- 4:56 gears in my 94 camaro 6 speed??
- 3.90 gear in a stock rear end?
- 3.90 gear with stock rearend
- Rear Clunking???
- trans noise
- Five speed is dripping...
- Help please, big bang(s)!
- 3.73 install myself?
- Shifting Issue
- 8.5 10 bolt anyone done it?
- Question about my tires
- Automatic to Manual :)
- Am i downshifting too hard???
- I need opinions on where to go....diff is gone
- will a zo6 tranny swap into a 00 TA
- Is it hard to rebuild a T-56??
- Odd sounds have me a bit worried...
- Lokar 700r4 Dipstick install help
- Where can i get a rebuild kit for my posi?
- how much power can the stock rear end take!
- TA Girdle ... Studs or dont bother?
- tranny tube part number
- A4 won't go into park
- Input shaft questions???????
- Differential fluid change
- Those of you with the big cams on the stock converters
- 4:10 GEAR guys...Are you using stock steel Drive shaft?
- New flywheel + new clutch = grinding noise
- Proform Universal Pinion Depth Setting Tool HELP!!
- $ 950.00 to rebuilt tranny ,is it a good price?
- 3rd gen rear in a 4th gen??
- T56 is making noise
- Is this the input shaft bearing or throw out bearing?
- Adjusting Hurst Shifter?
- What did you gain at the track with your Vigilante converter?
- Should I worry about breaking my 10 bolt?
- Got my vig 3200 in today
- Need help!!! T56 questions
- This clutch any good?
- stock driveshaft and 12 bolt
- will it hold up ??
- finally nice to have it fixed!!!
- When does the M6 need a rebuild? with motor rebuild?
- Replacing Clutch....Need recommendations
- Time for a Stall Converter...which one though?
- A4->M6 Swap Complete!!
- Post M6 Swap Issues.
- T56 rebuilder's guide????
- Guys with th400 w/ reverse manual valve body
- T-56 Troubles
- Does the Ratech Install kit come with the chalk?
- just got tranny done, now key is stuck
- Posi rear end??
- Motive 4.11 Gears
- pressure plate torque specs
- How much to switch to 3 series carrier?
- Gears affecting my times?
- 12 bolt or 9 Inch?
- TC or not?
- another tranny fluid question
- rear end question
- to stay auto or go manual? that is the ?
- proper shifting
- R+I Borg T56 in 2001 SS M6...
- Rear End Swap
- 4.10s - motive or strange??
- A4 shift problem
- LS1 alum driveshaft u-joints?
- Need opinions on rear strengthening
- Short Shifters
- Neutral Safety Switch part number?
- Mcleod street twin question
- Transdoctor.com has a few answers for those with?
- Preload on gears..
- T56 conversion??
- Abs Sensor
- which torque converter??? help!!
- lt1 auto transmission/good or bad?
- Sigh....trans problems.
- big block + t-56
- transmission
- New gears whine only part of the time.
- auto trans question?
- Got a t56/A4 swap Question!
- east coast trans guy?
- fed up with t-56 problems - experts please help
- Trannys Talkin ?????
- My differential cover is leaking a little. Do I have to replace the gasket?
- Synthetic Gear Fluid
- How to change differential fluid?
- I think my transmission is going out
- Beefing up a 4L60E?
- How much did you pay for your Torque Converter?
- How many people have been lucky enough to bolt on their street twin with no balancing
- How do I know if I have a 4l60e transmission
- Tranny seemed dead, sat all winter, now runs fine??
- whats the width of a 96 camaro rear end??
- Push in the clutch, get a grinding noise
- Mod to get 1st gear and does manually shifting the my 460 hurt it?
- McLeod street twin install ?????
- Installed Pro 5.0 Shifter...
- Lt1 Tranny
- urgent easy question, 12 bolt fluid fill??
- What is this part for in Street twin clutch
- Spohn Torque Arm Q's
- Soft Loc PP and Iron disk clutch is alive and kicking
- RKSport CAGS Skip Shift kit
- ABS and 9inch
- grinding noise or vibration from tranny!
- how much noise is my stock rear end supose to have?
- Shifter came loose, did I do any damage?
- putting in clutch and driveshaft
- Can my car's 10 bolt handle 4:10's??
- LSD ?'s
- To lockup or not
- Need a new POSI!! Help!!
- 4l60 downshifting ???
- CC306 4.10's 4L60E ,4.10's too much?
- 3.73, 4.10 or other gear ratio???
- I think my rearend is shot??
- one rear wheel is out more then the other...
- Upgrading read axle to a 3.73 posi...
- Will a 93z rear fit into my 94z
- 12-Bolt question
- Actual parts cost for rebuilding a '95 4L60-E?
- Clutch/Rearend help
- torque arm ?
- bad u-joint(s)???
- What is needed to correct the speedo on a 93 Formula?
- new tranny in, now problems, HELLPPP!
- How much to replace transmission front seal?
- Who has painted their rear end?
- TC lockup issues...?
- T-56 Disassembly question
- Is there a gasket for trans pan?
- tranny cooler?
- auto tranny "kick shift"
- what converter?
- tranney problems
- Notice a change in gas mileage after TC?
- ExtremeChassis Ford 8.8" rear end
- For those who got a 2.73 and converted to 3.73 gears
- Gear change?
- rear end clunking?
- Feels like i'm ridin the clutch...wait i have an a4
- Royal Purple syn trans oil??
- need help ASAP - what's the best way to drop the tranny pan in a 4L60??
- 4:10's are in...speedo question
- A4 to T-56 Conversion
- Art Carr race 700r4 problems - 1st is gone, suspected reverse sprag?
- Weight diff. between aluminum and steel flywheel ?
- Can't get car in reverse!
- Rearend ?
- Pro-Built 4L60E Rebuild Kit?
- Does anyone actually like their 2.73s???
- Moser vs Strange
- Clutch dilema: Do different SPEC "stages" use same PP? :(
- driveshaft noise? need balanced?
- Bang for Buck convertor?
- 3.42 or 3.73
- What gears do I have?
- Lugnut Question
- what differential fluid?
- The hughes GM30 (3000 stall) converter for three speeds?
- anybody go from 3.42 to 4.10's????
- have a question about getting gears installed on my Ls1 camaro
- m6 input shaft seal did a search but.....
- what size converter do i need
- Changing gears
- Best place to get a used tranny??
- Tranny opinion
- 4l60e: QUICK QUESTION............
- 12 bolt install
- What Years Did car did this come in?
- Jarrod's Short Stick
- Not the normal "grinding" post
- Lakewood U-Joints Part Number
- Driveshaft help!
- what clutch to get
- Stall T/c
- Where did my hard shifts go?
- rear end swap
- Anyone using the GMPP transmission controller?
- strange 12 bolt, lots of drivetrain loss??
- Pro-Built Automatics
- what does lock-up converter mean?
- Whine in stock differential
- 4.10's in A4
- Transmission Cooler
- Bent shift forks/time for new shifter?
- 93Z Tranny/TV cable question. Maybe related to 52mm throttle Body
- Stang 8.8 in 4th gen
- shaking at 100+mph
- 12 bolt question, different than most...
- Bad tranny or computer?
- Stage 5 spec
- Lost all forward gears/ still have reverse???
- Spec stage III need to go on a certain way?
- Will my rearend hold?
- car stroke btw 1st and 2nd
- Does the stock y-pipe come off when doing convertor?
- TH400 Inspection cover bolts
- Rear end thunk concerns
- Gotta buy a clutch...
- 12 bolt owners inside
- Recomendation on where to get Moser12?
- What is a good way to make my 10-bolt stronger?
- Backlash range recommendations ???
- How often to change rearend fluid?
- McLeod single disc with SLP pressure plate - Qs inside
- 12 bolt vs 9 inch
- Big HP - A4 or M6?
- tranny?
- which ATF?? syn or dino??
- Rear end oil? syn or dino??
- hard 1st-2nd shift, then 2nd start!???
- Moser Questions(D.S)
- Sound like a vehicle speed sensor?
- Not your typical "need clutch advice" thread...help me decide...
- Not your typical "need clutch advice" thread...please help decide.
- clutch slipping ??? Or pressure plate weak ?
- 12s with 2.73????
- 4.11 gear?
- Tranny cooler size?
- Rebuild 700R4
- new slp ctuch slipping, replace or fix?
- 1978 Trans-Am 10 Bolt Factory pinion depth
- will my stock rear end handle 3.73
- Crusing Engine RPM with 3.42 and 3.73
- HELP PLLEASE! rear end clunk- U-joints?
- converter lock up
- Spec Stage 4 Review
- odd gear install question?
- which transmission to upgrade from stock 4l60e?
- Tractech Differential?
- rear motor seal
- which converter for my setup
- gear brand choice
- What tranny fluid to use in T-56 trans?
- performance
- Clutch questions
- Too much tranny fluid cause grinding??
- Need Info/Advice on 1st Gen Conversion from Auto to Manual
- 4l60e 2nd gear start
- Removing a '95 4L60E?
- shifter accidentally went into reverse from 3rd on my A4 60E
- Help!!!
- Vacuum modulator conversion for 4L60E
