Advanced Tech
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17
  1. Oversized Rings?
  2. please help me pick a cam for my BBC (sorry so long)
  3. questions about longer rods
  4. De-Stroke or Stroke
  5. Big Block 4th Gen Headers and other questions
  6. Fuel? Max hp with Walbro 255lph?
  7. Bore/Stroke Gen III v. Gen I/II SBC
  8. GM forged rods
  9. Budgent FI 355. I have machine questions
  10. Tuning help (carbed Big block)
  11. Callies mailing: "don't use multi-keyway timing gears" WTF?
  12. 2 crankshaft questions
  13. solid cam in a daily?
  14. First gen SBC heads on an LT1???
  15. Hot Cam Setup
  16. High rpm oil controal
  17. Where does Detroit go from here (gas milage)
  18. A bit of trouble with head studs
  19. Wiring questions...???
  20. A few questions for the advanced crowd
  21. How does one test an "R" lifter
  22. Are there any reverse flow cooling aftermarket blocks?
  23. New motor stumble.
  24. Exhaust Temps. ?
  25. bottom end questions
  26. questions about air flow and volume
  27. Seating Rings
  28. knock sensor with Hard Blok "short fill"?
  29. New Comp 26120 Beehive spring. It's a biggun
  30. Which bearings to use?
  31. Manifold Isolators - Reducing Intake Air Temperature
  32. How much HP and Torque Can stock block take?
  33. World Products Sportsman II Heads - 72 cc
  34. 355 with 6" rods...Small base circle cam?
  35. 4v Heads
  36. Best cam bearings?
  37. First Look? - Valveless Heads
  38. renault F1 video
  39. how to calculate optimal header primary size?
  40. Rant about "how much hp can my block take"
  41. Ram air? A second (1027nd) look? advanced?
  42. engine salvageable?
  43. Major Problems.. motor locked?
  44. finding peak piston velocity in terms of crankshaft degree
  45. Forced Induction eng help
  46. Desktop Dyno 2000.. How Accurate? Realistic #s?
  47. Narrow rear end and a 5 inch BS wheel
  48. Welded some Titanium today
  49. Best way to clean SVO injectors @...
  50. '05 gt head flow numbers
  51. coates engine
  52. Dead miss@3700, using delteq my brain is still itching
  53. Metal comparison(strength, weight, cost, etc.)
  54. Aftermarket fuel injection options
  55. HEI coils & modules... need EE help understanding
  56. What killed this LT1?
  57. Splayed 4 Bolt mains or 2 Bolt???
  58. Head Gasget Locked bottom end up???
  59. #'s on my AFR 227 ported A.R.E. heads
  60. 80s CC carb to non-CC conversion
  61. Effects of Primary Size on Turbo Motors
  62. What is the LT1 Stock Valve Length?
  63. will a LT1 bolt to the 4 speed in my belair?
  64. possible to remove a rocker to....
  65. Compression Ratio Equation?
  66. changing car from alcohol to gas
  67. Exhaust crossover questions
  68. Four Barrel Throttle Body vs. 90mm with Elbow.
  69. .040 pistons for 3.875 stroke
  70. HR Closed Spring Pressure Question
  71. for those that have converted to fuel rails...couple of questions
  72. why can cars accerate and decellerate faster than 1 G?
  73. connecting rod question...
  74. Coolant fitting near siamesed exhaust ports
  75. 32 valve heads!
  76. Hydraulic roller questions
  77. Thinking of adding A STS rear TURBO
  78. Sts Rear Turbo Discount
  79. Doing partial block fill, should mains be torqued?
  80. Comp cam tech says can run hyd on solid cam
  81. AFR210 and Edelbroch TPI Hiflow base possible?
  82. Increasing ~.030 lift worth it?
  83. Intake Runner Length
  84. I don't under stand RODS 5.7",5.85",6" and pistons for C ratio
  85. high end miss...
  86. Bearing questions......
  87. At what CFM does a stock MAF "peg"
  88. Head cross section vs intake cross section?
  89. Pinout for ford TPS
  90. Pro's & Con's of Hell fire rings
  91. How to check and re-assemble the oil pump?
  92. Fuel System Help Needed
  93. Home thermal coating?
  94. Do LT1's sound anything like an original Gen I SBC? Differences?
  95. Need help fasing in the Distributor
  96. intake port CC, cross section
  97. Intake Pro's & Con's --- Advantage = ???
  98. Possible solution to main bearing problem?
  99. JE Dome Piston and AFR 210 Heads with 69cc Combustion Chamber
  100. question about gm847 cam and rear mounted distributor gears
  101. Stealth Ram IAC
  102. question about getting block decked
  103. 1/2 of a +1 rod & main bearings Ok
  104. copper gaskets
  105. Carb Tuning help
  106. #s on my SB2.2 heads
  107. What is the best operating temp for engine oil?
  108. Picking the Right Cam???
  109. 383 stalls at 5700 come help
  110. Valve seals on a 1993 - 1994 lt1
  111. 3 Valve per cylinder SBC/LT1 head swap!?!?
  112. Pump gas motor queston?
  113. Different Valve Springs for Exhaust and Intake?
  114. Spring Height
  115. LT1 intake on smallblock heads
  116. thru bolts vs. cap screws
  117. Which weight oil to use in my stroker?
  118. Less unsprung weight
  119. Need Major Help pls Motor Still Locked
  120. Functions of the MAF and MAP on LT1's???
  121. What's the story on XE cam lobes???
  122. Cam Selection .....help
  123. Help Pick a Set of BBC heads
  124. Cooant leak with Cometic head gaskets
  125. flow for lt1 heads
  126. amunium vs my iron heads
  127. FAST Comp & aftermarket EFI?
  128. threw a rod,,,damaged head ??
  129. Help On Main Bearing Bolts
  130. Is this even possible?
  131. Engine displacement vs. emmissions
  132. Need cam help
  133. Water injection
  134. Car cuts out at 5.2k+ rpms, has Delteq, need advice.
  135. Comp Rs set to 1/32 turn = no change
  136. 18* Heads and Pistons
  137. ADvantages disadvantages of running dual coolant temp sensors?
  138. I need LT4 383 stroker help to run a big (300) shot...
  139. Head Flow Numbers Here...Help with a cam
  140. Is 475-500 rwhp NA possible with an LT4 intake?
  141. Dominion 4-valve LT1 heads for sale
  142. Larger cams, EGR and Passing Smog ?
  143. Cometic gaskets?
  144. safety wire
  145. Misfire, Bucking, Loss of Power, Ping, Higher Engine Temps, Fuel Economy,
  146. Anyone know what these are?
  147. I can't figure out this damn noise :(
  148. Shop wants to use 30 thousandths clearance
  149. Manley t-6 rods?
  150. first gen in fourth gen
  151. How much air to change valve springs?
  152. Aluminum LT1 Block - Would it sell?
  153. 65:1 air fuel ratio??
  154. What happened to the Plastic LT1 intake idea?
  155. upgrade #1 and #5 main caps
  156. Question for those good with math and fluid dynamics? (not me)
  157. are these heads not usable?
  158. concerning quench on a FI motor...
  159. Moroso Blueprinted Oil Pumps?
  160. Engine Transplant
  161. Does stroking a engine effect Compression Ratio
  162. Where is Nutek Motorsports?
  163. 406 with lt1 intake
  164. Max Effort LT1 383 street/strip motor w/ Single Plane. Carb or EFI
  165. Offset vs. Centerline solid roller lifters?
  166. how do you match the "right" cam to ported heads?
  167. LT1 IAC discussion
  168. Question concerning Compression calculator
  169. How to figure out how much....
  170. hotcam causing EGR problems???
  171. higher than normal fuel pressure
  172. Which one?
  173. plentum volume and runner length..
  174. Valvespring rate/pressure question.
  175. Solid roller cam recomendation
  176. required custom work on sbc2.2 heads?
  177. no distributor pulse...
  178. 6 in rod?
  179. sbc motor in 94 TA
  180. Variable duration lifters
  181. High Compression + High Boost + High Ocate = OK?
  182. how important is valve size in a supercharged motor?
  183. Awesome flowing LT1 heads, numbers needed
  184. RPM range applying to heads
  185. What affect does static cr & cam adv/ret have on dcr?
  186. Broke ARP head bolt inside the block!!!!!
  187. Purpose of 2 bar map sensor?
  188. 383 build, what is the better compression height?
  189. How to improve the flow on the stock LT1 manifold?
  190. Help me get a broke head bolt out the block!
  191. BBC manifold runner cross section question
  192. Rod Length Question
  193. Solid roller lifters in late model block
  194. Large bore on an LT1 block?
  195. Rod Bearing crush problems
  196. Stroker engine, need piston help
  197. where did 28 inches of water, come from?
  198. Will sbc fit in 86 jeep comanche truck
  199. When are shaft mount rockers necessary???
  200. figureing out how much flow my heads have
  201. SBC EFI Intakes: LT1/4, Holley StealthRam, TPIS MiniRam, GM RamJet, etc.
  202. When will I be maxing/limiting the 52mm TB?
  203. Porting Heads.. DIY Mistakes...
  204. block fill??
  205. "Negative" Dyno Pull
  206. CAT Billet Splayed Main Caps?
  207. Spohn Tubular Solid Engine Mounts
  208. Velocity Ring
  209. Ignition w/ Aftermarket Computer Questions
  210. Which Heads for Stroker
  211. Cutting Large Journal Crank to Small journal rods?
  212. swapping LT1 for LS1
  213. LT4 carb intake and engine Dyno
  214. HP and Engine Theory
  215. Friction Coated Bearings
  216. Dynamic Compression and Quench
  217. American Hot Rod and 1200HP TT 434CI motor
  218. I need fuel setup help for a big hp 383...
  219. Looking to get into machining, any good schools that people know of?
  220. How to choose a stall.
  221. Culprits that make a very rich mixture
  222. "Best" fuel rail configuration?
  223. assembling block
  224. LS7 head flow numbers
  225. 40/60 Valve spacing rockers/shaft mts?
  226. LS1 Valve Timing
  227. cross sectional area and velocity?
  228. Manley valve question
  229. A/C delete questions (obd2 need tune?, etc)
  230. Best heads for a 421 turbo motor
  231. 6.125 manley rods along with J E pistons
  232. Crankshaft Bob Weight
  233. Do I need to rebalance?
  234. bacteria could be living in your gas tank.
  235. Nitrous & Compression Ratio
  236. Anyone know intake runner spacing?
  237. Above 28".....
  238. Data loging idea.
  239. Somebody help!
  240. 14:1 on pump gas?
  241. Comparing cams by the advertised duration
  242. RIP z28... swap motor into v6 body....
  243. Do I have an intake restriction?
  244. .005 piston clearance causing slap and perhaps causing false knock ....any cure?
  245. Balancing a rotating assembly and other ?
  246. usefull engine formulas?
  247. Head flow data conversion
  248. Thin Head Gaskets for LTx cars
  249. Detonation problem...Need all the help I can get!
  250. Pics sbc intake converted to lt1 needed
