- 4L60e aftermarket rebuild kits
- ...Rapid acceleration......
- Don't flame me but need clutch advice
- flywheel ridge
- proper shifting with a 4.10...
- spec stage II
- Clutch vibration/grinding
- flywheel HELP!!!
- T/A rearend cover question
- my TA wont go into FOURTH! any tips?
- Messed up E-brake during shifter install...
- Last bolt on transmission
- Axle snapped, cant get peice out...
- Clutch
- transmission question?
- Rear Diff interchange
- Performance 4L60E rebuild kits
- Any real world difference at the track Th400 vs. Th350
- Manually shifting the 4L60E?
- grinding noise? Tranny or Clutch?
- Width of Stange 12 bolt?
- Ram clutch
- help me find out my rearend question
- Dual friction?
- Would this converter allow me room to grow?
- B&M Hammer Installaion Question
- 94z tranny questions
- 4L60E or TH400
- Wheel stud removal
- Detailed instructions on converting a LT1 T-56 to a SFI bellhousing
- Axle hub
- reliability of the 4l60e
- what to do next
- Clutch fluid
- Differential rebuild question
- Stock Clutch hold 350rwhp?
- Ok gearheads some info please
- rear differential exploded during a dealer test drive
- rear end hp
- whats the best tranny route??
- Sounds like my Clutch needs WD40?
- Driveshafts
- transmission fluid
- Transmission removal troubles
- LS1 drive shaft?
- Unplugging lock up(Can't find harness)
- bellhousing????????
- transmission sensors ??? where to go
- SS wheels not going on correctly
- which shift kit?
- where to mount aux. tranny cooler
- Problems After installing Mcleod Clutch
- My tranny has about 65K on it, should change the fluid? And what should I use?
- Need to beef up my rear end without getting new one
- Got my car back from shop after spec clutch (stage 3) got a few ques...is this normal
- Powertrax lock-right?
- TH350 shifting issues
- People with 2.73's..what RPM @ 60mph in D
- HELP...Need part #
- Programming for my Art Carr 4L60E
- Rear end noise
- clutch link
- aluminum flywheel balancing question????
- Need price on stock flywheel(asap)
- cheapest place to buy SPEC stage 4?
- heres some help for people doing a t56 swap
- Weird vibration
- Do i need to tune pcm for new converter?
- strange feeling clutch pedal, what can cause this
- Need help bleeding hydralic clutch
- Clutch reservoir line all full of holes... how to replace?
- Posi install gone bad!
- funny noise in clutch/tranny when downshiftin-help!!
- Slipping in Automatic question
- Mcleod rebuild
- Limited slip not working?
- Popping Sound
- best trans for drag car?
- Should I flush my 98 T56? Advice plz
- How long will it last????
- built 4l60e or th400
- clutch "clunk"
- 4:10 Gears is it worth it ??
- Cheapest Place for Axels?
- Limits of LPE driveshaft
- Whats the best/cheapest trans. cooler?
- need a new 4l60e
- Wrong Fluid in my TH400
- T56 noise (pics inside)
- Drive Shaft doesnt want to come off!
- What about 4:56 gears
- Yup. You guessed it. ANOTHER Rear end noise.
- Have questions about stock flywheel.
- how many quarts in a 12 bolt
- 28 or 31 spline for 8.8 conversion.
- 4.10s vs 3.73s M6(pros and cons)
- B&M Deep Transmission pan?
- How do you drain and refill the T56?
- Tranny installed, couple Q's
- Where does the speedo gears go?
- New Moser axle... NEED ANSWERS!
- 1985 iroc z28 tranny identification
- Stock clutch questions
- ...pinion seal and bad bearings...
- 4l60E 3rd gear slips (or fourth, not sure) when at WOT
- Pro 5.0
- How hard is it to remove TH350 valve body?
- TH400 swap cost?
- Good clutch that doesnt chatter? Z06 in an LT1?
- West Coast Converter's?
- MOSER- EATON - CLUTCH NOISE? help
- Torque Converters?
- tranny
- 4l60e
- New Spec Hybrid Clutch
- Tranny Install/please help
- Squeek from clutch fork pivot point
- clutch install
- rear sway bar hittin rear end?
- race prepped 4L60E
- TC help!
- Tranny Cooler
- M6 to A4/ Swap ?s
- Are new Master/Slave assemblies pre-bled?
- What will I notice going from 3.73's to 3.42's?
- rear end
- cannot get M^ on after trying for three days, need help
- Limits of a stock A4
- Big converter in a 94Z ?
- Drag racing with a TC question.
- LS1 clutch disks work in LT1's
- Whats that noise?
- Rear axle
- What the??? TC's increase hp too?
- What should my first Mod be?
- used 4l60e, how to flush radiator
- Clutch or Coolant?
- Tranny Fluid in Exhaust
- Clucth problems
- general T56 swap question
- camaro rear end
- flywheel
- Pulled the Pan on my Th400 w/in
- They sent me the wrong Gears
- Well the trans needs a rebuild.
- Will this clutch hold up
- B&M 4L60E Deep Trans Pan
- 4l60e or 700r4 ??
- 17" et streets
- tranny doesn't want to kick down
- do i need a aftermarket flywheel
- how much for a used 4l60e?
- tranny lines
- Won't shift into 3rd at WOT
- torque converter for daily driving???
- tell me why i need a torque converter
- Need advice on tranny choice
- tci converter
- will a 700r4 off of a 305 tpi bolt up to a lt1?
- Moser 12 bolt or Moser 9 inch???
- rear end clank
- Clutch pedal switch mounting clip?
- Shifter knob removal on my ls1
- How Necessary is Power Steering?
- T56 Swap Kit For LT1
- clutch problem?
- LT1 Dave Tranny
- 4l65e
- 4:56 or 4:11 gears
- Which shift kit?
- torsen take out diff?
- M6 to 700r4 Swap Help
- dreaded 4l60e
- Torque Converter:
- Spools
- Manual shifting an auto
- how much tranny fluid into stock tranny?
- Gas Milage with 2800 Stall
- stock tranny?
- Transmission problems
- 1st and R giving me troubles
- PCM tuning after TC install
- Need new brakes and rotors, suggestions...
- 2800 or 3200 Vigilante? Opinions PLEASE
- Adjustable Clutch Master cylinder thingy.
- cheap 9"
- Clutch engaging earlier now?
- How do you know when its time for a new clutch/gears?
- TC problem???
- yes centerforce will hole 500rwhp PROOF
- Are V6 pedals the same as V8 pedals?
- Auto to 6-Speed swap ???
- car won't stay in reverse
- Limited slip additive?
- Transmission Cooler!!!!!
- Is my next mod going to be a rear end?
- Stock gears in a 98z?
- converter ?
- 2.73's vs. 3.42's or Bigger
- Clutch fork problems, can I get some help?
- drag radials
- C5 Z06 trans question, will it bolt up to LS1???
- one wheel peel
- Torque Converter Issues* Please read*
- ram clutches
- Started T56 swap today!
- Overdrive engagement problems
- Drained and filled my rear end with 80/90 do I need an additive??
- What's it like having a stall without a shift-kit?
- 1st Gear in Auto
- pinion shims and bearing
- 4L60E transmission line fitting
- Rear End Popping
- Which route should I go? Help me decide!
- 3 And 4 Series Carrier?
- switching from 26 to 28 axles
- rear end additive?
- Any tips for torque converter install | 3rd gen
- How much would it cost A4-M6
- 12 Bolt: Whats a reluctor ring?
- rearend noises
- 4l60e high wot shift points
- Fidanza flywheel needs balancing?
- Which will go out first.
- TH350 speedometer fix?
- just got my strange 12 bolt today, questions??
- What causes a 4L60-E to slip?
- Would a 4L80E fit in a '95 Z28?
- Rebuilt 4L60E slipping after 800 Miles!!!
- Rear Diff. ??
- hows this sound for a 4l60e?
- Best trans cooler for '95 LT1?
- 94 4L60E Problems
- Question to those with automatic's (700R4) important.
- Little grind while rowing into 2nd gear.
- Rear end poppin
- 3.73's or converter, or both?
- 2.73s or 3.23s for a th350?
- OBD1 Highest Stall Converter?
- what is this bolt for on a 12 bolt, pic inside
- Is this my carrier?
- Limited Slip (posi)??
- rear end loose or tight???
- Rear end blew up
- Just broke the 10 bolt
- 323 vs 373
- SPEC Stage III Clutch users here
- 4th geners: 'Da Rear Go Boom
