- Ne1 use Innovate DB kit with the A/C Datamaster mod
- '99 SS - Tuning or 4L60E trans problem?
- Reusing a tune and pulling a tune...
- Anyone using MAF Translator Pro w/OBD II?
- 1st prime pulse width vs coolant temp
- What's neede to tune OBD1/OBD2 LT1's?
- Mail order or Dyno tune?
- Can you split this forum in two? 1bar vs 2bar?
- How to remove wiring Harness 94 lt1?
- anyone tune obd1 LT1's in jacksonville?
- Timing reduction issue
- Cable NOT Found???
- mechanical or tuning?
- OBD1 Scanner or laptop?
- Fans not comeing on
- 1996 Z28... Data Logger and tuner?
- Heated O2 and running rich
- 96-97 Crank Sensoe Relearn ?
- can't get data master to run
- performance chip/module
- Which tuner cat program do I need?
- Tuning Spark Advance w/out a working Knock Sensor?
- LT1 Tuning help, 02/fuel trim #s
- p0441
- Can someone help with some trouble codes i got with datamaster?
- 95 3.4L, OBD '1.5' - Can't get scan tool to connect
- Scanmaster and laptop question
- Computer/Electrical Problem
- O2 sensor error codes and tune questions
- No Start 95 Z28
- boosted lt1 stock pcm
- Need advanced tuning help. MadZ28 Tune.
- No lift to shift box
- DTC42 starts then dies
- very wierd problem not sure what it would be considered NEED HELP!!!!!!!!
- Finally got things set up to tune, and now the questions
- Stock lt1 pcm and boost?
- Long Term Fuel Trims Split
- 94+ T56 VSS pulse per mile
- Please, help with knock. TTS data attached
- 97 lt4 383 tune help, jet tuner
- Trouble with tune
- Rough idle with big cam
- Program: LS1 Edit
- not accessible?
- Tuning LT1 for no tranny
- Timing question
- Need help with tuning discrepency
- 93 computer converting to 94+
- A4 ECM for T56 car
- O2 sensor depth (in bung)
- Volumetric Efficiency vs RPM vs MAP....
- No Communication
- DataMaster/Tuner Cat questions.
- Black stains on White bumpers
- Cheap software to read DTC with link cable/laptop?
- What reads other than engine codes (>c1200)?
- Using VEmaster with the 96-97 LT1
- Tuning in michigan
- help, running very rich
- 2 Codes P0100 and P0303
- Camsurge related problem...SD and Jet DST(tunercats) OBD II question
- trouble code p1361? help!!!!!
- Maybe a bad PCM? (Kind of long.)
- bank 1 ltft at 25%
- I goofed up and wiped my ecu
- OBD2 to OBD1 Conversion - No 4th Gear?!?
- Stall Wall Fix
- 95' camaro PCM tuning
- 2-Bar Scaling - Questioning the validity of 2x
- Holding a tune
- service light comes on and off
- where to send pcm to be flashed back to stock?
- OBD 2 Inspection question
- SpeedO
- ABS woes
- Problems with my 97
- Freescan Help
- Need help! I think it's running rich, rich, rich!
- Got the laptop, now I need to know where to get the free version on DataMaster
- Needed: 98 & 99 LS1 F-Body Connector Pin-outs
- Stock ECM with MSD opti, or Big Stuff 3 and a dizzy?
- How to send a Datamaster log
- Blue Smoke out back on less than 1000 mile non raced motor?
- BLM locker won't work
- Stumble at Start
- Tuning after a gear change
- 98 ls1 wiring question
- No cats, how to take of engine lights
- Frogot How TO Read the PCM (TunerCat) ~ Been A While!
- Dyno tuning shops
- Any free scanning software for OBD2 vehicles?
- P0154 is stumping me
- Timing 96 Lt1 OBDII
- no temp reading
- Got in a wreck is there a reset for the pcm?
- Looking for a bin file 95-95 Pontiac F-Body
- 93 z28 wont start
- 96 PCM in a 94 Z28
- LT1 TCC Forced Lock Speed at WOT
- PCM recieving no signal and no fuel pump?
- Engine Swap and FreeScan
- Needs some answers!!! (stock computer)
- No Check engine light.. EVER!
- stock injectors
- ABS code scanning
- Possibly bad VSS?
- T56 conversion CATS
- Preset tunes for Tunercat
- New Injectors... What's are the PCM changes needed to make them work?
- Tuner cat BARO RESET?
- 93 computer upgrade
- New to This, and Looking For Help
- LT1 Edit question
- Need help making VE table
- More ABS issues
- Freescan will not set up, anybody have this problem?
- autoxray 3000 scanner work for 94 OBD1?
- Tuning with a Netbook?
- New Gears, Change Shift Points?
- VE master on windows 2000?
- application EDIT_LT1
- Help me decided...2 bar or Maf 600+rwhp
- Fan temps in tuner cat
- what turns the ac pump on? Electrical?
- why is there 3 serial data terminals in port? OBD1
- code 83 TCC PWM Solenoid Circuit Fault on my 1994
- autoxray vehicle not rersponding when clearing codes
- Car runs like crap after converter swap???
- Lt4 knock module, Transmission matter?
- After market ac wiring ?
- runs horrible in closed loop great in open??
- pcmforless vs mad z
- soldered eproms which ones are they?
- wideband output to ac pressure port?
- OBD-II Scanner Options?
- LS1 engine computer and harness
- Understanding DataMaster
- O2 Rich/Lean Swing Threshold
- Running the stock PCM past 7k rpm
- VE table for LT4 heads/intake and hot cam?
- Question about Pulling Codes on a 1994 Z28
- Another VATS issue??
- Tuning for a 114lsa cam?
- Need some help... OBD2 port isn't powering up?
- going from a obd1 to a obd 2 pcm
- O2 sensor help
- 2 Probs, 1. knock sensor; 2. A/C Sequence of operation
- Short idle log
- lt1pcmtuning.com's mail order tuning experience?
- plz check datalog :(
- OBD II... I'm a newb. HELP!!!
- CEL came on and I got this code
- BLM Locker ?
- In Need of a Datalog Reader
- Weird BLM counts?
- Big Cam, 107 lsa need somewhere to start!
- Lean! on startup.....
- Can 96-97 ECM be programmed with OBD-1 Tune?
- TPS code
- Getting started....usb or serial??
- who can do a mail order tune on a 97 firebird PCM?
- O2 sensor question
- OBD I codes?? tuner cats
- OBD2 to OBD1 do pins need to be changed around?
- Scan error codes
- Anyone know where these PCM Pins goto?
- Changed Fuel Injectors no start
- lt4 knock module
- Street Manners
- LT1 AF ratio off the chart
- In need of stock lt1 M6 tune
- Went to 75lbs low ohmes injectors now hard to start when hot
- GM or Vetronix tech 2 question....
- Multec 42# injector offset table???
- Low idle at cold startup
- LT1 Hot cam fuel & Spark tables
- LT1 tune
- 93Z computer diagnosis
- Question for tuners, Hypertech + shift points.
- WOT Ignition Timing
- pcm bad?
- LT1 Tune Help. Fresh 383
- Decreased cranking duration
- Swaped stock radio in 99' TA aftermarket and now the A/C does not work. What to do???
- Looking For A Tune To Start With (383, LE2, 236/236, M6, 58MM TB, CAI, Flowmaster)
- tunercat with mark 8 fan
- Where's the false knock coming from?
- High rpm issue
- Transmission Settings for Dyno Run
- fried PCM?
- Gauge Connector
- What's the car do when it hits rev limiter?
- usb -serial adapter cable driver problem
- Part throttle fueling...........
- Freescan data problems
- False knock?
- Anyway to defeat the P0335/P0336 Trouble codes?
- Can i go to the strip with a P0336 code?
- Any Dyno tuners in Central - Southern California?
- 1994 harness on a 1997 T/A
- Another dumb question about TCS
- Pushing panic button (LT1 Edit OBDI) please help
- To everyone that has fried their PCM with a USB cable.
- My 383ci LT1 has been running like crap.. V. injectbank PW 1&2 are way off
- tuner for adjusting timing?
- anybody have obd1 cc503 to compare?
- BLM Locker Programs 16159278
- Thank you Trifecta
- traction control
- car has a draw problem
- Fan problem
- Purchasing LT1 Edit
- Question about VEMaster
- inatalled new engine. mph on dash raises with eng rpm
- 93 LT1 tuning help!!!
- Tell me what is wrong here?
- Can RPMs to the ECM be wrong?
- where to buy a cable for tuner cats
- so whos runing e85
- PCM Junk After Succesful Flash?
- I need a base tune, accel, gen7 who can help
- FAST Question
- Leaning out at WOT and random at part throttle... tough problem
- How many have had Tunercat problems? Thinking of buying
- Which PCMCIA to Serial Adapter Card Works?
- Cheapest place for Datamaster?
- DFCO help and few other ?s
- 4l60e trans tables in TunerCat
- Jet Dynamic Spectrum Tuner for 96-97 LT1: Opinions
- Overheating and High Idle
- Is there a place to get tune files for tunercat?
- LT1edit and emissions
- No PCM Detected?
- BLM Locker
- LT1edit question
- Looking for a stock 94 A4 camaro tune file
- question reading tune with tunercats
- question about fan setting in tunercats
- cold start up closed tps timing
- Why would the cylinder volume be off?
- Tunercat - Compbin - Any good?
- Tuning Q
- Any Mail-Order 2 Bar Tunes?
- hitting rev limit before shift, why? tunercats
- EMERGENCY!!! MAF question
- FP vs BLM
- Bin file for LT4 needed
- ? on tunercats
- AKM cables not responding...
