Advanced Tech
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17
  1. SBC machine work?
  2. to overbore, or not to overbore
  3. Blown 420 into a 95, need some advice
  4. Exhaust dyno questions
  5. Interesting interview with GM chief engineer
  6. Reproduce a Ferrari Sound
  7. DFI O2 sensor
  8. Even Warren Johnson has bad days.....
  9. Compression / Piston problem.
  10. Acid porting
  11. Convert to HEI w/ stock PCM?
  12. 3.5 Inch Stroke?
  13. Adjusting Oil Pressure
  14. which 383 to go with?
  15. Can I get some advice about cast iron heads on LT1 hi-po buildup?
  16. Importance of intake tract design.
  17. 383 engine swap question
  18. Miller-Cycle V8 conversion?
  19. Where is the mileage stored?
  20. The new vortec head design
  21. Copper head gaskets and oringed block decks????
  22. Correct way to fix heads that have been ported through the walls?
  23. Need correct cam degree bushing set ...where to get and what PN (' 97 LT1) ????
  24. Why Canton pans for LT1s?
  25. Two Powerhouses Bang Heads - Video
  26. Jet Hot coated intake
  27. Home made headers?
  28. Nitrous wet kit in 1 bottle?
  29. Designing a fuel system
  30. T-56 output shaft upgrades (300m?)
  31. Ball Bearing
  32. CFM vs Velocity when porting heads
  33. Dynamic Compression Ratio Question
  34. Ring Gapping
  35. Stepped Headers?
  36. Cam math...are these formulas correct?
  37. Correct way to Balancing pistons
  38. Q? re: Mixing 1.6 & 1.5 rockers
  39. Car runs on 4 cylinders
  40. Build Check
  41. Want to help a Swede?
  42. Intake ?
  43. increasing cubes to 377
  44. Very simple question on a complex issue. (Long Post)
  45. Advanced suspension question
  46. 2 stroke engine
  47. coil bind is good.........sort-a
  48. holley people
  49. rod orientation?
  50. Solid Roller:Advantages? Changes?
  51. What should the ideal exhiast temp be on a carbed SBC?
  52. Cam Question
  53. Something else I always wondered about...
  54. Buick turbo v6 swap with 97 6spd Z
  55. Fuel Trims
  56. Cam design softwear
  57. Chevy IRL Engine
  58. Engine/engine theory forums on the net
  59. SBC in a '94
  60. automotive knowledge
  61. Choosing A Deck Height For A 434 SBC
  62. 112-114 lsa?
  63. wrist pin lockup
  64. Gen I SBC vs. BBC in 4th gen.
  65. ARP 8740/2000/L19 Rod Bolts, same weight?
  66. Holley Stealth Ram cam choices? Mine was wrong. Why?
  67. Air?Fuel ratio?
  68. Gear Drive on a LS1?
  69. Spark Plug Wire Length
  70. Possible to sanity-check valvetrain timing without damper access?
  71. ? for those running a inductive pickup with a FAST
  72. Retorquing Cylinder Heads?
  73. Question on building headers
  74. Solid Roller Part Number Question
  75. Atmospheric Pressure
  76. I want to calculate something, but I don't know how...
  77. cam bearings
  78. gen 6 dfi and opti ?
  79. Hemi
  80. LT1 head / the other 23 deg chevys
  81. Which carb intake to efi
  82. TH-350 _ Accumulator Housing Cracked
  83. What do my heads need to flow to match my cam?
  84. new vett tranny old camaro, how do i make it work?
  85. Formula to figuring out Compression Ratio?
  86. MAC 1 7/8 headers question, I did a search
  87. 3.48 vs 3.50
  88. Rule of thumb for E.T. changes based on Atmospheric Conditions?
  89. Non Detergent Oil for the first heat cycle of a new motor???
  90. 400 sb, 2 bolt, how much can it take, well- prepped?
  91. Cyl head & timing
  92. Cam and vaccuum relation question
  93. Dart or World Products Big Block?
  94. 383 Windage tray
  95. Can you run Alcohol on FI cars?
  96. Essentials for Understanding Engine Technology
  97. Detonation and Pistons?
  98. Indexing spark plugs on a 12-1 CR stroker?
  99. Help what is broke?
  100. Strokers + big cams
  101. Exhaust options and their effect on flow.
  102. Siamesed Bores??
  103. Where to get header materials??
  104. looking for a program
  105. improving flow through stock heads
  106. head porting ???
  107. SBC crank trigger distributor hold downs...
  108. Need Help Fast!
  109. LT4 heads and rocker-girdles...
  110. Valve to Rocker Lash
  111. Trying to find compression ratio
  112. How many CFM per HP
  113. 3rd Gens...w/EFI.. Pics of cleaned up or out engine bay?
  114. Moly rings in forced induction 1000 fwhp motor?
  115. Need a formula for CR?
  116. Corvette transaxle in LT1 f-body.
  117. Will the head hold up?
  118. Converting heads
  119. Map Sensor Question
  120. Gas ports on a street/strip car?
  121. Oilpan ?
  122. Flat milling the LT1 Aluminum Head
  123. Do you have to have oil pressure to set valves properly or not?
  124. Chambered Pipes
  125. Would these titanium valves fit on these 227cc AFR heads?
  126. Porting Head: Velocity VS. Flow, (long)
  127. Backcut exhaust valves for more port velocity on exhaust
  128. 403
  129. rebuilding the short block... details inside
  130. Homemade Muffler
  131. longest stroke???
  132. 6-71 Blower, 2.02 Fuelie Heads, 327
  133. Question about Cooling System
  134. Crane valve spring compressor?
  135. Off Topic: Non-Automotive materials question
  136. Sorry for the non advanced question: Desperate
  137. 94 Lt1 wont start, PCM Dead??
  138. Converting to sbc heads, carb, and distibutor on lt1
  139. Use of hyper pistons with moderate to high power
  140. Couple BBC conversion questions
  141. lt1 2bolt and 4 bolt(yeah another one)
  142. engine knock
  143. aluminum heads vs. iron and compression
  144. Head gasket bore sizes...
  145. Stroker Question
  146. What size torx to remove air bag?
  147. Lightest front end setup?
  148. Ls7 Big Block Chevy Heads
  149. lt1+big shot of n20 motor question
  150. Headers for bigblock in 4th gen
  151. #'s on LT1&4 intakes
  152. Desperate: valvetrain problems?
  153. Connecting rod-to-block clearance issues...383...HELP ASAP!!!
  154. Boost vs. Ignition timing
  155. MSD Programmable Launch Limiter with Mallory 685 possible?
  156. Best combination to get CR=8.5 - 9?
  157. Compression ratio question.
  158. Head Brands and successful numbers??
  159. Parts that im looking at
  160. Belt drive options for cam?
  161. Engine Swap Questions
  162. Roller rocker issue (noisy after run)
  163. Specific lt1/lt4 intake specs?
  164. Cam profile vs exhaust
  165. Radiator Question
  166. timing
  167. Magnum?
  168. can this head be repaired?
  169. LT1 396 using a 6 inch rod and direct port nitrous?
  170. 702s what do they flow/
  171. Strange lifter adjustment
  172. Can i make my own electric cutout?
  173. crank
  174. Hand porting versus CNC porting. Variations?
  175. Afr 220/227
  176. Importance of intake tubing air velocity?
  177. Spun bearings VS. Head and Cam swaps.
  178. Lifter question, seeking help.....
  179. Mallory 685 +Shift Light questions???
  180. Stroker Build Help !!!
  181. Head and Cam question
  182. RR ratio combo mixing
  183. 408 turbo LT1
  184. Valve to Piston clearance
  185. Many Many questions, pistons, CR, injectors etc...
  186. Street driven & alcohol powered
  187. Had to cut wire harness and splice back together, do you think any prob's will arise?
  188. X pipe and H pipe
  189. Anyone have a guide to home porting a set of Lt1 casting heads?
  190. Specialty Diagnostic tools wanted
  191. Why are LS1 owners reporting HP loses from K&N filters?
  192. SBC Brackets to fit in a 4th gen
  193. thinking about a grand national swap
  194. Alcohol Injection??
  195. Setting Timing - Vacuum and Mechanical
  196. Achieving extra-ordinary VE
  197. simple quick question
  198. Superram with ZZ-X cam, will it work well?
  199. Cam Question
  200. 90 degree elbow & single plane intakes
  201. No optispark and high rpm is what I want!
  202. Importance of valve cover breathers
  203. Which would you prefer in an Engine & Why...Look inside please...
  204. Port volume comparisons.
  205. Cam lobes wiped during breakin
  206. Milling Trick Flow Heads n other stuff
  207. tips on installing new springs on a Jesel Shaft mount s/u
  208. Stroker Clearence Issues ??? Rookie here !!
  209. help with buddies merkur
  210. 3.4 to 5.7 swap. lets talk! all kinds of info wanted
  211. Piston/rod maintenance (uninstalled)
  212. BEST Rings and bearings out there?
  213. Interesting LT1 to distibutor find...
  214. White smoke, but no coolant/oil mix....what is it?
  215. 3.5 inch Y pipe..anyone done it?
  216. Can any one tell me about the fuel you buy at the airport high comp race use ok?
  217. internal engine strength, combustion forces
  218. Figuring Effective lift – HR vs SR
  219. nitrous question
  220. Cam Timing At Lash Point?
  221. fuel pump install???
  222. Hi
  223. Stoichiometry of nitromethane
  224. get smarter.
  225. big block help
  226. Direct injection with spark ignited engines?
  227. jesel belt drive??
  228. GM PM rods
  229. How do I calculate g-forces on a piston?
  230. Question about Valvetrain geometry and will I be pushing it.
  231. LT1 ci question.
  232. Volume flow rate in NA vs FI motor
  233. Diamond or JE Pistons?
  234. Intake runner design, short vs. long. w/pic
  235. 3.8L Wiring Diagrams
  236. Viscoelastic filler for dual mass flywheels
  237. sheet metal intake question
  238. A couple Crazy Questions
  239. measuring crank throw? 355 vs 383
  240. distributor question for an opti swap
  241. DCR on a boosted motor
  242. Setting Valves on LS1/LS6 (Hydraulic Roller)
  243. BBC kinda big cam no brakes
  244. High end studder/power loss..I need help bad guys.
  245. Anyone experienced with Predator carb?
  246. high rpm power loss on new 355
  247. Sm. base circle cam?
  248. How do i build a motor with high hp at lower rpm
  249. Carbed SBC conversion
  250. Oversized Rings?
