Advanced Tech
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17
  1. honed what?
  2. How much HP is timing worth?
  3. Carb to FI swap- i dont think anything else could go wrong! help///////1
  4. Need a formula...maybe one of you know
  5. Motor Building questions.......long
  6. HELP!!! I have no oil presure!
  7. Compression test results....let me know what you think...
  8. WHat could cause a A4 tranny to slip only at WOT? Please tranny experts!
  9. t56 experts inside please............
  10. cylinder pressures and spraying at low rpm
  11. Need help with rod side cleance
  12. 355 buildup questions inside?
  13. You guys that DO or KNOW how to CC cylinder heads in here>>>>>
  14. Longer pushrods... Why ?
  15. crane coil 3 or 4 prong?
  16. Advantage of 6" rods in a small block?
  17. Cam question for Blown Stroker Application
  18. Explain Valve springs
  19. Ignition unit New Delteq opti Delayed / another optispark replacement?
  20. gears
  21. '78 block FI conversion options.
  22. Callies Cranks
  23. Need help!!!
  24. duration questions
  25. Why doesnt this add up? - Comp Ratio...
  26. Low Speed Cylinder Pressure
  27. Does cryro treatment really work?
  28. When is a stroker too big?
  29. Small block oiling system questions...
  30. Question about 2 oil pumps for a Turbo car....
  31. 700r4 ? slow 2-3 shift @6000
  32. 383 Carb Swap
  33. Intermittent Code 43.
  34. code P1351 anybody?
  35. Valve jobs altering angles gains of 18 cfm?
  36. Puzzled over high exhaust temps
  37. 110 vs 112 LDA?
  38. Engine about to go?
  39. Underdrive pulleys and water pump
  40. Persistant Oil Leak
  41. Best heads? TFS, Victor Jr, or AFR?
  42. Tranny rebuild at Cottman transmissions? Please read
  43. Any interest in a tunable MAF?
  44. compression ratio question
  45. offset gound crank
  46. LS1 in an LT1 f body...
  47. Turbos
  48. Valves and cuts, tulips etc
  49. Pro Performance?
  50. PLEASE help!! 2nd trans in 2 weeks!! What is wrong??
  51. Spinning alternator the opposite way: How to cool?
  52. Stroker Motor
  53. Compression Ratio VS. Fuel Octane
  54. Where can I get stock rod bearings for LT1?
  55. Advantage of low CR/high boost?
  56. Seasoned versus New Aftermarket blocks?
  57. TH400 No Pressure in Drive...
  58. swaping in a th400
  59. Largest injectors that can be driven by PCM?
  60. E-brake and Ford 9"
  61. Rearend experts - humm or gear noise
  62. 108 LSA on an LS1?
  63. Loose crank pulley!!! What damage could have been done???
  64. A discussion I had with my tranny guy
  65. Any progress on the OPTI alternative
  66. 18 Degree Topend FS if anybodys Interested
  67. Z06 MAFf use on a LT1
  68. Valve Cover Spring Oilers
  69. ceramic coating ??
  70. Viper T-56?
  71. Combustion chamber size
  72. 355,383,396 effeciency per cube?
  73. Does cubic inches affect optimal cam intake centerline?
  74. How to test fuel pumps for flow at home?
  75. 120 fuel comp
  76. Optimal head flow numbers?
  77. Power Brakes and Steering
  78. wiring to the tack, need help
  79. Custom intake manifold, where to start?
  80. Rebuild every year due to billet connecting rods!?
  81. adapting heads
  82. High rpm studder/miss
  83. 400 block + 350crank = 377 Can anyone tell me anything about them???
  84. 383 build........tell me what you think
  85. Cylinder head flow efficiency
  86. 350 block
  87. Unusual mod, ver unusual
  88. timing at 7500 ft elevation
  89. Alcohol Injection???
  90. Pro's/Con's: 1-piece versus 2-piece seal cranks
  91. Compression Ratio
  92. A3 Swappers, what shifter cable lenth?
  93. Running a F-body on Alcohol
  94. CVT "6-Speed" Tranny...
  95. Theory: pushrodless LT1 engine?
  96. Stock computer with a Gen I engine?
  97. port velocity
  98. Using LT1-designed cam in L98?
  99. LT1 Engine Balancing
  100. exploded diagram of th350
  101. Solid roller/lash question
  102. Whats the proceedure for adjusting rocker arms for a solid roller??
  103. Winston Cup Cars
  104. Is this right?
  105. Removing guide boss in LT1 head??
  106. Belt Drive on a LT1
  107. Moving the altnator
  108. Theory for bad opti.
  109. Ideas on Rod lengths and Rod Materials
  110. std. 1.7 roller rockers?
  111. Changing 6th gear ratio in T56?
  112. bore distortion, measurements, and pistons
  113. help with 383 set up
  114. high vol pump.. another twist
  115. Anyone know about the TKO II or F-body cars with 2.73s???
  116. Water Jacket Or Head Gasket
  117. Help Wiring Inline Fuel Pump
  118. Pros/Cons of Overly large Throttle Body
  119. Opinions on strokerkits.com..
  120. header flange question?
  121. Dropping piston "in the hole" to lower compression?
  122. piston oilers
  123. would this work?
  124. HP loss @ the rw
  125. Camshaft gurus in here please!!
  126. Swappin' Blocks
  127. NEED HELP PLEASE!!! W/cross fire to fuel injection
  128. Thinnest Quality Head Gasket Available?
  129. How restrictive is the intake?
  130. 383 Head selection with what piston ?
  131. solid roller lifters?
  132. Building 355- what's best bore/stroke?
  133. anyone running 6.125" rods on an LT1 383?
  134. glowing header question
  135. Discussion on headers and = length primarys
  136. 50 over 383 is this ok?
  137. x 236/242 cam
  138. Problem: i think my deck is past zero and piston is above it
  139. WATER/ALKY injection on high comp. NA motors?
  140. I can't get the input gear out of the trans.
  141. Blower Pistons, rings, other misc. rebuild questions and concerns....
  142. Gen I 383
  143. If using new heads and new valves does it require lapping?
  144. Are expensive oil pumps REALLY worth the money....experience witin please
  145. Dyno and the consequences on an engine or car?
  146. Aeromotive pump using stock lines
  147. Injector Offsets needed???
  148. 9" or 12 bolt (Noise)
  149. Forged internals for a T56. . .
  150. What gear to go with?: 4.10,3.90, or 3.73's
  151. tranny mounting questions ...
  152. cam formula ???
  153. 454... Will it fit?
  154. Pulleys/Brackets/Accessories
  155. MSD DIS and coil packs how much?
  156. Notching piston skirts for crank clearance?
  157. changing transmisions (a4 to 6m)
  158. Rod choice for hi-po/low rev setup?
  159. 406s make more power than 400s I don't get it?
  160. building engine this winter, questions about balencing
  161. Cam Question
  162. My 383 wont spin tires?
  163. custom grind cam request ???
  164. Calculating actual load on the torque arm?
  165. 1.65rr or 1.7rr's......Can it be done?
  166. Head porting
  167. Let's talk about engine bearings.
  168. what top end for a turbo lt1
  169. Titmium valves and the gains with it?
  170. I just broke my second input sprag in 2 weeks. What the heck is going on?
  171. Motor didn't perform as expected what could be wrong?
  172. Electric AC
  173. Ford mustang 8.8'' rear for a 4th gen rear swap?
  174. Arao Engineering 32 valve heads
  175. How does air velocity relate to torque?
  176. Rebuilding transmission, got a quick Q
  177. How much can I stroke this block for?
  178. Finding Cubic Inches
  179. arao 32 valve heads- what are you guys talking about?
  180. Mild 350 build questions
  181. Please Help!
  182. Last minute stroker start up questions... Almost there!
  183. Best Crankshaft for LT1 Engine?????
  184. Pipe CFM, Muffler/Exit Location and Resonance...
  185. Building 383-Use 5.7" or 6" rods?
  186. machine work
  187. Some fuel system calcs
  188. Stock LT1 internally balanced or externally
  189. torque spike in automatics
  190. 2 piece rear seal adaptor for 86 and newer
  191. Conversion for Brodix heads?
  192. compression vs head porting vs forced induction
  193. What Type Effects Would Too Long Of A Push Rod Have On Engine Performance?
  194. Paging Injuneer or any other experts (long)
  195. What rings?
  196. What are your thoughts on thin stem valves
  197. Opti substitute for bbc to keep LT1 pcm
  198. Anyone read SUPERCHARGED! by Corky Bell?? Opinions please.
  199. Limits of the stock fuel lines and rails
  200. What's normal MAP (psi) at idle?
  201. How much money to "coat" exhaust ports in a cylinder head????
  202. ceramic coating question
  203. Guys with fast 6 spds, what do I need to keep from breaking them
  204. Best Flowing Stock Heads
  205. Low end torque 383 w/ big port heads
  206. max lift recommended ???
  207. Camshaft LCA statements within. ARE THEY CORRECT?
  208. Can you "overcam" your motor? Am I?
  209. stock valve size and head diameter please?
  210. GM 350 Block(10105123)
  211. headers to small or engine to big.
  212. BBC in 4th gen Camaro
  213. LT1 Fuel Injection on a different engine. Doable?
  214. Lugging engine in 5th and 6th gears
  215. Raising Intake Roof
  216. Piston crown thermo barrier
  217. backpressure and torque
  218. Brodix Track 1 heads
  219. Anyone here have any input on this?
  220. 8.1L to LS1 Swap
  221. 383 D-1 w/ LS1 coil packs and no more opti
  222. Gear ratio formula
  223. Questions on Combustions Chamber Coatings??
  224. Allright, Final camshaft questions i promise = )!!
  225. 18* heads
  226. HELP GAS IN OIL never seen this b4 on a lt1
  227. Camshaft gurus.....need some help pleaze
  228. block rust...
  229. What is the formula for figuring injector size requirement for an application?
  230. Cross fire hardcore
  231. Position of Exhaust crossover
  232. head porting question
  233. Engine Experts Please Help
  234. Need information on stock harmonic damper balancing
  235. head/cam/headers combo or 383??
  236. 4L60E to M6......Wiring problem please help
  237. Stroker Engine Longevity as primarily a daily driver
  238. Going back to 5.7" Rods from 6"
  239. Oil pressure constant under all conditions- blearances, guages & pickup???
  240. Need help with engine math
  241. Firing Order...Flat Fire
  242. xe 230/236 and crane 230/238
  243. seperately cooled heads
  244. 396 questions
  245. Do not post "for sale" on this forum
  246. Octane--Pre-ignition
  247. 86 TPI top in on 350 in S10
  248. My Car has gone PSYCHO!
  249. High Perf 700R4 parts recommendations.....
  250. Insanest cam on VORTEC heads
