Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 [24] 25 26 27 28 29 30 31 32
  1. Autotap and Ls1edit
  2. Quick question on OBDII scanners...
  3. A few sensor values, from multimeter...
  4. '95 PCM Problems!!!
  5. First Datalog, Help Analyzing.
  6. tuning the '93 z28
  7. Best Laptop tuning/troubleshooting program
  8. ECM identification
  9. Tuning a specific cell??? Question please...
  10. cheap tuning software
  11. Delteq creating DM Data ERR?
  12. 94/95 4L60E Parts Swap
  13. Blowing Ecm/ign Fuse
  14. Hypertech Tuning: Is it hype?
  15. Theft Detterent Sys????
  16. Jet DST Software
  17. negative trims after h/c?
  18. Should I adjust my stock BLM boundaries?
  19. Tuning Software
  20. Autotap Palm software?
  21. Help. Autotap file question
  22. E85 and OBD1
  23. lterm reading high in open loop mode
  24. p0300 icm, opti spark? need help
  25. tuning my 96 z help
  26. Security Light
  27. OBD not ready
  28. Car has no power. 15 deg knock. Looking to maybe have it programmed.
  29. Small Correction To Timing Nets Big Gains :)
  30. which tuning software?
  31. freescan, checksum errors
  32. SLP Programmer
  33. can you tune out the after cat O2's?
  34. Tranny programming asked differently this time!
  35. "pcm hardware failure (3)" error while tuning pcm
  36. Are all 95's obd1?
  37. Why convert an obd2 system to obd1?---
  38. edit vin
  39. Hypertech fried computer?
  40. knock all over the place, then none
  41. Lt-1 cop car CPU in Camaro?
  42. Finally got rid of my datalogging demons :D
  43. Question about timing at WOT
  44. 95 OBD I auto computer into an 94 Z m6?
  45. PCM High Rev Limit
  46. scanner
  47. OBD1 forced induction/maxed maf issue
  48. Injectors bleeding down
  49. actron scanner cp9145 any good ?
  50. Catalytic converter tuner
  51. Freeing up Com ports? TTS
  52. turbo 383 LT1/misfire
  53. Need Freescan
  54. How Hard To Learn How To Tune???
  55. O2 Simulator
  56. adding timing with 110 octane
  57. Teach me some basics about LT1EDIT ...
  58. When shutting off engine, how do I get the IAC to park not fully opened?
  59. Can anyone interpret my latest data log?
  60. what's a safe redline to tune
  61. Jet Performance chip for 84 Z28
  62. begginer tuner here
  63. gen 7 ???
  64. computer question
  65. RoadRunner PCM
  66. abuse mode
  67. Reprgraming 95 PCM from 120mph to 150mph
  68. Can anyone analyze my Freescan log?
  69. code??
  70. 84 Camaro Z28 H.O.
  71. Lean out air/fuel to pass smog?
  72. knock sensor ?
  73. trans out of a 94 into a 95 need bin file?
  74. OBD-1 won't scan
  75. what gauge?
  76. idle with motron 60#s
  77. wierd computer problem???
  78. Opti Dead?
  79. TPP problem
  80. Where to get tuning software?
  81. scanner results
  82. lt1 edit help supercharged
  83. Help with Jet Tuning software
  84. Porgramming my v6 computer for 3.73 gears HELP
  85. Gen 7 help
  86. Got PCM4LESS tune in today!
  87. diablo sport rpm programer
  88. knock retard
  89. TunerCat... How do I change inject.....
  90. What do you need the stock computer for?
  91. VE tables alter non-SD mode?
  92. First Scan TTS Datamaster, Please Tell me if my Numbers are what they should be...
  93. EE PCM Hack
  94. PCMforless is it worth the price
  95. input needed
  96. GM Wiring Diagrams & Pinouts
  97. 94/95 Pcm ?
  98. Help...please
  99. Which is data port on 95?
  100. hand held programmer help
  101. can someone look at my scans please?
  102. tunercats no longer available....
  103. What prog do I use to edit.
  104. sixspeed to auto
  105. tuning OBD1!!
  106. Easy TunerCat questions
  107. tcc lockup disable
  108. Tuning w/email tune OBD1...
  109. Please,Help! Anybody in here know how to Reset A 97 Hypertech Programmer Plus??
  110. ABS INOP and BRAKE light???
  111. LT1 tuning problem? datalog inside
  112. LT1 Edit
  113. lt1 obd2 tuners in/near nashville TN??
  114. datamaster help please
  115. 96-97 obd 2 motor in 94 ta Q's
  116. Funny VE table problem 94 LT1 in SD mode
  117. REMOVING cats on 96 lt1
  118. any program i can run threw my laptop?
  119. I need computer files!
  120. Injector flow rate question
  121. Who makes ScanMasters, I have a question
  122. Tuner Cat Help?? What Table?
  123. most hp with stock pcm? are they limited?
  124. Looking for a .bin or .lt1 file
  125. On an OBD2 LT1 car, what happens if a rear O2 sensor is bad?
  126. What trim cell should I be in WOT??
  127. LS1 scanmaster works on my 97 LT1
  128. Scanmaster DTC 63
  129. Hypertech tuning problem
  130. pcmforless vs. madz28 vs. hypertech
  131. Trouble codes & comp. questions
  132. Newbie Question
  133. AFGS on blown a blown 355
  134. what needed for LS1 tuning?
  135. OBDII to OBDI Help needed
  136. Where is the Radio Fuse?
  137. General Tuning
  138. tuning
  139. 30lb inj v.s 24lb with tunercat? new tune ?
  140. Moates.net tuning/datalogging cable . help needed.
  141. speed density question
  142. running rich
  143. car cutting out
  144. ECS code 43
  145. datamaster question
  146. can you guys take a look at my freescan log?
  147. help with a4 downshift
  148. Has anyone ever mapped out the OBD2 LT1 PCM program?
  149. New pcm
  150. 1997 Camaro 3.8 - need help with plugs flooding out
  151. speed density tuning
  152. Interface Cable problem
  153. can i delete datamaster from laptop after free trial?
  154. lt1 computer options
  155. Can I get rid of the computer in my 81' Z28?
  156. Got datamaster and a old lappy..
  157. auto file
  158. lt1 edit files or scan data
  159. Couple questions regarding MAF
  160. In need of an LT1 file
  161. Megasquirt vs. other aftermarket ECUs...how does it compare??
  162. LC-1 Xd-16 and loging with a stock PCM
  163. ALDL cable issues
  164. ECS code 43
  165. Forcing Open Loop - OBDI/Tunercat
  166. Accel Starting Problem
  167. datamaster question
  168. Stock M6 programming
  169. Limp Mode?
  170. supercharged pressure side maf tuning problem
  171. Is their any place in NJ that I can take my car to get dyno tuned....
  172. Need wiring diagram
  173. Can somebody explain my dyno graph to me
  174. 8* knock retard at 4200 RPM
  175. O2 with leaded fuel
  176. Quick pcm question
  177. 4th gen keyless on 3rd gen?
  178. What are the PE tables?
  179. Looking for beta testers for PCM programmer
  180. dyno tune with predator?
  181. Another gear swap, shift point thread...
  182. Possible 93 PCM causing me Problems!
  183. 3.42/4.10 gear change
  184. Running out of fuel..but shouldnt...
  185. Recomended tuning options
  186. Easy Tunercats question
  187. Will a 95 jet module work in a 96????
  188. new to tuning
  189. what is wrong...O2s all over in PE
  190. Password
  191. Help Interpreting Scanner Data
  192. Lt1 Edit version 2.0 vs. 2.2?
  193. 94 block 93 pcm???
  194. ses codes
  195. obd2 tunercat/Dynamic spectrum tuner
  196. Idle problems.Need help!
  197. ls1 timing vs lt1 timing
  198. Pcm tuning for idiots
  199. 93 PCM basic info ?
  200. Where to get LT1 tuning software?
  201. L69 prom work in stock 86 LG4 ecm?
  202. Injector Duty Cycle..cant go above 60% with new injectors!
  203. disabling knock sensor
  204. EASY MegaSquirtII install? 9 wires. . .
  205. is there a way to clear the pcm?
  206. th350 and automatic pcm
  207. flashing my PCM
  208. 98 ls1 tunning question
  209. lt1 pcm
  210. 3 fried ECM's in a row! What's going on?!
  211. found a Code forum..
  212. PCM Backward Comptible?
  213. PCM on a 1996 Grand Sport hot enough to purn you
  214. Problems with new computer
  215. Help
  216. 87 camaro help!
  217. Speed density tuning
  218. Anyone using megasquirt on an LT1?
  219. IAC follower is too long
  220. Stand Alones
  221. Failing ECM?
  222. Modifed 95 Camaro z28 A4 bin files with 323
  223. HELP!Car won't idle very well in gear when cold!
  224. Latest Tunercat EE version?
  225. Iat and stumble question
  226. Changing Park Idle Rpms
  227. Can someone take a look?
  228. 1997 Camaro SS / MM6 program
  229. Knock retard (4*) when I stomp on it
  230. Very strange situation
  231. DFCO information???
  232. VATS dissable on 96 grand am
  233. OBD II all new cars?
  234. Tunercat
  235. why the 1-2k rpm backfire look
  236. Speed density theory and 2 bar tune
  237. Speed density theory and 2 bar tune
  238. need help with shift points
  239. scanmaster or datamaster?
  240. Help with FAST and a FastTrack harness...
  241. Stuck in cell 16 128/128 at Idle or at any time TPS=0
  242. 2001 catalytic converter recall
  243. Lt4 knock module?
  244. ECM troubles
  245. error 51
  246. Any LT1 Edit Tuners???
  247. LT1 edit hardware
  248. lt1 into another car
  249. Will a '95 computer work in a '94?
  250. code P0153
