Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32
  1. Autotap users, please help
  2. playing with tuner cat what does shift time mean
  3. 93 chips? What kinda eprom do i buy?
  4. can't get Belkin F5U103 to work
  5. Just used free OBDI scanner, some notes, help me make sense of it!!
  6. 3rd gen ECM probs....
  7. How do you know if freescan info is good
  8. ABS Codes
  9. what changes(tunercat)
  10. T56 to TH400 swap...
  11. GMS MAF & tunercat
  12. tuner cat( individual fuel trim)
  13. Question about cables for LT1 Edit.
  14. SD LT1 tuners - PE vs RPM
  15. Got pcm program need help
  16. We need a "how to tune walkthrough"
  17. Fuel map,Timing table.....
  18. How to Disable PE mode?
  19. scanmaster won't start
  20. Need stock OBDI A4 pcm file for LT1 edit...
  21. dyno 2000 files
  22. How to correct BLM's
  23. will this adapter work?
  24. tuning 2001 GMC truck
  25. Need help!(OBD2 to OBD1 swap)
  26. Datamaster says I have no PCM!
  27. Dont know if one exists, but..
  28. I want high timing file
  29. Who to send my computer too
  30. 78 RF Solenoid Open or Short to Battery???What does it mean??
  31. What do you change when dynoing an A4
  32. Reading plugs to tune WOT
  33. Going to dyno ???
  34. Datamaster scan
  35. FAST Q? Lean spike on tip in?
  36. HELP......PCM not responding
  37. how do i turn off cags/ trouble codes on lt1 edit??
  38. tuning for the track tomorrow....need help
  39. good article on spark timing inside....
  40. A computer ? about engine swaping
  41. possibly bad ground computer problems
  42. Looking to buy tuner cat ?
  43. heads/hotcam program
  44. A home computer problem...
  45. question about obd2 pcm and RPMs
  46. Getting there, just need some assistance...IAC and Idle low
  47. Firming up shifts
  48. SES light/Short Shift
  49. How to "re-play" a log in Autotap??
  50. AFR vs temp weird question
  51. Were do I start?
  52. 1/4 mile test data on a new 396
  53. Removing timing at start up
  54. knock retard--hard starting?
  55. aftermarket computer recommendations
  56. SES lights and tunning
  57. Timing using LS1 edit
  58. Obd1 Chips
  59. Question about adjusting timing...
  60. tunercat(% change to fuel air ratio v.s rpm @wot)
  61. tunercat( geting xtra timing from somewhere?)
  62. 396 lt-1 tuners please read
  63. definition files
  64. DFCO (Decel. Fuel Cut Off) Question
  65. Editor and Lightweight battery
  66. 2nd computer for emissions?
  67. uploading with LT1 edit and then swaping chips?
  68. Hypertech for a 99 V6?
  69. Street wideband - FJO Racing
  70. lt1 editing software?
  71. 350 Computer Crap
  72. code 44 (I think)
  73. Finally fixed the high stall problem!!
  74. Split BLM fix
  75. Brents page of lt1edit files?
  76. how will car run with no coolant temp sensor?
  77. My Z wont start if I drive it on hot days.
  78. 96 LT1 will not start on hot days.
  79. individual cylinder fuel trim tables
  80. need good programmer custom pcm
  81. how do I lower my BLMs?
  82. LT1 transplant w/ A/C
  83. LS1 Custom PCM Tuning in NE Ohio
  84. URL for diagnostic software?
  85. Have some datamaster logs of my car up, opinions??
  86. CAGS trick to disable the dreaded 3-2 shift
  87. Tryin speed density
  88. Ac request signal NON STOCK USES
  89. TPIS chip users?
  90. Why so much Timing
  91. Tuner won't work on my car anymore..
  92. Where to buy LT1 Edit
  93. Fuel Injection not getting Ground Pulse from PCM ... Need Help ASAP
  94. I think PCM problems...
  95. Had car dynotuned and now A/C is affecting tach readings
  96. 93 Lt1 Pcm
  97. Knock retard
  98. BLM short-term corrections in PE mode???
  99. Correcting the VSS from a M6 to 700r4 swap with LT1 Edit
  100. "Transmission Perform" input pin on PCM?
  101. What do i need?
  102. plz take a look at my tune and help
  103. 94 Z blowing the 15amp courtesy fuse
  104. What tuning softwares are out there???
  105. Transmission Shift Table??
  106. WOT tuning's effect on part throttle performance
  107. tuner cat (spec..)
  108. Looking for tuner cat pro
  109. Installed bigger cam,Can I start it up on stock program?
  110. Datalogging
  111. Dependable parts, reasonable prices
  112. Where can I find the .lt1 to .bin (lt1edit to tunercat) converter?
  113. Tranny shift point question
  114. Andrew @ AKMCAbles where is he??
  115. Thanks to Javan at B & B Electronics!
  116. file for 224 236 cam and ported heads
  117. Stock Engine w/ some tuning
  118. PCM Adjusting To New Mods ?
  119. Should i switch to OBD1? What will it do for me?
  120. anybody familiar with the ROMutator?
  121. PCM Reprogramming???
  122. Transmission tables
  123. tuning help, what do i do?
  124. Random multiple DTCs?
  125. How to tune w/ wideband o2?
  126. '02 z28 programming
  127. Open Vs Close Loop
  128. Hmm...how did you tune for gas mileage?
  129. Holy transmission tables/Tunercat
  130. Help with fuel tuning
  131. What are you running for IAC counts at idle?
  132. computer diagnostics with labtop
  133. Anybody know if my injectors are maxed out?
  134. File for XE224/230 with bolt ons
  135. Should I add fuel to my tuning and take 1* of timing back out?
  136. wHAT PROGRAM ARE OUT THERE FOR 97'S
  137. Need stock values in LT4 Main Spark Table
  138. Tunercat & M6 idle tables
  139. %change to fuel/air ratio @ WOT
  140. Read .LT1 pcm file
  141. Tunercat: Low octane tables
  142. LS1 Edit vs. Auto tap
  143. LT1 edit price?
  144. Bad PCM?
  145. Need OBD1 Diagnostic software
  146. Anyone with tuning experience in the Tri Cities MI area?
  147. Anyone Know if a Snap-On OBD-I connector will work with Cable???
  148. new -- TuneMaster
  149. Can i use a "non LT1"scanmaster on my LT1
  150. Who can flash my extra PCM so that I may remove my current one that has LT1 Edit?
  151. Need help with a code
  152. software glitch in lt1edit?
  153. Computer Diag Listing/94 LT1?
  154. 1995 Z28 with obd1 or obd2?
  155. 1 wire to 4 wire o2 conversion question.
  156. Need help FAST PLEASE!!! PCM's keep dying during flash
  157. TPI sd vs LT1 MAF?
  158. Rough Idle/Stalling Datamaster File
  159. Speed Density Tuning Programs Help
  160. ? with gt 100 and detonation
  161. How to Raise Target Idle RPM????
  162. Why dont I have a check engine light?
  163. Interesting thing happened??!! Tunercat!
  164. ECM Constants (everyone read)
  165. Looking for a code listing
  166. Datamaster Problem
  167. BLM's are Low and Car Running Lean on Right Side??
  168. O2 sensor readings in TunerCat
  169. computer programming????
  170. EGR and LT1 edit
  171. Missing link -OBD1 files
  172. Engine idles rough and stalls
  173. is my 95' obdI or obdII?
  174. TTS Datamaster problems
  175. What would cause this miss?
  176. Hesitation, Won't accelerate. Scanmaster readings inside
  177. Question about tuning
  178. grrr...MAP readings:code 33 on Scanmaster, also Lean o2's both sides..need some help!
  179. Trouble with car, bucking/hesistating under 2000 RPM DM logs inside
  180. Request for information on Aftermarket ECM flashing and possible consequences.
  181. newbe
  182. Auto Xray readings...
  183. speedometer wrong. ooops
  184. Fuel pump engaging when trying to reprogram?
  185. Clicking underhood while programming
  186. I want to start experimenting with my car...
  187. Hesitation diagnosis with Datamaster needing help!
  188. car gets too much knock
  189. LT1 edit and delting EGR/AIR
  190. logfile in LT1edit
  191. Obd Ii To Obd I Conversion
  192. 93 Won't run right with piggyback adapter. Help please!!!!
  193. Datamaster help ??????
  194. how to set up idle tuner cat
  195. running on 6 cylinders
  196. OBD1 high stall problem
  197. How to get LT1 computer to work after accident
  198. car has black soot on bumper, how to stop this? w/ tunercat
  199. Ltrem fuel maxed out @ +25
  200. can someone explain to me how to diagnose misfires on OBD1 computers?!?
  201. need cheap computer programming
  202. Need Help With Tuner Cat!!!!
  203. speed limiter
  204. Software
  205. files for 58mm TB
  206. anybody know how to enable closed loop ONLY after 1000 rpms?
  207. Tuning tips?!? Help me out allittle here!
  208. CAN someone look at my DATALOG?
  209. Computer ???
  210. Tuning question on new heads
  211. LT1 edit and EGR
  212. can't read tables window(tuner cat)
  213. OBD1 conversion kit, where to get it??
  214. Looking at buying LT1/LS1 edit.....
  215. What to use to program?
  216. Need OBD2 program again...
  217. PCM Repair after intterupted programming?
  218. VEMaster???
  219. OBD2 code help
  220. Would moving to a lower altitude cause the engine to run leaner?
  221. tunercat/LT1 edit ???
  222. LT1 edit terms
  223. best editor
  224. Easy Datamaster ?
  225. Stupid Laptop wont stay connected..Plz Help!!
  226. how to lean out a/f ratio( tunercat MAF tables)
  227. Problems with andew's aldl converter
  228. Spark Advance on 383
  229. Crank A.I.R.
  230. Air
  231. tunercat help
  232. No serial port on the laptop... USB?
  233. Predator users inside
  234. Help tuner cat security viloation?
  235. Having Trouble Pinpointing Problem
  236. min spark advance v.s rpm(tunercat)
  237. SES Light
  238. how to compensate for cam surge? HELP!
  239. cylinder balance question, thanx.
  240. Performance chip?
  241. idle/air fuel ???
  242. how much to alter MAF tables by for descreened MAF?
  243. Need Help Fast!!!
  244. Strange DataMaster reading - and I mean strange
  245. Help!!
  246. Air/Fuel diagnosis help
  247. Anyone have a stock 3.42 A4 Tunercat BIN file?
  248. Question about valvetrain noise Madwolf!!
  249. SES and CAGS
  250. What causes PCM to go back to open loop after in closed loop?
