Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 [19] 20 21 22 23 24 25 26 27 28 29 30 31 32
  1. tachometer problem.... help!!!!?
  2. Running rich I think - any advice?
  3. dum question
  4. What s/w will work with my EASE cable?
  5. Can someone help me out? 2.73 to 3.73 change
  6. VIN changed in PCM, now it won't program!!
  7. Custom Tune'd PCM?
  8. Equus/Innova 3110 OBDII C.A.N. Scanner?
  9. need akm cable help
  10. how can i tell if my computer is shot?
  11. Takes a little cranking to start when warm
  12. P1115, What is it?
  13. dyno tune..on the street
  14. mail tune...confused on what to get
  15. How do I get into my steering column?
  16. lean condition
  17. supercharger tunes.
  18. looking for tunercat expert. need help tuning stock 94z
  19. Need Datamaster .UNI file for 1227730 ECM (90-92 F-body)
  20. LT1 in 49 ford pcm help!!!!
  21. Innovate Motorsports Widebands
  22. Need To Tune Car. HELP!
  23. PE Tables and A/F ratio
  24. Iffy about friend tuning
  25. 95 LT1 and 700R4
  26. ALDL Problems
  27. OBD1 cable and 95 Z28 Question
  28. ANYWAY to simply check if the Laptop is correctly connected to the PCM ???
  29. Enabling lean cruise mode...?
  30. Help with Speedo Correction
  31. Predator tuner
  32. Need VCI number.....please help
  33. Tune for gm 847 cam and afr190 heads?
  34. Scanning, ALDL, and more, oh me oh my!
  35. ProScan v2.0! what do you think
  36. time to tune???
  37. Live Data Question
  38. HELP! Alarm system is preventing my car to start!
  39. Datamaster Help
  40. power off storage/failed emissions
  41. Anyone use a Serial RS-232 to USB Adaptor?
  42. GM847 Tune...
  43. tunercat
  44. OBDII leaning out closed loop
  45. What do I need to buy to use tunercat?
  46. 1997 LT1 Camaro LT1edit or Tunercat
  47. Easyiest and Cheapest way to bump my shift points
  48. HELP 94 TA has low rpm miss, HELP, PLEASE.
  49. Is this Bad Programming?
  50. Tunercat Customer Service :bs:
  51. Aldl cable problem
  52. Help: Dyno question on 94 LT1 A4 car
  53. Freescan is not working right with USB adapter
  54. how to save stock tune?
  55. Madz28 saved the day
  56. Open loop 02 sensor readings insane!
  57. HP tuners vs. LS1 edit
  58. question
  59. putting in a new wiring harness, mine is junk, will this one work?
  60. Can someone please look at a datamaster file, PLEASE.
  61. Can't Decide
  62. Need New Tuning??????
  63. Lbl And Rbl
  64. mail order tune...how?
  65. IPAQ rx3115
  66. Free LT1 PCM editing and diag software
  67. How should I go about upgrading my computer?
  68. Need a tune for a stock (ex. full exhaust) LS1
  69. OBDII files for LT1
  70. what temp is closed loop in pcm for less tuning with 160 termostat?
  71. TunerCat & PCM Questions
  72. Anyone using the new FAST XFI?
  73. "ASR Off" light is on all the time...why???
  74. ASR wiring schematic...
  75. Programming new remote
  76. need 96 LT1 auto tranny file for 4.10's
  77. What are the symptoms of having a bad batch of gas?
  78. recommendations for pcm repair
  79. Stock tune capabilities???
  80. tunning for a turbo
  81. Will 486 33mhz computer run tuner cat?
  82. 94/95 .bin file work in a 96/97 pcm?
  83. Misfire in the rain
  84. 95 Z28 T56
  85. Can someone lower my idle and change my rear end?
  86. Can someone please take a look at my cars scan
  87. 97 z28 will not start
  88. tuning the new TA with new mods
  89. Is there a problem??????
  90. Converting 93 to 94-94 pcm
  91. PCM Scanning
  92. need someone with experience to look at this datamaster scan for me, injuneer?
  93. Open Loop part throttle tuning
  94. a4 shift point tuning help
  95. I've tried everything! PCM: Invalid response!!!
  96. madz28 or pcmforless tuning
  97. Can somone look at my data logs? BLM's
  98. Installing Infinity in-dash navigation into another vechile...
  99. New AftermarketComputer Needed
  100. mail order tune for STS kit
  101. Need Copy lt1-edit
  102. ABS INOP light coming on and car being weird..
  103. Code 42, how do I fix?
  104. Wdieband to datamaster
  105. Lost Speedo During Reflash
  106. Can anybody take a look at my scan?
  107. Neutral Safety Switch Issue
  108. EFIlive or Autotap?
  109. LT1 A4 shift point programmaing survey
  110. Question about A-Tap
  111. Can you make a tune to add "lope" with a stock cam?
  112. Is there a common problem with these codes...
  113. hitting rev limiter
  114. [B]Who burns 3rd Gen Proms?[/B]
  115. Bad Program?
  116. maf high code
  117. Best Tuning Software/Hardware (Yes, did a search!)
  118. trial version of TC
  119. Dastek Unichip?
  120. P1441 Code Evap ...Help?
  121. HP tuner to tunercat
  122. Factory Stereo Problems
  123. "HELP" tried to program ECM and now car wont run
  124. open loop
  125. readiness monitors - how long?
  126. dyno tune or have garage scan car?
  127. P0430 TWC system low efficiency bank 2
  128. Help With Diablo Predator Tuning!
  129. LT1 Scanmaster?
  130. OBDI vs OBDII; USB vs RS232
  131. Is it safe to adjust the idle with freescan?
  132. Please look at my freescan log
  133. lookin for info on tunercat
  134. RPM slow to come down at a stop
  135. Tune needed for new mods?
  136. Timing retard for nitrous
  137. C6-r
  138. ? about OBD1 conversion
  139. a4 to m6 swap
  140. Code scanners
  141. 7000k stock PCM limit
  142. Advance Auto Parts scanner says I must plug device in....?!?!?
  143. Question for Autotap Users
  144. Can anyone take a look at this DM log?
  145. can i check TPS voltage with engine off?
  146. Can a 94/95 ECU be swapped in for a 93 car?
  147. How much spark advance?
  148. engine swap
  149. dash all lit up HELP!
  150. code p1336 after pcm exchange
  151. Will my shift point change if my gears arnt programed right
  152. Idle too low after slowing down
  153. Anyway to permanetly disable VATS...need quick help...
  154. Hooking up a scan master on an OBD II connector.
  155. Data Logs/Few Questions
  156. Tunercats Tables Menu Display
  157. tuning
  158. TPI TroublingShooting
  159. reprograming
  160. Will changing the target AFR change gas mileage?
  161. EVAP solenoid
  162. 2k rpm surg
  163. Need Some Help
  164. help with datalog questions
  165. NEED HELP, laptop shut off during reprogram
  166. Turned my 8 into a 4!
  167. wiring up a standalone F.A.S.T.
  168. Another happy Ion cust.
  169. 1995 PCM pin-out verification
  170. making a cable, how to test
  171. really frustrated with o2 sensor problem. car has major power loss. seems to be rich
  172. Tunercat Fuel tables
  173. front 02s
  174. Tuning for blower and 42# injectors
  175. Tunercat - Tuner, or Tuner RT? Can't figure it out.
  176. Need help Excessive spark??
  177. Right Rear O2 sensor on 95 Vette
  178. temp guage quiet
  179. Free real time diognostics?
  180. Help! I'm looking for a 98 Edit file # 9365941
  181. PDA to LT1
  182. Canister Purge effect on BLMs
  183. Science behind O2 sims.
  184. Adapting OBD1 Connector to OBDII (95) ALDL for scanning
  185. anyone have a tune for a 383 M6
  186. rear o2 sims change timing?
  187. Electronic gauges on screen
  188. hypertech programmer
  189. Does anyone in Austin area have akm or similiar cable I can use to download a tune
  190. scanner software for a 95 3.4 VIN S
  191. excellent work Ion (madwolf)
  192. Air/Fuel programming
  193. **HELP**Even cylinders all misfiring
  194. P0133
  195. Autotap datalogs
  196. help! 383 stumble putting in gear...got some Tech II scanner info included
  197. What to get to scan a 97 for codes?
  198. Iac zero,block learns at 160 at idle.
  199. free scanning program for DOS
  200. can someone send me a 383 tune
  201. Determining RWHP using datamaster...
  202. my pcm?
  203. which scanmaster is needed for OBDII LT1?
  204. TTS datamaster - com port locked?
  205. HPP3 and MadWolf Tune
  206. Open Loop Tune Verification
  207. can someone take a look at my log from my 383
  208. tts datamaster
  209. What laptop?
  210. How to identify different year PCM's?
  211. Belkin USB to Serial Drivers
  212. TunerCat Instructions
  213. computer turned off while loading tune
  214. OBD1 Free scanware for Laptops
  215. AKM obd1 cable help
  216. What is the top of the line OBDII scanning software?
  217. codes for a '95
  218. Good General GM Software
  219. o2 sensor probs, and more........
  220. 230/236 tune
  221. Another satisfied customer....
  222. pcm question
  223. a4 to m6
  224. Can anyone look at these Datamaster logs?
  225. Usb and datamaster
  226. Fried a PCM
  227. obd2 cable
  228. IAT sensor questions
  229. Deleted the O2's
  230. tps code?
  231. can someone convert a .lt1 to .cal file for me?
  232. TTS Datalog transmission question
  233. Quick Freescan Question
  234. Help programming
  235. a4 to m6 pcm question
  236. programming for a m6
  237. Computer won't connect to PCM
  238. Does this look like Reversion???
  239. no dyno tune close
  240. if your from il, please help
  241. engine coolant temperature sensor..
  242. VE Tables and Big Cam Idle
  243. Keyless entry
  244. newbie needs help please
  245. Handheld Programmers for LS1
  246. Wideband o2
  247. which cable do you guys recommend?
  248. are pcmforless and madz28 chips interchangeable?
  249. LT1 Edit / Tunercat tunes
  250. p1667
