Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32
  1. Computer corrects too lean...
  2. 93' no spark adv & ping w/ load?
  3. Racing CAGS
  4. TunerCat puestion
  5. How can I make the car go into closed loop faster?
  6. Any info on Pcmforless dyno tuning would be greatly appreciated!
  7. FreeScan Help
  8. Tip in problem
  9. Tip in problem
  10. 383" 224/236 36#injectors ... will this work?
  11. OBD1/OBD2 Question
  12. Spark Retard without increased Knock Counts?
  13. A few questions on DFI
  14. Lean at part throttle?
  15. PCM locked out by Ed Wright. Need options
  16. Learning how to Program
  17. need technical advice
  18. misfires
  19. LT1 tuning/diagnostics
  20. Good tunning?
  21. Did I disable cags right?
  22. Check out my Freescan Track data. Looking for suggestions...
  23. Need a lt1 edit file for a stock lt1 supercharged car.
  24. PDA, LT1, Need Help w/Editing
  25. anyone with OBD2 dyno experience HELP
  26. Auto file in M6 car
  27. Tune help please
  28. 94PCM in 93 car
  29. 97 PCM in a 95
  30. LT1 base gen 6 DFI maps needed
  31. When are Predator Updates going to be available online?
  32. is this too much timing?
  33. High KS Count without any Spark retard
  34. 95 PCM issues...
  35. what will tuning do for me??
  36. Shift firmess value #
  37. TurboLink Promo
  38. Tunercat help
  39. Need PCM options and opinions
  40. VE tables and increasing displacement
  41. pcm wiring
  42. Lt4 Knock module vs. Lt1 Knock Module
  43. 93Z, looking for Data Program, DataMaster or Turbo-Link???
  44. Why remove EGR???
  45. Tuning A/F ratio?
  46. How high to adjust line pressure?
  47. How does this timing table look?
  48. Will Predator void my warranty?
  49. Making my own OBD 1/2 Cable for 95 Z
  50. HPP3 VIN mismatch...how to get it back to stock...
  51. More problems with F.A.S.T
  52. Why can't I get AT EFI Live5.0 to work???
  53. This cannot be good......
  54. Idle MAP Cell 4?
  55. v6-lt1 swap qpu question
  56. Will this cable work with LT1edit/free scan on my 95 Z?
  57. When to switch to aftermarket?
  58. Helpp!!! I Need Pcm Tuning For 96 Z In Nj A.s.a.p.
  59. Data Master engine DTC error
  60. LT1 Edit A4/ shiftpoints
  61. computer edit for m6
  62. Paging Andrew Mattei
  63. Looking for PCM file.
  64. Individual Cylinder Fuel trims
  65. Tuner cat or LT1edit?
  66. VEmaster results... Look....
  67. TunerCat timing tables, which way to go...
  68. Injector constant and offsets??
  69. best software to scan/program LT1s
  70. Would anyone like to see a tuning column in GMHP??
  71. What to do first with tunercat?!
  72. no OBD link in a 93?
  73. How do I use freescan properly?
  74. flash chip sockets
  75. Guys running NOS and tuning themselves, quick question inside please...
  76. changing injector
  77. Injectors, Fuel pump, and Dry kit question inside please...
  78. Reading DTC's w/ PCMCOMM from Carputing
  79. ses light still on
  80. LT1 Edit files for CC XE 224/230? Anyone?
  81. where to buy tuner cat or lt1 edit?
  82. Benefit of alot of timing at a high KPA and low RPM?
  83. F.A.S.T. who deals real cheap ?
  84. In the power enrichment vs RPM table...
  85. Trouble Code Help. Please?
  86. LT1 edit w/ PCM For Less
  87. Help with Tunercat
  88. swap question about my computer HELP
  89. KR upon startup--stall condition
  90. does anyone have desktop drag2000?
  91. Gear ratio/top speed limiter
  92. Programming help tunercat?
  93. torqe conv. lock up switch question
  94. Tunercat second to none!!!!
  95. Fan Temps ?
  96. Scanmaster LT1 and scanmaster 2.0
  97. who sockects pcms
  98. PCMForLess guys is ill, anybody know where I can get new program?
  99. LS1 edit files
  100. crank trigger ignition ???
  101. OBDI trouble code 11?! Help
  102. tuning for an ls1
  103. Tuning for 1.6RR
  104. Help: Error during programming with PCMforless
  105. PCM bench tuning
  106. Code P1336 HELP!
  107. Is there any point in correcting...
  108. prom chips!
  109. SES and stock programing
  110. Turnaround time for receiving LT1 edit?
  111. Data Master/ glowing headers
  112. Auto computer EXPERTS inside please
  113. running rich
  114. DIY o2 sims (possible?)
  115. SES light, low water temp, cooling fans stay on
  116. Dfco
  117. DATAMASTER veiwed parameters
  118. What can be read from OBD-II plug?
  119. Funny Injector size
  120. VEMaster!?!
  121. Have datamaster....what info for bad map?
  122. Wiring LT1 to a 3rd gen
  123. injector offset
  124. GOOD tune for XE224/230 stock heads??
  125. What is the differance between F.A.S.T. system bank/bank +sequential?
  126. Predator owners, what do you think about logging?
  127. Quick fuel pump question please....
  128. How to Erase trouble codes
  129. SES is killing the joy
  130. How much can I gain from computer programming
  131. FAST eDIST with FAST SEFi and LS1 Coils
  132. Playing with FAST. Car is'fa*ting'?
  133. EPROM Programmers and eraser.. which one works?
  134. need a GOOD tune for 355ci w/hot cam ported heads
  135. programming for 3200 stall
  136. SES Trouble...Help
  137. wanted:stock tpi bin file
  138. where to get calibration file $42
  139. Just fried my computer?
  140. HELP:installed MSD-6A-ASR service light on?
  141. OBDI conversion worth it?
  142. This place isn't very busy
  143. 4L60E to a turbo 350....what to change flash program?
  144. need help with tunercat
  145. LT1 AIR/EGR technical question
  146. Anything I can do programming wise to increase my off-the-throttle vaccum??
  147. Cc306
  148. Understanding DataMaster information? Max and min values???
  149. ??? for you pcm pros
  150. early OBD2 no scan, error
  151. Computer Problem??
  152. For Sale LS1 Edit and Two 98 PCMs
  153. woohoo
  154. tuning shop needed in S. FL
  155. seat belt
  156. Datalogging Question (Datamaster, Free Scan)
  157. Can I disable Traction control
  158. Does the cam LSA effect tuning at all?
  159. Bought and installed the serial-to-usb adapter for laptop...still nothing!
  160. need $ee calibration file
  161. serial to parallel adapter for autotap? possible?
  162. Just getting into Programming, few questions....
  163. Oxygen Sensor Simulators
  164. BLM Locker
  165. where to get dyno tune
  166. CCXE 230-242 program changes?
  167. FAST Programming
  168. xe230/236 ported heads need tuning help
  169. Best Book For Learning What each Readout Means
  170. URGENT: Need help on Wiring
  171. URGENT: Need help
  172. PE tuning for 1228746/L03
  173. free scan (doing strange stuff) ver 2.07
  174. Anybody know how to lock the TC in the computer?
  175. MSD 3-step question
  176. 99 Z and Hypertech
  177. Car won’t run when MAF is disconnected?
  178. I am running lean with Headers
  179. help with error code
  180. Adjusting speedo calibration with Tunercat?
  181. '95 V6 Camaro Question...
  182. Tech edge Wideband setup. Where did ya tap in the RPM wire for logging?
  183. Tuning in general
  184. Advantages of using LT1 Edit on an OBD2 VS and OBD1?
  185. A4-M6 swap.is the wiring the same as 97' for a 99'
  186. blown 383 Solid Roller files?
  187. How does low octane retard work?
  188. Flshread.exe error #5 address 9039? Anybody know what this is?
  189. Opti Spark low res wave form questions
  190. 93 Diagnostics SES Light
  191. How Do I Check BLM'S
  192. I have exactly 1 week to get this right....please take a minute to look
  193. Stock OBD2 tune and larger injectors
  194. Wiring oil temperature sender into OBDI PCM
  195. What can/should I get changed in my programming
  196. How to re-program A4 for an M6 conversion ???
  197. hypertech pp3 shift points, need help
  198. Cheapest aftermarket ECU?
  199. Throttle follower?
  200. Need Help with Hotcam and stage 2 heads programming..can someone take a look at it??
  201. Target Air fuel ratio with FAST
  202. Any experience with EPROMER or the ROMulator
  203. Anyone using an Accel 375+ on their car?
  204. 00 v6 to 00 ls1 in progress, need wiring diagrams, please help
  205. trans. performance mode
  206. Just bought Tunercat ????
  207. What cable is needed to run autotap...
  208. 02 simulator electrical question
  209. Help w/ Scanmaster readings!!
  210. Anyone mess with the cranking advance?
  211. Code 51 Scanmaster 95 Ta
  212. Offset tables for Accel 48lb injectors???
  213. Need help with LS1 computer
  214. Need an SC tune
  215. Code 44???
  216. OBDII LT1 edit....controlling detonation/pinging?
  217. Part throttle tuning?
  218. What would it take...
  219. Premature shifting A4
  220. guage lights out
  221. Where to Buy LT1 Edit ?
  222. Can someone HELP???
  223. CRAP...my PCM is now erased..how/were do I get it reflashed?
  224. AutoTap w\o Laptop?
  225. Is there a programmer that will do LS1 and LT1?
  226. Closed throttle tuning/advance...
  227. 30# injectors w/ no tune???
  228. Car feels like it missing or jumping forward...
  229. A4 pressure offset to soften shifts ?
  230. Idle stays up after LT install.
  231. WB Vlin into Oil Temp Input
  232. AFR, tip-in and related q's
  233. HPP3 question...
  234. obd1 computer
  235. MAT sensor
  236. need some tuning advice!!!!
  237. How to convert .bin to .lt1 file?
  238. Bought a camle for OBDI and need some software...
  239. Help me....somebody please view my Autotap log.
  240. What can ls1 edit do?
  241. What should I log for autotap?
  242. Timing question and a 160 T stat fan setting
  243. What kinda Cheap Laptop can I use with Lt1 edit?
  244. Timing Suggestions
  245. Neat/creative programming idea; can't get LT1_Edit or Tunercat to do it, any ideas?
  246. speed pro F.A.S.T.
  247. speed pro F.A.S.T.
  248. How do they program your ECM with a Dyno Tune?
  249. transmissions DTC err.
  250. Anyway to tune for rich idle or low RPMs?
