- code29 Can anyone help with diagnostics on this .
- two different tuning softwares on same laptop..Any problems?
- Cam Surge
- OBD1&2 Scanner
- PE % change to Fuel/Air ratio vs coolant temp
- 95 Formula tunercat problem
- PCM Detection Problems (2 New PCMs) Some Comunitcation?
- PCMForLess.com FREAKING OUT - To Much Work - Maybe Pick Someone Else?
- Cable
- pcm
- Unusual Lean Condition at Idle
- has anyone ever "made" your own pcm wiring harness
- Is WOT Always Open Loop?
- My DFCO doesn't work, why???
- Which OBD2 O2 sensors are not used with OBD1?
- Tunercat O2 Rich/Lean Swing Threshold?
- Could some look at my freescan log??
- Is a tune a good idea yet?
- Transmission tuning question
- Codes 29 and 48
- Speedometer way to low...
- Does Freescan need engine running to scan for engine codes?
- DE-tuning ??
- Wide BLM split at cell 16 & 18
- Datamaster vs. Stupid cop
- What version of Windows for TunerCAT?
- Freescan won't begin a CSV File!!
- MAF problems
- tuning for MAF size
- need prog file for ecm for ford svo 30lb injectors 1994z28 6sp
- How to test O2 sensors heating circuit?
- TunerCat Idle air/fuel adjustement (BLM)?
- Datamaster Log 95 Z28
- Finally got some line pressure readings after rebuild.and.
- Atlanta Area Emissions
- motor fires up with starter fluid but no injector pulse
- AKM Cable issue...or something else? Dropping ALDL connection during scans
- Car flops in and out of closed loop?
- FreeScan vs. DataMaster ?
- What gives an idle the lope?
- Retrofit question. I think I may have something not 100% right
- wiring pinout for drivers side engine bay harness
- Fuse panel for 2000 camaro
- siemens 80lb injectors tuning help!!
- obd-2.com?
- Obd1 pcm
- Can't Clear History Codes (2 A/C Related)
- security?!
- automatic pcm in a manual ???
- STerm counts and LTerm counts
- O2 sensors full of soot,can i clean them?
- cam lope at 45-55mph
- AutoTap Sample Rate
- How do I Calibrate my MAF?
- tuning Q
- Need a real expert to look at my Datamaster File
- Anyone ever use VE Master?
- Are SES codes stored after light goes out?
- BLM's and Fuel Trim Multipliers
- New to tuning - Dont understand my BLM's ....
- MSD Digital 6, Have it Rebuilt or Buy new?
- This sucks...Please help...
- MAF Voltage 3.59?
- Need driver for WOT tuning cable
- Can someone look at my logs (BLM 16 & 18 issues)
- datamaster help
- freescan "hiccups"
- Question on OBD II datalogging software
- am I on the correct path?
- Car Stereo Security
- normal data from sensors
- Oxygen Sensor heater monitor won't set ready
- autotap newbie
- Pulling Codes
- ALDL port not communicating
- Speed Density tuning
- FAST dual wideband O2 through TTS Datamaster?
- Nitrous Timing retard with traction control?
- Running rich codes PO175 and PO172
- Cluster not working
- BLM question Park vs. Drive
- PLEASE!!I need a bin file for 30lb ford svo injectors
- EFI Tuning series in "Engine Masters"
- freescan help needed
- ideal PCM for forced induction setup
- tuner / scanner
- Any way to lock my idle BLM's only? Or stay Open Loop at idle ONLY?
- my camaro
- looking for obd1 lt1 cam tune
- Wideband o2 bung question
- OBD II to OBD I, auto trans question
- Can ABS light be deleted from PCM?
- oil temp and fan functions
- high idle problems after dyno tune.. HELP
- Help with choosing tuning platform
- Reverse Lockout Malfunction after new Master
- How did you route your wideband wires into the car?
- Update To My Split BLM Issue - Suggestions?
- getting set for tuning
- Need a few opinions on no-mod tune
- MEMCAL socket
- 383 on stock injectors, 42lb tune
- I want to tune my 95 camaro
- Stock or fast computer for tuning stroked and supecharged lt1
- wideband o2 question
- Aeroforce Interceptor Guage
- Need a stock tune for a 94Z A4
- 95 LT1 Issue
- 93 computer conversion Q's
- Where to jump 12V switched wire for wideband
- BLM Boundaries HELP
- Sketchy RPMs at WOT
- cuts out wot and boost...
- Target A/F ratios at throttle positions
- MALF 41: EST Open
- HELP!!! rough stumble between gears
- Running lean after backfire
- DFI gen6 .. getting timeout errors
- Win7 and TTS Datamaster
- Which cable and software best
- 95 OBD1 in 97SS
- First datalog- have questions
- Why can't I check my codes on my LT1
- 133 and 139 codes..should i worry?
- About check engine light
- problems with the ta codes 48 and 32
- Heads
- Intake
- DFI or BS3 and HOW????
- Bad Computer
- Tuning?
- does this make any sense
- HPP3 and HPP Plus? Questions on both.
- Remove TCC functions?
- Problem with starting '95 lt1
- Idle spark advance
- Programing question
- closed loop tuning question
- engine idle
- tuner cat lt1
- Ecm
- still no where to tune a 93??
- Where to download tune
- Deleting Emissions
- odd misfire only when temp is above?
- Wideband for twin turbo setup
- Is ecm bad?
- akm cable and vista
- Baro Update RPM Threshold
- Help me understand BLM cells
- wideband recommendations
- Trans Tuning
- trouble codes help
- can scan sensor data master but not with a snap on scanner
- hypertech tuning
- DFCO Spark Retard: Why does it matter?
