- Strange P0174 Bank 2 too lean error
- Split BLM/IAC fix-Anyone tried the "tube trick" from throttle body to manifold?
- Scanmaster
- BLM Cell Boundries after CAM install
- Accel thruster lt1 dfi system.
- is there anywhere that has .bin files for bolt on cars to just Down load?
- Speed density to Maf
- aldl cable
- MAF Calibration Questions for my 95 LT1
- ALDL OBDII Connector Pinout
- PCMforless of NC...
- fast track wiring question
- pcm harness wiring
- Computer & Car Not Gettin Along (Cant Comunicate)
- O2 sensor thread size
- Little Computer Help (Tuning)
- P1441?
- datamaster file
- Odd SD / MAF tune idea, input please..
- Making your own cable?
- Bad Alternator?
- aldl cable help
- MAF Calibration Excel Spreadsheet
- Running rich? take a look at log plz.
- Can these Actron scanners read realtime for retard?
- Arrrggggg!!!!!
- Remote entry
- Tranny tuning
- Is this false knock ??
- Unknown Black Box
- Possible to change a/f target?
- "Right 02 Fail" DTC in Open Loop Mode?
- GM Tech 2
- Need Help Fast Car wont start SECURITY light on
- looking for feed back on Zeitronix Zt-2 Wideband
- 1994 z28 OBD-1 scan tool check
- Which scan tool to buy?
- No Start, No security light on bulb check
- How do I check TPS voltage using a multi-meter?
- Security light and no starting on a 2002 Silverado
- Fuel pump prime duration
- Questions about my dyno tune tunes???
- Noob Tuning Question(s)
- freescan misfire ?
- 1997 Z28 Asr Question Need Help
- PCM tuning ? 94 LT1 stroker
- Misfires Not Detected By PCM...
- Car dies after dirving, then restarts. Data mater available.
- Data Master reads lower volts
- want to start tuning my self (obdII). where do i start?
- DFI Idle Help
- LT1 timing & fuel trim
- Scanner wont connect with car....?
- PCM Philosophy (paging Injuneer)
- '93 Knock Sensor Tuning
- 93 Lt1 Difference Between Jet 6 Speed And Auto Chip?
- Need Help With Flash Codes
- AKM Cable, Free Scan, can't connect?!
- TuneCat program came in
- Knock fast attack Retard?
- O2 Crossover Voltage
- Dyno tuner in the NJ area
- NEEDED: Bolt on tune for 94/95 z/6 speed, bin file
- Could anyone scan their instructions for a Hypertech PPIII #340752?
- AC question
- LT1 lean help
- Running Rich
- Actual "tune" from a HPP?
- TunerPro RT and DA3 Definition
- can not get speedometer right
- 94' PCM Rev B vs C : FAQ
- Anyone Familiar with this?
- Stupid ?? on o2 sensors, No-ECM
- VeMaster
- timing ?
- LT-1 tuning in CT area - or HPP?
- datamaster says no pcm syn- might need a driver
- HPP III manual ...
- Spark Map Tuning with tunercat
- Fast engine control unit
- Tune needed
- Needed-TunerCat file for a turbo application
- Tunercat OBDII VDF
- Hypertech "cartridge required"..?
- WOT RICH, don't make sense
- Camaro LT-1 No Start/Corvette PCM
- New Member needing Tuning Advice
- Free Scan Issues - Will not collect any data
- Burning spark plug wires...... help!
- Need help... Datamaster log
- 1993 OpenLoop Tune,-WOT help!
- Left Bank Rich, Right Bank Lean? Why?
- Donor cars for 93 LT1 and trans
- installed a CompCams camsahft into 1987 IROC 350.
- Project '99 SS threw two codes today - help?
- malf 42 est grounf
- Confused about scanners and programmers
- Upgrades.
- Help with LC1 setup
- Running very bad !
- mail order tune?
- ? about tach signal
- what tuning cable for obD1 conversion?
- 98 Camaro V6 - Electrical problem(Radio, Transmission, and now Starting problem)
- Is it possible to convert OBD 1 to OBD 2?
- Anyone having problems getting ahold of tunercat recently?
- Code 33 MAP high
- Datamaster 1/4 Mile Estimator...lol
- Looking for a dyno tuner in Phoenix/Tucson area.
- Am I missing any options? looking for help.
- Map reading high I think
- gear ratio vs shift point
- Turn your iPhone into a scan tool
- MPH versus rpm question
- Already have AutoXray ALDL cables, wanna use to link laptop
- How to change LT1 vin in file?
- obd1 to usb ???
- PCM reflash question ,Gurus help!!!!
- tunercat help
- Interesting link for noobs to datamaster
- datalogging for obd2
- HELP Emissions Problems
- quick question bout ways to datalog
- Building an Bench EFI
- TP sensor
- issues
- ECM are they the same
- Fried the ECM
- FNG checking in, like some advice, datamaster file
- OBDI PCM - Past 7K
- diablo tuner
- cats files anyone?
- Service engine soon
- Question on running the LT1 with a non OD transmission
- which one?
- 94 M6 Stock Virgin Tune Needed Please
- jet lt1 soft ware
- 94 camaro LT1 in 1997 camaro ss
- p0420 quick fix for emmisions
- PE idle
- hypertech on lt1
- lt1 edit or jet ds tuner
- Bcm or alarm module
- Tuning Question on '96
- CAS Sensor
- 93 ecm interchangeability?
- Rough Idle runs good at WOT - Data Log Inside
- MAF delete?
- p1406 code help
- p1870 help
- Can't get TCC to stay engaged in 4th!
- 93 camaro to 95 firebird Harness and pcm
- help tune ??!
- Bad sensor in water-pump????
- Can someone help with Datamaster .CSV's, Please
- tuning options
- 1996 does it need a chip?
- Using RT Tuner with a 97 LT1, OBD2 to OBD1
- 95 LT1 WOT VE tuning issues!
- P0507 code
- 1995 lt1 pcm tune help
- Soo i just killed my first PCM. Questions...
- M6 or a4 tune?
- 3.90 R&P to 4.11 R&P. What do I change in my tune?
- Switching from MAF to SD...turbo,2Bar map???
- Reprogrammed PCM problems
- MAF and Speed Density?
- Tuning for GM 847 cam
- Stock 95 Z28 M6 PCM file
- Need Jet DST file
- Scan Tool Sensor Information
- PCM help
- 383 tuning
- No Power to scanner?
- How to replace Bank 1 #2
- places that dyno tune obd1 cars
- Security problems...still
- Hypertech
- Lt1 edit - help got questions -
- Can't get a data logging program to work
- Need help choosing a way to go about tuning
- RELAY (Fuel Pump) is chattering...
- needs help
- Accel dfi emissions tuning
- wide band readout with fast xfi
- ? about data port?
- Knock retard
- Flasher unit Location
- Did I ruin my MAF?
- LT1 obd1 pcm use with BCM???
- knock sensor....how much timing
- car runs better right after tune, then falls on its face.
- Knock retard @ idle, but goes away when I give it gas??
- My '95 camaro z-28 will not start
- OBDI low octane tables
- problem code 0118 need help
- Shift points
- Abs
- Question about stock car w/ 60# inj. and open loop
- obd1 scanner help
- Can anyone give me the correct calibration for my speedo?
- Where did most of you guys start???
- guage problems on dash
- ECM constants affecting spark
- Is this true ?
- Datamaster or Freescan help?
- lt1 tuners in ne arkansas, se missouri, or west tenn
- 1987 IROC Any Ideas?
- perfect tune maybe
- SLR motorsports chip
- IAT adjustments?
- Tuning for installing cats? Recommendations so I dont ruin the cats?
- fans coming on way early?
- lt1 runs on ls1 computer using modded OPTI
- Is my PCM going brain dead?
- Disable alarm on 00 SS
- Dual-bank wideband users...
- Power Lock Probelms
- Tuner Cat PE questions
- just bought tunercat and a laptop..should I buy a USB or serial cable?
- which tuner to choose
- Tuner Cat Questions!!
- Tuner cat questions!!!!!
- Lets discuss WOT tuning strategy.
- Which OBDI Cable?
- Seeking pcm suggestions
- DA2 Tuner Cat help
- Set new gear only with ALDL cable
- Datamaster intermittently going out
- 2 Bar MAP conversion chart
- Invalid response from pcm
- Theft system
- What does Hypertech tuning do actually?
- Guru's please look at Freescan file and tell me whats wrong.
- LT1 Tuner in central Florida area
- need advice, nehoff vs. gm vs salvage PCM
- Need help with my tune
- Brothers LS1 ******?
- trans temp
- Tuning for 58mm TB and ported intake? (tunercat)
- Who is re-socketing PCMs now?
- Lean at WOT with open loop.....
- Best pc based diagnostic software?
- Dyno tune or street tune which is better??
- Strange issues with my tuning program files
- Cant scan the comouter!
- SES light but no codes?
- Bench testing PCM
- Cruising & WB goes to 12.5 then normal
- Surging at idle
