- how to set idle rpm in tunercats?
- Tuning out trouble codes.
- 87 ss monter ecm and prom work in place of a lg4 set up?
- Injuneer, can you look at this datamaster? 383 problem
- 150 MPH cluster
- Which painless harness to use
- Got My Codes Read and need some help...
- Stock Lt1 A/f Ratio?
- ghost codes
- Removing air bags and deleting air bag light
- Maf Sensor H.p. Max.
- Nitrous tuning
- How to Fix Stall Wall?
- LT1 and HPTuners
- Spark Retard Question
- Running a 94 4L60E with a 01 411 ECM
- help tuner pro?
- 95 camaro tunerpro
- Mastech vs. AKM vs. Moates.net Cables
- new to tuning..
- check engine light
- 22 Throttle Position (TP) sensor circuit (signal voltage low)
- EFI Live: Request for Information please
- security light
- Can't read PCM with BenchTop Harness
- Props the Bryan at PCM for less.
- LT1 and a rear dist.
- New Chip for a 1993 Z28
- Interceptor Scan Guage
- Tuner help
- Rear 02 Sensor
- Hypertech does not say what to do
- Re-Pinning 9354896 pcm
- What cable do i need?
- LS1 PCM on LT1.
- High map code after BLM locker and weird rpm incrementing
- is there a way to test the obdII port
- flashing PCM outside the car
- knock sensor
- Disabling/modifying lockup.
- autotap logs requested
- can the guro's look at my freescan log?
- Help with some error codes please!
- P0172 Trouble Code (system too rich bank 1)
- Pcmforless, or madz28?
- 95 LT1 383 tuning help
- Software for ECM programming?
- ALDL Software for 1994
- Need help with switching from a 1 bar map sensor to a 2 bar...
- What benefits would I gain by switching my setup from a single bar map sensor to a 2?
- Reprogramed ECM, now speedo is spazing
- Basic scan and tune
- code 43 (esc Module or Sensor circuit problem) i am new at this!
- Looking for detailed descriptions of how OBDII PCM's do EFI
- Is there a way to test a PCM?
- Locked HPP
- not sure if this is the right place to post ?
- Thanks Shoebox!
- P0300 ( Random Misfire)
- TTS Mastertune anyone?
- Power programmers who's is the best
- Please help diagnose some problems
- 95 lt1 fuel adjustment
- Best program to datalog obd2
- Keep hitting the rev limiter
- 94-95
- Security System Issues
- Need stock 94 A4 .bin and have questions
- Car is throwing two Crank Position Codes - P0335 & 6
- No MAF? Good or bad?
- Anyone need any small changes?
- madz28.com?
- lt1 computer???
- Getting rid of spark retard.
- 95 and 97 lt1 ecu difference??
- Which scanner???
- OBDI Codes 23 & 48
- VATS & lt1 edit??
- best tuning software for a 95?
- ODBII LT-1 Edit A4 Questions
- Aeroforce Interceptor Gen II OBDII Gauges Available and on Sale at MarylandSpeed
- SES after catback install
- buddies mustang gt vs. my ss
- Better to tune with the stock MAF maxed? Or with the new LPE MAF?
- 94 computer switch with 97
- programming ?
- How to tell if I have a reprogrammed chip?
- SES and 5 codes,
- P0135 O2 heater causing SES... any ideas?
- Need stock 95 Z28 bin file for M6
- PLEASE: Help me out
- tried search: testing O2 sensors, which wires?
- Installing a Knock sensor light ??
- Need Help with MAF sensor calibration.
- Need help with tranny asap
- veh. factory security
- Transmission Tuning Tutorial
- New and I need some help with SES code.
- TTS Datamaster OBD1 Cable Tester Program
- obd1 vs obd2
- p.c.m. tune,who's best/scanmaster
- shoebox and others need help with fans
- Is this a Good Deal on a Dyno Tune?
- Retarding Cam
- OBD I and II
- What determines the downshift?
- Datamaster File
- 30 lbs injector tuning
- what kind of chip should i get?
- MADZ28.com....Ion???
- chip location
- Another Datamaster file
- whats up with my lt1 edit
- Trans help needed
- P0443
- Timing
- Tuning???
- SERVICE ENG. SOON light
- bad extension cause heater code????
- tuning help blinking ses
- Datamaster help!
- Speed Density tune, easy?
- OBDII Tuning and Emissions
- PE Tables in Open Loop tune (93 Car)
- 1994 z28 58,000 miles question on tuning
- Miss at 6,200 RPM, need help
- ls computer and wiring
- P0140
- Code 15, 1993 Z/28
- Vista and Datamaster
- OBD I conversion
- USB Cable Connection (laptop - port) problems
- 6.0 liter LS in place of LT1 (wiring)
- Security light wont turn off
- TTS Datamaster software
- Laptop OBD II Interface
- computer swap
- going le-2
- freescan w/ vista
- Acceptable a/f at cruise (SD, open loop tune)
- banks read different
- F.a.s.t., Bg3, Accel Dfi Gen7?????
- burned up pcm
- Tech 2 air to fuel ratio
- shape of WOT timing advance curve
- ECM Options For Turbo
- code 33
- Just recieved laptop off Ebay...now what?
- best datalogger for obd 1+2?
- Switching to EDIS 8 Need help
- 2.2L and Caddy V8 Coil Packs
- Help with reading datamaster file
- Shift Point Tables for a 3.42
- Idling with big injectors
- code 43 and a code 29 ?
- ECM Programming
- JET Dynamic Spectrum Tuner
- looking for wiring diagram
- 1994 Harness into a 1995? Help!
- 1/4 mile ET from GPS
- No Start Problem - Have data log
- Tuning for 55lb injectors
- DTC 83 code? Help needed.
- Need someone to check my datamaster logs
- ignition control output waveform
- fuel inj. values/ handheld programmer?
- '95 With the OBDII body...but OBDI wiring...grrrr
- 93 Speedometer scalar Tunercat
- Max line pressure constant?
- WOT Tuning without a Wideband - UPDATED
- Mat ?
- Using TC With EPROMs
- Tuning and EGR will increasing the EGR effect at idle/part throttle increase mpg?
- Tuning using PE maxes out?
- Security Light on 96 Z
- Do Lt1's have a blackbox?
- '96up keyless on '95?
- Got a new cam have some questions about lt1 edit
- tuning of the stock computer.
- Replacement LT4
- LT-1 Cam Sync Signal for Aftermarket PCM's
- Tunercat connection issues...
- VATS reset
- Is it that easy ?
- offset for A/C pressure sender
- Tuning Help!!!
- LS1 Edit
- New to Tuning...Where to start?
- Need QUICK advice re PCM flash please
- lt1 edet
- 96 formula, what cable?
- shift firmness on pcmforless tune?
- handheld tuner questions...
- datamaster+96 Camaro+Obd1 PCM+errors
- retuning a car with lt1 edit
- Power programmer 3 ????
- Scanned Car showing a couple of codes
- got my car scanned?
- 96-97 LT1 Question
- dyno programming
- I need the VATS programmed out...
- Switching to speed density 94 LT1
- computer reprogram
- How do I change VIN# in the PCM.
- Valet tune suggestions?
- on the quest for a perfect tune...
- cam/383 tuning
- ***USB Data CABLE***
- 12200411 PCM ('01+ LS1) conversion on an LT1? Links inside!
- Deleted EGR on PCM - IF still plugged in will it still toss a SES?
- Software to delete SES codes?
- ALDL Cable hookup....
- datamaster displaying wrong data
- HELP - Code 26, Code 77
- LT1 Edit guys in here! Tuning guys!
- Can I tune out EVAP without physically removing system?
- Est circuit code 41, 42
- How to Lean Car using Tunercat?
- Need stock 94 M6 program.
- deleting P0400?
- VE Master use
- Did my PCM blew a gasket?
- Got a '95 AKM cable but a OBDII connector...
- Tunercat and Windows Vista
- 95 camaro z28 lt1 bin file
- A4-M6 swap - running problem - computer??
- Looking for a bin file thats close
- best programmer
- Cable connection problem
- Dash lights acting up
- Speedometer is incorrect
- timing tables? do they show advance or retard?
- How to calibrate speedometer
- Turn signal/Park lamp on '01 WS6
- Aftermarket ECU geniuses in here please!
- What's needed for lap top data logging?
- Open Loop AFR vs Coolant Temp vs Map
- Have a mail order tune, what next
- what exactly is HP tuner?
- P0135...?
- A4 pcm vs. m6
- Tuning question?
- tunercat OBDII Tuner / WinFlash Help
- Innovative LC-1?
- 93 LT1 Can I change tune myself?
- Changing Idle in CATS
- Air Bag light after programming! Please help!
- OBD II PCM interchange
- madz28.com VS PCMforLess.com
- flash program
