Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32
  1. If Im using SVO's and my FP is 50psi....
  2. Which version of Autotap?
  3. Tahoe Programming?????
  4. Converter locking at 105mph, why?
  5. Annoyance with Tunercat
  6. Tuning suggestions needed...Please come in and post.
  7. how do i get cyl vol for 355 ci in tuner cat ?
  8. Help me find Tuner cat/LT1 edit files and the file converter
  9. CAM programing??
  10. tricking emissions
  11. "Not a Licensed PCM"
  12. Why is it that Datamaster only records up to 6375rpm?
  13. Anyone have a stock 96 M6 file?
  14. how do i change a/f ratio at idle in tunercat?
  15. BLMs near 128 but it still smells like raw fuel atidle.
  16. Stuck in cell 16
  17. What kinda AKM cable to I need?
  18. How often do you fry your PCM with TunerCAT?
  19. where are the ls1/lt1 dyno tuners around detroit
  20. Anyone program out cam surge?
  21. OBD2 Autotap users inside please
  22. A:F/PE tables on the wideband
  23. Possible to fry and MSD box by jumping battery??
  24. Sunpro code scanners?
  25. Anyone have a 95 LT1 A4 bin they can email me?
  26. Can anyone look at my autotap log?
  27. PCMCIA & USB Serial Adapters
  28. why wont a scanmaster work in a 93
  29. bin file
  30. Anyone have a bin file for a 94 auto?
  31. Tuning for stall ?s
  32. Where can I go to learn basics about LS1 tuning?
  33. Can some1 tune my OBD2
  34. Flash in Windows or in DOS?
  35. where is PE v.s RPM in tunercat?
  36. How to reflash a new PCM???
  37. lets explain this computer stuff
  38. Can you look at my log file?
  39. Just read the pcm off my ss, now im lost?
  40. Question about stock program and Tunercat
  41. chip for a 93?
  42. Does tunercat need a language convertor ??
  43. PEvsRPM table comparison....stock vs supposed ws6 file.
  44. Cheapest place to purchase F.A.S.T.
  45. ?s about programming
  46. Large CFM MAF Sensors: What's Available?
  47. Disconnect Scanmaster?
  48. hookup regular pc to pcm?
  49. Park/Neutral pin on PCM, do I need it?
  50. new cam is in.. now i have a very large BLM split at cruise?
  51. Lowering idle to get more lope?
  52. Low RPM part throttle timing adjustments for cammed cars?
  53. Need Holley Pro-Jection Program for Slightly Moded 350
  54. LT1 Program Help
  55. No serial port on my new laptop!
  56. Questions about the Predator.
  57. accel 30lb injectors
  58. db25 pin layout
  59. Transmission related tables....How do they affect the tranny?
  60. 93 Speedo settings in TunerCat
  61. Stroker guys. Please post your timing tables.
  62. Is this right cable?
  63. Swapping from 93 to 94 PCM in a custom setup.....
  64. OBD I pcm rev limit?
  65. what are the minimum PC requirements for Freescan? Tunercat? etc...
  66. Knowledgeable OBD2 PCM and electronics guys within...??'s
  67. FAST tuning opinion sought.
  68. Can someone help me figure out whats best for me?
  69. Closed throttle tuning while cruising..
  70. BTC29EAS Electrical Fault?
  71. Anyone have a 96 .LT1 file that is really STOCK? Can you please email it to me?
  72. LT1 Edit and 58 MM throttle body?
  73. 50 lb injectors and LT1 edit help?!
  74. OBD-2.com scanner problem...
  75. Some simple questions for avid tuners!
  76. 96 SS computer different???
  77. Anyone want to look at my autotap file?
  78. predator question?
  79. lt1 edit or tunercat
  80. 1996 Scanner Codes
  81. Disabling the knock sensor and dialing in timing?
  82. what are the requirements......
  83. obd2 trouble codes
  84. How is Map related to closed TPS timing?
  85. Can I add more timing?
  86. Offsets for 42lb Lucas/Delphi injectors
  87. Ses Light Doesnt Work After Programming
  88. Need help with datamaster file...Look inside
  89. Please help with computer problem.
  90. Need some Autotap troubleshooting advise please.
  91. New to LT1 Edit
  92. Calibration File anyone??
  93. Anyone know where i can get GM Weatherpack Crimping tool for a good price?
  94. does a reman. LT1 pcm need to be reflashed?
  95. Knock count
  96. 1996 3.8 Starting Problem
  97. Which ALDL cable to get, AKM or Andy's?
  98. My long term fuel trims are...
  99. Checksum Disabled???
  100. newbie ? how do you burn your own chips?
  101. speed density vs maf for FI?
  102. tuning masters.. i need your assistance with timing!
  103. LT1Edit for free?
  104. DIY o2 sims
  105. PCM for OBDI conversion. A4 or M6 matter?
  106. OBD-2 program help plz
  107. Getting ready to fire the car up but have ? on tuning??
  108. LT1 Files...Can I look at your A4 file?
  109. 0bd1 or 2
  110. A4 Transmission Settings
  111. If I bought LT1 edit, could some of you experts on here help me out.
  112. Increased fuel = increased idle?
  113. Anyone running FAST and an Ignittion Box?
  114. new to this
  115. TunerCat injector offsets for 93's
  116. DTC 55 Fuel Lean Monitor
  117. 93 Stock Chips Question
  118. tuning stuff
  119. ported MAF sensor
  120. Price for a tunercat tune?
  121. URGENT car wont run
  122. 42# SVO "Lightening" injector help?
  123. knock retard at just 10-12% throttle???
  124. mass air for speed density??
  125. anyone have O2 sensor voltage/ fuel ratio chart
  126. Still having trouble
  127. Engine VE
  128. Will a '94 computer bolt up to a '93?
  129. What power adder is easiest to tune for?? N2O vs Blower??
  130. timing question
  131. Cable question
  132. problem with A31p IBM laptop and AKM cable
  133. With tunercat or LT1 edit can u tell the PC that it has 28 lbs/hr FI's?
  134. MSD Start/Retard Box, affecting timing?
  135. B&M 3000 & Tuner Cat???
  136. How much wot timing can this car run?
  137. Simply question about turnercat
  138. OBD2 to 1 conversion.
  139. Could a bad O2 cause....
  140. PCM Programming Prob
  141. '95 Dodge diesel computer reprogram
  142. what's the deal? no tunercat for obdII?!
  143. lean bank 2 LS1
  144. Checking SES light without HPP or laptop
  145. Tuner Cat 1.98
  146. PCM "loses it memory"
  147. Makin the A4 shift
  148. how to comp. scan 5.7 ltr vortec tahoe?
  149. question about ses codes
  150. Anyone have FAST file?
  151. Can someone clairify
  152. Low Trac Light On And Abs Keeps Comming On?
  153. Conversion ODBII to ODBI Speed Density
  154. LS1 Tuning
  155. keep frying pcms with tunnercat uploader
  156. tunercat injector help needed
  157. Easy ? About VE Tables and MAF Tables..
  158. Heads/ Cam Upgrade
  159. F.A.S.T. tuning question
  160. PCM for less tune ??
  161. Does a Bad Injector Driver Mean a Bad PCM?
  162. How do I make a '94 LT1 OBD2?
  163. Where to put scanmaster on TA?
  164. May have found a solution to KR...please check out!
  165. Newbie can't get Freescan to work, help?
  166. Spark advance under boost question?
  167. low coolant temp code keeps coming up
  168. Code P1107?
  169. Who wants to evaluate my freescan logs.
  170. MAF table Hz - what are they?
  171. Wideband dynoing - new bung required?
  172. Autotap 02mv Question??
  173. How to make my A4 shift like it has a shift kit?
  174. odd OBDII code problem
  175. I have windows 95, do I need to upgrade
  176. Getting a few codes, please help?
  177. Spark advance, please help.
  178. Where is extra advance coming from?
  179. Looking for a FAST file for a 396
  180. Speaking of data loggers...
  181. KR when shifting
  182. tuning advice
  183. How does PCM read speed?
  184. A4 tranny bounces off rev limiter before shift after programming?
  185. why cant i read using tunercat ? used to read just fine
  186. anyone used the RT tuner with the Xtronics ROMulator ?
  187. Can a piggyback chip be installed backwards???
  188. AutoTap Users: C'mon In
  189. Cell 18 for anything off idle?
  190. egr and timing advance ???s
  191. I want to use Granatelli LS1 MAF, need help!!!
  192. Hooking a 93z to a laptop??? New chips?
  193. how do i change idle rpm with tunercat?
  194. Transmission line pressures
  195. Spark advance!!!
  196. Accuracy on DIY wideband from techedge Australia
  197. ever fry a PCM and get it replaced under warrenty
  198. Oxygen Sensor Readings
  199. Using AutoXray with gutted car
  200. someone please help me with this airbag light
  201. cant fix my 1800-2000 RPM knock retard!
  202. Laptop Mount
  203. Wrecked My 98... Cant Reprogram My Hypertech
  204. A4 Tuner Cat shift table question?
  205. can someone explain what wideband 02 dyno is
  206. Trouble w/DataMaster (trial expired but i have even recorded a run)
  207. getting into tuning?
  208. Need help with low RPM bucking and surging..
  209. can guys running LT1-Edit use bin files from someone w/tunercat and vise versa
  210. Which code reader?
  211. What table in tunercat to lower shift rpms?
  212. new to tunercat
  213. 140 IAC Count from Scanmaster??
  214. SES light again
  215. PE tuning
  216. a4 and tuner cat
  217. Is this possible?
  218. Sorry tried both Tuning and LT1 Tech. Need tuner cat help.
  219. ses light and code downlaod
  220. startup problems
  221. LT1 computer control of third-gen style dist
  222. Wideband O2
  223. Can someone email me a stock A4 text file from Tunercat.
  224. new to programming send me your tuner cat files please
  225. what is your WOT timing?
  226. PCM Programing
  227. What Cylinder Size do I use in LT-1 Edit
  228. BLM's need some help see inside?
  229. Disable EGR in LT1 Edit
  230. Cylinder volume for my 355 ?
  231. If madwolf does my proggy, what all do I need to datalog and poss slight tune
  232. Alpha N
  233. 26 and 46 error codes
  234. Cheaper alternative to AKM cable?
  235. i need a program for sunday !!!!!!!!
  236. PUtting 96 trans in 94 car; PCM conflicts?
  237. Questions about Tunercat
  238. Tuning Problems
  239. Who uses OBDII on their modified LT1?
  240. ? About Mr.Dyno.com equipment
  241. Custom chip for charger??
  242. LT1 Edit Starting Point
  243. LT4 HotCam File
  244. sevice codes??
  245. Anyone ever add (+) fuel in PE mode?
  246. No one can give me a diagnostic! anyone ever have this promblem?
  247. Best OBDII scan tool...
  248. Question about LS1 edit
  249. How to tune for timing on the streets?
  250. WOT Tuning Without a Wideband - A Discussion
