Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21 22 23 24 25 26 27 28 29 30 31 32
  1. tuning newbie...
  2. Lower Degree Thermo Without a Tune??
  3. Tunercats
  4. Lean hesitation on '95 LT1 turbo
  5. PCM Problem
  6. Tuning Questions Please Help!!!
  7. PCMforless + transgo shift kit problem
  8. Caddy PCM Swap
  9. PCM Bad?
  10. Converting 1995 bin to 1993 bin
  11. New to LT1s, Which tunning programs...
  12. Question for tuners
  13. Still having problems
  14. P0300 after Trex install, i've check about everything!
  15. Help getting CATS going
  16. Wideband Accuracy? Which ones work the best?
  17. Finally
  18. tunercat/ Knock sensor
  19. Learn to tune
  20. Freescan log
  21. free scan
  22. LS1 edit
  23. will this Moates product work with our Fbodies?
  24. Running Rich?
  25. Reading Message 0, Word 52 (Knock Retard) from the ECM
  26. Tunning Woes
  27. emissions question.
  28. Shift points tunercat
  29. HPTuners and Superchips
  30. Timing tables needed
  31. code 29...fans on all the time
  32. Camaro 3.4 and Firebird 3.4 Same PCM?
  33. How to run in open loop
  34. maf/o2's
  35. Is it Legal to tune or not?
  36. What all does the PCM use the MPH reading for? My PCM is 5 time higher then my spedo
  37. Questions about pulling timing with the Traction Control tables
  38. tuning for XE236/242, tips/suggestions appreciated
  39. Can a predator tune for M6 swap??
  40. Low rpm stumble...Have Tunercat
  41. ALL VINs with LT1edit
  42. Quick question about o2 sensor readings....
  43. Code 33
  44. Adjusting Fuel
  45. looking for a 383 CC306 with 58mm tb tune
  46. shifting woes with 4.88's
  47. Big cam and stock PCM?
  48. Whats better cutting fuel, or spark for rev limiter??
  49. Need help with Gen 7
  50. changed O2's and still throwing a code?!?!
  51. knock retard
  52. Data Login with TTS Datamaster
  53. I got code 43 and o2 sensor is reporting 200-600mVolts
  54. Code 410 questions
  55. tuning for fuel economy
  56. m6 swap programming & JET SCU ?'s
  57. FS NOKIA N91 AT JUST $230usd, MOTOROLA RAZR V3 AT JUST $140usd
  58. code 24 (output speed low) & 34 (map low)
  59. OBD1 High Stall Problem
  60. The most basic tuning questions
  61. hotcam idle problems
  62. MAF circuit? code38
  63. Need a stock 95' Z28 M6 bin file please....
  64. Need a bit of advice on VE tables Vs. MAF tables
  65. Compilation of Fixes for OBD1 High Stall problem
  66. Who Sells ALDL cables
  67. Modifying ASR (Traction Control)
  68. More knock after LT4 KM?
  69. 381cu in stroker - tunercat newB.
  70. Security Light/No problems starting
  71. Need Auto (((HELP)))
  72. Long term fuel trim question...
  73. 94 Camaro RS PCM readin
  74. adjusting fuel -tunercat question
  75. Code P1131 - I need help
  76. Looking for 93 Lt1 .BIN's any kind
  77. Knock Count
  78. Had tunercat failure while programming 95 LT1. Now what?
  79. ALDL ports on V8 & V6 cars
  80. 1996 LT1/4L60e shifting problems...
  81. Scanner cable... will it work??
  82. Is -15.2 Long Term Fuel Trim Normal?
  83. SD Mode and Fuel Trim
  84. Service Engine Soon
  85. Worth it to custom program a mostly stock '99 LS1?
  86. Service Sengine Soon code 29
  87. help with custom tune
  88. Code 51 'EEPROM ERROR'?prob..
  89. OBDI conversion: do I need
  90. how will stock computer react with piggyback?
  91. i have a 306 and a tune...
  92. 6 and 8 running RICH....Monoblade?
  93. Why run a standalone ECM?
  94. MAF Problem
  95. spark advance & another ?
  96. i have high injector DC, can this be tuned out?
  97. How does my PCM control A/F at WOT?
  98. lt1 edit question
  99. Tuning for super Heavy shootout in Atl
  100. Need help creating Timing Table for 396
  101. Bad (corrupt) tune?
  102. Using LT1 Edit, how do you turn off the knock sensor?
  103. desktop dyno
  104. Tranny shift / possible tune problem
  105. OBDII Software for Elmscan Interface
  106. can i do this?
  107. Auto PCM Question
  108. will 100 LL airplane gas kill my o2 sensors
  109. Make your own ALDL cables
  110. Questions on WOT/PE mode, Open/Closed Loop
  111. How do I learn to tune?
  112. What scanning software to use?
  113. ALdl connection problems...Please help..
  114. No more knock
  115. VE tuning
  116. BLM locker program?
  117. will a scanmaster used for a 94 obd1 car work on a 96 obd2 car?
  118. OKAY ... so my car shuts off when I unplug MAF
  119. where can look on my data master file?
  120. Jeff Creech Reccomendations?
  121. Question about lean condition(wideband used) only in 3rd gear (A4)?
  122. O2 voltage stays 1092?
  123. ODB2 to OBD1 conversion: cyl balance q
  124. Proper way to perform a data log?
  125. coolant level sensor
  126. What sensors/inputs tell the PCM to turn the fans on/off?
  127. Actron CP9145 PID questions
  128. Forgot how to tune after returning from Army
  129. Has anyone done an open loop program on a 93?
  130. Do I need the MAF?
  131. Running rich. Someone look at my log.
  132. P1860 TCC PWM solenoid Circiut Electrical
  133. Accel Gen 6 ECM Question
  134. wont idle properly after driving 381 lt1...
  135. Computer to OBD1 port cable
  136. Any TTS Datamaster experts?
  137. Idle speed ..
  138. Which cable is the best???
  139. Rev limiter???
  140. hyper tech?
  141. mem-cal number help
  142. 16188051 "94-95" LT1 PCM pin out
  143. Who has the best price on PCM tunes?
  144. OBD1 or OBD2 for mild mods & emissions (i've done searches!)
  145. Lt1 tuning
  146. $EE definition file
  147. LT1 pcm MAF table file values NEEDED
  148. Bank 1 Lean only at idle??
  149. WTF, datamaster TTS program wont record properly?
  150. Computer problem, kind of technical.
  151. Headlight problem...
  152. transmission dtc code 73????
  153. free tuning software
  154. Dtc 26 Evap???
  155. A/F ratio ?
  156. z06 maf tune
  157. How to lower my idle? with tuner cats?
  158. spark retard and CCM questions
  159. Help me tune my car
  160. Autozone can't scan my 95?
  161. What to get to program an LT1?
  162. Use for OBD2 cables
  163. 2nd ECU fired!!!! Whats going on??
  164. IAC at 160 and running very rich
  165. tuning questions, tuner cat - newbie
  166. who the best for pcm tune
  167. Laptop Question
  168. where can i get a in car mount for my labtop??
  169. Wideband O2 opinions
  170. DFCO Problems
  171. Who here has had light throttle cam surge and beaten it? How?
  172. vss, 95 lt1 TH400
  173. anyone know where i can get an OBD1 scanned???
  174. ODB-II cable questions
  175. HELP! 94 Z keyless entry won't work
  176. OBD2 cable
  177. Can someone look at my BIN File for me??
  178. What scanner to use.
  179. Computer Controlling Only Fuel
  180. Should my IAC's go above 130 when driving
  181. 96 w/ OBD1 comm data + "learn disabled ' before and after O2 replacement
  182. After Market ECU's
  183. Need help with ALDL Cable!
  184. best chip/programmer
  185. 94 L32 PCM Reading
  186. ? about Freescan start temp
  187. Tunning for crusing with tunnercats
  188. TunerCAT file password?
  189. pcm chips
  190. Tuners in Savannah
  191. christian millards site
  192. Help Please Bank 1 STerm High, only?
  193. can't read pcm
  194. Replaced Exhaust now Service Engine light on, Connection?
  195. Setting up with Hpertech tuner
  196. not shifting from 2 to 3-HELP!!!
  197. fuel gauge!
  198. ALDL not communicating with Auto X-Ray.
  199. Diagnostic cable for 94Z
  200. Help With Pcm
  201. whats the difference between the ob1 and ob2?
  202. power programmer plus or 3
  203. Which Computer?
  204. Need Help with 02 / Fuel Inj Pulse problem
  205. Question for PCM For Less
  206. Help for adjusting timing w/TunerCat
  207. Any EFI Live users in ARKANSAS.
  208. PE Idle Help!!!
  209. Help with Fastchip Options/Setup 3.4
  210. pcm forless???????
  211. cable help please
  212. Madz28?? No response?
  213. High stall obd1 fix people
  214. Little help?
  215. Diagnostic Scanner
  216. LT1 edit/Tunercats
  217. low load bucking
  218. Will higher fuel pressure lower NOx on speed density?
  219. WOT Electronics question
  220. Will the stock '95 ECM go into PE when engine is cold?
  221. data master problem
  222. 92 Corvette LT1 intermitent miss
  223. tuning forum for aftermarket EMU's?
  224. Bryan at pcm forless
  225. Software
  226. wireing diagram for 94 bose cd player
  227. speed density mode?
  228. Winflash will not connect
  229. Hey Im looking for BILL from WAUPUN WISCONSIN
  230. ? about fuel pressure vs mixture on speed density
  231. #$&*@! SES light on. Poor man's way to check?
  232. hydraulic roller lifters
  233. OBD1 Palm Data Logger?
  234. Wiring gurus: tan wire abs & ?tcc?
  235. Tunercat for a 96?
  236. cable question
  237. question about tunercats
  238. what type of laptop do yo use
  239. Obdii P0100..
  240. how to e-mail auto tap logs
  241. Wideband placement
  242. OBD II SCAN for OBD I
  243. Help!!! asap
  244. Im about to give this car away
  245. Laptop Connection Problems
  246. Data Logging for an LS1?
  247. Found A Usb To Serial That Works!
  248. VE table Help
  249. Just Ran an OBD2 Scan
  250. Madz28 Tuning
