- SB2.2 head question
- Setting main bearing clearances general building question and low oil pressure.
- Highest DCR for 92 octane?
- LT1 intake....siamese runners?
- Timing on a carbed LT1
- 350 or 400 mains
- spark plugs with black at bottom, white up top
- can some one explain fuel trim to me
- What's up with the color of this exhaust valve
- LT1 in a 3rdgen conversion. What wiring harness??
- 84Z 305/a4 to 350/m6 conversion
- Which carburator do I have?
- Cylinder sleeve material
- Help, QUICK! Jesel question...
- Who is right when deciding to rebalance the crank?
- Leakdown Test Technique
- Is this cam surge?
- Spark Plug Modifications
- Main Bearings
- What is cam surge
- Undersized stock crank?
- DCR & Compression test calculation
- Distributor gear
- Need some help from THE guys
- Block O ring Problems Help !!
- DCR question/confusion
- Finally made some progress on the SB2...
- LS1 vs LT1
- How big a cam will make power in an LT1
- Need help - Anyone who builds engines - inside
- Time to rebuild!! please help!
- PR/EP (Pressure Relief / Engine Protection) Spark Plugs
- sbc questions
- Compatibility issues with AFR Rev kit and Comp R lifters?
- Rocker Arm ratio question
- HSR intake oil leak mystery.
- Density Altitude effect question....
- Fuel pump question
- The 6.1L Hemi...
- Anyione ever blown a cometic head gasket
- cam question
- can billet be distinguished from forged by appearance
- first build problem
- cc305 checked out diff than cam card
- intake manifold gaskets not holding a seal
- how much HP can a stock SBC rod take?
- Forged Cranks who makes decent price Forged Cranks?
- Oil Filter Tech
- carb'd 408 in a 4th gen?
- Better intake flow = what on cam spec change
- hey guys
- Help!!
- LT-1 Dowel pin
- Differences between RACEMASTER and DRAGONSLAYER
- converting SBC heads to reverse cooling.
- Engine operating range questions.
- decking Q
- Any of you engineering types also a mathamagician? (Also paging Rich)
- Help With Degreeing (searched)
- Welding Sphon torque arm
- weird oil pressure problem
- Piston design for power n/a: flat or dish?
- dynamic compression ratio
- another "how much can it take" type question..
- DAvid Vizard
- 2 Bar MAP Sensor with 17 PSI Boost?
- AFR or Brodix?
- Degreed Cam, ITS OFF, Now What?
- Some comparisons
- High N/A power in speed density
- Biometrics for door entry..Possible PLC usage
- Pistons for big block
- Harmonic dampers
- Intake sets to low on engine
- camshaft lift for 383
- A different Carbed LT1 question
- Electrical Help!!
- Backfired at track now ticking and cooant smell
- Neutral Safety Switch Issue
- Sell my parents on SAM!
- Cam question.
- flexplate diameter issue
- Block Oring Problems
- Head Gasket help?
- Measuring Deck Height with a Dial Indicator and Base
- Cam Bearing Walk
- lunati vs callies
- how can you find the instant center on a torque arm rear suspension
- rod bolt stretch: Maybe you shouldn't stretch to spec
- Name this part
- major engine problems
- Exhaust port size vs. Header port size
- Crankcase evacuation and the muffler placement?
- Explaing Torque (How a Dyno Graph Displays Torque)
- Wont rev beyond 5400rpm
- reducers effect resonance pulses?
- Formula 1 suspension
- mixture distribution
- buying a forged shortblock how can I tell...?
- Lifter Failures
- O2 Sensors -How and Why
- Dyno question
- Thinking of building a motor...need some advice
- what should fuel pressure be on a 383 stroker
- Do I need to Mill The Manifold?
- Checking compression ratio
- Nitrous and Fuel
- 84 TA 420hp
- Variation on the Alcohol fuel for a street motor question.
- Increasing Vacuum at Idle & Canister Operation
- Fuel System Help?
- Air intake tube size/power correlation?
- True or False?
- Mixing Methanol and Gas
- Engine Dies When in Drive
- interested in starting new project NEED INFO PLEASE....LS6 RX7
- What is GM trying to do with block prices?
- Calculating load at the nose of a torque arm?
- two questions, oil, i think, in exhaust, whats it mean? next..
- Unknown Motor
- Best EVAC for the street
- Any experiance with Beck Mechanical?
- 355,h-beam rod clearance..?
- Cryogenics for block strength??
- Hypereutectic vrs Forged
- Cooling fan 'backflow'
- My engine buildup...
- Engine/head Casting Numbers
- how do flowbenches work?
- Anyone running 160# injecters(part 2)
- info about my camshaft
- Hp VS Weight
- 11:1 Compression on the street?
- absolutly best 23* sbc head??
- What the hell is wrong with this truck?
- HELP!...Need immediate help!...
- Rev kit & roller cam in old block???
- What makes straight cut gears stronger?
- About to Give Up -- Still having running problems
- Reduce rotating weight... helium in tires?
- Engine Balancing...
- Solid Roller P/V clearance measuring
- Delteq with Large Duration Cams HELP!!!
- Intake Manifold Gasket Failures
- Rod Bolt Stretch
- Titaniam Valves
- Why do heads need to be ported?
- Block Deck Surface
- 396 13.6:1 compression need cam help to hit low 10's high 9's n/a
- 4L80E How much power will it hold?
- Approx Max Dish Before Compromising Strength.
- At my wits end...
- Solid Roller Springs w/ Hydraulic roller cam?
- looking for a 4th gen fuel cell
- Carfax Please
- TFS heads with LT4 intake?
- too much valve spring?
- LS7 potential
- 7 quarts instead of 5?
- Minimum Deck Height
- 400+ci chevy owners...how big can you go...
- trying to get the stock pcm to run trany while running a Holly Pro DFI
- Piston to valve clearance?
- Motor Advice Needed
- Would you run this crank??
- Headgasket with a oring block
- Head Gasket Design Question
- The relationship between quench and detonation
- Exhaust Valve Opening for Boost, NA, and Turbo
- cross drilled crankshafts?
- SB2.2 vs 32v heads
- Why not fill water passages with epoxy?
- Got some numbers from my EPW ported Trick Flow heads
- Gear lube in T56
- 434 LT1-injected motor build in progress
- Compression effect on Gas Milage
- anyone make LT1 style TB adapters for the single plane conversion?
- Perfect Headers...
- Will any SBC solid lifter work to check pushrod length?
- bare or already assembled?
- 383 vs. 396 Comparison
- Can I use any 350 Chevy rotating assembly for my stroker?
- 4-7 swap
- Pushrod length using Morel Lifters...
- What tools do I need to do basic porting?
- Oiling System
- Reciprocating versus rotary engines
- stroker 381 oil problems, now end play way out
- Quick oil pressure problem question...
- Fuel rail tech - Part II
- SFI ECU or smaller injectors
- Can a TB be "too big"?
- Beginning a large study on hydroforming.
- Exact Movement of 383ci Stroker
- Computer Behaviour in SD Mode
- forged or hypereutectic
- Lifter Boxes
- need solution for fan switch problem
- Why do bent valves occur? How does a piston hit a valve???
- 3800 motor mount tech (need a metal fabricator's opinion)
- 3.48" stroke + 6.0" rod = ?
- Team G or Brodix hv1000?
- Broke 3 valve springs....Solid Roller
- Timing and VE on a SC'd 383
- LS1 cam bearing install
- Diesel oil vs Regular oil in a stroker?
- pistons for a 396 used with a 355?
- Consistant Size Variance in Exhaust Ports?
- Hydraulic Roller Potential
- KPA vs. compression
- Advancing the cam to 5-6 dgrees
- Lifting the threads out of the block
- is there any interest in this custom stuff I'm doing?
- DCR for boosted motor
- Valve spring Lock gaps
- Timing marks & a Dual sync distributor on an LT1
- Exhaust tuning/flow delema
- exhaust pipe diameter as it relates to the ideal gas law
- Gen7 setup, intake info
- Injecting excess pressure into exhaust stream.
- Since LT1s use virtually the same block as Gen1 SBCs...
- options for DIS ignition on LT1
- Soes anyone make a small dome piston for LT1's?
- 500 cube LS motor
- input please
- EGR and aftermarket Cams, LT4 Stock & CC305
- "free wheeling" the engine?
- 12562317 heads
- Need a opinion on oil pressure
- Timing
- Quench on big bore small blocks
- Stainless Steel Shaft Rockers versus Aluminum Shaft Rockers, Etc
- cylinder head airflow and it's affect on power.
- DCR on pump gas
- "full floating rods"???
- Rocker arm ratios
- World Products Motown Intake manifold
- Spark Plug Placement (Top vs. Conventional)
- Spherical Rotary Valve Cylinderhead...Wow!
- The physics of Drilling Metal
- Crane's Quick Lift Tech
- Need help with a formula (turbo/hp stuff)
- 6" Rods
- Dyno tested: Block stiffness.
- Few questions - Camaro '86 - intake, tranny, NOS
- Rockers ratio question
- Flow volume, oval vs round tubing
- Oil Pan/ Rack and Pinion Clearance Problem
- Making springs last on the street with high lift cams??
- Questions on putting the motor back in??
