Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32
  1. Pro Tune/Self Tune
  2. Autotap question in relation to LT1 Edit
  3. What 'log'ing software does everyone use?
  4. wierdest thing i have ever seen
  5. FS:OBD1 conversion "kit" & 50# Injectors
  6. tazzo vs. g-tech
  7. Urban Suburban Question
  8. Logged 1/4mi runs, KR comes and goes
  9. Once the mods are in, how do I go about programming? With LT1 edit?
  10. Tuning reccomendations
  11. required parts to finish obd1 conv.
  12. 93-obd1
  13. Motor Magazine's Scanner Tool Review
  14. possible burnt wire? (not plug wires)
  15. Please post your track logs
  16. obd11 causes misfire with cam?
  17. How do these BLM's look....
  18. correct way to correct knock
  19. "Burst" knock? So there's true knock, false knock...AND "burst" knock? Really?
  20. TunerCat users.... Question inside please....
  21. ODB1 and ODB2 cables..
  22. How to display CSV values properly in MS EXCEL??
  23. Cpk Symptoms?
  24. Is there a difference B/T programmed shift points and actual shift points?
  25. idle setting
  26. Lt1 Edit install help
  27. any good sites or articles explaining timing
  28. Question about Tunercat
  29. Tuning with 50#injectors in the NJ area?
  30. WTB FAST DEFI computer?
  31. need FAST info
  32. Fuel Trim 108??
  33. How do you tune out cam surge?
  34. what diagnostic prog. do u guys recommend
  35. Ebtcm
  36. O2 sim value?
  37. i got a code 2-3 shift solenoid need help!!!
  38. LT1 Edit open loop program ...a couple qwik questions
  39. will a B-body PCM work in an F-body?
  40. OBD1 F-body and B-body differences. HELP!
  41. Open Loop VS Closed Loop
  42. Best place to get LT1 Edit???
  43. TunerCAT and DOS
  44. Datamaster files inside...what you think?
  45. Completely disabling EGR and CCP using TUnercat
  46. Auto Tap analyzing .....
  47. Auto X ray on ebay
  48. cheap laptop for tuning for sale on ebay
  49. Auto X-ray cable question
  50. Analyze my dyno numbers please ... looooooooong
  51. 93 to 95 conversion
  52. Ryan94ZA4 - OBDI Stall solution question
  53. Harness Trimming...
  54. All you tuning gurus inside please>have ?'s
  55. Simple A4-M6 swap question
  56. Matching TTS fields to Freescan...
  57. Any one ever use Ed Wright Tuning for 50# injectors?
  58. Code 23
  59. what resistor do i use to make obd 1 pcm work w/ obd 2 k.s?
  60. What can I look for to find out if I'm running rich/lean with Diablosport predator?
  61. OBDII
  62. BLMs at 160. How to fix?
  63. Anybody have a cc503 cam and LT1 edit file
  64. 95 LT1, LTFT 100, running lean, hesitation
  65. nitrous file
  66. What cable fo I need
  67. Q about MAF.
  68. is it true Z28's are downtuned outta the factory???
  69. LT1 edit help
  70. Just Boght LT1 Edit and have some questions. Also Knocked .47 with the first time it
  71. What is code P131
  72. anyone know anything about Holley Commander 950 computer
  73. Why are blower/turbo guys not using...
  74. SES light, then it goes away, no code?
  75. having problems with HYPERTECH PP3, need help please
  76. which editer to buy?
  77. 42lb bosch injectors
  78. can someone help me change a tune file?
  79. Do I need an MSD 6BTM.....
  80. Hypertech programmers & shift points....
  81. Tunercat bin request
  82. '99 LS1 C5 Diagnostics...
  83. Using Tunercat to adjust auto tranny
  84. Online datalogging anaylsis!!
  85. problems after obd1 conv.
  86. codes tps low and map low
  87. Please take a look at these files!
  88. Need PE/dyno help ASAP!
  89. 1990 4x4 silverado tuning
  90. Needhelp please view and give me your thoughts..
  91. HELP! PCM locked-up
  92. Rear window defoger
  93. is this possible....
  94. Hypertech Power Programming with LT4 Hot Cam Kit?
  95. Guys running a FAST and Boost. In pls.
  96. Can somebody send me the software for LT1 Edit?
  97. OBD2 troubles w/'98 Vortec 350 (van)
  98. LT1 edit & Datamaster, will they work on a Palm or win based hand held
  99. PO154 O2 sensor circuit no activity( bank 2 sensor 1)????
  100. Tuner Cat for 94 LT1
  101. Continued Laptop Problems..
  102. Hmmm....should A/F ratio lean out as rpm increases
  103. Help! I can't get online anymore!!!
  104. XE230/236 be tuned to pass emissions?
  105. PCMFORLESS questions
  106. Anyone using a open loop tune
  107. what would be programmed on my puter if i sent it in
  108. Tunercat file needed
  109. Tunercat help
  110. FAST computer guys. In please
  111. i'm scared :(
  112. Palm 515 for you guys
  113. afr at idle?
  114. what type of tune do i need??
  115. Logging problems with Freescan and PCMComm. Also...
  116. Did I ruin my PCM?
  117. anyone want to trade their OBD2 edit and PCM for my OBD1 edit and PCm?
  118. Questions for TunerCat owners
  119. ScanMaster for a '93 Z28
  120. Pcm
  121. Quad Drivers?
  122. Newbie to tuning:What software do I need for my 93 ta
  123. hot cam tuning question?
  124. HPP3 question
  125. OBD II connectors
  126. TPS%vsVoltage
  127. Whats Needed...93 to OBD1???
  128. Look at these files part: 2
  129. Puter guys... please tell me how... (IRQ)
  130. Car running rich. what do I change; lt1 edit
  131. Who needs a laptop?
  132. Need to see what engine sencors read
  133. stock pcm tuning
  134. datamaster software
  135. Has anyone eliminated the stock PCM
  136. Keyless remote ??? yup another one
  137. Using HYPERTECH
  138. OBD II diagnostics scanner......
  139. Does anyone know how to bypass the driver side airbag
  140. Can LT1 Edit Program Out A Traction Control Code?
  141. 1.6 RR's now lean on throttle tip in
  142. Mem cal adapter for OBD1 chip burning?
  143. what exactly do they do to a pcm when reprograming?
  144. Greddy air/fuel gauge vs DIY wideband
  145. Dynotuning
  146. Whats needed to use Tunercat on '95 LT1?
  147. Could I get away with...
  148. lt1 edit
  149. What do I need to get started tuning the car myself?
  150. big cam and emissions
  151. (fbod vs vette) ecu's
  152. Stock ECM
  153. PE mode and n2o
  154. hypercrap and alternatives
  155. Same heads, same cam, now a 383??
  156. 93 PCM help
  157. can I make my car open loop?
  158. obd1 conv, and adj fuel press reg.
  159. Pcm tuning
  160. How can I convert 4k/mile vss to 2k/mile?
  161. Anyone have M6/LT/Pulleys/CAI tune?
  162. pcm tuning
  163. VSS questions
  164. soft wear for obd2
  165. computer chips
  166. Bad pcm causing po200 code??
  167. ? on a rebuild, with a paxton(computer issue)
  168. APEXi Super AFC
  169. stock computer
  170. Bigger Cam & Idle Misfire Problem
  171. Stuff needed for a 93
  172. OBD ll PCM Tunning in Central Texas?
  173. DTC help!
  174. what is avalible to scan '93s?
  175. scanmaster and datamaster
  176. msd 6al
  177. Question on PCM tuning....
  178. can someone edit my lt1 file for me?
  179. Auto-Tap Tips???
  180. FAST Harness, where to start?
  181. tunercat-How do you make it run?
  182. Do you agree that this has to be true knock?
  183. Fixing split BLM's due to AS&M 58mm TB.
  184. Inlet Air Temp questions...
  185. Is there anyway to keep fuel psi's the same with pcm tuning?
  186. Scan Master
  187. Wiring up new 4L60E connector
  188. shift softening procedure ?
  189. Do I need Tunercat if...
  190. Hypertech ?'s
  191. How do you tune for 30# SVO f.i. with tunercat
  192. Just got the Tazzo Vehicle Performance Computer
  193. Need keyless programming instructions for a 2000
  194. Is it possible to lower my injector duty cycle?
  195. Need tune program for LT4 383 w/comp 305 cam
  196. trouble code
  197. BLM contents
  198. Can timing be adjusted in between 100 KPA and max boost at a given RPM?
  199. ALDL Cable question
  200. How hard to learn the Lt-1 edit
  201. Fuel Trim values....
  202. Knock?
  203. MAF and injector Q.
  204. LT1 question?
  205. Installingthe FAST today.Any websites?
  206. Dumb question
  207. closed throttle decel surging (I got data!)
  208. converter locking and unlocking on top end run.....
  209. a few ?
  210. Which is more user freindly... Tunercat or LT1 Edit?
  211. what does this code mean?
  212. stockish lt1 tuning
  213. FreeScan/Data logging software
  214. old police laptops on Ebay
  215. Weird things with TunerCat
  216. Anybody else doing OBDII tuning besides Carputing (LT1edit LS1edit)?
  217. Is there any OBDII cable available to reprogram PCM?
  218. Smog pump removal, will it setoff any codes?
  219. A 98 v6 a4 camaro computer problem!
  220. Relating a misfire to the PCM!!
  221. TunerCat help needed please....
  222. Accel DFI?
  223. What port does the laptop need to have?
  224. Someone please help tell me: is it the computer????
  225. Any tuners for a 96 3.8l?
  226. Starting tunercat
  227. advancing spark and leaning out afr
  228. invalid com port specified
  229. shock sensor for alarm
  230. pcm tuning after porting heads?
  231. Tuning for PE mode
  232. High Knock Retard...
  233. VIN info
  234. Trade Tuner Cats for Datamaster
  235. Open loop and Nitrous?
  236. What tuning program should I get?
  237. lt1 edit ?
  238. I'm going Stand Alone, any suggestions?
  239. ABS Software?
  240. Help please
  241. OBD2 W No Crank Pos Sensor???
  242. dtc help
  243. Edit Settings for 160 Thermo?
  244. autotap tuning software opinions and info needed
  245. DFI kits
  246. How to upload Programming
  247. TunerCat retry after getting dead PCM back...
  248. Scanning.. help, please
  249. Will this work?
  250. Predator tuning guys, what did you set your spark advance to?
