Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32
  1. Lost my PCM again using TunerCat....
  2. laptop speed
  3. Emergency brake light
  4. Think I fried my PCM...doh!
  5. What the hell does this mean!?!
  6. tuning for ls1 hot cam
  7. sir dtc
  8. Minimum requirements on laptop for custom programming?
  9. Help! MAF problems
  10. What are my options for a 96 OBD2 SS
  11. Reseting 'check engine' light after an accident
  12. My TunerCat issue update.... Long, but you Tuner users need to read.
  13. Help needed--rough running
  14. Question for TunerCat users... Please read and post...
  15. Are all ABS reluctor rings created equal? :)
  16. stupid question
  17. Is There Anyone Who Will Program A 96 3.8 Computer?
  18. Any Way To Remove The Factory Speedo Limiter Myself????
  19. Whats the cheapest way to scan/tune OBD2
  20. Exactly what does tps% used for?
  21. i would like to say Bryan is the MAN!
  22. Can Freescan Work with a '95??
  23. tunercat/lt1edit
  24. LT-4 With Hot Cam using LT1 edit. How much can you advance the timing?
  25. LT1 Edit!!!
  26. code 72
  27. T56 to A4 swap PCM question
  28. obd2 free scanner?
  29. Atlanta area help
  30. Senors ignored in open loop?
  31. Available reprogramming from GM itself?
  32. hooking latop up?
  33. Paging kevin97z28 or anyone else thats familiar with F.A.S.T
  34. Trying to load PCMfor less;cable error ect. need help
  35. I need a stock 95 a4 2.73 .lt1 file please!!!
  36. I need a how to on OBDI conversion
  37. 42lb injectors vs ?
  38. tunercat problem
  39. How to change a/f at wot in Tunercat??
  40. Switch to OBDI, now fans won't turn off
  41. flat spot, 1000- 2000 rpm/tunercat
  42. F.A.S.T Part Numbers
  43. Unusual OBDII to OBDI question...
  44. Is tuning really needed with 1.6 RR?
  45. MISTERY Detonation
  46. Maybe its not the Opti-Spark
  47. TTS datamaster fuel readouts.
  48. knock retard
  49. Definition list??
  50. Can LT1 Edit Cause Computer Problems with frequent use?
  51. How hard to use LT1 edit?
  52. Venom 400??
  53. s.a.f.m
  54. Running OBDII PCM and OBDI Knock Sensor...
  55. dyno tune
  56. Used Pcm
  57. Forcing PCM to run diagnostics?
  58. tuning a heads/cam car
  59. MAF table adjustments...
  60. Black dot to the left.....
  61. tunercat users
  62. Setting Closed Throttle Spark Advance?
  63. Tryin to stay cool, can anyone help?
  64. TechEdge WB narrow band output ?????
  65. Anyone have or know where a 230/236 file is??
  66. anyone ever heard of using a paper clip?
  67. rough running engine and lost power.
  68. would using a HPP with a cammed car work?
  69. How much would you pay for OBDII tunning cable and software?
  70. Third Gen Chip Reprogramming
  71. What about the chip?
  72. new pcm/ base program ?
  73. anyone have a true fix for the odb 1 high stall no shift problem?
  74. 96 hypertech work on a 94?
  75. New Laptops and Tunercat, serial port and USB
  76. New to all this and have a ?
  77. Are there any LS1 tuner's in the North West Region?
  78. DIY-WB almost done, but NEED HELP!
  79. Benefits of increasing injector flow rate?
  80. New to the reprogramming side of the house...quick question
  81. Correcting A/F ratio with tuner Cat ?
  82. Freescan question??
  83. Laptop minimum requirements?
  84. How to retard ignition timing using LT1 edit
  85. problem with PCM
  86. OBDII Idle Timing
  87. Changing Shift Points for a 95 Camaro
  88. BLMs steady 108 after tune...
  89. Would minor head work Hot cam and 160 stat cause low BLM's
  90. Anyone need some spare ECMs?
  91. interface cable questions?
  92. Need help with laptop please. Missing file Msvcp60.dll???
  93. Limp Mode
  94. Anyone using http://www.obd-2.com software
  95. I have some questions about LT1_edit
  96. Should I bother
  97. anyone here use fast tracks harness for accel DFI?
  98. Shift rpm problem
  99. PCM question please help??
  100. 93 LT1 What are my Tuning Options?
  101. tuning sites
  102. Hypertech Book?/Manual? where can i get?
  103. TunerCat Definition file
  104. Tunning for best power?
  105. LT1 edit prrgram for 230/236, or 236/242
  106. Lost timing on 7730
  107. Lt1 Edit List
  108. Why Can't I Check Codes?
  109. Does Anyone Have A Lt1 Edit File For A 12 Psi Vortech W/50 Lb Inj.
  110. LT1 edit tuning for larger injectors
  111. BLMs at 108. What is wrong and what is the best fix?
  112. Looking for a nice laptop
  113. Anyone mod their A4 tables for Autox?
  114. HELP with closed throttle spark advance
  115. computer tuning
  116. F-body 93 PCM vs 94-97 PCM
  117. WOT converter lockup and dyno shift file
  118. LT1 Edit
  119. How will my computer respond to long tubes?
  120. Interface Cable
  121. pcm4less or get tuned on dyno
  122. New to programming - when do I need it?
  123. Anyone have/know of any good stroker tunes?
  124. Dyno Tune vs. Others
  125. Custom programming a 93, is chip soldered
  126. LT1 Edit gear change
  127. just logged a drive, have ?'s
  128. any program out so i can change the VIN in the PCM?
  129. Dirty MAF = Rich?
  130. Torque management
  131. split BLMs
  132. Do You Have My LT1/BIN File ?
  133. DTC 42 and arcing problems
  134. What things cause "Limp Mode"??
  135. Super Quick programming Question??
  136. Pros/Cons of all tuning/diagnositc programs
  137. Anyone using an EMP-10 to reprogram thier Flash chips... Questions inside...
  138. Opt-Spark can be cleaned!!!
  139. Injector Programing????
  140. ecm and 7000 rpm ?
  141. Stock ign.map from LT1 wanted
  142. Anyone running a FAST?
  143. ANother Programming Question... Throttle Body
  144. PCM Resetting SES Codes by itself?
  145. Superfueler guys come in
  146. when stopping I get idle issues.
  147. Show me your odb1 connector!
  148. car going crazy please help
  149. Tranny slippage
  150. freescan
  151. LT1/BIN file for 95 Z28 M6 with HypTech Power Prog.
  152. Knock Recovery Rate??
  153. code p0410
  154. A Few Computer ?'s
  155. What is OBDI LT1 edit locked to?
  156. False Knock??
  157. HELP!! need CC306 emissions file for TunerCat
  158. Converting OBDI programs to OBDII
  159. Bin to LT1 edit?
  160. Programming out CPS?
  161. pcm lock up?
  162. can you upload a 95 LT1 tune to a 94 LT1 pcm?
  163. Used 94/95 LT1 PCM's? Where to buy???
  164. Help!! Please!!pcm Definition File!!!!
  165. ECM Not Responding!!
  166. Can I upload a program on to my PCM if....
  167. ODB2 to ODB1 swap ? & LT1 edit Install ?
  168. Should I remove knock in PCM?
  169. Tuning For xe cam and stage 1x heads
  170. VE Master
  171. .bin files
  172. Tuner CATS Help - Simle Question
  173. Hypertech cable same as LT1 edit?
  174. O2's, LT's and cold weather. Q's
  175. Various part-throttle tuning ?s
  176. P0404/p1404
  177. Ccp %
  178. PE VS RPM tables
  179. fast and opti
  180. Need injector offsets..
  181. AKM Calbe = Cable Needed for AutoTap?
  182. Need help with PCM on Bench Dyno......
  183. What would happen to my o2 if i left it out of the bung?
  184. 12.5 or 13.0 AFR?
  185. Laptop requirements for Tunercat/LT1 Edit?
  186. laptop for lt1 edit
  187. Open loop vs closed loop tunning
  188. In tunercat what is CAT protect program
  189. Advice for programming 383...
  190. shift point help
  191. cable help
  192. Where is LT1-Edit's home page?
  193. What from OBDII transfers over from OBDI
  194. Need stock M6 OBDII tune...
  195. Freescan question
  196. What are the best sites to get .bin files?
  197. What does DFCO stand for?
  198. Problem, dont know if it has to do with advance, PE, or what
  199. cant get it right. anybody have some good programs or good advice? 1.6 and LT car
  200. Split BLM's @ idle and low RPM's. Any data monsters willing to take a look?
  201. Anyone have a 96/97 A4 .bin file (or .lt1)?
  202. pcmforless.com programming & dyno tuning?
  203. tuning for a v6
  204. OBDII vs. OBDI conversion questions
  205. Need to find shop to tune car!!!!!1
  206. PC to PCM cable? Can you...
  207. Is VIN an issue with OBDII in this case??
  208. Easiest way to delete CAGS with OBDII
  209. What year cable (laptop to pcm) do i need?
  210. Can you soften a hard shifting tranny with tables?
  211. Anyone have a tune for xe 224/230
  212. Stupid Question. Quick and straight the point.
  213. Need some timing maps from some of you...
  214. PCM flash chip repair
  215. OBDII LT1 Edit-Deleting Crank Position Possible?
  216. Need help with computer
  217. airbag light????HELP???
  218. Tech 1&2, Tunercat- How to make compatable
  219. can someone with LT1 edit or tunercat help
  220. 383 guys, how much timing
  221. Just got tunercat where do i start???
  222. do we have an electronic device for measuring HP yet?
  223. Need a lt1 edit file for a stock lt1 supercharged car.
  224. Could to little timing cause Knock Retard?
  225. need a file for hotcam kit w/ ported heads
  226. LT1 edit
  227. EFI Live help site
  228. Crower Cam tune please look
  229. Can Tunercat be run on a comp with 16MB RAM?
  230. Tunercat installation problem
  231. to port or not to port (MAF)
  232. spark curve
  233. Cam specs...Where do I change???
  234. who does good tuning in illinois????
  235. obd2
  236. LT1-Edit
  237. I still have a problem
  238. electical masters.. please come in
  239. how to lean out the car..CC306..PIG RICH!!!
  240. Minimum computer requirements for LT1 edit.
  241. ECU Pins
  242. good program for a long list of mods?
  243. hot cam tuning lt1_edit
  244. ODBI Big Convertor shifting problems
  245. no fuel pressure
  246. 93 lt1 Accel DFI base Calmap file needed
  247. Need Eprom
  248. TunerCat EEB file
  249. Fuel , Air , Spark , Technology
  250. Question about 1997 LT1 program
