- Main cap orientation?
- spark lines look like a heart monitor! Pics
- changing springs, but i cant get the locks off.
- Engine Building Checklist SBC
- low tention oil rings for street
- stacking head gaskets.
- COMP XE hydraulic rollers vs. Crane Powermax Hydraulic Rollers????
- How much does coating add to size
- Front end question (engine)
- 383 to 396 stroker
- Head stud nuts won't clear between "big" springs
- Knife edging a crank..not really "how," but "where?"
- Any advanced way of telling if valve springs are too small?
- houston, i think we have a problem...
- RR 23* heads vs standard 23* heads?
- head surface question
- spring pressure. How much difference is allowable?
- tire presure at the dyno
- Question for people running 5.7" Eagle H-Beam Rods
- Wiring diagram to install fast
- Taking out T56... ecu related ?
- Cola Ultra-Lite U Crank??
- ram air a myth?
- AC intake?
- figuring converter slip from dyno figures
- Rich and richer...
- Lashing valves with feeler gauge?
- Any advantage to coating or painting the INSIDE of the intake?
- SBC, cam, stall, rear gears, nitrous oxide
- Disturbing.. GM hightech article LT1 spun bearings
- 6 liter ls block
- 1993 with TH400 - VSS? SGI-5? Proper hookups?
- How to select propper transmission gearing for a car
- make a 2.8 into 3.4?
- Alternatives to EVAP system?
- Just finished my Dart 200 port.
- injector fuse vs duty cycle
- Does humidity affect cam selection?
- LS1 engine & T56 Tranny Swap
- File Fit rings on 383 SC
- GMPP block/hp ratings
- 6 Inch Rod Vs Stock Lt1 Rods
- Spark voltage
- Vented Opti and Boost?
- Calculating carb jets: Can it be done?
- Will valve stem lash caps increase lift?
- some engine math.. need help
- head gaskets that hold for +900 BHP
- Want to build a 500hp motor...
- Automotive Calculations on CamaroZ28.Com
- Kevlar bellhousings for LT1 T56s?
- coolant smell/loss
- Engine Load vs. Output Power
- Drivetrain Loss
- If Magnafluxing doesn't work on Al, how do I check for cracks?
- EGTs
- Spark line curve on scope test
- finishing touches
- big bore lt1
- Advanced disscussion on engine oil for stroker.
- quick geardrive question!
- advance or straight up?
- Intake manifold runner lenght vs cam duration?
- Can someone help me out with "stall torque ratios"?
- Trade FAST ecu for DFI Gen VII
- Anyone have their motor fully balanced?
- Camshaft LSA and advance questions...
- Head work.........
- Why not 10W-40?
- FAST, E-Dist, Crank trigger, Cam sync... argh- what do I need?
- The Truth: Emissions and Smog Equipment.
- can you make power with a very wide lobe seperation N/A?
- Optimum Timing
- Do Final Gears Change Output Response on a Chassis Dyno
- White smoke coming out of carbs?
- Big VATS problem car wont do anything
- Bearing Clearance and Oil pump selection
- difference between small block and big block rockers?
- Airflow vs. HP
- Crank heat treating
- Port matching AFR220 heads to LT4 intake
- Camshaft gear wobble
- Crane gold series rockers interfering with springs
- Major Timing Or Compression Problem
- confused need help with 355
- Intake manifold length vs exhaust primary tube length?
- new gears = no 1/4 gains?
- For those who have converted to a SBC dist.
- 95 Z28 Camaro
- Stroker Crankshaft Questions
- stroker cylinder wear LT4 396
- Hard Blok a daily driver 396?
- 220 protopline with HSR?
- Getting rid of stock ECU
- Dyno Graph
- can any SBC solid roller lifters work for an LT1??
- Big springs & Head stud nuts
- What is hyperutectic and what are its properties?
- front to rear rim size comparison...
- how to remove Callies main caps, splayed???
- Bret B., comments about Cryo treating?
- Paging Taner
- 5,250 RPM cross of rwhp and rwtq
- GM declares "Dominion," or kinda "Dominion?"
- Cross-plane V8 vs. Flat-plane V8 crankshafts
- I need some computer & Cam help
- building my stroker, external or internal balanced??
- How necessary is resizing con rods?
- Bench Flow
- V8
- Short duation and tight LSA?
- LT-1 cylinder honing
- Using a "010" block to build an LT-1
- Rod Tap
- odd compression question
- Ls1 Coil Pack Conversion For Lt1
- So what is it about V6's that make them so terrible
- Motor Mounts
- Rev-kits: how much pressure is added.
- Effects of supercharging?
- ? about LT1 block vs. old SBC block
- Power Tuning Tips and Explanation (Carburetred)
- idiot light wiring
- Running 1.7 rockers with 211/219 .530/.560 on 112 lobe with ported heads?
- Ring Seal
- Calling the "head masters" how many more CCs can i get out of these chambers? (pics)
- black intake ports
- MSD on my 97 Vortec?
- Where does the balancer key go?
- Double Keyed Crank
- Calculating airflow
- teeth getting sheared off my reluctor wheel???
- will 2.08/1.6" valves fit in stock heads??
- UB Helps BPR Take It To Another Level...
- EA Pro files
- Piston Ring Tolerance with Nitrous
- Got the Malibu on the dyno, finally. Help me "break the DynoJet code"
- QUICK GUYS could this cause my oil pressure to be low?
- How much gain w/ pulleys?
- few questions about a sbc engine
- Curiousity regarding big block f-bodies
- head and valvetrain geometry questions
- Engine Management Forums
- What's the most I could stroke a small block?
- Titanium valves for hot street Yes or no?
- Any formulas to determine how much exhaust would flow through a cutout?
- Harmonic Balancers
- anyone know approx. flow numbers for AFR227's out of the box????
- What are all the theories behind performace...
- This diameter tube flows how much?
- Restrictions and Pressure differences?
- Cam swap
- Why run a rev kit on a solid roller?
- could use some Gen VI install tips/ identify some stuff...
- Brodix Heads??
- rod loading
- 400 Blocks
- Piston Question
- Cam Walk possible in LT1's??=Opti failure?
- What makes an engine rev higher...
- Big Block vs. Small Block Torque
- welding in cc's
- cam bearings
- piston rings
- exhaust question
- Pressure recovery in the intake at speed?
- AFR Head oil leak at gasket?
- BBC compresion heigth question
- 396 LT1 clearance/rotating assy. questions
- 5.7'' or 6'' rod for 383
- Single vs Dual Plane vs Stealth Ram
- Bottom end assembly?
- advance cam question
- Solutions to a 400 block being weak?
- How long are wrist pins?
- Fmu
- Intake (Again)
- Timing chain streching issues..... might need a custom chain...
- Best sb head?
- Hydraulic lifter limitation - what is it?
- 110 or 114 LSA???
- Stock LT1 block piston-to-deck clearance
- Voltage problems...drops under wot
- Single plane intakes on LT1...my results
- Convertors-- Lockup vs. non-lockup? Help...
- Tell me what is up with these flow numbers?
- Canted vs Wedge?
- Old rods in an LS1
- over the top 383 questions
- carb q's and timing q's on bb chevy...
- where to hook up a wide band O2 sensor
- O2 problem, weird!
- Stock oil pressure sending unit, with autometer gauge?
- What do you guys think of this CC XE cam. Short duration, high lift.
- cast nodular iron welding
- EFI Intake Plenum?
- Five angle valve job
- closer look at xpipes and hpipes
- SBC Brodix 23* Heads vs LSx 15* Heads
- Any tips on installing a vacuum evac. on an LT1? TIA!!!
- need help with running msd dist. electrial ?'s
- afr 227
- New MSDProgrammable Launch Limiter
- 23* Intake on 18* heads?
- What kind of surface to leave on intake port?
- 5.565 rod length
- Intake Help
- Removing ValveGuides for Porting
- torque peak at lower rpms?
- Harland Sharp Valvetrain Geometry
- Recommended gap on moly rings with spray
- *caution* lunati cranks are bad
- Anybody ever come across ported E-tec #'s?
- Hughes Torque Converters
- will i need additional clearancing be required for my new Oliver rods on my stroker?
- Why are Hydraulic LS1 engines able to spin so high?
- Gurus-Follow up to my earlier thread
- Hex head vs. 12-point vs. undercut 12-point
- ANOTHER solid lifter(s) cam question.
- Rhodes-style hydralic lifters
- Modify lt1 intake to accept standard distributor
- Engine Block
- Fuel pump advice needed (1/2")
- exhaust theory
- Good ways to learn more about engine internals?
- DFI Gen VI question.... about injectors
- Sensor Usage in OBD1 & OBD2 LTx/LSx Engines
- Cam/Timing question
- Thrust bearing
- Debate- Cold air affects turbos or big Cubes more?
- Emmissions-friendly hp...
- LT1 heads/intake on a 400 block?
- At what point do 4 bolt mains become necessary?
- Need Help with Ignition key cylinder
- .43 06 1/16th rings for n2o
- Anyone NOT running valve seals
- exhaust valves look real bad???
- Crank turning/nitriding strength
- LT1 heads retrofitted to a 355"
- Age old question... torque vrs horsepower
- Best 23 Head on LT1 with stock PCM?
- Single planes and turtles?
- Rod side clearance
- r lifters
- Rebuild ?'s
- Cam Bearings? PIC INSIDE
- What is a good Damper to get?
- Custom Alloy Steering knuckles...
- Is my converter slipping to much????
- Heads...am i asking for trouble?
