  1. tranny's slipping what to do...
  2. anyone familiar with the fast kit
  3. Is this my clutch??
  4. Spec Stage 2
  5. New Clutch and Flywheel
  6. 40-50 mph in D ?? a4
  7. Anyone with McLeod Single Disk and/or SLP Flywheel???
  8. 4L60E wont upshift past 2nd gear?
  9. Clutch and flywheel ?'s
  10. 99Z Rear End Rebuild Kit
  11. line pressure
  12. P1870 transmission code
  13. Need a 4L60-E, told only a '94 will work
  14. How scared of 10bolt? Price of 12bolt?
  15. can't get diff out. little help please
  16. 700 hp t56
  17. what are my gears options?
  18. 4L60E and EDGE Converter Problem
  19. if u put a detroit locker in a 10 bolt
  20. Stock 4L60E specs?
  21. dacco converters any good?
  22. Best stall for the money?
  23. vig converter same for 96 lt1 as ls1??
  24. trans is slipping
  25. 4l60E auto tranny
  26. mcleod kevlar/organic or street twin in my ls1??
  27. SPEC To Develop a Twin Disk?
  28. 2.73 to 3.73
  29. how to tell? Tranny slipping
  30. Spec Stage 3 hybrid is in
  31. Strongest drivetrain on a budget?
  32. turbo 350 band adjustment
  33. Drivetrain Question
  34. rebuild question
  35. No 3->4 shift
  36. Is This A Good Tranny?
  37. clutch, tranny and rear end questions
  38. 2.73's and 3500stall??
  39. Question about rear end "clunking"...
  40. Equivalent to MCLEOD TWIN w/ Alum. FlyWheel???Cheaper of course...
  41. What Gear Noise is Acceptable?
  42. how much worse will my gas mileage be goin from 3.23 to 3.73?
  43. what stall and brand would you recommend?
  44. Upgrading my Gears
  45. Will a 99 vette T56 work in my 95 TA if I use my bell housing?
  46. Differences between Mac and TA rearend covers?
  47. WOT line pressure drop
  48. spec clutches bad?
  49. shifter ?
  50. torque converter lockup at WOT??
  51. 12 bolt or 9"
  52. 2 different trans go kits???
  53. Writeup for DIY rear gear install?
  54. 3rd gear Syncro problem
  55. A4 4.10 owners inside please.
  56. Z06 clutch in 99Z hydraulics required?
  57. Blew up my limited slip, what are my options??
  58. clutch and gear ?
  59. (Wrong section I know) Need quick answer about bent CLUTCH fork
  60. Tranny wont downshift into 1st gear
  61. Did the 95 lt1 formula really come with a Australian rear end??
  62. steady "clunk clunk clunk" diff prob?
  63. Removing Strange 12-bolt axles
  64. Necessary tools for settup up rear gears?
  65. Hydraulics or Bad Clutch???
  66. person at pi says get 2800 stall? seems to low in my opinion
  67. does size matter
  68. what is the backlash for gm superior gears and how do you adjust it?
  69. How many trans mounts?
  70. Paging all converter owners
  71. SPEC II or III ??? 410hp/450lb ft..?????
  72. How to put posi in.... read!
  73. Put new SPec III clutch in.. Grabs but clunks when rolling??
  74. going from 3:23 to 3:73 on a A-4, any difference?
  75. Art Carr vs Pro Built, whos better
  76. A4 to M6 swap kits
  77. COPO Posi traction with 4.10 gears rear end - Does this exist?
  78. clutch return???
  79. 8.8 rearend
  80. How are aluminum flywheels fro street cars
  81. Quick Question
  82. cop camaros and their rear ends
  83. Identifying 4L60E
  84. Is the trans mount from pep boys just as good as the dealer (for a ls1)
  85. 12 bolt or 9" ford rear" pros and cons please
  86. Vibration Not driveshaft!!!!
  87. M6 sticks in 4th
  88. Rattling noise when clutch pedal is all the way down...
  89. Slave and Master cylinder for clutch
  90. Is this rear worth $400?
  91. Automatic Trans. Hits Rev Limiter Before Shifting
  92. What are the symptoms of air in the clutch lines?
  93. Problems with an A4 car after cam install
  94. New G2 Diff Cover, need help with installing please!
  95. Tranny Grinding/rubbing noise
  96. On my recent roadtrip I noticed something, is it a worn synchro? Please take a look..
  97. soild pinion spacer install
  98. how do i know where the shift points should be with 3.73 gears?
  99. Tranny go boom (M6)
  100. Lost all forward gears - Still have reverse. What broke? and don't say the tranny!
  101. LUK Clutch and Flywheel
  102. 1993 M6-Any problems?
  103. Absolute horrid, end of the world noise coming from drivetrain
  104. Tinny click sound in Tranny
  105. gears
  106. TC help from a roll?
  107. is transmission shot?
  108. Auburn carriers?
  109. throttle position and shifting
  110. How hard is it to convert to manual
  111. Rebuild or buy new T56 tranny
  112. driving an A4 manually in first
  113. new trany
  114. Adjusting B&M Megashifter in 3rd Gen
  115. Tranny cooler in! did I do it right?
  116. New Mcleod. Totally Hosed.
  117. Grinding?
  118. Upgrading my a4
  119. gears
  120. Breaking a 10 bolt? What happens
  121. Corvette Servo
  122. Is this normal?
  123. HELP! Vibration problem!
  124. What to look for when pulling diff cover?
  125. Info please
  126. Rear end shaking on downshift!
  127. My auto is P-R-N-OD-D-2-1 ?
  128. transmission?
  129. Manually Shifting an auto?
  130. Not impressed with the Pro 5.0
  131. gear choices
  132. Broke a ring gear - are my gears trash now?
  133. No Overdrive
  134. LT4 clutch ok into LT1 motor?
  135. Clutch toast?
  136. What's my rear gear?
  137. What's up with my LSD?
  138. help m6 tanny making noise
  139. stay with the 4l60e or move on to another type of tranny?
  140. Converters too loose, Can I kick it into 4th gear down the 1/4?
  141. p/n on GM 4.10 gears for 3 series carrier?
  142. Clutch fork instal woes
  143. stall converter question
  144. Tranny swap guide?
  145. Help me Pick a clutch, Cant decide!!
  146. tranny temp with stall
  147. What are the symptoms of a bad throwout bearing???
  148. clutch install
  149. Before I ****ing spend all this money on a rebuild kit...
  150. Want to use a 3 series rear in a 4 series car?
  151. will my rear end hold?
  152. 2 series carrier
  153. Grrrr...TC or Gears?
  154. any reason NOT to go with a 8" converter
  155. how much HP will a stock t-56 hold?
  156. Need advice... balance steel d/s, or go aluminum?
  157. Driveshaft: Aluminum or Steel?
  158. 4L80E into '97 F-body..who's done it?!
  159. Anyone replaced a pinion seal in thier Moser 12 B?
  160. Cleaning clutch disc?
  161. clutch install
  162. 93 t56 swap couple questions
  163. slave cylinder woes
  164. how to mount rear sway bar to moser axel ?
  165. Gears or Torque Converter
  166. Thumping noise on acceleration
  167. 99z Rear End
  168. How hard to drop a 4L60-E tranny?
  169. drivetrain
  170. Where to get new driveshafts?
  171. good or bad thoughts on a 8" 3200 converter on a bolt on LT1
  172. Vig3200 is in
  173. M6 swap: floor hole location
  174. What years had 700r4
  175. Which year cars had 700r4
  176. vig ?????????
  177. bmr tunal brace
  178. torque arm
  179. Moser 9" questions
  180. stock rear end
  181. Centerforce Clutch???????
  182. Shifter install - shifter out, saw some trans fluid down there, how much is normal?
  183. Ok to use compliant oils from NAPA for drivetrain parts?
  184. 4:10 gear diffrence
  185. tci converter wont bolt up to flexplate
  186. Stall speed and lock-up via PCM
  187. Downshifting from OD or bad converter? HELP
  188. Tranny cooler and TV cable reset?
  189. tci torque converter ?
  190. 3 series gears in 2 series carrier??
  191. M6 - bucking at low speed - normal?
  192. Need Help Trans-go install gone bad
  193. Trans go install need help
  194. How do you guys feel about TCI tranny's
  195. Does the tailshaft have to come out to put my speedo gears in?
  196. moser 9 inch install...what will i need
  197. stall and daily driving?
  198. 4 channel ABS
  199. Want in a TC causes min. rpm drop between gears
  200. Tranny Rebuild???
  201. Can somebody tell me...
  202. HELP/McLeod Street twin engagement issues
  203. Tranny Problems
  204. 4L60E Question?
  205. Issues with freshly installed SLP PP & McLeod single disc clutch
  206. spec stage 4..carbon/kevlar or ceramic?
  207. If the transmission shop tells me I'll need to replace the electronics in my 4L60E
  208. Need a 3.73 2-Series Gear
  209. Clutch problems after cam install...
  210. How much HP can the 02' stock rear end handle?
  211. quick ?: How much will it cost?
  212. Problem with Ram Clutch
  213. trans question
  214. Would you do this with your rear end?
  215. Strange Chrome-moly driveshafts ?
  216. Were is that thread on OBD1 highstall fix. (the shift cable adjustment one)
  217. All 9" rear users question
  218. All 9" rear users inside please
  219. Tranny time....AGAIN
  220. I have a question about my moser with 4.10s?
  221. Tranny Problems
  222. STUCK!!Having trouble after street twin install
  223. Trying to Verify gear ratio on a LS1
  224. Can a sturdy 10 bolt be built?
  225. when do i need an adjustable slave cylinder
  226. Revised T56 Slave/Master Cylinder.
  227. Need Ls1 Transmission Mount part number
  228. leaky pinion seal & gear change
  229. Beefing up 10-bolt
  230. TH-400 into LT1 car swap
  231. Pinion Install ?
  232. ID this sound please!
  233. my rear is crooked...
  234. Helpful tip for clutch install
  235. 12 Bolt questions, Moser or Strange?
  236. Tranny question in my 96 z28.
  237. Driveshaft length
  238. Z95M6 sent you pm
  239. Street Twin question
  240. Very bad Vibrations
  241. Good Set-up?
  242. Towing question
  243. Burnt/Blown tranny?
  244. Chromoly, Steel, Aluminum Driveshafts??
  245. Help 95 no 3-4 upshift
  246. Normal 2001 A4 Shifting?
  247. tranny slips shifting to 2nd
  248. stupid oil question
  249. Need help with transmission problem
  250. Need help with transmission problem
