Advanced Tech
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17
  1. The infamous obd1/high stall converter problem
  2. Define EGR and it's effects
  3. Benefits & Disadvantages of various temp thermostats on engine performance
  4. Took apart T-56...made a mess
  5. Arao 4-Valve Heads
  6. Fuel flow vs. HP
  7. Multiple Fuel Pumps (Injuneer please comment)
  8. Working on the Opti solution.
  9. 16v conversion (usually race only)
  10. Where to get a custom ring and pinion set?
  11. Those with ported heads, enter hear.
  12. Can anyone make a 4L60E live?
  13. What's do you think about David Vizard's 90's head porting book???
  14. Smaller TB....more power?
  15. Big valves, small bores, and a lot of boost....
  16. Cast 383 Crank experiences? - Good and Bad please....
  17. LT1 Intake Manifold Flow
  18. Yo.......
  19. LT1 Victor Jr. heads
  20. intake/exhaust flow % question
  21. calculating overlap?
  22. stroker question
  23. Opti Question
  24. New here and really in the woods with Flywheels..
  25. Factory OBD1 PCM limits (again)
  26. Is David Vizard on target for LT1 Heads?
  27. Removal of abs system
  28. cementing bottom 1/2 of block???
  29. Calculating CFM Question (NOT GENERIC)
  30. Problems with running a carb and opti
  31. Engine block question
  32. Trans Break
  33. Non lockup converter question
  34. BOOST/NOS/COMPRESSION
  35. Tuning help, track times fell off..
  36. Need help on telling what wires are what on a o2 sensor quickly!!!
  37. Tremec T-56 versions
  38. Air pressure and air intake location
  39. MTI b1 cam shaft? Cam Newb here help plz
  40. Max power on GM lt1 head gaskets?
  41. power lose
  42. 2piece crank to 1 piece crank conversion??
  43. 6.0 liter Camaro 1994
  44. 91 TPI 350 TRANSPLANTED INTO A FIRST GENERATION
  45. Rearend Help.
  46. Getting oil out of pressure plate
  47. PLEASE HELP - questions on 383 stroker
  48. billet cams and the oil pump drive gear compatible?
  49. Trans experts please help!
  50. ASR Delete - Anyone???
  51. Custóm aluminium flywheel ...Where
  52. Limits of stock block
  53. Need some not-so-typical Opti help
  54. 383 stroker?
  55. Hopefully a solution to the LOUSY LT4 Intake air distrbution!!!!
  56. How much is to much? cam and 383 w/ Vortecs
  57. EGT Question
  58. help have a gremlin in my camaro,ses light and 02 sensors
  59. Oil pressure problem after cam install
  60. A3/stock DS users
  61. How to make a skip-shift eliminator for 99 SS
  62. What would cause an intake manifold to blow off the engine
  63. LT1 mods
  64. Spun bearings, is block still good?
  65. Tuning the F.A.S.T. ECU for NOS...Need Highly Technical help!!!!
  66. Cam Heads and Springs Question
  67. T56 to TH400 Swap
  68. Gear drive and Opti?
  69. Cut through the BS..are max effort LT4 heads worth it over lt1s?
  70. **Paging Injuneer 94FormM6**
  71. Blower cam on a NA car?
  72. crankshaft hubs
  73. Need some help on tuning the f.a.s.t system
  74. v6 to carberated v8
  75. pistons
  76. anyone rebuilding a T-56?
  77. long-tube headers - heated O2 sensor?
  78. Knock sensor bypassed, why is knock retard still present?
  79. cam selection help for upper end lt4 and bottom end 383 stroker?
  80. over 5000 rpm miss
  81. this board
  82. ZZ430 BUILD-UP VIBRATION!!!!
  83. ANYBODY HAVE A PICTURE OF A STOCK Y pipe for a 1997 Z28?
  84. I need help with building a 355, AND I PLAN ON GOING REAL FAST!!!!!!
  85. How to wire alternator with Painless Wiring kit?
  86. keyed hubs ???
  87. Gears/T/C selection question
  88. deck height make a power difference?
  89. Eagle 4340 one peice crank
  90. no power to ecu
  91. ATTN: rskrause and Injuneer
  92. LT1 + T56 and 9 second s ?????
  93. chevy 383 stroker - please help
  94. Engine knock... HELP
  95. Mystery injectors???
  96. Need Fuel System help !!!!!
  97. question :)
  98. big cams, big tubes, adn knock sensors????
  99. Flow test on my Injectors.. Can anyone tell me what these numbers mean? Feul Experts!
  100. started 383 stroker......
  101. Can Rod Clearance be TOO much?
  102. L-98 stroker kit, can I use it on an LT!?
  103. thermostat question
  104. Stroked and Blown???
  105. Strange issue... (long)
  106. TRANNY?
  107. Can someone explain the differences of Solid roller, and hydraulic motors for me????
  108. Need help with ATI Balancer ASAP !!
  109. Air conditioning Questions?
  110. Piston ring gap, (2nd ring gap larger?)
  111. Why are the exhaust ports "siamesed"?
  112. Rod/ Stroke Ratio
  113. 383 upgrade
  114. Intake port roof slanted?
  115. I Need help installing ASP Crank & Alt Pullies!!!
  116. Stock valve covers leaking on AFR 210's, help ASAP!
  117. Noise coming from intake valve #3
  118. Please help me diagnois trans problem!
  119. 700R4/4L60 tranny problem
  120. Strange 12 Bolt problem, maybe
  121. 391stroker, is this insane?
  122. Converting Gen 1 heads to work with Gen 2 Block
  123. What kind of engine is this?? need help
  124. Combustion chamber size after milling .020"?
  125. Valve seat test....
  126. CFM
  127. logrythm for purging evap
  128. Anybody make their own Racegas?
  129. Computer simulated dyno comparison (kinda long)
  130. Big Problem, no one knows...
  131. Questions about the 383 NEED HELP
  132. How hard is it to fit a 4" stroke into an LT1 block?
  133. went over pot hole,,now no power windows or radio???
  134. Recommended valve sprgs for Comp306 roller?
  135. are there any aftermarket LT1 blocks?
  136. oiling issue (lifters)
  137. Timing issues on a 383
  138. T/C question
  139. problem found, but what caused it???
  140. Hows my car?
  141. Help!! 355 in my 90 mustang coupe.
  142. new gm 383 crank
  143. CUT OUT!! HELP ASAP
  144. Anyone convert a carb intake to EFI and done it THEMSELVES?
  145. Rearend and Ring and Pinion
  146. PC to ALDL question, ie. programming with a homeade PC-ALDL cable
  147. 86 Berlinetta v-6 stick to 305 auto turbo350 ...not shifting right.....
  148. What about the 7.4......
  149. Building a pretty wild stroker... opinions needed
  150. Need help getting my 396 to idle good
  151. A4 - T56 tranny swap. HELP!!!
  152. Converting to a crank triggered ignition
  153. Need help finding Correct Pushrods
  154. HELP PLEASE Who would have MSD Injectors Part# 2013 in stock??
  155. 2 series ?'s
  156. Lets Talk Exhaust for Max power
  157. Gen II heads on a Gen I block
  158. Help with heads and cam for 383
  159. Shift forks on a (LT1) T56?
  160. looking into stroker motor
  161. Cowl and hood clearance with the Hogan intakes?
  162. Who's running the Hydra-Rev kit?
  163. help !!!!!!! 306cam install
  164. SB2 heads/intake on a standard SBC??
  165. Dynamic CR and Supercharging
  166. 99 Corvette LS1 swap into 95 Z28
  167. Do Lt4 valve covers require clearencing for roller rockers on a 396?
  168. Intake Manifold difference question???
  169. Anyone running a 284 NitrousHP cam?
  170. Hogan intake utilization
  171. pushrod ? about an olds motor
  172. differential, torque, limited-slip question
  173. Is it possible to run SD with a 94-95 computer?
  174. Swaping from Speed Density to Mass Air.
  175. Turbo 350 Install
  176. 383 to 396 conversion?
  177. Ideal Red Line for a 383 stroker
  178. Fidanza Flywheels
  179. HEI Distributors
  180. cooling
  181. fuel pump
  182. another SB2 question :)
  183. Strange 12 bolt Help pt 2!!
  184. T56 6 speed what is difference between LS1 - LT1 versions?
  185. Paging Mr. Horsepower...
  186. Need wiring diagram for Silverado
  187. Fuel Pump Question
  188. putting a carb and int on 94 lt-1, what will cause me problems
  189. Best times/most HP with optispark
  190. BLMs drop below 100 after bypassing KS...what gives?
  191. What else would cause a fire to jump other than the obvious?
  192. Torque arm geometry - traction related
  193. Jesel mounted rocker arms
  194. Fuel mixture question
  195. Egr prob
  196. stumble at cruise speeds
  197. Bore/Stroke Stuff
  198. Piston velocity/power/force vs headbolt stretch and stress capabilities
  199. Lets talk overlap and its effect on PA and NA motors
  200. Egnition switch
  201. Need help with T/C lock-up switch
  202. adjusting rockers
  203. 12SCNDZ and other who can build a 4L60E HELP!!
  204. Headers glowing red, jsut a bit???
  205. hydraulic vs. solid lifter cam
  206. Problems and questions on last minute stroker. Oil, fuel, rockers...
  207. Replacing Torque Converter
  208. Bad p.c.m. kills tranny 4x's in 6000km?
  209. Help me pick an electric fuel pump.
  210. Converting to Alcohol with EFI
  211. Need some help with a fuel system i want to use.....
  212. help with walbro 255lph INLINE pump!
  213. Head gasket thicknesses offered for a LT1
  214. Burning smell after the car has been parked.
  215. What RPM is the Scat cast crank good upto?
  216. LIGHT SHOW UNDER HOOD help!!!!
  217. Are the "China" forged cranks to be avoided?
  218. piston ring ?'s
  219. Need Help ASAP
  220. 700R4 experts, I need help
  221. More anti-squat / instant center Q's -- I understand some, and made some changes!
  222. what is the trick to seating the tranny pump?
  223. How important is it to program my PCM after a gear swap?
  224. I want to rebuild rear myself any help sites?
  225. THoughts on cryogenically treated rear end parts
  226. What A/F ratio to shoot for and where?
  227. 350 with 305 crank?
  228. Please Help...Z Problems...
  229. Whats stronger, SBC 400 steel crank turned down or Scat 383 cast crank
  230. 700R4 rebuild, where did i go wrong??
  231. Vaccum pumps
  232. Need help with 396 idea
  233. I need 350 swap help
  234. piston clearance
  235. Adjusting IAC Counts
  236. Flow bench variations?
  237. Coolant Seepage From Deck/Head Surface...Thoughts?
  238. any metallargists/fabricators in here?
  239. T-56 gears
  240. Anyone swapped in a standard sbc for an LT1?
  241. 396 swap from v6
  242. top end oiling problems
  243. Accel DFI -vs- Speedpro F.A.S.T.
  244. crank trigger???
  245. Extrude Hone questions
  246. purpose of POLISHING CON RODS?
  247. Suspension geometry
  248. hp limits on cast 383 stroker
  249. Need your opinions
  250. F.A.S.T. Sequential EFI without opti?
