Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 [23] 24 25 26 27 28 29 30 31 32
  1. Lt1 Edit Vs Tuner Cat Whats Better
  2. good tuner
  3. O2 sims and rediness status
  4. Speedometer doesn't work
  5. how to keep tranny from downshifting on dyno?
  6. LT1 editr to tunercat question
  7. Startup Enrichment
  8. How Long Does it Take OBD Monitors to Be Ready?
  9. Anyone use a moates datalogging cable?
  10. stand alone engine management
  11. swapping to 3000 stall, any PCM tables to change?
  12. ALDL Data Transmission (OBD1)
  13. help
  14. EFI live tuning
  15. Trouble code 61. What is this please?
  16. Options for tuning
  17. troubles with freescan on my laptop
  18. What tables to adjust
  19. new tunercats question?? Pleas help???
  20. CHeck out my scan please:)
  21. looking for tuner-austin,texas
  22. Need Help!! Abs Inop
  23. help
  24. Datamaster differences: 3.4.1. to 3.5.1.
  25. What's with this ?
  26. tune optimized for cam only...if i add heads.....
  27. BEST OBD I tuner LT1
  28. Will open headers affect your wot F/A?
  29. help with cut wire harness......
  30. reason for intermittently going back into open loop?
  31. Having Idle problems
  32. Program or Scanner to monitor vital signs on 1999 ls1 ta
  33. Paper clip jump on my port
  34. programing a stock '95 lt1 for some more....
  35. Need Impala SS hotcam tune
  36. Recovering from a bad .bin upload?
  37. How is leaning out at WOT actually achieved???
  38. General OBDII Code Clearing Question
  39. 96 M6 PCM into a 97 a4?
  40. '94 LT1 scanmaster wont work!
  41. help me please
  42. Questions about full time "open loop" and logging (newb)
  43. F.A.S.T. Unit..making A/C work !! How ?
  44. calculated air consumption?
  45. tuner in LA. area
  46. Code P1680?
  47. How much timing do tuned heads/cam LT1's normally run?
  48. Scanning software with wideband input?
  49. 94 OBD1 trouble codes
  50. Scanmaster O2 voltages dropping.....
  51. Datamaster Support
  52. Can new O2 sensors make your car run leaner/richer?
  53. Best tuner program for the money?
  54. how can I tell if my car was tuned?
  55. F.A.S.T. ecu???
  56. Dyno operator/equipment errors with 2 tunes?
  57. Can Dyno operator/equipment cause erratic running of engine?
  58. I Need Datamaster 3.4.1
  59. How robust is a PCM? Can it survive a fire?
  60. What Software Package Should A Novice Tuner Buy?
  61. Scanmaster, is it worth it?
  62. ABS INOP but not picking up any codes on Datamaster
  63. To scan my car with laptop
  64. Tuning for emmissions. Where do I start?
  65. Need FAST EFI Dashboard sensor descriptions..
  66. Need LT1 Edit Tune for my car
  67. Service Engine Soon light and cooling fans stay on.
  68. Trouble Codes and Senso Readings... Need help!
  69. Tuning w/ and w/o SuperCharger
  70. Tuning at the track?
  71. Predator and Torque Management
  72. Is their a way to test the MAF sensor ?
  73. a little cleaning turned into a pile of problems
  74. Can a cable from a Snapon scanner be used for tuning with my laptop?
  75. What do I need to use with VEmaster?
  76. Here's a dumb question
  77. Looking for a reputable tuner near or in NJ?
  78. OBD-II protocol/fuel level
  79. deleting secondary air
  80. Datamsater question.......
  81. Low Impedance Injector Driver/converter???
  82. Gen 7 KINGS need some help !
  83. fried 2 pcm's
  84. VE Tables Question.
  85. Which O2 sensor?
  86. Can someone email me the $EE Def. File?
  87. changing fuel tables in tunercat
  88. Dynojet wideband where to install sensor
  89. Datamaster How to determine HP and TQ
  90. People with 95' Computer in here!
  91. PCM Tuning on 07 Vehicles
  92. Question Scan Tool
  93. LT1 pcm & DFI Gen 7
  94. Changing computer chip
  95. Anyone able to get ahold of Andrew at AKM cables lately?
  96. Post your tunes (.bin & .lt1 files)
  97. # on back of key fob
  98. Is the AEM widband O2 gauge accurate?
  99. Gen 7 & closed loop corection
  100. obd 1 and 2 question
  101. Can someone help me out with a stock Canadian 95 M6 ecm file?
  102. check engine light...
  103. Can anyone answer ac questions
  104. Cable for efi live
  105. throttle position problem
  106. locking up the converter early??
  107. Help a noob... Basic Cable Software help?
  108. LT1-edit 2.2 users help needed
  109. Fyi Mxscan
  110. Where to Start
  111. need some help
  112. somebody analyze this datamaster file
  113. Will my cable work with obd II?
  114. can't get datamaster to work!!!
  115. Code 43.. Please Help...
  116. Scanmaster on 93 Camaro?
  117. 93 owners
  118. Tune myself? Recommendations please
  119. Any '94-'95 OBD1 WBO2 users want to test a tool?
  120. Dell Pocket PC
  121. Wideband O2 PCM hookup and logging
  122. MXscan for Tunercat OBD II released
  123. Help !!!!! This Is F*$ken Pissing Me Off !!!!!!!!!!
  124. Help!!...superchips #2150 Or Hypertech????
  125. 93 camaro chip question
  126. msd digital 6 box - timing retard, knock, & datalogging
  127. Can no signal from VSS cause the car to run bad?
  128. ScanGauge by LinearLogic
  129. HELP ME!! My car idles too high!!
  130. Can someone take a look at a Datamaster file for me?
  131. Question on differences between manual and auto (stock tune files) for converted car
  132. tunning after cam
  133. freescan???
  134. Can Someone Help With diagnosising A hard start after 3 days?
  135. Electrical System going haywire?
  136. TTS DataMaster Help
  137. VATS disable?
  138. is hypertech chip good upgrade for stock 94 z28
  139. random trouble codes for split second
  140. "VATS" I need help with resistance!(shoebox)
  141. how do you adjust timing on
  142. computer flash programming ?
  143. EGR enable question
  144. crank sensor code
  145. Car throws some codes.
  146. Need a FAST timing tune 355ci turbo lt1
  147. %change to fuel/air ratio vs rpm @WOT table
  148. increase timing
  149. running rich 383
  150. timing question?
  151. obd2 -> obd1 conversion issues
  152. programing 96 Z28 with laptop
  153. PROM ID Question
  154. EFILive Scanner with a 96-97 LT1 pcm
  155. Borrow LT1 edit file...
  156. running rich 383
  157. PCM and TPS problem again
  158. Tune LT1 like LS1???
  159. How do I make car run at 14.0AFR closed loop?
  160. LT1 "commanded afr" pid?
  161. New To tuning?
  162. 383 tune
  163. LT1 edit?
  164. Can ABS be disabled by tuning?
  165. Datamaster just stopped working
  166. ve table or maf frequency
  167. now that pcm has "learned" it runs like crap
  168. needing new def file.
  169. anybody know a good dynotuner for LT1 in st. louis...
  170. 95 Impala stock tune.
  171. failed program
  172. ECM tuning question
  173. Help tuning open loop and idle...
  174. NEW TOY: scanner / trip computer
  175. need some tranny wiring help
  176. Possible PCM problem?
  177. 383 Drowning While Driving ?????
  178. tuner pro
  179. ? ford ecm tunning any body know of programs?
  180. Trouble with Freescan
  181. Sensor circuit commons.. SD vs MAF
  182. A transplanted 93 Z28 Lt1
  183. Diff between closed and open loop
  184. torque management question
  185. downloading 94 program through OBD2 plug?
  186. T-56 swap tuning
  187. Need to compare a timing table for a larger cammed motor
  188. Will a "hypertech scanner" read ses codes?
  189. USB datalogging????
  190. Tried to Link to my cars PCM- Getting a "LOCKED" message???
  191. OBD1 conversion ?
  192. TPS Issues
  193. boost retard or advance?
  194. Low Octain
  195. OBD1 PCM question
  196. Table #'s help please
  197. getting dynotuned this weekend, have a question..
  198. Tuning software and Cable question
  199. Do LT1's have "Lean Cruise" or a similar option
  200. Question
  201. Turning off the IAC in the PCM
  202. PCM wont communicate with laptop
  203. who all has...obd2 swap 94
  204. obd2 t0 obd1 conversion
  205. tunning mass air
  206. How to get trouble codes from a '95
  207. Where can I get an OBD2 ALDL port?
  208. no request fro second fanw/ ac
  209. LT1 edit???
  210. 2 bar MAP sensor
  211. Can I use an M6 obd2 pcm in an A4?
  212. 91 bird 5.0 with 24#ers
  213. mass air flow circuit low?
  214. Got PCcomm......what am I looking at???
  215. OBDI PCM Source?
  216. Knock sensor problems (maybe)????
  217. HELP! 1661 trouble code & emissions failure
  218. BLM Low on right, high on left, abnormal?
  219. Quick Props to Bryan @ PCM4LESS......
  220. OBD2 Cables
  221. important question about dash's speedo, laptop and GPS
  222. car runs really rich under WOT, new tuner
  223. True engine mileage from the computer?
  224. VSS Needed?.
  225. iBook
  226. which tuner program is vin locked?
  227. MAF, SD or PE tune please help
  228. ported maf
  229. <$10 EEPROM programmer for $EE folks
  230. Tuner Cat Timing tables
  231. 1996 z28 Smog pump removal / ABS light now on ?
  232. Obd-2 Dtc P1543
  233. tuning software for 95 obd1 computer
  234. dtc 51 bad checksum
  235. tuning with ls1edit help?
  236. Manifold Differential Pressure Sensor
  237. nooooooooo
  238. Db-9 to Usb interface cable
  239. Self tuneing software.
  240. help understanding trouble code
  241. Uploading a program with tunercat
  242. getting tunercats and datamaster
  243. MAF table adjustment for Ported MAF
  244. 'cooling/TPS' HELP
  245. ABS / ALDL Stream Reader (Bets Tester Rqd)
  246. Need a little advice...trying tuning on my own
  247. Timing & Power Question
  248. Which Tuning Software Should I Use
  249. Big Time Newb here needs help....running rich burning too much fuel
  250. 224/230 A4...some tuning tips?
