Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 [28] 29 30 31 32
  1. programing the bcm in a 97ss
  2. I need some pinouts of these 98 LS1 connectors (c100, c105, c210, c220, c230)
  3. Those who flas there own flash chips inside please. Need Help!
  4. Free datalogging software?
  5. Weird MAP readings
  6. Mail Order Tuning...Who???
  7. Knock retard after replacing MAP. Why?
  8. Need help wiring up my 98 LS1 in my 1996 Z28. Thanks
  9. Freescan Question...MAP readings
  10. Tunercat Lt1/lt4 Tuneing Program
  11. OBDI guys, how are you reading your wideband data?
  12. fault code 43????
  13. Output Driver Module Fault
  14. Cant lean out AFR
  15. Any ideas:replacement PCM causing incorrect speedometer readings and reverse difficul
  16. Someone Help me with TunerCats and Freescan Problem
  17. Wireing Help/ How to wire a OBDII port?
  18. O2 mv rich/lean mean threshold vs airflow tables? LT1/4
  19. HAS anyone used PCMFORLESS to Dyno/Tune?
  20. akm cable question?
  21. ALDL Signal Ground wire/ Where does it come from?
  22. C.A.T.S users in here please......
  23. How Do I Know
  24. Question on TCC Settings 1994 Z28
  25. AutoTap Sample Rate
  26. traction control disable
  27. datamaster question
  28. OBD1 Scan Gauges?
  29. Datamaster for AFR Data?
  30. Weird Speedo problem
  31. electrical problem
  32. Help Could It Be Opti!!!
  33. OBD I Not Giving Codes
  34. Changed gears from 2.73s to 3.42 speedometer is off.
  35. did a little shift point adj.
  36. How many dyno pulls in an hour?
  37. madz28 tuning
  38. Dyno Tune In Ga
  39. Question on Hypertech Tuning Module
  40. Are Manual and Automatic steering colums interchangeable?
  41. got efilive now i need a wideband 02 sensor
  42. Locking converter under WOT bad?
  43. hooking up obd1 to a obd2 scanner
  44. MAP threshold to enable WOT ???
  45. 1994 Z28 PCM revision "B" or "C" ???
  46. Crunching the numbers...
  47. is there a way to by pass the knock sensor on a 93
  48. car won't start HELP!
  49. 95 lt1 and tunercat
  50. Where is the diag. codes thread?
  51. looking for a Tunercat tune file 383 with 306 cam
  52. PCM Error writing Tunercat
  53. obd1/obd2 quick swaps
  54. Found good PCM tuner in Vancouver, BC
  55. Tune to make shifts less firm?
  56. running rich at idle
  57. Using wideband for tuning supercharged lt1
  58. Left bank running richer than right
  59. 2 Bar Stock PCM Speed Density Tune for >6psi (Forced Induction)
  60. Roots blown LT1, need serious tuning help!
  61. New to Tuning. Need Help pleasee
  62. hypertech III
  63. LTFT questions
  64. Using LM1 Wideband Simulated 02 Output?
  65. RAM-AIR MAF tables
  66. data cable
  67. tcc trouble
  68. 94 formula not connecting
  69. anti theft elating to not cranking
  70. Map programming for boosted car?
  71. tuning myself with a base calibration tune
  72. VSS wire location?
  73. Chip # or model# for '93 LT1?
  74. LT1 computer problem
  75. Can a bad battery cause an improper PCM response??
  76. Help with the BCM!!
  77. my speedometer is possesed
  78. 94 z28 pcm cable
  79. Does Tunercat run on Vista?
  80. 95 lt1 engine harness and computor going in a mustang.
  81. My Datamaster files - Wanna take a look?
  82. will a 94 computer work with a 93 wiring
  83. stock 95 trans am file
  84. Software using USB cable
  85. pcm fried sorta
  86. Custom PCM mods to support nitrous
  87. wanting to change from obd1 to obd2
  88. DFI timing map
  89. LT1 wiring harness question
  90. Screw in IAT
  91. Corvette LT1 tune vs Camaro
  92. Need some help with tuning in NC
  93. Running corvette bin
  94. 93 z28 --clearing codes-which fuse to pull?
  95. is it worth it to have 94 camaro that is stock to have the pcm tuned?
  96. Step by Step instructions for LT1 Edit
  97. My mystery code...
  98. think my pcm is shot
  99. Quick Question-TunerCat and Win XP
  100. Whitch Way?
  101. General question about Madz28
  102. Latest Tunercat $EE Def File
  103. Has anyone used this for SD tune with success?
  104. A good tune file?
  105. Need Tuning Advise?
  106. Swapping the stock fuel pump for a 255 lph, will I need a new tune?
  107. Instrument Cluster
  108. anyone here use an LM-1 to tune an OBD1 LT1?
  109. tuning for max power
  110. How to diagnose possible PCM problem
  111. Trying to track down idle problem when warm(Kind of Long)
  112. Not your average Hypertech tuner question.
  113. trans swap
  114. F.A.S.T or innovate wideband???????
  115. Autotap and ABS
  116. standalone tuning 383
  117. Upper RPM leaning?
  118. High MAP at idle
  119. Good place for tune
  120. please post your map readings with a big cam like the le2.2
  121. Best free datalogging software
  122. Need some tunning guidance please.
  123. Is It Worth It To Get The Setup for Data Logging?
  124. how to upload my pcmforless tune to pcm
  125. What WideBand to use?
  126. wiring harness question
  127. help with gear change tuning
  128. Where is Madwolf?
  129. is there anyone who has put a 94 wireing harness in a 93
  130. Need help getting inspection sticker
  131. DataMaster Trial Version
  132. Is the odometer reading stored in the computer?
  133. coupon code
  134. Can Datamaster Read Above 6375?
  135. CATS OBDII update
  136. F.a.s.t. & Delteq?
  137. Build my own data cable?
  138. 93 Dyno tune needed
  139. Datamaster pro's, got a question for ya...
  140. Moates Autoprom
  141. MIL delete through wiring harness?
  142. I think my ECM is shot ?
  143. hypertech??
  144. dfi and stock gauges? need help
  145. STFT pulling fuel(too rich) wideband says lean at idle?
  146. will this burner work for me (car in sig)
  147. Cant scan 95 TA with AutoXray 2000
  148. Do I need to get a tune with my mods
  149. BLM's at idel.. Need some help.
  150. TunerPro Results (BLM & TPS Question) 1992 5.7 Camaro
  151. C#.net Programmers Inside
  152. Datalogger, anyone use this one?
  153. Speedo values (LT1/TunerCat)
  154. 96 File in 97 PCM?
  155. SLP Skip Shift Eleminator v/s knockoff
  156. 93 ECMs different for auto/Manual?
  157. Chasis Dyno tuner in Miami?
  158. Keep OBDI conversion or go back to OBDII
  159. How much h.p is the stock pcm good for ?
  160. chip for a 93 z28
  161. Ported MAF driving me nuys!!
  162. Need stock .CAL file for a 97 A4 Z28
  163. Low Coolant Light
  164. PCM tune to enable lock up with a high stall converter?
  165. ? about OBD1 conversion
  166. 60# mototron injectors on a stock motor
  167. Quick ECU Question?
  168. Software for scanning your LT1
  169. What PCM is this for?
  170. another wiring ?
  171. trial tunercat Q.
  172. Need stock 95 LT1 A4 .bin
  173. 1995 Z28 code 43 runs sluggish, Help Please?
  174. What FTP site best to use to export csv datalog???
  175. Noob Questions about Software and a cable for 94obd1
  176. need help computer tune
  177. PE idle 95 car.
  178. Low Z injectors Lean Tip In advice needed
  179. tuning programs
  180. Wideband says fine, pcm pulls fuel
  181. wiring using stock PCM and XFI
  182. TTS Datamaster. How does it work?
  183. tps sensor
  184. Datamaster v3.4.1 anyone
  185. Security light always on 97 LT1..Anyway to reset
  186. considering buying Autotap
  187. False Rich Condition
  188. Why would deleting O2 codes cause PO1133 an PO1153
  189. probably a stupid question....
  190. Progam Remote
  191. LT1 tuning write up
  192. Car runs with fuel pump relay?
  193. Security light?....
  194. Odd issue in Cell 6
  195. Pinging on 383 with stock timing
  196. Do i need to wait before logging the car?
  197. x24 Reluctor Question
  198. Wideband o2 question
  199. can anybody please translate the meaning of this obdII code
  200. tunercat vs. tunerpro
  201. Tuner Cat WOT on LS1
  202. Need to flash my PCM ....
  203. hypertech programmer
  204. Finding datalogs with similar mods as mine
  205. So what are the Pros and Cons of some of the aftermarket computers?
  206. Questions what to do after tune
  207. PE Fuel Curve, Speed Density vs MAF
  208. Different split BLM question
  209. Newbie cam tuning questions
  210. pcm read issue w/ tunercat
  211. b4 you try tunercats,please read
  212. Diablosport Predator Programmer Question
  213. Will Freescan work on VISTAs?
  214. flashing lights
  215. 97 z28 LT1 swap into a 92 RS 3.1 HELP!!!
  216. leaning out idle cc305
  217. Hypertech PP3 Reprogramming?
  218. God place for LT1 dyno tuning in the northeast?
  219. About shoebox's PCM Connector diagram
  220. Making an O2 simulator
  221. tuning near stock 03 vette
  222. how to get datamaster to work?
  223. opti wiring harness...
  224. Help with TunerPro RT
  225. Added Lt Headers, How Do I Tune? Lt-1 Edit
  226. Pass-Key & Key Bypass (shoebox's Diagrams)
  227. Obdii Dtc P1416
  228. Ignition module required?
  229. Understanding DataMaster EE 3.4.1
  230. I need a Stock 96 M6 tune
  231. 1994 to 1995 pcm
  232. cable questions
  233. How do you tell if rich or lean during WOT?
  234. Jet Dynamic Spectrum Tuner 14005
  235. Best PC scanning tool
  236. Gauges out: Oil pressure, engine temp, fuel
  237. Rec. a wideband set-up
  238. More timing that what is commanded?
  239. No power to diagnostic port?
  240. Tuning Programs - LT1/LS1
  241. scan guage question
  242. Please look at my scan and let me know what you think.
  243. killed my pcm with efilive
  244. LE2 383 1stStart Up - Scan/Log Attached
  245. 95 stock bin file
  246. No start after pcm read attempt
  247. Where to get your version of DataMaster
  248. Help with harness conversion please
  249. Link Error Pcm Scan
  250. MadZ28Tune??
