- new single plain intake design...
- Block flex
- compression
- Piston design
- UB...we're one step closer to dominance...
- What does it take to rev high?
- Camshaft Question
- Question regarding modifying centrifugal SCs...
- Big exaust is overrated
- Solid roller lifters/hyd cam?
- Single Plane Guys - PCV Question
- Intake tract length.
- who does reverse cooling conversion to sbc heads to work with an lt1 block
- anyone fab a manuel rack in their 4th gen?
- Cutouts and Exhaust/Backpressure Theory
- Various cam related questions
- effects of DCR on available SCR
- Valve shape
- Does exhaust HAVE to cross?
- Physics: How does more rpm = more power
- I have to make front turn signals from leds need some help and advice
- Lower Temperature vs. Higher
- Converting SBC heads to LT1
- help find out cubes of my motor
- SB2.2 LT1 updates, fuel cell, sheetmetal console, NX direct
- how much hp
- head repair?
- sb2.2 heads
- experts: converted brodix 18x on LT1
- Something I've never understood.
- Ring gaping ?
- big cube small blocks?
- Bearing discussions
- Valvetrain Weights
- Ok gearheads, check this out!
- heads
- Accel Gen 6 wiring instructions????
- bore vs stroke 2
- Blowby / Piston skirt scuffing
- custom clutch system design
- stroker questions please help
- TDC pointer
- Taste Test...
- opti spark replaced?
- How do Dynos Actually Work????
- What type of alum is the bell housing made out of.....
- couple questions on my 398 lt1
- Crank Trigger -vs- Dual Sync Distributor
- Problem with Stud Gridle Rocker Arm Nuts
- Any machinist?
- Dyno Q:
- Where can i get ahold of the machine draftings....
- Does anyone make 4.040 X 3.875 X 6 in rod pistons?
- alright need some opions
- How do they make piston rings have that "spring" to them?
- Fastener engineering question
- 15 degree pontiac heads and intake??
- 4Th Gen Aerodynamics
- single plane???
- Anyone running LT1 on alchahol?
- Roll Cage and Street Safety?
- Alky Injection on a NA Motor?
- Will detination cause the top areas of bearings to shave away?
- Oil blowby detonation help?
- Discolored Rocker Arms...
- How do you determine what # injectors you need?
- Piston Speed
- Custom Cam Grinding...Where?
- stock lt1 heads.
- Maximum DCR before coating is required
- Single plane good for turbo???
- Found a Gen V 454 - good deal?
- Shaft Mount Setup
- How to tell the stroke of your crank shaft?
- Mahle Bearings
- Camshaft
- RACE TECH Magazine: F1 Engine HP, Torque, RPM, etc.
- Engine block strenght: L98 vs. LT1
- Eagle Cast Crank Ground 40 over
- taking out a/c
- Got bored this weekend....
- DTI P&P Kit. Are they worth it???
- Need Help With LT1 into Pre-Runner
- Motor plate question
- EXhaust Building Questions
- Rod Oil Clearance Not adding up?!
- Piston Question
- Electrical Design for Racing
- Please Help With BBC Questions!!!
- can a stock FPR handle a stroked motor
- Just wondering about camshaft duration
- Switching engine combo's
- Shelby VS Smokey
- DCR with E85?
- MAIN CAP WALKING ISSUES!!!! High rpms
- anybody have any flow numbers of bare bbc intakes
- Building a custom intake manifold.
- Making my own headers. Questions
- manley pro-flow or LT4 valves for every day driving
- How do ported heads change the characteristics of a motor?
- LT1 cam in 91 350 TBI
- 91 camaro vacuum diagram
- Block swap
- 2-piece crank/flywheel question
- 60lbs forged crank or 53lbs cast crank?
- Intake Velocity Versus Compression Ratio
- True or False? #2
- Coating the block internally.
- '06 Engine Masters
- Timing chain q
- sodium-filled exhaust valves
- Which is better?
- honing for piston fit
- Block Strength, Dart vs. GM
- Questions about AFR's
- Alright well it's that time again
- Technical discussion on what would cause a piston to explode at idle
- Gen 1 SBC (mid late 70's) and LT1 top end?
- Scr:dcr - Ivcº Abdc
- I've searched and read about it, but still have a ? 6.125" rod
- Acceptable tolerance rod big ends?
- 225 psi is my timing chain off?
- Too much timing chain slack?
- AFR or Brodix
- help! oil pan on 383
- external oil pump question
- Engine Lacks power
- rocker arm q
- High(er) RPM cars, who's is/isn't running the stock style lifter spider?
- Who's right?
- Breaking engine in proceedure
- Piston selection
- best single plane intake design
- ABS Sensor Signal to EBCM
- rhoads lifters
- Suggestions for setup
- chamber cc and milling has an effect on flow numbers and port velocity?
- Rod length (?)
- Crack in bore
- Where do we stop with bearing sizes?
- Resleeve No4 cylinder?
- VersaFueler
- G5X4 Cam specs.......
- 1.8" spring recommendation for cam
- Sheet Metal Intake under 7000 RPM's
- Any thoughts/impressions on this?
- I thought it was futile to sleeve an LT1
- Cam repair???
- did i mess something up? (lifter)
- Carbon Nanotube technology
- Air/Fuel Ratio A/F
- Quench with this piston
- Opinions on King "alecular" bearings?
- Fuel System for standard SBC coversion in 4th Gen
- Header Adapter Plate
- Anybody run a half-filled block?
- Intake CC...volocity vs. volume?
- Rust on Rockers?
- Using the stock thirdgen radiator with LT1..
- 4th gen bbc headers
- Tuning for my stroker?
- 383 stroker diagnostics LTCC
- L6 Q.
- DCR & Cam Geometry LT1
- Independent Rear
- Yes, there is such a thing as a cam that is too big!
- Electric or Mechanical Fuel Pump???
- Rod Lenght.....
- Doing a paper on valve springs, need help!
- need help undersstanding fundamentals of our ignition system, i changed everything!
- Rear Windshield Wiper
- Is this normal for oil psi in a 383?
- Engine design
- 1.5 or 1.6 Rockers on a Solid Roller Cam ???
- 383 Engine Simulation
- Good Fuel Pressure Setting for SBC???
- Cylinder head problems
- Boost + N2O + Meth injection??
- What would you do?
- (stalled) automatics VS manuals... dyno comparisons...
- cyl walls to thin for resleeve, what to do?
- 350 into fourth gen camaro pics and info
- Anyone know about Oldsmobile Auroras?
- Micrometer question
- What's More Important for HP
- Interpreting plastigauge readings... Help
- What thickness spring shim? No access to a checker.
- Larger throttle bodies...
- Detonation Obvious On Rod Bearings...???
- judging hp based on injector duty cycle?
- Custom EFI setup
- dome top pistons hitting
- lt1 heads
- XFI 218 Cam Or Custom Cam
- ICS Titan Head gaskets by SCE???
- 4 Bolt Main Splay Question
- Roller springs vs Flat tappet springs
- Headers hit steering gear box??? HELP
- Paging Bobby Simpson
- DCR Help
- Headers are glowing ... Very strange problem
- BBC/SBC carbd 4th gen cars
- compression question?
- Oil Control Questions
- Leaded fuel in EFI LT1; Denso O2 sensors
- Oil volume at sending unit vs above oil filter question...
- URGENT HELP!!! Flat Top or -16cc?
- Started New 383 Le2..idleing Issue
- Need Immediate Help with Mighty Demon 825!!!!
- can someone answer these questions for me
- Retorquing heads - need advice
- Hot Tank Proof Paint?
- advice on vic jr to lt1 swap
- What the inside of an LT1 intake manifold looks like
- Intake Port Volume Confusion
- Cleaning aluminum heads
- Initially Setting Valve Lash
- Block Prep 101
- Motor swap time, need advice from the pros
- Need engine rebuilding advice...
- An interesting statement
- Miniram an upgrade?
- Degree Wheel
- Hellfire Rings
- Degreeing Cam @ IVC
- Cometic Head Gaskets
- Advanced Misfire Problem
- new cam, advance, retard or straight up?
- Crank adapters?
- Results of carb to EFI conversion
- The SB2 LT1 lives
- advanced missfire
- Reading plugs to determine rich or lean
- Oil problem?
- Internal vs. external balancing
- Checking Valve sPrings height
- 1st gen sbc heads on a lt1
- A "pro's" view on rod length.
- Hypereutectic aluminum pistons and nitrous.....safe?
- Hyper-square motors?
- 383 not running right after rebuild
- A "pro's" view on engine coatings
- Aww shoot! Piston looks like a piece of Swizz Cheese
- Looks like I'm getting some crank walk.
- My Big Block into a 4th Gen install journal...
- LT1 TFS head issue...bad casting?
- Which head/intake combo?
- looks like my machinist messed up
- stroker main stud and head bolts
