Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31
  1. DFI TUNING SHOPS IN NEW JERSEY?
  2. DIY Wideband logging
  3. Cylinder Volume with Tunercat...
  4. Comp Cams 230/236 and Emissions ?
  5. Strange Idle after PCM Tune? IAC Related?
  6. Who makes the best diagnostic/data log program for OBD1 ?
  7. Fastchip or PCMforless
  8. 36* in program....datamaster says 39*
  9. PCM Diagram.
  10. SPLIT BLM'S...SOLVED.
  11. Whats my timing??
  12. Anyone gone from Stock pcm tuning to the F.A.S.T system
  13. Anyone else have issues with AutoTap Windows Software v2.01
  14. Auto X ray
  15. major problem with HPP
  16. SES problem (I know you see these often...sorry)
  17. TC error code 75?????
  18. Tuning For Heat/Humidity
  19. Best place to purchase a PCM???
  20. Blower .bin files.
  21. Tunercat connection issues
  22. Service engine light is driving me crazy!
  23. Problems with ECU
  24. airfoil experience....and IAC counts.
  25. Any programs work w/ MAC?
  26. Internally modify OBDI computer for an OBDII car?
  27. VE Master for 93's?
  28. ( SES ) P0174 Fuel Trim System Lean Bank 2
  29. I know nothing about scanning. Help me out.
  30. How to recalibrate MAF to read to 512 from 471 with Tunercat?
  31. Why does my car purge the ccp so much
  32. No cyl. volume or fuel inj. flow rate in Fastchip program
  33. Left O2 Sensor stuck at 1097mv, even after replacing it
  34. any one have a stock 95 auto bin or lt1 file
  35. Gains from pcmforless with just bolt ons?
  36. LT1 Edit ???
  37. Injuner or some with good tunning skills need help
  38. Dynotuning
  39. Speedo Recalibration
  40. Where to buy Siemens 40amp waterproof relays?
  41. What is the difference between the Hypertech HPP+ & HPP3
  42. Tunercat Flash read/ Exe
  43. want to learn to program
  44. Changes to Injector Offset in LT 1 Edit
  45. Where to get windows version of tunercat??
  46. Alright, I have the Stock Flash of my puter, what next???
  47. lt1 edit.....shft firmness
  48. idle problem after warmup, and...
  49. What is my shift RPM?
  50. Anyone want to take a look at my OBDII LT1 Edit file?
  51. Help! SES Light but no code!
  52. DIY ALDL Cable?? (search)
  53. jet chips,hypertech power mojule....which is best
  54. what programmer should I buy to do the following?
  55. Opening freescan files..?
  56. 02 sensor and/or O2 simulator?
  57. Need help troubleshooting '97 SS
  58. LT1 Edit for '94?
  59. Modified A4 users, need tranny help
  60. Where can I find pinouts?
  61. DTC 26 quad driver module
  62. How do you..........
  63. Hitting Rev Limiter on 1-2 Shift...
  64. need info on program change after rear gear change on A4 car
  65. Checksum ? from Lt-1 Edit
  66. DIE REV LIMITER DIE!!!!!!!!!!!!!!!
  67. could the TPS really make a difference???
  68. Mr. Mattei, I need help on my programming-new 24lb svo's
  69. Need help w/ laptop and tunercat
  70. B.S. Gains
  71. lt1 edit
  72. PCM interchangability!!!!!!!!! VERY COOL
  73. diagnostic equipment
  74. went over pothole,,now no power windows and radio???
  75. something gone wrong after warm up
  76. Trans pressure tables in Tunercat
  77. Any one have the Windows based flash program for Tunercat??
  78. tuning?
  79. Locked hypertech, need help!
  80. HOW DO I KEEP MY 4L60 TRANNY'S TORQUE CONVERTER FROM LOCKING UP IN 3RD GEAR AT WOT?
  81. Consequences of Exhaust leaks..
  82. Mr Mattei- You still around?
  83. PC to ALDL question, ie. programming with a homeade PC-ALDL cable
  84. Jet Stage 2 chip???
  85. So many Fuel Injection Setups.!!!!! Help Me choose
  86. A4 manual shift 2 - 3 hits limiter
  87. Where to find .BIN or .LT1 tune files????
  88. WANTED : stock 93 bin file
  89. Flow rate
  90. Mode 6 scan codes
  91. Fan Issue
  92. whos running constant open loop?
  93. Where can i get LT1 edit....And would it really benefit me?????
  94. Long term fuel trim question
  95. Security light?
  96. Where to Buy Wideband O2 Sensor
  97. Corvette LT1 computer Q's
  98. any recommended tuning for my new set up ?
  99. Anyone use the dyno inside Datamaster?
  100. In tunercat... Which is the PE table?
  101. Quick FreeScan Question
  102. Upload/download files
  103. Tuning
  104. tuning msd digital 6?
  105. Urgent: PC- ALDL Interface Question regarding Port Power.
  106. Tuning with lt1 edit?
  107. Having problems with tunercat
  108. Part Nos for piggyback/eprom
  109. Autotap???
  110. What about tuner software for a PALM??
  111. Review Datamaster File: Shakey on top end, slow MPH?
  112. Some questions about programming
  113. Scan Master Rin=88, Lin=185, what the.....
  114. Need help tuning VE tables on 93 Z
  115. Need Stock .bin file for LT1 A4 3:23
  116. Programming a '97Z
  117. 96 Computer ID
  118. PE table in Tuner Cat?
  119. LT1 PCM for 400 sbc and FAST eDist compatibility ??
  120. How to lower BLMs?
  121. Problems w/ FreeScan
  122. Question about tuning?
  123. TunerCAT tables for Burst Knock????
  124. 93 SC bin files
  125. Rough cold idle, tuning tips?
  126. Sensor in washer reserve?
  127. pcm problem.....
  128. Anyone try the Line Pressure Mod in WOT vs RPM (TC)?
  129. Anybody using USB/serial converter?
  130. Vigilante 3200 now I need pcm help!
  131. LT1_edit: Would someone tell me how to move shift-points both upshift and downshift??
  132. Looking for 1995 Bin
  133. Problems with 98 LS1 PCM
  134. Tunercat starting point
  135. I just bought new computer, downloaded prog,but
  136. Computer newbie...some basic materials questions
  137. anyone ever put a carb and single plane int on a 94
  138. TC- Editing the %Change F/A vs. Cool Temp WOT
  139. Odd BLMs only on cell 06.
  140. what to use to program an LS6?
  141. Finally got it to work now what
  142. looking for work
  143. Datamaster/freescan
  144. SES light flashes after program
  145. LT1-Edit; How to compensate for changing from 5 --> 8lbs of boost?
  146. Any one have some shift point tables for 3.42 gears??
  147. LT1 Edit/BIN files for stock/modded cars
  148. Help
  149. Is the AFR X 10 file used along with the (2) %Change tables to calc PE???
  150. Stumbling problem, extremely rich. Why??
  151. P0300 code flashing even after being disabled!?!?
  152. I need a Hotcam 3.42 auto bin file please help?
  153. Powerdyne6#, pulling PE like crazy and still rich?
  154. Can you adjust injector size in Tunercat??
  155. where to start w/ tuning
  156. I want my A4 to shift harder
  157. ? For those with Trans Performance button in TA
  158. weird, stupid ses light.
  159. Code 43...should I start with KM or KS?
  160. PCMforless.com
  161. service engine soon light after ran out of gas
  162. Anyone successfully tune with an FMU?
  163. Paging Michigan Skip
  164. Please help - I can't get DataMaster to work!
  165. 3" Cat SES Light ... 0420
  166. PCM kills tranny regularly(4x's in 6K)
  167. Problem reading PCM
  168. Anyone w/ .bin or .lt1 files inside please! :)
  169. Basic Hypertech Question
  170. Lookin for a 396 blown + stroked lt1 edit file
  171. tuning issues for tight LSA cam
  172. 383 D1 file?
  173. '97 pcm in a '94 z28
  174. Question about reprogram after cam install
  175. What is an opti?
  176. Need 323 A4 trans tables
  177. False Knock Caused by dirty O2 Sensors????
  178. Finally found that dang auto 3rd gear hang...
  179. Computer Codes not displayed
  180. LT1 Edit File for cam and heads
  181. LS1 edit idle return adjust?
  182. First run on open loop 13.3@98, 9 degrees retard!
  183. What pcm's will interchange with mine?
  184. Just got my new Laptop, what kinna programs can i get?
  185. Help code 36, 42
  186. need help with TunerCat security error
  187. 93 LT1 computer upgrade options?
  188. How important is it to program PCM after gear swap?
  189. If my WOT mph shift points are.....
  190. PCM forless tuning options
  191. MAF out of range and injector locking
  192. Is changing the injector voltage necessary?
  193. How much hp would I gain on a dyno tune vs. mail order
  194. Need some help with split idle blm's...
  195. offsets for seimans injectors? idle problems also, after injectors.
  196. Broken digital odometer ??
  197. MALF 34 + 16 on LT1
  198. Guys who know A4 trannies, shift points...
  199. How to adjust Shift Points?
  200. LT1 Edit?
  201. Using LT1 Edit for my 97 Z-28 (OBDII)
  202. Help ASR won't turn on
  203. Hal- What Should I Shift at ?
  204. LT1 scanmaster-blow up Prom?
  205. EGR
  206. What does PCMForless actually program in PCM to gain the extra 10 horse???
  207. Programming tranny pressures now....
  208. questions tuning with MAFT+ and Auto X ray.
  209. Can an ECM be programmed for a different year or type of car?
  210. What should my Idle RPM be?
  211. 95 m6 file
  212. my car is running rich.....
  213. Do I HAVE to have my pcm programed with a cam
  214. Anyone else running Speed-Pro(FAST)?
  215. 160 thermostat
  216. Who runs a scanmaster in a 97 SSor Z28?
  217. If you run obd1 in a 97 car will scanmaster read trouble codes?
  218. Raising Rev Limiter
  219. Computer Problems
  220. reverse lockout
  221. heads cam file for auto
  222. Ed Wright tuning
  223. MAFT worth it?
  224. Tuning newbie - I got questions for those who have gone before......
  225. What better for tuning (perf application) LT1 Edit for OBDI or OBDII
  226. Archive of .bin or .lt1 files?
  227. Putting a used PCM to replace current PCM with LT1 Edit??
  228. anyone close by that can scan my car for me?
  229. Fan settings, what is stock and what should they be set at??
  230. cruise controll not working....and hints tips??
  231. Bin and Lt1 files. I am sick of waiting. bring it on
  232. Can Tunnercat work for an OBDII?
  233. Reseting BLM's after programming for SVO's.
  234. Anyone have some trans tables to make my 4L60E live??
  235. OBD1 conversion now I'm having high stall problem?
  236. lt1 edit cable
  237. Trouble codes??
  238. Any software available for the Palm and OBD1??
  239. OBDII to I conversion- Can still diagnosis computer problems?
  240. Can the computer ignore your LT1 Edit commands?
  241. ANY Accel DFI Calmap files?? please
  242. What Do VE Tables DO Exactly?
  243. Learn enabled on LT1-Edt??
  244. OBD2 LT1 edit help
  245. Please help me get my car tuned .
  246. Edit out Skip shift OBD1???
  247. Turning off knock sensor
  248. Accel DFI 6.0 files
  249. 26# injectors
  250. hypertech
