Advanced Tech
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17
  1. SBC1 to LS1 transplant
  2. Light weight battery talk. Good reading and info inside.
  3. oil pump
  4. putting down power - general discussion
  5. Cam Recomendation
  6. Quetion about a cam.
  7. Pushrod length + or - allowable?
  8. Mallory/MSD distributor mounted in LT1 intake.....
  9. "Black Box" reprogramming question...
  10. solid roller lifter HELP needed !
  11. Anyone use a knock sensor with the Gen 6 dfi?
  12. Ign. Fuse Popping
  13. Which MAF for my 383, need input
  14. Cam distributor gear and oil pump drive assembly question?
  15. Injuneer, Dr., other experts please help
  16. Oil pump drive
  17. How does plenum volume effect engine performance?
  18. custom camshaft design
  19. transmission conversion
  20. Gen1 SBC and K member help
  21. stroker owners help?
  22. Rotating Assembly
  23. Water injection?
  24. Low lift flows effect on power?
  25. Ls1 Vs Lt1
  26. Simpler Cam Design...
  27. Spinning off Hub/Balancer
  28. 23 degree heads for twin turbo
  29. Injector positioning, BATCH FIRE
  30. determining compression ratio...
  31. Timing: Any rule of the thumb?
  32. Help me figure compression so I can tell Lloyd what to mill them to!
  33. Determining shim size in valvetrain
  34. Traction Control Information
  35. HP vs RWHP
  36. Car will not start after FAST install
  37. No one has been able to help me so far (opti)
  38. Cam recommendation from comp cams
  39. Driveshaft question. Need some math help.
  40. How do you set pinion depth?
  41. springless valvetrain
  42. Intake volume vs port velocity in a NA and FI engine.
  43. Anyone using a knock sensor with Speed Pro (FAST) system?
  44. having [a problem] with fuel system.... Advice?
  45. Bent a Push rod in my new stoker. See inside please
  46. Need opinion on TEA heads
  47. O2 injection... has it ever been done?
  48. Valve springs / ZZ4 cam question
  49. 383 break in?
  50. removal and replacement of governor on 700R4/4L60 transmission, quick questions
  51. Speed Density vs MAF for large cams
  52. Manual Valvebodies and Lockup converters?
  53. 383 vs. 406
  54. head gastket break in period?
  55. barely passed smog
  56. Dyno Techs or Thermo Inclined People IN HERE PLZ
  57. LS1 heads maybe not so great
  58. balancer/harmonic dampner talk...
  59. crank weight?
  60. swirl
  61. Poll: What is your favorite racing fuel?
  62. High Compression and Valvetrain...
  63. 383 Stroker Questions
  64. Leaking Oil into coolant
  65. major clutch problem
  66. stroker
  67. Pcm Help!
  68. Lets talk exhaust....
  69. Making a 4L60E a 4L60
  70. What is too rich WOT/Boost?
  71. I need cam help on a BB ford this time.
  72. AFR 210, 220, and 227 -vs- CID
  73. 4l60e-->Th350 Quick Speedo Question
  74. 4.0 crank in an LT1
  75. 383 build up/ Measurement ???
  76. Extrude-Hone??
  77. align boring, what is needed to get it done?
  78. Maybe an opti solution?
  79. 383 stroker vs 382 all bore
  80. Inside of the valve body??
  81. Port Velocity?
  82. Any (T56) Trans Experts.. I Have Symptoms
  83. LS1 heads kill LT-1 heads why? One more time slowly for us IQ challenged
  84. Auto Trans. Fluid Temp. Question....
  85. Help getting my intake to fit some milled AFR 220s
  86. Anyone seen these heads before ????
  87. An advanced look at why Mustangs sound like they do
  88. Minimum piston/head clearance?
  89. LT1 lifter diameter?
  90. Tight Engine/Nu-tek>>>
  91. [What] is a trans-brake??
  92. Pm rods
  93. Diesel Question...
  94. tranny removal looking for site
  95. HELP with cloyes set? & 847 cam
  96. Would going to 1.7 RR with my setup yield any noticable hp? (specs inside)
  97. lets talk solid roller lifters
  98. need opinions 355 or 383??
  99. intake vs exhaust duration?
  100. Maximum Compression ratio on 383 LT1?
  101. UPdate on 1300hp camaro
  102. 427 will it fit?
  103. Formula for timing needed?
  104. Anybody have real info on MSD's 7600 CPC setup
  105. Performance Differance between I beam and H beam rods?
  106. how to figure cam lobe flow area.
  107. Intake Air Temp
  108. Need some "slick" advise
  109. Coating piston tops in a liquid-air cooled application?
  110. Q's about methanol, injectors, and fuel pump.
  111. help me with my next 4x4 engine. (bottom end and custom cam specs)
  112. could I make my own headers?
  113. clarification's sake
  114. Iam running a Holley 255 intake fuel pump on my 396, is this a good fuel pump to use?
  115. Converting fresh rebuilt 350 to stroker
  116. Aftermarket PCMs
  117. Lighter vs Stock Flywheel?????
  118. I hear "detonation" thrown around a lot on this board. What is it?
  119. bellhousing bolt pattern ?
  120. LT1 T56 rebuild
  121. SBC head converted to LT1 head?
  122. Head conversion to LT1 Reverse Flow
  123. High Octane Fuel and Performance (or lack thereof)
  124. FAST eDIST with FAST SEFI and LS1 Coils
  125. Aftermarket LT! Block or Can U use lt1 parts on a gen1 small block
  126. transgo install
  127. Explain Vaccum?
  128. Egr
  129. sbc spark plugs - gap, hotter, colder. help
  130. shifting to early.
  131. Fluidamper, vs ATI, vs Jegs, vs stock damper
  132. 4th-gen chassis and 'stiction'
  133. How much power difference will extra compression make?
  134. 12 bolt strange Question
  135. Strokers and emissions
  136. how many hp does p/s eat?
  137. Difference in single pattern and dual pattern cams?
  138. Ring and Pinion manufacturing (why is it the way it is?)
  139. HELP! Need valve guide size for LT1
  140. How can my Inj Duty Cycle be 140???
  141. Compression and Milling Heads
  142. Fuel Cell
  143. Radiator in Trunk
  144. Hardest FI engine parts?
  145. Please advise.
  146. Problem with my th-350
  147. Engineering of Wheel Spacers
  148. A/F ratios and VE tables???
  149. ram jet intake with aftermaket heads on an LT1?
  150. o-ringed heads
  151. Vette wheel hubs on a Camaro?
  152. Miracles of Internal Combustion
  153. Car won't rev!!!
  154. is a 502 strokable?
  155. Aeromotive A1000 pump making noises
  156. 402 bigblock in a 95 camaro
  157. Want to do a compression test on my car, how do I accomplish this?
  158. Fuel experts inside, tell me if this is normal.
  159. Intake runner vol. vs rod/stroke ratio
  160. versatile shortblock
  161. Changine the transmission fluid as maintinace and negative effects on trans life???
  162. Cross Drilled, Slotted, and plain old Vented rotor under the 'advanced' microscope...
  163. Promoting Swirl when porting heads????
  164. Difference Between Low and Standard Tension Rings???
  165. EGT readings around 1250 at WOT.
  166. Crankcase Vacuum pumps/wet sump oiling system.
  167. D stroked LT1
  168. rotating assembly wieght and its effect on power
  169. Coil on Plug ignition
  170. LS1 new technology?
  171. I almost have all of the pieces
  172. (LT1) Converting to HEI Distributor - What about the Crank Position Sensor?
  173. Dana 44 8.5" rear questions
  174. Overheating a new motor?
  175. Ferrea 6K's wich flow better
  176. Setting Idle RPM
  177. Need Idler pully, any ideas?/ Eaton M112... LT1 update
  178. Hooking up LTCC need opti help
  179. value of plug indexing on an LT1/LS1...
  180. LS1 heads vs SBF heads?
  181. Please explain the advantages/disadvantages of different rod lenghts
  182. Crane gold race rockers hitting please Help!
  183. Water Injection on n/a or nitrous apps?
  184. PLEASE HELP - 93LT1 to 95 LT1 conversion
  185. Air/Fuel and washing Cylinder walls
  186. Coefficient of Drag on performance?
  187. 3.4 --> Gen I SBC V8?
  188. Help needed for a project.
  189. Piston to valve clearance on this LT1 cam?
  190. AFR 100s and ferrea 2.055 possible?
  191. 396 wont rotate at initial startup
  192. non lt1 motor install in 95 Z
  193. Apprenticeship: GM vs. Individual
  194. Car making funny fluttering sound out of the exhaust.What could it be?
  195. Is This Moser Rear New?
  196. Firing Order
  197. Turbo Downpipe – Head porters, flow junkies… looking for ideas
  198. running rich on 4 cyl.
  199. Cam Help !!!!?????
  200. using LSA to adjust powerband
  201. 700r4 problems
  202. Semi-advanced header discussion... :)
  203. Muffler in series?
  204. which piston??
  205. Fuel Injection
  206. Need ABS conversion help on my 95 TA!
  207. Extenal balanced crank
  208. any 70's 4x4 owners???
  209. Any Engineers Care to Explain in Laymans Terms, INSTANT CENTER?
  210. valve spring seats
  211. 12 bolt
  212. 5.7" or 6.0" rod for a 383
  213. Eaton RUNS!! LOUD PROBLEMS WITHIN..
  214. Split BLMs & KR at idle...
  215. Possible to fry an MSD box by jumping battery???
  216. Easiest/Best Tools for Polishing Combustion Chambers
  217. Question about Dynamic Compression Ratio (DCR)
  218. ? on milling heads -block - intake
  219. Radial Engines
  220. Template for a 3.750 stroke clearance
  221. Solid Pinion Spacers...
  222. Replacing Valve Seals with Heads on Block.
  223. ARP Mainbolts and line boring
  224. Fuel System Reconfigure After Motor Swap Quest:
  225. where to get bare fuel rails?
  226. What is the proper procedure to matching heads to a cam?
  227. VP racing fuel on the street?
  228. How to put in Large Diff Pin/Block?!?!
  229. 4l60E rebuild /OD diagnostic question
  230. LTCC and still missing??
  231. % Leakdown ???
  232. Going from carb to fuel injected questions
  233. Ok I'll try this here......
  234. Can someone explain AN fittings to me?
  235. Axle specs - too much end play.
  236. Runner length vs air flow?
  237. Matching a cam to head flow #'s
  238. s'chargd 383 LT4, loose MAP symptoms?
  239. LSA vs I/E ratio?
  240. i need HI PO tranny advice and prescriptions
  241. Is this safe compression for boost?
  242. Carb single plane intake for lt1
  243. track
  244. Carbed 350 in my 99
  245. I'm an idiot, serious cam help needed!
  246. Temps vs. overbore vs. cam
  247. Is 10.8:1 cr too much for pump gas?
  248. RIP: Carroll Smith
  249. High volume oil pump NEED HELP??
  250. Timing
