Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 [26] 27 28 29 30 31 32
  1. Looking for some steps.
  2. Desk top programming
  3. pcm reflash
  4. Tuning Software that Tracks
  5. MAF sensor functioning
  6. Question about OBD I and II
  7. Speedometer background change
  8. Can't connect to 97 TA?
  9. Injectors still not grounding out...
  10. PCM Programming Special from Trifecta
  11. Quite pleased with the outcome
  12. Need GEN 6 DFI Tuning in New Jersey
  13. Dyno tunes
  14. Which is better Tuner CATS or LT1/LS1/LS2 Edit???
  15. lean idle in closed loop?
  16. speedo tuning
  17. which plug (obd1 or 2) do i have?
  18. Tunning for 37# lucas injectors?
  19. Is LS1 Edit 'outdated'? Newb to tuning.. Couple Q's.
  20. LE1 heads and 230-236 cam bin.file for a 95
  21. Datamaster Log Review
  22. PO335 and PO336?
  23. throwing code, cheapest way to scan??
  24. top end problem debugging
  25. N2) before MAF tunning.
  26. hypertech
  27. wideband output into EGR input?
  28. ECM question
  29. connecting akm cable
  30. Hypertech Programmer Issues
  31. spankin new motor..code 42
  32. Just DST some help please
  33. Logging software and edit software(100% NEWBIE)
  34. Shift Table for 3.73s
  35. Can VSS (circuit) be bad, but speedo still work?
  36. DFCO not disabling as expected
  37. Good place to grab connectors?
  38. obd1 code reader
  39. 2nd Thoughts About My Tune
  40. PCM Question
  41. Hypertech verse pcmforless
  42. tuning help
  43. is this normal?
  44. buying a 94 - can I tell if PCM is correct to the VIN?
  45. ECM Port not working right
  46. DTC code 41
  47. O2 Sensor Reading? Open Loop Issue..
  48. OBD1 LT1Edit help/can't make changes
  49. datamaster file
  50. LT1 aftermarket ECU users... need a little help.
  51. a scanner question
  52. which mail order tune is the best?
  53. Installing ported heads, do I need a retune?
  54. Idle Open Loop Really Rich after BLM Locker
  55. Need info on tuning trans tables
  56. JET performance chip
  57. backfire problems
  58. Hypertech with cam/ or stock computer tuning
  59. Cool - a Free Desktop PC is always welcome!
  60. Getting Data from my '95
  61. Code 55?
  62. What is the computer on drivers side frame rail
  63. 1996 Caddy ECM w/ auto work in my 1996 z28 6 speed for tune? ---
  64. Too Rich in Closed Loop
  65. Dyno Tune
  66. LT1 Edit Noob (HELP)
  67. Tuning Question!
  68. Factory alarm. I need to disable or get it working.
  69. How Do I Decode My Datamaster Findings?
  70. help me understand computers
  71. 373 gear reprogram diablo programer
  72. Car not running
  73. '93, DIY cable, did I use wrong design?
  74. Pcm Tranny Tricker
  75. quick handheld question.....
  76. 30 lb tuning question
  77. Tunercats questions
  78. tuning options for the LT1
  79. Idle in Park Great - not so in Drive
  80. AKM ALDL cable
  81. Trouble code, and reading help
  82. cc306 tuning ? changed cam now it wont idle
  83. OBD2 Data logging
  84. .BIN to .LT1?
  85. security light on (all the time)
  86. If You Have Had You Pcm Programmed Come In Here!
  87. gaining power from pcm tuning
  88. Internal PCM Resistor Mod: OBDII to OBDI Conversion?
  89. Can I Pull my OBDII tune from PCM with this cable?
  90. ECM Tuning
  91. My ALDL cable won't work correctly!
  92. What Pin at PCM for wideband to AC input?
  93. computer and wiring qustions
  94. What should spark advance be at idle?
  95. will this work
  96. BLM question
  97. How do you get codes out of a 94z LT1???
  98. If I take out my wiper fluid tank will I throw a code?
  99. Turning off VATS in LT1Edit
  100. swaped a 97 computer into a 93, how do i set up the OBDII so i can scan it
  101. Need Corvette 94-95 M6 file please
  102. Tuning MAF for leaner idle for large cam
  103. Stall wall
  104. Tunercat stock tranmission
  105. codes?
  106. Anyone else Zero out the PE vs RPM table?
  107. Would this work for a 95?
  108. Idle Air Control Defaults in LT1Edit?
  109. Got your PCM tuned yet?
  110. tuning for my 94LT1?
  111. Tuning Help
  112. Changed Tune, Car hangs at high idle longer... Why?
  113. How do you learn to tune?
  114. 93 LT1 datalogging
  115. right side blm maxxed
  116. PCM for less question
  117. Transmission Switch
  118. Where can i buy LT1 edit
  119. New 94 Z28 Owner
  120. Tunercat 273 rearend settings
  121. dyno tuning near alpharetta GA
  122. BLM locker
  123. A cheap 93 z link cable?
  124. PCM is tuned - can it be copied and detailed?
  125. Could someone explain these codes???
  126. Ive got a headache, Why is 93 eprom confusing
  127. need help on a code
  128. PCM Expert Pls help
  129. 16 pin ALDL configuration
  130. key cylinder problem
  131. Does anybody sell a 'Bench' setup to program a LT1 PCM ?
  132. Are Mail Orders Just A Band Aid?
  133. Can someone with autotap check....
  134. what other software can I ise to log with autotap cable?
  135. tuning question
  136. f.a.s.t/ delteq
  137. Wake up PCM, wake up!
  138. 383 le3.2 cam , le3 heads timing comparo
  139. Wideband:single bank or double bank
  140. 81 computer: info amnesty
  141. how do i bypass vats in the PCM...
  142. rpm limitations on stock pcm
  143. MADZ Tune ?
  144. can i keep the 93 tranny when switching to a 94 pcm?
  145. failed Md emissions - need help
  146. Help with TCC engage and release?
  147. lose communication with PCM when car starts but have it when its off
  148. Air bag light is on whats up?
  149. Transmission DTC Codes
  150. Egr Q
  151. 89 F-Body- which wire (a/c signal) alters iac signal?
  152. severe timing retard**file inside**
  153. $50 updates
  154. cant open .lt1 file
  155. 1998 corvette pcm came as 1998 pcm?
  156. Uugh, I need help!
  157. 94 lt-1 Auto to Manual
  158. PCM and volt meter reading???
  159. BLMs stuck at 128/128 in closed loop, no correction!
  160. cant connect with akm usb
  161. Free Scan Log Question???
  162. FAST/Speed Pro (old version) vs. XFI
  163. Running rich please help
  164. SLP Shift Improvement Module
  165. New Painless engine management
  166. BLM are between 108-115 most of the time and the exhaust is back at WOT
  167. trans tuning issue
  168. Problem with VATS
  169. LT1-Edit or Tunner Cat question?
  170. Please take a look at 93 datalog
  171. 94 Z28 ABS Codes
  172. Manual fan switch no longer works after PCM retune.
  173. 1993 code 44 and poor fuel economy
  174. jet software tuning problems help!!!
  175. can anyone reccommend an LT1 dyno tuner near columbus, ohio?
  176. Using A/C pressure PCM pin for wideband O2
  177. Datalogged the car and......
  178. Coverting 96 LT4 vette, to 95 ODB1 PCM
  179. rev limiter issues
  180. Scanmaster code 61
  181. DataMaster log reading?
  182. Setting fan on/off points in TunerCat
  183. Anyone know how preform CPR on a PCM?
  184. LS1 PCM conversion ?'s
  185. Causes of Knock?
  186. Innovate wideband sensor connection?
  187. How much timing?
  188. Shift Firmness
  189. Which Cable?
  190. Oh my god im such a dummy (tunercats)
  191. codes 26 and 46
  192. L.A. Tuners?
  193. P0300
  194. If you were starting out?
  195. whats this mean??
  196. Which wire for tach signal on 93 LT1 with LTCC?
  197. How long will the PCM hold a code after SES light?
  198. ABS delete...EBTCM module location?
  199. Can anyone please HELP me?
  200. LT1 Knock Sensor Electrical Specs
  201. line pressure offset,shifts hard at low tps
  202. Removing PCM?
  203. First Time Looking at Data, Help Please
  204. Need help with scan results!
  205. VE tables in SD DA2 question.
  206. WOT PE Tuning Questions
  207. TunerCat question
  208. tuner cat questions! give me a hand guys and gals!
  209. dyno tune in GA, savannah
  210. Replacing a 93 4l60 with a muncie 4 speed..what PCM changes needed and what effects?
  211. What's your EGT Temp?
  212. DataMaster Log; Need Help Diagnosing
  213. Can't create a good File with Tunerpro
  214. Normal knock count
  215. car pulling timing below 1500 rpm
  216. can a 96 pcm be reprogramed for my 95
  217. Scanning/datalogging software help
  218. Actron scanner users - is knock retard displayed with tenths of a degree?
  219. chip burner?
  220. *ADVICE* - power programmer/performance chip
  221. what is this wire?
  222. F.A.S.T B2B Tach signal?
  223. scanmaster lt1 question
  224. Can I run the spedo without a pcm?
  225. P0336
  226. Looking to go wideband, what is my best choice?
  227. Ques about tps volt vs tps %
  228. Tuner packages
  229. air feuel ratio question?
  230. Diagnostic port
  231. auto to manual conversion, but do i need...
  232. what dose this mean?
  233. %Change to Fuel/Air Ratio Vs. RPM at WOT
  234. 94-95 - which byte changes Carline?
  235. Code Trouble PLEASE Help
  236. tuning the '93 Lt1
  237. finding lt1 edit
  238. Fuel Trims & MAF & Stuff...
  239. changing gear ratios, what to change in tune?
  240. New to tuning... had some basic Q's
  241. 1994 tuner cats fan constant...where is it?
  242. shift points with tunercats
  243. Shift point question
  244. FAST USERS: Base F.A.S.T LT1 tune?
  245. Datamaster logs, and tunercat questions
  246. Will this affect my Tune?? STS
  247. Anyone running the old fast bank to bank with Fast track harness?
  248. dyno tuning in or near atlanta ga
  249. Which tuner would you recommend
  250. DTC 66 - ABS Motor
