Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32
  1. DIY O2 simulators?
  2. Stupid Govener
  3. TunerCat A/F Ratio Spreadsheet
  4. Tuner resource page
  5. Datamaster/Freescan help
  6. Computer problem with swap
  7. New to TunerCat need some help
  8. Freescan help!
  9. code
  10. Can I program the car to eliminate misshifts? (lock unwanted gears)
  11. Open element breather causing hi BLMs?
  12. slow to return to idle speeed while coasting? (6M)
  13. datamaster.....Cyl ID#. what is it.
  14. tuning for a 58mm tb
  15. Runs like crap after longtube install, getting codes please help!
  16. SES light
  17. Tuning without FMU and I need a supercharger program.
  18. No fuel or spark
  19. programming mode?!?!?!
  20. Change Knock Sensor with OBD2 -> OBDI Conversion?
  21. LTCC wiring problem...need help
  22. Need knock counter explination please...
  23. o2 readings
  24. Where is a good LT1 PCM tuner SoCal?
  25. need some diagnostic help...
  26. How does programing change shift points?
  27. How do I tune out burst knock...
  28. Is it possible to put a LS1 PCM and harness on an LT1?
  29. Scan tool for a Jeep??
  30. I need a .bin or .lt1 with the high stall fix...
  31. looking for Accel gen VII tunes
  32. What's the best way to tune Speed Density?
  33. What is a Scanmaster?
  34. reseting computer
  35. vortech tuning
  36. LT1 DataMaster, where's the MAF counts? ?
  37. Keyless Entry
  38. Why do people say the Granatelli MAF's Suck?
  39. LT1_EDIT PCM Tweaking
  40. Scanmaster Output
  41. What tables the ECM uses to calculate a/f in different modes?
  42. BCM Question..
  43. cloning pcms?
  44. Accel DFI Gen VI Question
  45. PCM failure/injector drivers ?? SVO42#
  46. Here my problem what do you guys think?
  47. questions about winaldl
  48. questions about my BLM, AFGS, and BPW readings
  49. Idle / to rich in open loop /
  50. headlights n taillights
  51. any tips on DFI installation, routing, etc....
  52. stock 1995 z28 LT1 a4 3.23 .bin file
  53. Rookie to LT1 Edit!
  54. speedo in-op
  55. web page/pages on tuning,
  56. odb1 high stall problem
  57. Rpm limit on stock pcm
  58. programming/diagnostics for a 3.4L v6
  59. GEN7 DFI LT1/LT4 For Sale
  60. Need Help Diagnosing Car from DataMaster Files
  61. XP and datamaster
  62. I'm a newbie...need help with VATS
  63. General LT1 edit question
  64. Bad PCM?
  65. LT1 swap into 55 Chevy
  66. bench programmer for lt1
  67. When is it time for a custom computer program?
  68. Rich at WOT
  69. Tuning help for 1993 LT1!
  70. 86 T/A PCM Part#??
  71. Equipment required?
  72. What should MAP be at WOT?
  73. Scanned my Stroker - What's it all mean?
  74. Dyno A/F question, am I lean?
  75. Holley Commander 950
  76. starting poing..
  77. Is it possible to convert from a 92 LT1 to 94 flash PCM without problems?
  78. What are the best learning bounderies?
  79. DFI harness question
  80. Mail Order Tuning
  81. Newbie to programming needs help.
  82. Good Diagnostic Equipment ?
  83. Anyone have a LT1 Edit Cal w/ a vortech?
  84. o2 readings
  85. madwolf....do you just tune common cams?
  86. Keyless Entry remote number
  87. T56 is out TH400 is now in!
  88. code 1153?
  89. who burns the best 93 chip??
  90. The Willem Eprom programmer?
  91. VE Tables & MAF Cars
  92. High Resolution Sensor
  93. Can someone look at this cvs log for me??
  94. Car wont run without MAF plugged in!
  95. DO I NEED TO REPROGRAM THE COMP with this cam???
  96. How to test PCM?
  97. Pardon My Ignorance but . . .
  98. are the 93z & 94z body harness the same
  99. lt1 Edit!!!
  100. How good is an Acell GEN 6 DFI system?
  101. How much slower will a car pulling 15 degrees of timing run?
  102. Why did I lose communications? Please help!
  103. Here my problem? To all the big brains out their
  104. TunerCat or LT1 Edit
  105. How do you affect A/F ratio at WOT and idle?
  106. 93 speedometer problem
  107. IAC in gear w/cam surge
  108. Just ordered OBDI conv from Madwolf...
  109. New Calif Regs - Won't Pass
  110. Backfires on decelleration and only 15.5 MPG
  111. LT1 Edit or TunerCat on a Palm or PDA?
  112. need a bin file for a 847 and 230-236
  113. Tuning totally in speed density on a MAF car.
  114. Will this programer work with our flash chips?
  115. computer tuning
  116. Quick MAF table question...
  117. 96, want to tune it myself... TunerCat or LT1_Edit?
  118. "Tuning out" cam surge?
  119. Best way...
  120. Accel System 7 Dfi
  121. Tranny Codes
  122. Anyone willing to help me by looking at a Datamaster Log??
  123. lt1 edit
  124. lt1 edit
  125. .ECU file for $DA LT-1 & Winbin
  126. Autotap run? Fuel Trims
  127. Tuning with the knock sensor OFF
  128. how much is a F.A.S.T system??
  129. Major Question In Here Regards To Tunning
  130. need help with tunercat( wot tuning)
  131. sending pcm to madz28 in the morning...
  132. In car tuning?
  133. is it possable to tune to pass emissions
  134. had chip reprogrammed for n20.....now car smokes blue smoke....
  135. Freescan, Datamaster, Tunercat.....
  136. Did I fry my pcm?
  137. MADZ28 will be closed DEC12-JAN12. Check for savings inside...
  138. iac ohms
  139. Help Deciphering EFI Live Data
  140. -40* timing????
  141. knock counts on startup?
  142. got msd dist in. how do i make it work?
  143. tuner cat( vol efficiency vs rpm vs map) w/ hotcam
  144. Lt1 Edit
  145. Help Suck In Lafayette, Freescan info...
  146. How much Spark Advance is to much?
  147. Wasting my time?
  148. what is this table used for ( in tuner cat)
  149. Datamaster log files - stock A4
  150. IAT temperature reading vs spark retard
  151. Programming for bracket racing?
  152. low power, high & split BLMs, need ideas!
  153. How hard would it be to tune my car on the dyno?
  154. LT1 Scanmaster install
  155. Cut o2 harness now SES
  156. tunercat help, which table?
  157. Delete 02's?
  158. Wideband 02 as stock replacements?
  159. Air Bank Fault?!?!
  160. Jet Power Commander - Few Questions
  161. LT1 Edit help
  162. Tune on the Fly Tunercat???
  163. What is C220
  164. OBDI conversion questions
  165. Is this normal when I flash?
  166. Torque Management
  167. Fuel injector size question inside please...
  168. PE table for stock car
  169. LT4 converted idling 108 blms
  170. Tuner Cat Help
  171. OBD 2 not responding
  172. Diable Predator Tuning vs Custome Tuning at a Dyno shop
  173. Freescan question
  174. Cruise control doesnt work- Does it go Through VATs box under Glovebox?
  175. new lt1 383, newbie to computer tuning,what to do?
  176. What do you think of this???
  177. 6sp conversion & LT1 edit
  178. Anyone know where I can go to reflash my OBD I PCM?
  179. Tuning for open loop performance/mileage
  180. Questions about datamaster
  181. How to tune for vacuum?
  182. voltage and pcm
  183. ? about thermostat
  184. aldl timing adj?
  185. Laptop for tuning
  186. ? on scanning a 95 OBDII/OBDI
  187. GM Drive Cycle - Smog incomplete
  188. whats a GOOD program to view what my car is doing?
  189. Is this a tuning problem?
  190. Computer Code testing
  191. Computer will not learn idle...
  192. predator programer
  193. Definition file (help)
  194. Speed Density Help
  195. LS1 Edit- multiple license question
  196. Rich on cold start? LT1 editor
  197. Split BLMs on 95Z
  198. obd1 and obd2 knock module?
  199. anybody with new dell or usb port on their labtop?
  200. Need a tune for diagnostic purposes
  201. can this cause o2 sensors to be bad?
  202. URL for diagnostic software?
  203. obd1 or obd2
  204. MALF 83: TCC Control Feedback Fault
  205. Resetting ABS Computer
  206. LT1 Edit guys LOOK
  207. PCM burnt or Trans Bad
  208. Very Very NEW to programing
  209. datamaster problems, wont read PCM
  210. Interesting Sticky Thread on VE
  211. How much does LT1 Edit Cost?
  212. BLM's at 108
  213. Misfire problem/comp not reading
  214. PCM for Chevy Vortec 8100 engine
  215. better shifting for a stock 95 w/ 3.23s
  216. Socketed PCM not working
  217. car wont start
  218. WTF are "readiness" codes?
  219. tunercat questions
  220. Any better tuning resources?
  221. Anyone have a bin file for 306 comp?
  222. installed cc306 stock tuning question
  223. tunercat pcm mem program error?
  224. CC306 Re-Programming?!?!
  225. headlight?
  226. HELP cant read or reprogram pcm(tunercat)
  227. Swapping 96 PCM for 94
  228. Injector Constant Question
  229. Need Shift Tables For A4 with 4.10's... Help!
  230. Horn won't honk
  231. Crank fuel enrichment problem on '95 LT1 w/ 84# injectors
  232. any laptop programs that will interface the ABS?
  233. Where can I buy new PCM cheap for 93?
  234. This makes NO SENSE.. Auto Tuning...
  235. 93 speedo reprogram please HELP!!!
  236. What is the proper injector constant setting for Lucas 42lb/Hr injectors?
  237. New GM ECM Tuning tool
  238. pcmforless?
  239. Stock MAF vs Ported MAF vs Granatelli
  240. Injector offsets ? 42# SVO
  241. Scanmaster or equiv on '93 Z28
  242. cooling fans won't kick on
  243. how come no one has made a PC program that mimics a tech2?
  244. No injector pulse, no start..
  245. shift time VS TPS
  246. ?
  247. shift vs mph and rpm
  248. LT1 Edit (only OBDII and NJ people need read this)
  249. Reducing power through programming - tire spin issues
  250. Ford SVO 30# injectors, put them in as 30# or??
