro question
- what kind of gears
- Driveshaft balancing?
- "Breaking" a rear end
- Trans problems please help
- popping comming from somewhere under my car?
- What The ****ing ****!?!
- ls-1 t-56 in lt-1
- th400 tech?
- Driveshafts for TH-400?
- Torque Converter Lock-up problem...
- SPEC 3 info needed: lowest prices,where, and used one?
- tranny problems please help
- upping tranny line pressure vs. transgo SK
- installing clutch fork with tranny bolted up
- 4.10's and 10 bolt
- how to tell what gear I have?
- I hered a GRINGING NOISE. Now its CLACKING BAD in Rear END. NEED Help?
- what do i need to make a 700r4 work
- Ford 9" rearend switch???
- Whats the diff? SPEC Star Clutch and just spec clutch
- Rear and Trans oil
- Hot trans
- signals of broken tranny mount?
- Rattling noise from tranny?
- How much fluid is needed for tq conv. and shift kit install?
- How safe is a used set of gears?
- Didn't get the clutch fork engaged before bolting it all back up...
- Any 4th gens come W/OUT a damper on the drive shaft yoke?
- 4.10 owners 1/4 mile times.
- Weird problem with Slave cylinder...hose won't lock in
- How long will the A4 trans last?
- what series carrier is in a 2.73 rear end
- shift kit gurus....quick question on the one I just got?
- Dual tranny coolers?
- Who has wrecked tranny with hpp shift firmness.
- My last trans question for the day
- T56 Question.
- Driveshaft Vibrations?
- 12 Bolt or 9"
- Strange gears
