Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 [21] 22 23 24 25 26 27 28 29 30 31 32
  1. Fried ECM?
  2. Freescan for '95 Z28
  3. wont idle for 20 min
  4. any tips on finding an electrical problem?
  5. getting knock, don't know why
  6. Injector constant for a 60# Siemens injector please...
  7. Security Light Stays on
  8. MadZ28!!!
  9. car stalls on launch
  10. AIR pump system on my '99 Z28
  11. PLX M300 or AEM?
  12. mail oder tune?
  13. How to deactivate my 97 camaros anti-theft
  14. Deleting Vats
  15. MSD box braking up logging?
  16. Using PCM traction control to retard timing.
  17. Integrating an LM-1 into the OBD1 datastream
  18. tunning
  19. VeMaster Problems
  20. LE head cam tuning question
  21. any scan tools
  22. Question about using an OBDI M6 PCM on an OBDII A4?
  23. Will a manual fan switch eliminate the pcm from turning them on
  24. how to disable vats and egr using cats tuner
  25. pro chips
  26. Transfer frequency from one keyless remote to the other?
  27. TunerPro to change speedo?
  28. Hypertech issues
  29. where to tune?
  30. MAF Location = Problems?
  31. Service Engine Light after spark plug and wire change
  32. In Car Laptop Stands
  33. Where to buy LT1 Edit?---
  34. oil reset
  35. MSD Digital 6 Plus
  36. PCM Tables
  37. tunercat tunes for lt1
  38. loads of codes obd1
  39. Shift point problems
  40. How good is your Tune (Poll)
  41. reprogram speedometer for gear change?
  42. Quick question need some help guys!!
  43. MSD Digital 6 Plus
  44. just wondering how hard it is......
  45. Missing problem in the LS1!!!
  46. Coolant level low??
  47. Is this true
  48. LT1 or LS1 drivetrain into truck - computer?
  49. ....just erased my pcm and then the .... cable failed
  50. tuning for 42# lucas injectors
  51. Can I make a Man.Fan. Switch with this switch?
  52. dtc 16 & 51. HELP!
  53. P1371
  54. Changing maf settings affect PE tables?
  55. can anyone help me with an TC ECM def file
  56. t 56 swap
  57. 1996 PCM question
  58. Possible Failed PCM
  59. Big Stuff 3 with LT1 and SEFI
  60. wanting software
  61. Anyone have an old version of Autotap?
  62. Found some programming hardware sites
  63. obd1,comp controlled carb ecm help
  64. V8 Camaro Gauges to install on V6 Camaro
  65. programmer 94 z and 95 tahoe
  66. data logs
  67. Pcm Removal ??
  68. reprogram needed
  69. Sequential firing???
  70. Gauge for pillar...
  71. Worth It?
  72. 383ci cc306 1.6rr's---- looking for a tune..
  73. 6 speed conversion cags, and reverse lockout
  74. tuning automatics for bigger throttle body
  75. intake backfires
  76. otc scanpro 3409
  77. New Scanner: Autoxray EZ-Read 2000, "Vehicle not reponding"
  78. PCM tuning
  79. Open the Door...Trunk Pops!!
  80. engine manage
  81. Does datamaster read "speed" wrong?
  82. obd 1 cable
  83. air temp sensor vs timing?
  84. keyless entry problem
  85. madz28
  86. 96-97 LT1 Tunercat Timing Advance
  87. Tried search and nothing, tried resurrected post and nothing....
  88. True Duals, now I need help w/ tuning
  89. Weird RPM Sticking at 2,500 some times
  90. LT1 edit not connecting to car pcm
  91. Idle Tunning (DID SEARCH)
  92. Thanks to madz
  93. What will I gain
  94. Quick low oil level sensor question please...
  95. possible electrical problem
  96. Any tuning chips/programmers for a 3.4 V6???
  97. Tunercat / CAT WinFlash question
  98. changing gears
  99. Tunercats
  100. Tuning Help - Look at my Dyno Sheet
  101. No communication with car
  102. What is the formula?
  103. pcm for less??
  104. Looking for someone with cable in Baton Rouge
  105. Beat surge by disabling closed loop, now what?
  106. Dtc 51
  107. Obd2 tunercat and knock retard questions..?
  108. Dtc 41 & 42
  109. new pcm for 96 z28
  110. Shop Version LT1 Edit and Laptop 4 sale..
  111. orlando florida 95 lt1 tune help!!!!
  112. DTC 33 immediately on new setup startup, can someone look at data logs for me?
  113. Texas Speed Tune
  114. msd opti
  115. Guys with bigger cams and datalogging capability, post your MAP value @idle please
  116. mail tune and hypertech ?
  117. adjusting A/F ratio with Tunercat?
  118. profile swaps in lt1 edit
  119. hypertech PTM help!
  120. How tunable is TBI?
  121. 1996 Z28 Throttle Spring Problem***
  122. big block fi system
  123. obd ?
  124. OTC Genisys programming
  125. Ecm Pin Help
  126. Help with lt1 edit
  127. First time tuner cat
  128. help with lt1 edit
  129. Hypertech Power Programmer III Q's about shift points..
  130. Really tough nut to crack here on SES light
  131. LT1 Edit Cable Only?
  132. Tunercat equipment ?s
  133. Pcm Question!!!
  134. Datamaster reveals MSD rev module kicking in early?
  135. Air pump question on lt1.
  136. changing gears
  137. Which wideband 02 meter is the best for me?
  138. LT1 edit not connecting to pcm
  139. Madwolf....
  140. Shift point problem.....
  141. tts datamaser and tunercat ????
  142. can tune PCM to pass emissions on 383??
  143. Datamaster
  144. How much for a good tune
  145. Abs Inop
  146. How long does a code stay in the computer?
  147. tapping pin in ecm help
  148. hey madwolf, or anybody, ecm wiring question
  149. Madwolf....???
  150. PCM Identification
  151. Plx R-500
  152. Dead computer
  153. 108 BLMs...Any ideas?
  154. scanmaster not working
  155. Stumble/Miss under load... Any suggestions?
  156. BLM's on the rich side
  157. Guys running FAST XFI with LT1 cars with stock gauges???
  158. Drops in RPM when coming to a stop???
  159. 52mm TB, Increase Trans Line pressure?
  160. Ses Light Question
  161. TCC lockup at 93-100% TPS. Is this the stock flash?
  162. Need a stock 94 tunercat file
  163. OBD I issues on 97 LT1
  164. ? about LT4 KM and Madz28 tune
  165. Will a caprice OBD1 from a 94 work on my Z?
  166. stock 94 m6 tunercat file
  167. o2 sensor ?
  168. differance between a4 and m6 tunes?
  169. rs32 or usb cable?
  170. LE2 383 Idle AF
  171. Best place to buy AC Delco 02 sensors?
  172. PCM no read
  173. Cylinder Volume in Tunercat question please...
  174. "Invalid Response from PCM"
  175. Computer died the other day, but now its working again????
  176. VERY disappointed with Bryan Herter Customer Service..
  177. What is your favorite obd2 datalog program?
  178. Dtc 42 ????
  179. Tunercats question
  180. Tune out part of ABS?
  181. 5" Tach
  182. Repining the C100 Block
  183. ?'s about laptop, just got one
  184. Do any free obd2 scan programs work with the tunercat hardware?
  185. Any way to check codes on my obd2 lt1 without software?
  186. freescan not working?
  187. Someone to reflash my hpp!!!
  188. 99 ls1 deleting codes
  189. Tuner Cats larger injectors
  190. who is good at tuning a 93 speed density..
  191. Keyless entry programming problem. PLEASE HELP!~
  192. PCM 4 less
  193. Cables for OBD1
  194. Have 3.73s, speedo and odo are off by ~15%
  195. First Time tuning a 91 Camaro
  196. People with wideband setups
  197. a/f ratio hookup
  198. Dynojet Wideband O2 Sensor RPM Output Inop
  199. HP Tuners VATS Security Light Question
  200. Sure is nice to have an electrical engineer friend
  201. need help
  202. readiness test
  203. Low Oil Light
  204. LT1 tuning
  205. Low coolant sensor
  206. AIR/EGR delete question
  207. here is my datalog. can anyone decipher it for me..
  208. I need a Stock LT1 file
  209. Electrical problems on 94 Z28
  210. Gen 7 pro's NEED HELP !
  211. Need Gen7 wiring help
  212. Dtc 67
  213. 3.23-3.73
  214. ABS Light comes on then off! Please Help
  215. WOT Tuning, Spreadsheet attached.
  216. Headlight Trouble
  217. LT1 Definition file
  218. weird 94 formula abs inop problem
  219. tunercat
  220. 95 Lt1 Xdf
  221. How to tell if your 93 Lt1 has a stock program
  222. Adjusting idle with Tunercats for a M6 car
  223. 95 PCM question
  224. TunerCat for '98
  225. Z06 Maf
  226. can an Ed Wright locked PCM be reflashed with tunercat?
  227. those using LS1_edit, where do you get the gms air/cyl data from your scan tool....
  228. Whats causing my 108 blms at idle?
  229. Dyno Tune Wideband
  230. Spark advance table for hotcam/cc305 or equivilent? Share yours?
  231. TunerCat obdii vs lt1edit obdii
  232. lt1 edit help
  233. Average Long Term Fuel Trim
  234. disabling egr in PCM - I can leave it installed and connected right?
  235. Stock program needed
  236. new tune
  237. new tune, now car boggs off idle
  238. Spark retard and knock count
  239. Scanmaster
  240. Headlights will not turn off when car is running??WTF-Help
  241. msd digital 6 box
  242. camaro 1997 side Fuse Panel diagram-Anyone have a pic
  243. Flashing PCM and it failed to establish communication, now car won't run??
  244. Info needed on how to ZIF socket PCM and where can I get a kit to do it?
  245. I need help with the diablo tuner BADLY please help
  246. Wideband question
  247. Sources for AN28F512 chips?
  248. A different kind of EGR question - PCM related
  249. Hypertech Error
  250. Data logging
