Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32
  1. what the hell?
  2. (ATT. ANDREW)Erasing 93 EPROM Chip question...
  3. Wiring my drag car
  4. Idle tuning...
  5. New PCM
  6. What are some tuning tips for Stock then a Hotcam,bolt on car? 2 part question..
  7. Shift tables 95 a4 3.23
  8. Need help tuning in the NW Indiana Area
  9. Need a Stock TunerCat File for 95 A4 3.23 Car...
  10. Open Loop Obd2 Lt1 Tunes?!!?
  11. Autotap
  12. How to change Air/Fuel mixture in open loop
  13. Anybody get to look at a stock LT4 file?
  14. Why does the A/F ratio @ WOT table zig-zag?
  15. Question about LT1Edit log file data
  16. Wiring in FAST ecu
  17. OBD1 & Maxing out MAF
  18. Power Programmer?
  19. Looking for a LT1 bin file w/ the follwoing
  20. 94Z for my son
  21. Injector offsets
  22. Need source for packard metri-pack connector
  23. LS1/LT1 Edit
  24. leaning a/f ratio ( mass air)
  25. everyone running with no cat's in here
  26. Low end tuning and cam surge.
  27. What kind of wire does AKM use for the cables?
  28. idle at 65 KPA....what in the world
  29. byrans fix for obd1 stall
  30. Car stays into Open loop... could this be the work of PCMforLESS?
  31. Tuner Cat: Idle % Fuel/Air Table Question
  32. who has split idle BLMs b/c of a cam?
  33. question about tuning with timing
  34. injector setting seems WAY off.
  35. What all is Needed??? OBD-1 2 OBD-II????
  36. Can I make my car stay in open loop?
  37. what shift tables and tcc tables to use...
  38. VSS Buffer?
  39. idling/running rich, causes bog on heavy throttle
  40. Is this in any way remotely possible? pcm chip related
  41. Datamaster File inside, help me plz
  42. Ok..datamaster working with F5U103...LT1 Edit no go?!?!
  43. Diagnostic Software
  44. Need help deciding ECU upgrade path..
  45. speed limiter
  46. BLMs 160/160 at idle
  47. Tunercat free eval question
  48. 93 Tuning parts
  49. Datamaster log, please help
  50. LS1edit to bin
  51. 97 PCM pin outs
  52. Can a car with an LS1 edit program possibly fall in and out of tune?
  53. Tuning w/ Tunercat
  54. oil temp settings in tunercat
  55. What cable should I buy to scann and program my comp?
  56. Stock 02 shift points in rpms?
  57. Need stock bins - ASKW, ASKU, BDLF, BDLD & BDLC
  58. Installed Granatelli 85mm MAF. Need to program PCM??
  59. Someone help!! Starts up but turns off in 1 sec
  60. 60mph in 6th gear vibration
  61. P0102 Mass Or Volume Air Flow Circuit Low Input
  62. What's needed with Tunercat to program?
  63. 3800 PCM Tuning
  64. madz28.com?
  65. ccsmotorsport
  66. Where do i start?
  67. VE Master results
  68. Need help with TABLE in tunercat
  69. How do you switch your PCM to the performance tables?
  70. Activation wire
  71. CC306 and tunercat ?
  72. LT1 edit and real time tuning...
  73. Tuning Help plez
  74. Simple way to lower BLMs?
  75. Does F.A.S.T. make your car emission illegal?
  76. Tunercat Scaler
  77. Could use some help.....
  78. Need copy of Drag2003 demo
  79. Thats it I am taking the plunge... Tunercat? help please.
  80. auto-tap question
  81. timimg advance
  82. Any reason not to lower IAC Park position?
  83. BLM boundaries HELP !
  84. speedo and tach problem, related?
  85. 370+ rwhp tune help
  86. looking to do my own tuning??
  87. MAP sensor readings during dyno pull?
  88. Paging Dan K!!!!!!!
  89. LT1edit and TunerCat
  90. OBD1 High stall fix?
  91. O2 sensor problem.
  92. power programmer worth the $$$?
  93. MAF tables
  94. Looking for some good free Software
  95. in LT1Edit program, what folder to open??
  96. Problems Programming Flash Chips with PP2
  97. Best way to learn?
  98. After tuning, runs in P + N, but not D or R?
  99. VE Table Accell Gen VII+
  100. 383 Hot Cam And Ported Heads File
  101. Tuning DFI in Indiana
  102. OBD1 Hades
  103. 1.5*-2.0* KR at idle?
  104. Motor spec program
  105. Bypass VATS questions
  106. helping a guy get his car going with 42# SVOs
  107. Using Camaro program in Corvette?
  108. high maf readings
  109. ECM constants ????
  110. Programming
  111. Why does my STOCK MAF keep throwing a P0103 code?
  112. PCM programming cables and software????
  113. Datamaster
  114. Programming for my OBD1 conversion....
  115. Code 43 question....
  116. Clutch Switch
  117. Dyno Tune or LT1 Edit?
  118. Dyno Tune or LT1 Edit?
  119. LT1 edit and windows 2000
  120. LT1 edit and windows 2000
  121. Freescan.......from Desktop to Laptop?????
  122. OBDII - RS2323 Cable
  123. Can I use FreeScan on my 95 Formula?
  124. Airbag module reprogramming
  125. Odb2 connector question
  126. need with wot tune
  127. constant table
  128. datamaster 6300 rpm?
  129. help with over all tune
  130. Has anyone had a problem with the Epromer-5????
  131. need chip
  132. how to make my 94 a obd2
  133. How does the PCM make the transmission shift?
  134. 383 guys how much timing at WOT?
  135. CC305 cam, RRs, Headers installed..... where do I start?
  136. A4 with a mind of it's own
  137. Unplug power to ECM for chip change?
  138. a stupid relay
  139. aem for lt1
  140. Madwolf....
  141. Factory computer Limit of a 93 computer..?? 7K ???
  142. Tunercat Question
  143. vats and copying key
  144. data master
  145. wiring/ignition problem
  146. Need help with cells 6&7
  147. car quit PCM to blame???
  148. TunerCat and 24# SVO injector question please....
  149. Just killed 3rd pcm
  150. paging madwolf
  151. What exactly are injector constants?
  152. Tip In Hesitation with Larger SVO Injectors
  153. help with 95 Z28
  154. Gonna have mail order tune, need advice
  155. Question on pulling timing..
  156. Diablo predator?????
  157. desktop programmer tips
  158. Trouble Code P0100
  159. hypertech programmer -> rev limiter & shift rpm
  160. raising rev limiter with tuner cat
  161. desktop programmer
  162. Scanmaster: 5 degrees of retard
  163. Obd-1 to OBD-2 How will I DYNO TUNE??
  164. Stock 95 .LT1 flash....
  165. timing
  166. 383 is running, needs tune tweeks
  167. software: program any OBDII???
  168. The best edit program is....?
  169. questions about f.a.s.t
  170. Raise or lower shift points?
  171. Problems with my tune (FAST)
  172. 30# SVO Offsets vs Voltage
  173. Anyone know the pinout for the opti harness???
  174. Madwolf?
  175. Threw a code- Tranny related
  176. best location for wideband sensor?
  177. What can I program in tunercat for A4 tranny (line pressure, tc lockup, etc.)???
  178. Please Help! Myriad Of Computer/electronic Questions!!!
  179. For those of you that wonder what happens to a stock PCM after 7000 RPMs
  180. Actual line pressure vs. pcm values
  181. OBD 1 swap for 97 Z28....
  182. please look at my datamaster log and make suggestions
  183. Closed TPS vs. Main Timing Maps
  184. .LT1 file
  185. datamaster
  186. Getting AutoXray, what are normal sensor values (LT1)?
  187. Fried the PCM, Maybe ?
  188. Wiring Gearvendors to PCM and A4
  189. why won't freescan show my codes?
  190. Code P1133 AGAIN. Need help!
  191. Scanmaster LT-1 Installation
  192. '93 LT-1 Datamaster files
  193. How to richen up a/f ratio with Tunercat?
  194. Stock 1997 LT1 .bin file
  195. Auto Tap?
  196. OBD-1Con. OBD2 PCM ...How to scan????
  197. Open Loop and Speed Density and O2s
  198. Madwolf
  199. Tunnercat, gear changes, and automatics ?
  200. How do you lean out idle conditions?
  201. What to do next?
  202. my car wont shift help with data master file
  203. spit blm
  204. to use a th400. you program for m6 right?
  205. LT1 Edit?
  206. Will I need a special cable to use this?
  207. Split BLM in all cells, Capped Rich at idle, Capped Lean on Decel
  208. MAF sensor table tunercat
  209. Tuning Help
  210. LT1 edit, can I rewrite a PCMforless program?
  211. best way to tune at idle using an open loop program?
  212. What is the transent fuel function?
  213. What do you gain by running in open loop all the time?
  214. Any adverse effect on injectors when changing constants in pcm?
  215. Tunercat for a 97 LT1
  216. High stall fix needed...
  217. Vortec Computer?
  218. FAST Question
  219. over 80% duty cyl and high full pressure
  220. It got cold, now lots of black smoke at WOT?? couple other questions to
  221. PCMforless Question
  222. New thought on OBD1 high stall problem
  223. Ported MAF & MAF Tables?
  224. needing O2 sensor affects tutorial
  225. OBDII to OBD1 PCM conversion?
  226. Tuning & Datalogs needed.
  227. Using SY/TY engine managment to run V8 turbo.
  228. Auto tap any good?
  229. To Autotap Or Not To Autotap??
  230. Low voltage issue
  231. engine idle and throttle setting
  232. Programming for CC 306 + emissions
  233. which is a better computer?
  234. injector offset vs. Battery voltage table
  235. ses light, knock sensor
  236. Need help socketing & programing pcm.
  237. SES Light?
  238. Data Error and all DTC Codes present in Datamaster?
  239. please take a look at my autotap file
  240. F-body DTC's on a T56 1996 Impala SS
  241. LT1 Edit
  242. Help...want to add a little fuel 4500-6500 rpm's @ wot...
  243. Tunercat for OBD2
  244. Quick ECU question
  245. Best Programmer???
  246. where can I find
  247. Anyone dyno on a Dynapack dynometer?
  248. tps voltage change
  249. I need some software
  250. What would make the PCM change shift points?
